DATA SHEET
Pulse Transformers IT series with single
secondary winding
Pulse Transformer with Single Secondary Winding
Galvanic separation of drive and power
circuit
Approvals & Compliances
Voltage resistance up to 8 kV
Ignition current up to 3 A
Turns ratio up to 3:1
IT pulse transformers are designed to offer you
galvanic isolation for transformer coupled gate
drives. The IT series provides negligible delays and
the possibility of voltage scaling. They are available
with single or double secondary winding for
multiple gate drives. Choosing the IT product line
brings you the rapid availability of a standard gate
drive transformer. A wide selection on turns ratio,
ignition current and voltages are designed to offer
you the desired standard product.
Features and Benefits
Technical Specifications
Galvanic separation
Nominal operating voltage
Up to 3000 V
Allows high potential difference voltage scaling
Operating frequency
40 kHz max.
500 kHz max. for data transmission
DC to 40000 Hz
Optional grounded shields
Ignition currents
0.1 to 3 A @ 40°C
PCB through hole mounting or faston types
Rise time
0.3 to 2.3 µs
Custom-specific versions on request
Test voltage
Up/50 Hz/2 s max. according to VDE 110b
Max. partial discharge voltage
1.5 x Unom
Temperature range (operation and storage)
-25°C to +70°C (25/70/21)
Flammability corresponding to
UL 94 V-0 listed materials
Vacuum potting
Very low partial discharge effects
Typical Applications
Gate drive circuit
Power supplies
Power converters
Frequency converters
Switching applications
DC/DC converters
Line coupling transformers in high-speed data
transmission
2
Pulse Transformers
Schaffner Group
DATA SHEET
15. Jun 2022
Pulse Transformer Selection Table
Pulse transformer
Turns ratio
Ignition
Voltage
current
Voltage
Rise
Inductance*
Resistance
Coupling
Input/ Output
capacitance
connections
time area
time
Iign
Unom
Up
V0t
tr
Lp
Lstr
Rp
Rs
Ck
[A]
[V]
[kV]
[Vμs]
[μs]
[mH]
[μH]
[Ω]
[Ω]
[pF]
Weight
[g]
IT 155
1:1
0.1
500
4
480
1
5
85
1.2
1.2
6
02
13
IT 245
1:1
0.1
750
4
500
1.2
8
100
1.48
1.48
10
02
6
IT 237
1:1
0.25
500
2.5
1100
1
25
35
1.9
2.2
50
02
14
IT 239
1:1
0.25
1000
6
300
2.3
3
80
0.9
0.9
5
02
13
IT 255
1:1
0.25
750
4
250
1.1
2.2
40
0.8
0.8
8
02
6
IT 258
1:1
1
750
3.2
250
0.25
2.5
3
0.62
0.75
80
02
6
IT 370
1:1
1
1000
5
4000
0.6
0.3
6
0.16
0.18
40
02
71
IT 364**
1:1
3
3000
8
5000
1.7
1.5
10
0.16
0.14
35
IT 246
2:1
0.1
750
4
200
0.4
7
35
2.1
1.1
7
02
6
IT 248
2:1
0.25
750
3.2
350
2.2
17
80
3.2
1.6
9
02
6
IT 260
3:1
0.1
500
3.2
200
0.3
12
30
2
0.8
8
02
6
05
220
* Tolerance: +50%; -30%
** Not suitable for PCB-mounting.
Explanations:
– tr rise time at given load resistor R and 70% of the output pulse height.
– Lp primary inductance measured at 1 kHz (secondary coile open).
– Lstr stray inductance measured at the secondary side, short circuit at the primary side. If there are several secondary coils only one at the time is connected
(measuring frequency
10 kHz).
– The ignition current is a set peak value where the voltage drop over the coil resistance is still insignificant (mostly below 1 V).
3
Pulse Transformers
Schaffner Group
DATA SHEET
15. Jun 2022
Mechanical Data
IT 245, IT 246, IT 248, IT 255, IT 258, IT 260
IT 239
IT 155, IT 237
IT 364
IT 370
Dimensions
IT 245
IT 246
IT 248
IT 255
IT 258
IT 260
IT 239
IT 155
IT 237
IT 364
IT 370
Tol.
A
17.6*
17.6*
17.6*
17.6*
17.6*
17.6*
27
27
27
50
27
±0.2
B
16.7*
16.7*
16.7*
16.7*
16.7*
16.7*
22.5
22.5
22.5
50
32.2
±0.2
C
11.3*
11.3*
11.3*
11.3*
11.3*
11.3*
13.7
13.7
13.7
60
23.7
±0.2
D
5
5
5
5
5
5
5
5
5
10*
5.5
+1/-0
E
0.42
0.42
0.42
0.42
0.42
0.42
0.45
0.45
0.45
F
0.4
0.4
0.4
0.4
0.4
0.4
0.7
0.7
0.7
G
15.3
15.3
15.3
15.3
15.3
15.3
±0.2
H
12.5
12.5
12.5
12.5
12.5
12.5
15
7.5
7.5
42
10
±0.2
3.5
3.5
2.5
2.5
I
L
2
2
2
2
2
2
2.5
Ø0.8
3.5
±0.2
M
N
* Tolerance is ±0.1
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on connectors.
25
Ø4.2
±0.2
4
Pulse Transformers
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Holding AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Schaffner Group
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road,Pudong
district
201201
Shanghai
+86 2138139500
cschina@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E El
Soto de Moraleja, Alcobendas
28109
Madrid
+34 917 912 900
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tions are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
15. Jun 2022
Sales and Application
Centers
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
DATA SHEET
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya 7F
1-32-12 Kamiuma, Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1, #05-09, Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2, No 97, Section 1, XinTai 5th Road,
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Sathorn Square Tower
Room 3780, 37FL, 98 North-Sathorn Rd,
Silom, Bangrak
10500
Bangkok
+66 621056397
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
很抱歉,暂时无法提供与“IT239”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+116.225171+15.05523
- 10+104.8115010+13.57676
- 25+100.5256125+13.02159
- 50+97.3847250+12.61473
- 100+94.32651100+12.21859
- 300+89.65161300+11.61302
- 500+87.54893500+11.34065
- 1000+84.767191000+10.98032
