V13
CFM40D/T SERIES
40W DUAL/TRIPLE OUTPUT
AC-DC OPEN FRAME
Features
* Universal Input Range 90~264Vac
* 2” x 4” Size
* Industry-Standard Pin Out
* Efficiency to 81%
* Meets EN61204-3 Class B and
CISPR/FCC Class B
* Short Circuit Protection
MODEL
CFM40D-01
CFM40D-02
CFM40T-01
CFM40T-02
CFM40T-03
CFM40T-04
CFM40T-05
CFM40T-06
CFM40T-07
OUTPUT
VOLTAGE
5V(V1)
12V(V2)
5V(V1)
24V(V2)
5V(V1)
12V(V2)
-5V(V3)
5V(V1)
12V(V2)
-12V(V3)
5V(V1)
15V(V2)
-15V(V3)
5V(V1)
24V(V2)
-12V(V3)
5V(V1)
24V(V2)
-5V(V3)
5V(V1)
24V(V2)
12V(V3)
3.3V(V1)
5V(V2)
-12V(V3)
OUTPUT CURRENT(A)
RIPPLE
VOLTAGE
LINE
LOAD
O/P Power
(%) EFF.
Min.
Rated
Max.
(mVp-p)
ACCURACY
Reg.
Reg.
Max.
(Typ.)
0.4
0.2
0.4
0.2
0.4
0.2
2.0
3.2
1.0
3.0
2.0
0.3
5.0
2.5
5.0
1.5
50
120
50
240
±3%
±4%
±3%
±4%
±1%
±2%
±1%
±2%
±3%
±5%
±3%
±5%
40.0W
80%
40.0W
81%
5.0
2.5
0.5
50
120
50
±3%
±4%
±3%
±1%
±2%
±1%
±3%
±5%
±1%
40.5W
78%
0.4
0.2
2.0
0.3
5.0
2.5
0.5
50
120
120
±3%
±4%
±3%
±1%
±2%
±1%
±3%
±5%
±1%
42.6W
78%
0.4
0.2
1.5
0.3
5.0
2.3
0.5
50
150
150
±3%
±4%
±3%
±1%
±2%
±1%
±3%
±5%
±1%
42.0W
78%
0.4
0.2
1.0
0.3
5.0
1.5
0.5
50
240
120
±3%
±4%
±3%
±1%
±2%
±1%
±3%
±5%
±1%
42.6W
78%
0.4
0.2
1.0
0.3
5.0
1.5
0.5
50
240
50
±3%
±4%
±3%
±1%
±2%
±1%
±3%
±5%
±1%
40.5W
78%
0.4
0.2
1.0
0.3
5.0
1.5
0.5
50
240
120
±3%
±4%
±3%
±1%
±2%
±1%
±3%
±5%
±1%
42.6W
78%
0.4
0.2
2.0
0.3
7.0
3.5
0.5
100
100
120
±3%
±4%
±3%
±1%
±3%
±1%
±3%
±5%
±1%
30.0W
71%
1
V13
Specifications
CFM40D/T Series Derating Curve
Open Frame versions:
Voltage …....………........…........................................... 90~264Vac
Frequency ………………………………………….……………..... 47 to 63Hz
CFM40D-01, 40D-02, 40T-01, 40T-02, 40T-03, 40T-04, 40T-05,
40T-06
OUTPUT SPECIFICATIONS:
Rated Power for Convection Cooling ………...…. 40W (CFM40T-07, 30W)
Maximum Power with 30 CFM Forced Air ……….. 50W (CFM40T-07, 40W)
Holdup Time ……………………………………………… 20ms typ. @115Vac
Short Circuit …………………………….….… Hiccup Mode (Auto Recover)
Over Voltage Protection CFM40D/T ……………………..…... 6V on V1(5V)
16V/20V/ 30V o n V2(1 2V/1 5 V/24V)
Over Voltage Protection CFM40T-07 …….. 6V on V1 (3.3V), 9V on V2 (5V)
Temperature Coefficient ……………………............................... ±0.05%/℃
GENERAL SPECIFICATIONS:
Isolation ………………………………………… Input to output = 4,242VDC
Operating Temperature ............................. 0 ~ 70℃ (see Derating Curve)
Storage Temperature …………………..………...…....……........ -20 ~ 85℃
Humidity .................................................... 93% RH max. Non-Condensing
Cooling …………………………………………………….. Natural Convection
Switching Frequency …………………………….…….……. 62.5KHz Typical
100%
75%
50%
20LFM (Natural Conv ection)
25%
0%
40
50
Ambient Temperature (oC)
60
70
60
70
CFM40T-07
100%
Rated Load (%)
Inrush Current …....….. Cold Start@25℃ .................. 60A max. @240Vac
Input Current ………...........................…......... 1A max. (RMS) @115Vac
Leakage Current ……………………………………………...…… 3.5mA max.
Rated Load (%)
INPUT SPECIFICATIONS:
75%
50%
25%
0%
40
50
MTBF …………… MIL-HDBK-217F, GB, 25℃/115VAC …… 200Khrs min.
Altitude ……………………..……………………………….…………… 2000m
Dimensions
Open Frame versions …….. 4.000x2.000x1.063Inches(101.60x50.80x27.00mm)
Covered versions: CFM40D/T-XX-CA
Covered versions …. 4.606x2.480x1.850inches(117.00x63.00x47.00mm)
Weight ……………………….. Open Frame versions … 180g (0.40 Pounds)
Covered versions ……. 220g (0.49 Pounds)
40T-06
NOTE:
1. Voltage accuracy is set at full load and 25℃ Ta.
2. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for
Ripple & Noise measuring @20MHz BW.
3. Line regulation is measured from 100Vac to 240Vac with full load.
4. Load regulation is measured from 60% to 100% full load and from 60%
75%
50%
20LFM (Natural Convection)
25%
0%
40
50
60
CFM40T-07
100%
Rated Load (%)
to 20% full load (60% ±40% full load)
5. Input connector mates with Molex housing 09-50-3031 and Molex
2878 series crimp terminal.
6. Output connector mates with Molex housing 09-50-3061 and Molex
7. Safety approvals do not apply to the covered versions, only to the
open-frame versions.
Rat ed Load (%)
SAFETY AND EMC:
Emission and Immunity …..…..….. EN55022 Class B, FCC Part 15 Class B
EN61000-6-3, EN61000-3-2, EN61000-3-3
EN55024, EN61204-3, EN61000-6-1
Safety ……………………………..… IEC60950-1, EN60950-1, UL60950-1
100%
75%
50%
25%
0%
10
40
50
60
V13
CFM40D/T Series
All Dimensions are in inches(mm)
Tolerance:Inches:X.XXX±0.02
Millimeters:X.XX±0.5
ACN
1
2
3
4
5
6
ACL
VR
Typical at 25˚C, nominal line and 75% load, unless otherwise Specified
3
V2
V1
V1
COM
COM
V3
很抱歉,暂时无法提供与“CFM40T-02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+306.370471+39.62728
