31-903.3
31-903.3
    EAO
31-903.3 数据手册
HMI Components Edition 09/2021 Series 31 Characteristics Functions Market segments The compact 16 mm Series 31 is especially suited for: The Series 31 incorporates the following functions: The EAO Series 31 is especially suited for applications in the segments: ■■ ■■ Raised design PCB (with adaptor) ■■ ■■ ■■ This series is ideally suited for combined use with Series 51. ■■ Indicator Pushbutton Illuminated pushbutton Buzzer ■ ■ Machinery and Automation Panel building Please refer to the EAO website to obtain detailed information regarding this series www.products.eao.com Configure a product to your exact needs and request a quotation. Content 31 Overview Raised design Indicator 4 Buzzer 6 Illuminated pushbutton 7 Accessoires 11 Drawings 23 Technical data 24 Marking 27 Guidelines for use 28 Index 29 3 31 Raised design Indicator, IP 40 Equipment consisting of (schematic overview) 1.5 ... 6 L1 page {$l=BR31_ AGAE_Druckhaube_Kunststoff} Lens 26.5 page Single-LED L {$l=BR31_ AGAE_Single-LED} H 10.5 Product can differ from the current configuration. 23.5 33 3 Actuator Fixing nut Dimensions [mm] H = Universal terminal 2.0 x 0.5 mm, L = Solder terminal, L1 = Solder terminal 2.8 x 0.5 mm Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 18min. 18x 18mm / Ø18mm 24 min. 18x 24mm Ø2 18 min. 10.4 + 0.2 0 Ø16 Terminal Part No. Wiring diagram Diode 1N4007 Component layout Mounting cut-outs [mm] Weight Indicator actuator, Front dimension 18 x 18 mm 1 Universal 2.0 x 0.5 mm 31-703.006 4 1 0.006 kg 2 Universal 2.0 x 0.5 mm 31-704.006 4 2 0.006 kg Solder 2.8 x 0.5 mm 31-050.002 3 0.004 kg Solder 31-050.005 3 0.004 kg Universal 2.0 x 0.5 mm 31-051.006 3 0.005 kg 4 Indicator actuator, Front dimension 18 x 24 mm 1 Universal 2.0 x 0.5 mm 31-701.006 4 1 0.006 kg 2 Universal 2.0 x 0.5 mm 31-702.006 4 2 0.006 kg 4 Solder 2.8 x 0.5 mm 31-040.002 3 0.004 kg Solder 31-040.005 3 0.004 kg Universal 2.0 x 0.5 mm 31-041.006 3 0.005 kg 4 Terminal Part No. Wiring diagram Diode 1N4007 Component layout Raised design 31 Weight Indicator actuator, Front dimension Ø 18 mm Solder 2.8 x 0.5 mm 31-030.002 3 0.004 kg Solder 31-030.005 3 0.004 kg Universal 2.0 x 0.5 mm 31-031.006 3 0.005 kg 4 The component layouts you will find from page {$l=BR31_KAZE_Zeichnung} a - (x1) 3(+) a -(x1) 3(+) 1(+) a-(x1) b + (x2) 4(-) b + (x2) 4(-) 2(-) b+ (x2) Wiring diagram 1 Wiring diagram 2 Wiring diagram 3 5 31 Raised design Buzzer, IP 40 Equipment consisting of (schematic overview) 1.5 ... 6 Buzzer L1 L 67 10.5 Product can differ from the current configuration. Fixing nut 36 Each Part Number listed below includes all the black components shown in the 3D-drawing. Dimensions [mm] L = Solder terminal, L1 = Solder terminal 2.8 x 0.5 mm Additional Information To obtain a complete unit, please select the red components from the pages shown. 24 min. • Further information see «Technical data» 18 min. 10.4 Ø2 + 0.2 0 Ø16.2 Operating voltage Front cap Terminal Part No. Wiring diagram Mounting cut-outs [mm] Weight Solder 2.8 x 0.5 mm 31-801.002 1 0.015 kg Solder 31-810.005 2 0.015 kg Buzzer, Front dimension 18 x 24 mm 10 ... 26 VDC Plastic black Buzzer, Front dimension 18 x 24 mm 10 ... 55 VAC, 10 ... 75 VDC – U = 10 -26VDC + Wiring diagram 1 6 a Plastic black + Intermittent tone approx. 