8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
A
1764
B
1821
C
1903
DESCRIPTION
DATE
INITIAL RELEASE
07/23/08
UPDATE 'T' & 'P' PLATING, ADD 'S' PLATING,
CURRENT RATING 3 AMP WAS 1 AMP, ADD 'DUAL
BEAM CONTACTS' TEXT, .226 MAX DEPTH WAS .236, 11/4/2008
LENGTH .200 WAS .197, WIDTH .100 WAS .094
REMOVE TEXT '-RC' IN P/N CODING
UPDATE TOLERANCE BLOCK, RELOCATE BTM VIEW,
SPECIFICATION 20 MILLI OHMS WAS 20 MEGA
1/23/2009
OHMS
BY
ASK
F
JH
JH
DUAL BEAM CONTACTS
E
.100 2.54
.200 5.08
D
E
D
.256 6.50
.226±.008 5.74±0.20
MAX DEPTH
2X .140 3.55
POINT OF
CONTACT
.100 2.54
C
C
SECTION A-A
A
B
A
B
.100 2.54
A
NOTES:
1. INSULATOR MATERIAL: PBT, BLACK
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. PLATING: SEE PART NUMBER CODING.
4. OPERATING TEMPERATURE: -55 C TO +105 C.
5. OPERATING VOLTAGE: 250 VAC MAX.
6. UL FLAMMABILITY RATING: 94V-0.
7. DIELECTRIC WITHSTANDING VOLTAGE: 1000 VAC FOR 1 MINUTE.
8. CURRENT RATING: 3 AMP PER CONTACT.
9. CONTACT RESISTANCE: 20 MILLI OHMS MAX.
10. INSULATION RESISTANCE: 5000 MEGA OHMS.
8
7
6
UNLESS OTHERWISE SPECIFIED:
Pb
DIMENSIONS ARE IN INCHES[MM]
TOLERANCES:
ANGULAR: 30'
.XX= .012 [.30]
.XXX= .008 [.20]
.XXXX= .004 [.10]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
5
4
DRAWN
NAME
07/23/08
ASK
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
MINI SHUNT, CLOSED TOP
S_C02SYAN
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
DATE
REV
11134
SCALE: NTS
2
C
SHEET 1 OF 1
1
FILE NAME: Z:\COMPONENTS\Taiwan\11134, S_C02SYAN PRINT: 2/9/2009
A
很抱歉,暂时无法提供与“SPC02SYAN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.23123
- 100+0.22562
- 300+0.22184
- 1000+0.21816
- 国内价格
- 100+0.27500
- 200+0.22000
- 300+0.20900
- 400+0.19800
- 国内价格
- 10+0.25910
- 100+0.25280
- 300+0.24850
- 1000+0.24440
