2D Drawing
IGES
STEP
3D PDF
Check Stock
Solder Profile
Request a Sample
Send Us An Email
RoHS Compliant
REACH Compliant
UL Plastic
Certificate of Compliance
Generated Part Number
KPJX-3S
Part Number Builder
LR78160
DC POWER CONNECTORS: KPJX Series
KPJX
3
Series
No. of
Contacts
Snap and Lock PCB Mount Receptacle
Product Features
Laptop Computers, Power Supplies and Other Portable
Digital Equipment Applications
Snap & Lock Feature Helps to Prevent Accidental
Disconnects
3 or 4 Pins Transmit Power, or One Pin Can Be Used For
Signal Transmission
For Signal and DC Power Applications
CSA/NRTL Certified File No. LR78160
UL File No. E140125
Performance Specifications
Materials and Finish
Shield: Copper Alloy, Tin Plated
Body: PBT, UL 94V-0 Rated
HT Body: High Temperature Thermoplastic, UL 94V-0 Rated
S
Contact
Type
Shield
Option
Series
KPJX - Right Angle Receptacle
KPJXHT - High Temperature, Right Angle Receptacle
Number of Contacts
3 Pin
4 Pin
Contact Type
S - Socket
Shield Option
Blank - Non-Shielded
S - Shielded
Recommended to be used with Kycon KPPX Series Plugs
Contact Kycon for Other Options
KPJX-3S Series
Dimensions in mm
Electrical Characteristics
Contact Rating
3 Position: Pin 1 and 2, 48V DC at 7.5A Max.,
Pin 3, 48V DC 1.0A Max.
4 Position: 48V DC 7.5A Max. For All Pins.
Insulation Resistance: 50 Megohms Min. at 250V DC
Dielectric Withstanding Voltage: 500V AC for 1 Minute
Contact Resistance: 30 milliohms Max.
Mechanical Characteristics
Durability: 1000 Cycles
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 1018
很抱歉,暂时无法提供与“KPJX-4S”相匹配的价格&库存,您可以联系我们找货