2 kHz Continous tone b a – b U1 = 10 - 35 VAC 10-50 VDC U2 = 35-55 VAC 35-75 VDC Wiring diagram 12 7 6 Continous tone 2 3 7 6 3 5 Intermittent tone approx. 2.8 k Hz 8 5 2 8 1 4 1 Volume control 4 Raised design 31 Illuminated pushbutton, IP 40 Equipment consisting of (schematic overview) 1.5 ... 6 L1 36 page Lens {$l=BR31_ AGAE_Druckhaube_Kunststoff} Single-LED page{$l=BR31_ H L AGAE_Single-LED} 33 10.5 29 … 51.5 3 H1 Actuator 43.5 / 51 Dimensions [mm] H = Universal terminal 2.0 x 0.5 mm, H1 = Universal-Solder terminal, L = Solder terminal, L1 = Solder terminal 2.8 x 0.5 mm Fixing nut Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Product can differ from the current configuration. Additional Information 18min. 18x 18mm / Ø18mm • Material of contact Gold 24min. 18x 24mm Ø2 18min. 10.4 + 0.2 0 Ø16 Contacts Diode 1N4007 Switching action Terminal Part No. Wiring diagram Switching system Component layout Mounting cut-outs [mm] Weight Illuminated pushbutton actuator, Front dimension 18 x 18 mm Low-level element Snap-action switching element 2 NO B Universal 2.0 x 0.5 mm 31-451.036 4 9 0.007 kg C Universal 2.0 x 0.5 mm 31-481.036 4 10 0.007 kg 2 NC B Universal 2.0 x 0.5 mm 31-452.036 4 7 0.007 kg 1 NC + 1 NO B Universal 2.0 x 0.5 mm 31-453.036 4 3 0.007 kg C Universal 2.0 x 0.5 mm 31-483.036 4 4 0.007 kg 1 NO B Universal 2.0 x 0.5 mm 31-455.036 4 5 0.007 kg C Universal 2.0 x 0.5 mm 31-485.036 4 6 0.007 kg 1 NC B Universal 2.0 x 0.5 mm 31-456.036 4 1 0.007 kg B Universal-Solder 31-709.0292 4 11 0.008 kg 1 NC + 1 NO 1 2 B Universal-Solder 31-710.0292 4 13 0.008 kg 2 C Universal-Solder 31-718.0292 4 14 0.008 kg B Solder 2.8 x 0.5 mm 31-151.022 16 0.006 kg B Solder 31-151.0252 15 0.006 kg C Solder 2.8 x 0.5 mm 31-281.022 18 0.006 kg C Solder 31-281.0252 17 0.006 kg 2 NC + 2 NO B Solder 31-152.0252 23 0.008 kg C Solder 31-282.0252 24 0.008 kg 3 NC + 3 NO B Solder 31-153.0252 25 0.010 kg C Solder 31-283.0252 26 0.010 kg 7 Raised design Contacts Snap-action switching element 4Ö+4S Diode 1N4007 Part No. Weight Löt 31-154.0252 27 0.012 kg C Solder 31-284.0252 28 0.012 kg 9 0.007 kg B C Universal 2.0 x 0.5 mm 31-461.036 4 10 0.007 kg 2 NC B Universal 2.0 x 0.5 mm 31-422.036 4 7 0.007 kg 1 NO 1 NC Snap-action switching element 1 NC + 1 NO 1 4 B Universal 2.0 x 0.5 mm 31-423.036 4 3 0.007 kg C Universal 2.0 x 0.5 mm 31-463.036 4 4 0.007 kg B Universal 2.0 x 0.5 mm 31-425.036 4 5 0.007 kg C Universal 2.0 x 0.5 mm 31-465.036 4 6 0.007 kg B Universal 2.0 x 0.5 mm 31-426.036 4 1 0.007 kg C Universal 2.0 x 0.5 mm 31-466.036 4 2 0.007 kg B Universal-Solder 31-705.0292 4 11 0.008 kg 1 C Universal-Solder 31-713.0292 4 12 0.008 kg 2 B Universal-Solder 31-706.0292 4 13 0.008 kg 4 2 2 NC + 2 NO Universal 2.0 x 0.5 mm 31-421.036 2 NO 1 NC + 1 NO C Universal-Solder 31-714.0292 14 0.008 kg B Solder 2.8 x 0.5 mm 31-121.022 16 0.006 kg B Solder 31-121.0252 15 0.006 kg C Solder 2.8 x 0.5 mm 31-261.022 18 0.006 kg C Solder 31-261.0252 17 0.006 kg 1 B Universal-Solder 31-707.0292 4 19 0.010 kg 1 C Universal-Solder 31-715.0292 4 20 0.010 kg 2 B Universal-Solder 31-708.0292 4 21 0.010 kg 2 C Universal-Solder 31-716.0292 4 22 0.010 kg B Solder 31-122.0252 23 0.008 kg 3 NC + 3 NO 4 NC + 4 NO C Solder 31-262.0252 24 0.008 kg B Solder 31-123.0252 25 