FN2010B-10-06
FN2010B-10-06
    SCHAFFNER(夏弗纳)
    FN2010B-10-06
FN2010B-10-06 数据手册
DATA SHEET Standard Performance Single-Phase Filters FN2010 General Purpose AC/DC EMI Filter Rated currents from 1 to 60 A Approvals & Compliances General purpose filtering performance Optional medical versions (B type) Optional safety versions (A type) Optional enhanced performance versions Optional DC optimized versions Features and Benefits FN 2010 filters are designed for easy and fast chassis mounting Performance indicators FN 2010 B versions without capacitors to earth comply to 1MOP for ME (medical equipment) acc. IEC 60601-1 FN 2010 A versions with low capacitance to earth for safety critical applications with necessity for low leakage currents FN 2010 filters are also available as enhanced performance and DC optimized versions. With higher attenuation in very compact housing (M, N1,N types) All filters provide a general purpose conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior FN 2010 filters can be used to cover a broad range of usage and they offer a good size/amperage ratio Technical Specifications * ** Rated voltage* 250 VAC, 50/60 Hz; 250 VDC Operating frequency DC to 400 Hz Rated currents 1 to 60 A @ 40°C max. High potential test voltage P –> N 1100 VDC for 2 sec P –> PE 2000 VAC for 2 sec (equiv. cap PE 2550 VDC for 2 sec (equiv. cap >88 nF) P –> PE 2500 VAC for 2 sec (B types) Various terminal options allow you to select the desired connection style Typical Applications Electrical and electronic equipment Consumer goods Household equipment Temperature range (operation and storage) -25 °C to +100 °C (25/100/21)** Medical equipment Certified to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (applies to AC and DC applications) Office automation equipment Flammability corresponding to Laces for -07 version: UL 94 VW-1 Terminal plastic for -06/-08 version: UL 94 V-0 Grommet for -07 version: UL 94 V-0 Overvoltage category II acc. IEC 60664-1 Pollution degree 2 acc. IEC 60664-1 Altitude 2000m (above derating applies)** MTBF @ 40°C/230 V (Mil-HB-217F) 1,250,000 hours 3,200,000 hours (B types) maximum RMS operating voltage at rated frequency or the maximum DC operating voltage for dedicated requests exceeding this specification (e.g. -40 °C or higher altitude) please contact your local Schaffner sales office Datacom equipment Typical electrical schematic 2 Standard Performance Single-Phase Filters Schaffner Group DATA SHEET 04. Jul 2022 Filter Selection Table Filter* Buy Rated current Leakage current** Power loss Inductance*** Resistance*** Input/Output @ 40°C (25°C) @ 250 VAC/50 Hz @25°C/DC L Cx Cy R connections [mH] [μF] [nF] [kΩ] Capacitance*** Weight (@ 120 VAC/60 Hz) [A] [mA] [W] FN2010-1-.. 1 (1.15) 0.66 (0.38) 0.8 12 0.1 4.7 1000 -06 -07 65 FN2010-3-.. 3 (3.45) 0.66 (0.38) 1.1 2.5 0.1 4.7 1000 -06 -07 65 FN2010-6-.. [g] 6 (6.9) 0.66 (0.38) 1.7 1 0.1 4.7 1000 -06 -07 65 FN2010-10-.. 10 (11.5) 0.66 (0.38) 2.5 0.8 0.1 4.7 1000 -06 -07 85 FN2010-12-.. 12 (13.8) 0.66 (0.38) 3.6 0.7 0.1 4.7 1000 -06 -07 85 FN2010-16-.. 16 (18.4) 0.66 (0.38) 2.5 0.7 0.1 4.7 1000 -06 -07 -08 140 FN2010-20-.. 20 (23) 0.66 (0.38) 3.8 0.6 0.1 4.7 1000 -06 -07 -08 210 FN2010-30-08 30 (34.5) 0.79 (0.46) 6.3 0.7 0.47 10 1000 -08 470 FN2010-60-24 60 (69) 0.79 (0.46) 14.7 1 1.5 10 330 -24 1100 FN2010A-1-.. 1 (1.15) 0.07 (0.04) 0.8 12 0.1 0.47 1000 -06 -07 65 FN2010A-3-.. 3 (3.45) 0.07 (0.04) 1.1 2.5 0.1 0.47 1000 -06 -07 65 FN2010A-6-.. 6 (6.9) 0.07 (0.04) 1.7 1 0.1 0.47 1000 -06 -07 65 FN2010A-10-.. 10 (11.5) 0.07 (0.04) 2.5 0.8 0.1 0.47 1000 -06 -07 85 FN2010A-12-.. 12 (13.8) 0.07 (0.04) 3.6 0.7 0.1 0.47 1000 -06 -07 FN2010A-16-.. 16 (18.4) 0.07 (0.04) 2.5 0.7 0.1 0.47 1000 -06 -07 -08 140 FN2010A-20-.. 20 (23) 0.07 (0.04) 3.8 0.6 0.1 0.47 1000 -06 -07 -08 210 FN2010A-30-08 30 (34.5) 0.07 (0.04) 6.3 0.7 0.47 0.47 1000 -08 470 FN2010A-60-24 60 (69) 0.07 (0.04) 14.7 1 1.5 0.47 330 -24 1100 FN2010B-1-.. 1 (1.15) 0.00 0.8 12 0.1 1000 -06 -07 65 FN2010B-3-.. 3 (3.45) 0.00 1.1 2.5 0.1 1000 -06 -07 65 FN2010B-6-.. 6 (6.9) 0.00 1.7 1 0.1 1000 -06 -07 65 FN2010B-10-.. 