EC6A11
EC6A11
    CINCON
    插件,31.8x20.3mm
    EC6A11
EC6A11 数据手册
V26 EC6A SERIES ︳ 7.5WATT 2:1 INPUT RANGE DC-DC CONVERTERS FEATURES * 7.5W Isolated Output * 24-Pin DIP Package * Efficiency to 87% * 2:1 Input Range * Regulated Outputs * Pi Input Filter * Continuous Short Circuit Protection * CE Mark Meets 2004/108/EC * UL60950-1 Approval * Without Tantalum Capacitor inside INPUT CURRENT MODEL INPUT OUTPUT OUTPUT CURRENT % CAPACITOR NUMBER VOLTAGE VOLTAGE MIN. MAX. NO LOAD FULL LOAD EFF. LOAD MAX. EC6A01 EC6A02 EC6A03 EC6A04 EC6A05 EC6A06 EC6A07 EC6A11 EC6A12 EC6A13 EC6A14 EC6A15 EC6A16 EC6A17 EC6A21 EC6A22 EC6A23 EC6A24 EC6A25 EC6A26 EC6A27 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 9-18 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 18-36 VDC 36-72 VDC 36-72 VDC 36-72 VDC 36-72 VDC 36-72 VDC 36-72 VDC 36-72 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±5 VDC ±12 VDC ±15 VDC 3.3 VDC 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 1500 mA 625 mA 500 mA ±750 mA ±310 mA ±250 mA 1500 mA 1500 mA 625 mA 500 mA ±750 mA ±310 mA ±250 mA 1500 mA 1500 mA 625 mA 500 mA ±750 mA ±310 mA ±250 mA 1500 mA NOTE: 1. Nominal Input Voltage: 12, 24 or 48VDC 1 25 mA 25 mA 25 mA 30 mA 30 mA 30 mA 25 mA 20 mA 20 mA 20 mA 25 mA 25 mA 25 mA 20 mA 10 mA 10 mA 10 mA 15 mA 15 mA 15 mA 10 mA 781 mA 753 mA 744 mA 772 mA 753 mA 753 mA 529 mA 377 mA 359 mA 359 mA 372 mA 356 mA 372 mA 264 mA 193 mA 184 mA 182 mA 191 mA 182 mA 184 mA 136 mA 80 83 84 81 83 83 78 83 87 87 84 87 84 78 81 85 86 82 85 85 76 4700uF 4700uF 4700uF 2200uF 2200uF 2200uF 4700uF 4700uF 4700uF 4700uF 2200uF 2200uF 2200uF 4700uF 4700uF 4700uF 4700uF 2200uF 2200uF 2200uF 4700uF V26 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ….………….......……....... 12V …...................... 9-18V 24V ….................... 18-36V 48V ….................... 36-72V Input Surge Voltage (100ms max.) ……….….… 12V …….......... 20Vdc max. 24V …............. 50Vdc max. 48V …........... 100Vdc max. Input Filter ………………………………………………….…….……….. Pi Type Efficiency …............................................................................. See Table 9 Isolation Resistance ….................................................…… 10 ohm min. Isolation Capacitance …………………..…………………..…… 560pF typ. Isolation Voltage ………………………………………….…. 1500VDC min. Switching Frequency …......................................................... 300KHz typ. Operating Ambient Temperature Range …....................... -40℃ to +85℃ De-rating, Above 71℃ ………………… Linearly to Zero power at 100℃ OUTPUT SPECIFICATIONS: Case Temperature (note5) …………..................................... 100℃ max. Voltage Accuracy …....................................................................... ±2.0% max. Voltage Balance (Dual) ….............................................................. ±1.0% max. Cooling ………………………………….…………….. Natural Convection Storage Temperature Range ………….……....………..... -40℃ to +100℃ Humidity .................................................. 95% RH max. Non condensing MTBF ……. MIL-STD-217F, GB, 25℃, Full Load ………… 1800Khrs typ. Dimensions …… DIP ….… 1.25x0.80x0.40 inches(31.8x20.3x10.2 mm) SMD …. 1.25x0.80x0.45 inches(31.8x20.3x11.4 mm) Weight ………………………………………………………………… 18.4g Case Material ………… Black Coated Copper with Non-conductive Base Temperature Coefficient …………………………………………… ±0.05%/℃ Ripple & Noise, 20MHz BW …………….…………….…… 100mV pk-pk max. Short Circuit Protection ……………………………………………… Continuous Line Regulation Single/Dual (note1) …….…….……………......…±0.2% max. Load Regulation Single (note2) …..………..………....…………. ±0.5% max. Dual (note3) …………..……….………………… ±1.0% max. Start up time …………………….……… EC6A0XX …………………… 5ms typ. Other …………….…..……. 20ms typ. Typical Derating curve for Natural Convection NOTE: 120% 1. Measured from high line to low line. 2. Measured from full load to 10% load. 3. Measured from full load to 1/4 load. 4. Suffix “S” to the model number with SMD packages. 5. Maximum case temperature under any operating condition should not be exceeded 100℃ 71 -40 100% LO AD(%) 80% 60% Natural Convection 40% 20% 0% -40 100 -15 10 35 60 o Ambient Temperature( C) Case A Dimensions: NOTE:Pin Size is 0.02±0.002 Inch (0.5±0.05 mm)DIA All Dimensions In Inches (mm) Tolerances Inches: X.XX= ±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX=±0.25 CASE AS PIN CONNECTION Pin SEE NOTE 1,24 TOP 2,3 VIEW 4,5 BOTTOM VIEW Single Output Dual Output DIP SMD DIP SMD NP NC NP NC -V Input NP NC -V Input NP NC 9 NC Common 10,15 NC NC 11 12,13 14 16 20,21 22,23 NC NP -V Output NC +V Output -V Output NP NC +V Input NP NC +V Output Common NP NC +V Input * NC-NO CONNECTION WITH PIN * NP-NO PIN 2 85
EC6A11 价格&库存
很抱歉,暂时无法提供与“EC6A11”相匹配的价格&库存,您可以联系我们找货
EC6A11
    • 1+306.76320
    • 200+122.40720
    • 500+118.31400
    • 1000+116.29440