0.010 kg C Solder 31-263.0252 26 0.010 kg B Solder 31-124.0252 27 0.012 kg C Solder 31-264.0252 28 0.012 kg Illuminated pushbutton actuator, Front dimension Ø 18 mm Low-level element 2 NO 2 NC 1 NC + 1 NO 1 NO 1 NC + 1 NO B Universal 2.0 x 0.5 mm 31-431.036 4 9 0.007 kg C Universal 2.0 x 0.5 mm 31-471.036 4 10 0.007 kg B Universal 2.0 x 0.5 mm 31-432.036 4 7 0.007 kg B Universal 2.0 x 0.5 mm 31-433.036 4 3 0.007 kg C Universal 2.0 x 0.5 mm 31-473.036 4 4 0.007 kg B Universal 2.0 x 0.5 mm 31-435.036 4 5 0.007 kg C Universal 2.0 x 0.5 mm 31-475.036 4 6 0.007 kg B Universal 2.0 x 0.5 mm 31-436.036 4 1 0.007 kg 2 B Universal-Solder 31-744.0292 4 13 0.008 kg 2 C Universal-Solder 31-748.0292 4 14 0.008 kg 1 NC Snap-action switching element 8 Terminal B Illuminated pushbutton actuator, Front dimension 18 x 24 mm Low-level element Switching action Wiring diagram Switching system Component layout 31 B Solder 2.8 x 0.5 mm 31-131.022 16 0.006 kg B Solder 31-131.0252 15 0.006 kg C Solder 2.8 x 0.5 mm 31-271.022 18 0.006 kg C Solder 31-271.0252 17 0.006 kg Contacts Snap-action switching element 2 NC + 2 NO Diode 1N4007 3 NC + 3 NO 4 NC + 4 NO 31 Switching action Terminal Part No. Wiring diagram Switching system Component layout Raised design Weight B Solder 31-132.0252 23 0.008 kg C Solder 31-272.0252 24 0.008 kg B Solder 31-133.0252 25 0.010 kg C Solder 31-273.0252 26 0.010 kg B Solder 31-134.0252 27 0.012 kg C Solder 31-274.0252 28 0.012 kg Contacts: NC = Normally closed, NO = Normally open Switching action: B = Momentary, C = Maintain The component layouts you will find from page {$l=BR31_KAZE_Zeichnung} 1 a- 1 a- 1 3 a- 1 3 a- 1 a- 1 a- 2 b+ 2 b+ 2 4 b+ 2 4 b+ 2 b+ 2 b+ Wiring diagram 1 1 Wiring diagram 2 3 a- Wiring diagram 3 1 3 Wiring diagram 4 a- 1 3 Wiring diagram 5 a- 1 3 a- Wiring diagram 6 1 3 a- 3(+) 4 b+ 4(-) I 2 4 2 b+ Wiring diagram 7 1 4 b+ Wiring diagram 8 3 a- 3(+) 1 b+ 3 a- 1 3 2 b+ Wiring diagram 16 Wiring diagram 17 3 1 4 b+ 1 3 a- 3(+) 4 2 2 4(-) 2(+) x1- 1 b+ 4(-) a- 3(+) 1(-) 4 1 3 4 b+ 2 4(-) 2(+) a- 4 1 1 3 2 Wiring diagram 21 3 1 2 b+ Wiring diagram 18 1 2 4 x2+ 3 a- 3(+) 4 b+ 4(-) II 4 2 Wiring diagram 19 3 a- 3(+) 1(-) 1 II 4 x 1- Wiring diagram 15 I 2 x2+ 3 I I I 4 3 Wiring diagram 11 Wiring diagram 14 II I Wiring diagram 20 3(+) 1(-) I 4 2 Wiring diagram 10 Wiring diagram 13 I 1 a- 2 b+ I 2 4(-) Wiring diagram 12 2 3 4 2 I 4 1 b+ Wiring diagram 9 I 2 4 2 3 1 4 b+ 4(-) 2(+) 2 3 a- 3(+) 1(-) 4 b+ 4(-) 2(+) II I 4 2 Wiring diagram 22 9 31 Raised design 1 3 1 2 3 x1- 1 II I 4 2 4 2 x2+ Wiring diagram 23 1 3 1 3 1 II 4 2 3 Wiring diagram 28 10 2 4 x1- 1 3 4 2 2 x2+ 1 3 1 II x1- 1 3 2 x2+ 4 2 3 1 III 4 2 3 x1- 4 x2+ IV 4 2 1 3 1 II 2 4 1 3 1 II 4 2 3 1 III 4 2 2 4 3 x1- 4 x2+ IV 4 2 3 x1- 4 x2+ III Wiring diagram 25 I 4 3 I 4 Wiring diagram 27 I 2 3 II III Wiring diagram 26 1 1 Wiring diagram 24 I 2 3 I Accessories 31 Front Lens plastic Product attribute 15.3 x 15.3 mm flat, illuminative, not suitable for film insert flat, illuminative, less suitable for film insert flat, non-illuminative Part No. Weight 15.3 x 15.3 mm 15.3 x 15.3 mm 15.3 x 15.3 mm smoked transparent 31-953.1 0.001 kg red transparent 31-953.2 0.001 kg orange transparent 31-953.3 0.001 kg yellow transparent 31-953.4 0.001 kg green transparent 31-953.5 0.001 