10 (11.5) 0.00 2.5 0.8 0.1 1000 -06 -07 85 FN2010B-12-.. 12 (13.8) 0.00 3.6 0.7 0.1 1000 -06 -07 FN2010B-16-.. 16 (18.4) 0.00 2.5 0.7 0.1 1000 -06 -07 -08 140 -06 -07 FN2010B-20-.. 85 85 20 (23) 0.00 3.8 0.6 0.1 1000 -08 210 FN2010B-30-08 30 (34.5) 0.00 6.3 0.7 0.47 1000 -08 470 FN2010B-60-24 60 (69) 0.00 14.7 1 1.5 330 -24 1100 FN2010N1-1-06 1 (1.15) 5.34 (3.08) 0.8 12 0.1 68 1000 -06 70 FN2010N1-3-06 3 (3.45) 5.34 (3.08) 1.1 2.5 0.1 68 1000 -06 70 FN2010N1-6-06 6 (6.9) 5.34 (3.08) 1.7 1 0.1 68 1000 -06 70 FN2010N1-10-06 10 (11.5) 5.34 (3.08) 2.5 0.8 0.1 68 1000 -06 85 FN2010N1-12-06 12 (13.8) 3.69 (2.13) 3.6 0.7 0.1 47 1000 -06 FN2010M-16-.. 16 (18.4) 3.69 (2.13) 2.5 0.7 0.1 47 1000 -06 -08 140 -06 Enhanced performance FN2010M-20-.. 85 20 (23) 3.69 (2.13) 3.8 0.6 0.1 47 1000 -08 220 FN2010N-30-08 30 (34.5) 7.85 (4.52) 6.3 0.7 0.47 100 1000 -08 400 FN2010N-60-24 60 (69) 7.85 (4.52) 14.7 1 1.5 100 330 -24 1120 *** To compile a complete part number, please replace the -.. with the required I/O connection style (e.g. FN 2010-30-08, FN 2010B-10-06). The different letters code the used Cy values in the filter type (A = 0.47nF; M = 47nF; N1 = 47nF; N = 100nF) *** Maximum leakage under usual AC operating conditions (acc. IEC 60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. *** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10% 3 Standard Performance Single-Phase Filters Schaffner Group DATA SHEET 04. Jul 2022 Typical Filter Attenuation Per CISPR 17; CM=50 Ω/50 Ω sym; DM=50 Ω/50 Ω asym 1 A: Standard type A type B type Enhanced performance 3 A: Standard type A type B type Enhanced performance 6 A: Standard type A type B type Enhanced performance 10 A: Standard type A type B type Enhanced performance 12 A: Standard type A type B type Enhanced performance 4 Standard Performance Single-Phase Filters Schaffner Group DATA SHEET 04. Jul 2022 16 A: Standard type A type B type Enhanced performance 20 A: Standard type A type B type Enhanced performance 30 A: Standard type A type B type Enhanced performance 60 A: Standard type A type B type Enhanced performance Product Selector 5 Standard Performance Single-Phase Filters Schaffner Group DATA SHEET 04. Jul 2022 Mechanical Data Connection style -06, 1 to 12 A types Connection style -06, 16 and 20 A types Connection style -07, 1 to 12 A types (same dimensions as style -06) Connection style -07, 16 and 20 A types (same dimensions as style -06) Connection style -08, 16 and 20 A types Connection style -08, 30 A types Connection style -24 6 Standard Performance Single-Phase Filters Schaffner Group DATA SHEET 04. Jul 2022 Dimensions 1A 3A 6A 10 A 12 A 16 A 20 A 30 A 60 A Tolerances A 64 64 64 64 64 71 85 113.5 ±1 105 ±1 ±0.5 B 35 35 35 35 35 46.6 54 57.5 ±1 145.9 ±1 ±0.5 C 24.3 24.3 24.3 29.3 29.3 29.3 30.3 45.4 ±1 57.6 ±1 ±0.5 D 43.5 43.5 43.5 43.5 43.5 50.5 64.8 94 ±1 84.5 ±1 ±0.5 E 32.5 32.5 32.5 32.5 32.5 44.5 49.8 56 99.5 ±0.5 F 54 54 54 54 54 61 75 103 95 ±0.3 G 21 21 21 21 21 21 27 25 40 ±0.2 H 9.3 9.3 9.3 9.3 9.3 10.8 12.3 12.4 19.6 ±0.5 I 15.3 15.3 15.3 15.3 15.3 19.3 20.8 32.4 10.1 ±0.5 J 21.8 21.8 21.8 21.8 21.8 20.1 19.9 15.5 42.25 ±0.5 K 5.3 5.3 5.3 5.3 5.3 5.3 5.3 4.4 4.4 L 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6 6 M 0.7 0.7 0.7 0.7 0.7 0.7 0.7 1 1.2 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 O 8.3 8.3 8.3 8.3 8.3 8.3 8.3 ±0.5 P 21.8 21.8 21.8 21.8 21.8 14 14.9 ±0.5 AWG type wire AWG 20 AWG 20 AWG 18 AWG 18 AWG 16 AWG 16 AWG 14 Wire length 140 140 140 140 140 140 140 N M4 M4 M4 Recommended torque (Nm) 1.2 - 1.3 1.2 - 1.3 1.2 - 1.3 Earth terminal 1.5 - 1.7 1.5 - 1.7 1.5 - 1.7 ±0.3 Connection style -06 N Connection style -07 +5 Connection style -08 Connection style -24 N M6 Q 51 Recommended torque (Nm) 3.5 - 4 Earth Terminal 3.5 - 4 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connections. ±0.2 7 Standard Performance Single-Phase Filters Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 04. Jul 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN2010B-10-06 价格&库存
很抱歉,暂时无法提供与“FN2010B-10-06”相匹配的价格&库存,您可以联系我们找货
