BT820
BT820
    LAIRD(莱尔德)
    BT820
BT820 数据手册
BT800 Series Bluetooth v4.0 Class 1 USB HCI Modules and Dongle BT800 – BTv4.0 USB HCI Module BT820 – Packaged BTv4.0 USB dongle The BT800 series of USB HCI modules and packaged dongle are Laird’s first dualmode Bluetooth v4.0 offerings, bringing support for Classic Bluetooth and Bluetooth Low Energy (BLE) in a tiny package. Leveraging the market-leading CSR 8510 chipset, the BT800 series provides exceptionally low power consumption with outstanding range. Supporting the latest Bluetooth v4.0 Specification with EDR (Enhanced Data Rate), the Laird BT800 series enables OEMs to accelerate their development time for leveraging either Classic Bluetooth or Bluetooth Low Energy (BLE) into their operating system based devices. The BT800 has a footprint as small as 8.5 x 13 mm, yet output power at 8 dBm. This makes these modules ideal for applications where designers need both performance and minimum size. For maximum flexibility in systems integration, they are designed to support a full speed USB interface plus GPIO, plus I2S and PCM audio interfaces. These modules present an HCI interface with native support for Windows and Linux Bluetooth stacks. All BT800 series devices are fully qualified by the Bluetooth SIG. This also allows designers to integrate their existing pre-approved Bluetooth Host and Profile subsystem stacks to gain a Bluetooth END product approval for their products. The BT800 series is engineered to provide excellent RF performance with an integrated antenna and additional band pass filters to further reduce the regulatory and testing requirements for OEMs, ensuring a hassle free development cycle. As an additional benefit of the BT800 series, Laird has implemented CSR’s HID (Human Interface Device) Proxy Mode enabling out of the box HID connectivity for BLE pointing devices and / or BLE keyboard functionality, requiring zero host device software or configuration. The BT820 is a packaged dongle version of the BT800 module that allows OEMs to plug the device into any Windows or Linux device that supports USB connectors and an inbuilt Bluetooth software stack in its operating system. NOTE: HID Proxy mode on the BT820 works with “Just Works” devices and will not pair with BT devices that require a pincode or passkey. A fully featured, low-cost developer’s kit is available for prototyping, debug and integration testing of the BT800 series modules and further reduces risk and time in development cycles. Features & Benefits  USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2923.0610 wirelessinfo@lairdtech.com www.lairdtech.com/bluetooth Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth Version 1.0        Bluetooth v4.0 - Dual mode - Classic Bluetooth - Bluetooth Low Energy Compact footprint Class 1 output – 8 dBm USB, GPIO, I2S & PCM Industrial temperature range 64k EEPROM support for HID proxy mode* Bluetooth SIG approvals FCC, IC, and CE approvals Application Areas       Medical devices ePOS terminals Barcode scanners Industrial cable replacement M2M connectivity Automotive diagnostic equipment Note: Due to the proprietary nature of CSR BlueSuite, used for HID proxy mode, we only support HID proxy mode for OEMs and NOT for individual customers. The details in this document are subject to change. Download the product specification from www.lairdtech.com/bluetooth for the most current specification. 1 Laird Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852-2268-6567 x026 CATEGORIES FEATURE IMPLEMENTATION Wireless Specification Bluetooth® V4.0 Dual Mode Frequency 2.402 - 2.480 GHz Max Transmit Power Class 1 +8dBm from antenna Receive Sensitivity -89dBm Range Circa 100 meters Data Rates Up to 3 Mbps (over the air) USB Full Speed USB 2.0 GPIO 4 configurable lines HCI Host Controller Interface over USB HID Proxy Mode Human Interface Device NOTE: In the BT820, HID Proxy mode works with “Just Works” devices and will not pair with BT devices that require a pincode or passkey. Coexistence 802.11 (Wi-Fi) 2 and 3 wire CSR schemes supported (Unity-3;Unity-3e and Unity+) Supply Voltage Supply 1.7V – 3.6V Power Consumption Current TX (Max) -
BT820 价格&库存
很抱歉,暂时无法提供与“BT820”相匹配的价格&库存,您可以联系我们找货