kg blue transparent 31-953.6 0.001 kg colourless transparent 31-953.7 0.001 kg red translucent 31-951.2 0.001 kg orange translucent 31-951.3 0.001 kg yellow translucent 31-951.4 0.001 kg green translucent 31-951.5 0.001 kg blue translucent 31-951.6 0.001 kg white translucent 31-951.9 0.001 kg red transparent 31-955.2 0.001 kg yellow transparent 31-955.4 0.001 kg green transparent 31-955.5 0.001 kg colourless transparent 31-955.7 0.001 kg black opaque 31-951.0 0.001 kg grey opaque 31-951.8 0.001 kg Lens plastic concave, illuminative concave, non-illuminative Lens Lens plastic flat, illuminative Dimension 15.3 x 15.3 mm 15.3 x 15.3 mm red transparent 31-954.2 0.001 kg orange transparent 31-954.3 0.001 kg yellow transparent 31-954.4 0.001 kg green transparent 31-954.5 0.001 kg blue transparent 31-954.6 0.001 kg colourless transparent 31-954.7 0.001 kg black opaque 31-952.0 0.001 kg Lens plastic flat, illuminative flat, illuminative, not suitable for film insert 15.3 x 21.5 mm 15.3 x 21.5 mm smoked transparent 31-903.1 0.001 kg red transparent 31-903.2 0.001 kg orange transparent 31-903.3 0.001 kg yellow transparent 31-903.4 0.001 kg green transparent 31-903.5 0.001 kg blue transparent 31-903.6 0.001 kg colourless transparent 31-903.7 0.001 kg red translucent 31-901.2 0.001 kg orange translucent 31-901.3 0.001 kg 11 31 Accessories Product attribute Dimension Lens Part No. Weight flat, illuminative, not suitable for film insert 15.3 x 21.5 mm yellow translucent 31-901.4 0.001 kg green translucent 31-901.5 0.001 kg flat, illuminative, less suitable for film insert flat, non-illuminative concave, illuminative, not suitable for film insert concave, non-illuminative 0.001 kg 0.001 kg red transparent 31-905.2 0.001 kg yellow transparent 31-905.4 0.001 kg green transparent 31-905.5 0.001 kg colourless transparent 31-905.7 0.001 kg black opaque 31-901.0 0.001 kg grey opaque 31-901.8 0.001 kg 15.3 x 21.5 mm 15.3 x 21.5 mm 15.3 x 21.5 mm red transparent 31-904.2 0.001 kg orange transparent 31-904.3 0.001 kg yellow transparent 31-904.4 0.001 kg green transparent 31-904.5 0.001 kg blue transparent 31-904.6 0.001 kg colourless transparent 31-904.7 0.001 kg red translucent 31-902.2 0.001 kg orange translucent 31-902.3 0.001 kg yellow translucent 31-902.4 0.001 kg green translucent 31-902.5 0.001 kg blue translucent 31-902.6 0.001 kg white translucent 31-902.9 0.001 kg black opaque 31-902.0 0.001 kg grey opaque 31-902.8 0.001 kg Lens plastic flat, illuminative flat, illuminative, not suitable for film insert flat, illuminative, less suitable for film insert flat, non-illuminative 12 15.3 x 21.5 mm 31-901.6 31-901.9 Lens plastic concave, illuminative 15.3 x 21.5 mm blue translucent white translucent Ø 15.8 mm Ø 15.8 mm Ø 15.8 mm Ø 15.8 mm smoked transparent 31-933.1 0.001 kg red transparent 31-933.2 0.001 kg orange transparent 31-933.3 0.001 kg yellow transparent 31-933.4 0.001 kg green transparent 31-933.5 0.001 kg blue transparent 31-933.6 0.001 kg colourless transparent 31-933.7 0.001 kg red translucent 31-931.2 0.001 kg orange translucent 31-931.3 0.001 kg yellow translucent 31-931.4 0.001 kg green translucent 31-931.5 0.001 kg blue translucent 31-931.6 0.001 kg white translucent 31-931.9 0.001 kg red transparent 31-935.2 0.001 kg green transparent 