Comair Rotron Specification Sheet
Specification Date: Dec 12, 2017
Version:02
COMAIR ROTRON PART NUMBER:
COMAIR ROTRON MODEL NUMBER:
17000539A
CREC1238-4000
A.) MOTOR:
RATED VOLTAGE:
100~240VAC±10%
OPERATING VOLTAGE RANGE:
90~264VAC
LOW-START VOLTAGE:
80VAC
RUNNING CURRENT:
0.11~0.18 Amps
OPERATING FREGUENCY:
50~60Hz
INPUT POWER:
10 Watts
NOMINAL SPEED:
4,000 RPM 5%
(At Free Delivery)
MOTOR TYPE:
Brushless EC
MOTOR PROTECTION:
By Integrated Circuit
LOCKED ROTORT PROTECTION:
IC protected
POLARITY PROTECTION:
Yes
AUTOMATIC RESTART CAPABILITY:
ROTATION:
Counter Clockwise when viewed from the
impeller
B.) MECHANICAL
DIMENSIONS:
120mm x120mm x 38mm
WEIGHT:
370g
BEARING TYPE:
Permanently Lubricated Ball Bearings
VENTURI:
Die Cast magnesium alloy,
ED coating and powder coating
PROPELLER:
P.B.T+30%GF(Glass fiber) UL 94V-0
-1-
Version:02
Figure 1
C.) ENVIRONMENTAL
OPERATING TEMPERATURE:
-20C to +70C
STORAGE TEMPERATURE:
The storage temperature will be suggested at
-20℃ ~ 50℃ to ensure a better performance.
HUMIDITY:
20 to 85% RH, non-condensing
-2-
Version:02
D.) PERFORMANCE CHARACTERISTICS
AIR FLOW:
130 CFM 5%
(Measuring at zero static pressure)
STATIC PRESSURE:
0.43” Inches of H20
(Measuring at zero airflow)
ACOUSTIC LEVEL:
56 dBA Max. at MAX. speed
(Measured via Freely Suspended at 1 meter )
-3-
Version:02
E.) TERMINATION
Joint terminal:
suit with 0.5x3x7mm PIN
F.) RELIABILITY
Bearing type
Ball bearing
Temperature
20℃
Hours
60,000
40℃
50,000
60℃
40,000
90℃
20,000
G.) SAFETY
UL, CUL, CE
H.) FLAMMABILITY
The fan including all components meets a UL94V-0 rating or better.
-4-
很抱歉,暂时无法提供与“17000539A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+388.783731+48.64456
- 10+329.0353210+41.16885