31-935.5 0.001 kg colourless transparent 31-935.7 0.001 kg black opaque 31-931.0 0.001 kg Accessories 31 Protective cover, IP 40 Zusätzliche Informationen 32 10 10.5 • Please note that bigger minimum distances are necessary 23.5 • Front panel thickness reduces by 2 mm 25.5 • Hinged, with means for sealing 14.5 20 32 10.5 23.5 25.5 12 14.5 24 Dimensions [mm] Mounting cut-out Material Optics Dimension Part No. Weight transparent 20 x 23.5 mm 31-920 0.002 kg transparent 18 x 24 mm 31-925 0.002 kg Protective cover Ø 16 mm Plastic Protective cover Ø 16 mm Plastic Front protective cap, IP 67 Additional Information • Please note that bigger minimum distances are necessary 24 Two-part 24 • 24 30 13 Dimensions [mm] Product attribute Dimension Material Colour Optics Part No. Weight for button 18 x 18 mm with mounting cut-out Ø16 mm 24 x 24 mm PVC/PE colourless transparent 31-923 0.003 kg for button 18 x 24 mm with mounting cut-out Ø16 mm 24 x 30 mm PE/Silicone colourless transparent 31-924.2 0.003 kg Front protective cap 13 31 Accessories Protective guard • Please note that bigger minimum distances are necessary 18 Additional Information 12 20 26 24 Dimensions [mm] Product attribute Colour Part No. Weight 18 x 26 mm Brass matt chrome 01-926 0.011 kg 20 x 24 mm Brass matt chrome 01-927 0.011 kg Protective guard broad sides bent upwards, for button 18 x 24 mm with mounting cut-out Ø16 mm 14 Material Protective guard narrow ends bent upwards, for button 18 x 24 mm with mounting cut-out Ø16 mm Dimension Accessories 31 Blind plug 18min. 18 x18 mm / Ø18mm 24min. 18 x24 mm Ø2 18min. 10.4 + 0.2 0 Ø16 Mounting cut-outs [mm] Dimension Part No. Weight Plastic black 01-948.0 0.001 kg Plastic black 01-947.0 0.001 kg Plastic black 01-949.0 0.001 kg Blind plug 18 x 24 mm Ø 18 mm Colour Blind plug 18 x 18 mm Material Blind plug 15 31 Accessories Rear side PCB plug-in base Additional Information 9.8 2 • PCB plug-in base pins right-angle: With the extendable mounting the distance between plug-in base and PCB can be varied up to 3 mm 4 Ø16.4 9.6 17.9 3 4 6.2 17.9 9.8 17.8 1.5 4 12.9 Product attribute Part No. Weight axial PCB 31-940 3 0.002 kg right-angled PCB 31-941 1 0.004 kg axial PCB 31-942 2 0.002 kg PCB plug-in base for low level switching element Terminal PCB plug-in base for low level switching element Pins Component layout Dimensions [mm] PCB plug-in base for snap-action switching element 2.8 mm The component layouts you will find from page {$l=BR31_KAZE_Zeichnung} 16 Accessories 31 Flat receptacle Product attribute Weight 31-945 0.001 kg 31-946 0.001 kg Part No. Weight 01-928 0.001 kg 31-928 0.001 kg 31-929 0.001 kg Flat receptacle 2.0 x 0.5 mm plug-in terminal Part No. Flat receptacle 2.8 x 0.5 mm plug-in terminal Insulation sleeve Product attribute Insulation sleeve cover plug-in terminals for snap-action switching element 2.8 mm Insulation sleeve for flat receptacle 2.0 mm Insulation sleeve for flat receptacle 2.8 mm Terminal cover Part No. Weight 01-929_579 Terminal cover for snap-action switching element 16 0.010 kg 17 31 Accessories Illumination LED, T1 3/4 MG Additional Information • Due to high surface temperatures, the series resistor must not be soldered directly to the terminals of the equipment (use a terminal plate) Ø 6.1 max. 16 max. • When using AC/DC types with AC operation, slight flickering can occure • Luminous intensity data of the LEDs on direct voltage • Electrical and optical data are measured at 25 °C • The specified versions are built with a protection diode (halve wave rectifier) in series and the LED Dimensions [mm] • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination LED colour Operating voltage Operation current Lumi. intensity Dom. wavelength Part No. Weight 6 VDC +10 % 15 mA ±15 % 350 mcd 630 nm 10-2J06.3142 0.002 kg 12 VAC/DC +10 % 7/14 mA ±15 % 330 mcd 630 nm 10-2J09.1062 0.002 kg 24 VAC/DC +10 % 7/14 mA ±15 % 330 mcd 630 nm 10-2J12.1062 0.002 kg 28 VAC/DC +10 % 7/14 mA ±15 % 330 mcd 630 nm 10-2J13.1062 0.002 kg 48 VAC/DC +10 % 4/8 mA ±15 % 200 mcd 630 nm 10-2J19.1042 0.002 kg 6 VDC +10 % 15 mA ±15 % 300 mcd 587 nm 10-2J06.3144 0.002 kg 12 VAC/DC +10 % 7/14 mA ±15 % 280 mcd 587 nm 10-2J09.1064 0.002 kg 24 VAC/DC +10 % 7/14 mA ±15 % 280 mcd 587 nm 10-2J12.1064 0.002 kg 28 VAC/DC +10 % 7/14 mA ±15 % 280 mcd 587 nm 10-2J13.1064 0.002 kg 48 VAC/DC +10 % 4/8 mA ±15 % 180 mcd 587 nm 10-2J19.1044 0.002 kg 6 VDC +10 % 7 mA ±15 % 1050 mcd 525 nm 10-2J06.3145 0.002 kg 12 VAC/DC +10 % 4/7 mA ±15 % 1050 mcd 525 nm 10-2J09.1065 0.002 kg 24 VAC/DC +10 % 4/7 mA ±15 % 1050 mcd 525 nm 10-2J12.1065 0.002 kg 28 VAC/DC +10 % 4/7 mA ±15 % 1050 mcd 525 nm 10-2J13.1065 0.002 kg 48 VAC/DC +10 % 2/4 mA ±15 % 600 mcd 525 nm 10-2J19.1045 0.002 kg 6 VDC +10 % 15 mA ±15 % 680 mcd 470 nm 10-2J06.3146 0.002 kg 12 VAC/DC +10 % 7/14 mA ±15 % 650 mcd 470 nm 10-2J09.1066 0.002 kg 24 VAC/DC +10 % 7/14 mA ±15 % 650 mcd 470 nm 10-2J12.1066 0.002 kg 28 VAC/DC +10 % 7/14 mA ±15 % 650 mcd 470 nm 10-2J13.1066 0.002 kg 48 VAC/DC +10 % 4/8 mA ±15 % 400 mcd 470 nm 10-2J19.1046 0.002 kg 6 VDC +10 % 15 mA ±15 % 750 mcd x0.31/y0.32 nm 10-2J06.3149 0.002 kg 12 VAC/DC +10 % 7/14 mA ±15 % 700 mcd x0.31/y0.32 nm 10-2J09.1069 0.002 kg 24 VAC/DC +10 % 7/14 mA ±15 % 700 mcd x0.31/y0.32 nm 10-2J12.1069 0.002 kg 28 VAC/DC +10 % 7/14 mA ±15 % 700 mcd x0.31/y0.32 nm 10-2J13.1069 0.002 kg 48 VAC/DC +10 % 4/8 mA ±15 % 400 mcd x0.31/y0.32 nm 10-2J19.1049 0.002 kg Single-LED Single-LED red Single-LED yellow Single-LED green Single-LED blue Single-LED white 18 Accessories LED colour Operating voltage 31 Operation current Lumi. intensity Dom. wavelength Part No. Weight 15/14 mA ±15 % 600/630 mcd 625/525 nm 10-A312.314A 0.002 kg Operation current Part No. Weight 6 VAC/DC 120 mA ±10 % 10-1306.1349 0.001 kg 6.3 VAC/DC 200 mA ±10 % 10-1307.1369 0.001 kg 12 VAC/DC 75 mA ±10 % 10-1309.1309 0.001 kg 14 VAC/DC 80 mA ±10 % 10-1310.1319 0.001 kg 18 VAC/DC 40 mA ±10 % 10-1311.1249 0.001 kg 24 VAC/DC 35 mA ±10 % 10-1312.1229 0.001 kg 28 VAC/DC 30 mA ±10 % 10-1313.1209 0.001 kg 28 VAC/DC 40 mA ±10 % 10-1313.1249 0.001 kg 36 VAC/DC 20 mA ±10 % 10-1316.1179 0.001 kg 36 VAC/DC 30 mA ±10 % 10-1316.1209 0.001 kg 48 VAC/DC 20 mA ±10 % 10-1319.1179 0.001 kg 48 VAC/DC 25 mA ±10 % 10-1319.1199 0.001 kg Resistance Part No. Weight Bi-colour LED red/green 24 VDC +10 % Filament lamp, T1 3/4 MG Operating voltage Filament lamp Series resistor Additional Information • Only for filament lamp 48 VAC, 25 mA • For lamp voltage reduction • Keep to the country specific safety instructions • Due to high surface temperatures, the series resistor must not be soldered directly to the terminals of the equipment (use a terminal plate) Operating voltage Series resistor 110 VAC 2.7 kOhm 02-904.0 0.003 kg 125 VAC 3.3 kOhm 02-904.1 0.003 kg 145 VAC 4.7 kOhm 02-904.3 0.003 kg 240 VAC 10 kOhm 02-904.7 0.003 kg 19 31 Accessories Terminal plate empty Additional Information • For fitting with series resistors Product attribute Dimension Part No. Weight Terminal plate empty 5 spaces 62.5 x 60 x 15 mm 02-912.1 0.025 kg 10 spaces 125 x 60 x 15 mm 02-912.2 0.045 kg 15 spaces 187.6 x 60 x 15 mm 02-912.3 0.090 kg 20 spaces 250 x 60 x 15 mm 02-912.4 0.095 kg 20 Accessories 31 Mounting Lens remover Part No. Weight Lens remover 02-905 0.011 kg Lamp remover Additional Information p Caution: A switching process might be released when replacing the lamp Part No. Weight Lamp remover 61-9740.0 0.003 kg Mounting tool Additional Information • for tightening or loosening of the fixing nut Part No. Weight 01-907 Mounting tool 0.020 kg 21 31 Accessories Dressing tool Additional Information • For aligning buttons Part No. Weight 01-906 22 Dressing tool 0.03 kg Drawings 31 Drawings 3.81 Extendable mounting pins 3 1 4 2 3.81 a b 17.9 a 24 9.6 Ø2.1 hole for central mounting with M2 screw, if desired 10.16 9 31 Switch 7.62 4 7.62 3 b +0.1 Ø1.0 0 all holes 17.9 1.27 Ø1.0 all holes 7.62 15.24 1.27 5 x 2.54 1.27 Component layout 1 1.27 0.85 Drilling plan (solder side) Component layout 2 3.81 3.81 Ø1.0 Ø2.1 hole for central mounting with M2 screw, if desired 10.16 5.08 all holes 12.7 Component layout 3 Terminals (rearside) Drilling plan (solder side) 7.62 18 x 18 mm 18 x 24 mm 3.81 2.54 Ø18 mm 10.16 5.08 2 4 1 3 a b 2 4 1 3 a b 2 4 1 3 a b Anti twist device only 18 x 24 mm Ø1.0 all holes Component layout 4 23 31 Technical data Actuator with snap-action switching element Switching system Self-cleaning, double-break, snap action switching system (with contact gap 2 x 0.5 mm). 1 Normally closed or 1 Normally open contact per element. Snap-action switching elements with soldering terminals at the sides: Up to 4 switching element can be on a pushbutton (max. 4 Normally closed and 4 Normally open contacts). Snap-action switching element with axial plug-in terminals 2.8 mm stachable, only 1 switching element can be on a pushbutton. Material Material of contact Gold plated silver Switch housing Axial plug-in-/soldering terminal 2.8 mm: Diallylphthalate (DAP), Polyamide (PA66), Polysulfone, heatresistant and self-extinguishing Soldering terminal: PA 6.6 Ultramide Actuator housing Polyetherimide, self-extinguishing Mechanical characteristics Terminals Snap-action switching element with tinned soldering terminals at the sides: Max. wire diameter 2 wires à 1.2 mm Max. wire cross-section of stranded cable 1 x 1 mm² Snap-action switching element with axial plug-in terminals, which can also be used as soldering terminals: Plug-in terminal 2.8 x 0.5 mm Soldering terminal: Max. wire diameter 1 wire of 1.5 mm² Max. wire cross-section of stranded cable 2 x 0.75 mm² or 1 x 1.0 mm² Tightening torque for fixing nut max. 50 Ncm Actuating force 2 N … 5.5 N, depending on the number of switching elements Actuating travel 3 mm Rebound time ≤ 5 ms Mechanical lifetime Momentary action 2 million cycles of operation Maintained action 1 million cycles of operation Electrical characteristics Standards IEC 61058, EN 61058 24 Rated voltage 250 VAC/VDC Rated current 5A Contact resistance Starting value (initial) ≤ 50 mΩ Conventional free air thermal current 5A The maximum current in continuous operation and at ambient temperature not exceeding the quoted maximum values. Switch rating 250 VAC, 5 A (cosφ 1) 250 VAC, 3 A (cosφ 0.3) Switch rating AC (cosφ 0.7) Voltage 125 VAC 250 VAC Current 3 A 2A Switch rating DC (inductive) L: R = 30 ms Voltage 24 VDC 60 VDC 110 VDC 220 VDC Current 2 A 0.7 A 0.2 A 0.1 A Electric strength 2500 VAC, 50 Hz, 1 min. between all terminals and earth, as per IEC 60512-2-11 Protection class II Environmental conditions Storage temperature -40 °C … +85 °C Service temperature -25 °C … +55 °C For indicators and illuminated pushbuttons mounted as a block, make sure the heat can escape freely. Protection degree Front as per: IP 40 IP 67 with spray cover Shock resistance (Single impacts, semi-sinusoidal) 15 g for 11 ms, as per IEC 60512-4-3, IEC 60068-2-27 Vibration resistance (sinusoidal) 10 g at 0 – 2000 Hz, amplitude 1.5 mm, as per IEC 60512-4-4, IEC 60068-2-6 Climate resistance Standard condition, as per IEC 60068-2-3 and 2-30 Changing condition, as per IEC 60068-2-14 and 2-33 Technical data Approvals 31 Declaration of conformity CE Approbations CB (IEC 61058) CSA ENEC (EN 61058) Germanischer Lloyd UL Actuator with low level switching element Switching system This low level switching element was designed for switching low powers in electronic circuits. The mechanism assures reliable switching of loads ranging from a few μA/μV up to 100 mA/ 42 VAC/DC. Single-break momentary contact, as normally open or normally closed with 4 independent points of contact. 2 momentary contacts per switching element; combination of normally open and normally closed is possible. Special features are the long life, extremely short rebound time and stable contact resistance. Material Material of contact Gold plated Switch housing Polysulfone, heat-resistant and self-extinguishing Actuator housing Polyetherimide, self-extinguishing Mechanical characteristics Terminals The universal terminals permit these units to be mounted on printed circuit boards (PCB). These terminals can also be used as soldering or plug-in terminals. For these terminals we can also supply a plug-in base which, when soldered on to the board, enables the switch to be plugged in. Soldering terminal: Max. wire diameter 2 wires à 0.8 mm Max. wire cross-section of stranded cable 1x 0.75 mm² Mechanical lifetime Momentary action 5 million cycles of operation Maintained action 1 million cycles of operation Electrical characteristics Standards EN 61058 Contact resistance Starting value (initial) ≤ 50 mΩ Switch rating 10 μA, 100 μV to 100 mA at 42 VAC/VDC Electric strength 2500 VAC, 50 Hz, 1 min. between all terminals and earth, as per IEC 60512-2-11 Protection class II Environmental conditions Storage temperature -40 °C … +85 °C Service temperature -25 °C … +55 °C For indicators and illuminated pushbuttons mounted as a block, make sure the heat can escape freely. Protection degree Front as per: IP 40 IP 67 with spray cover Plug-in terminal: 2.0 x 0.5 mm Tightening torque for fixing nut max. 50 Ncm Actuating force 3 N … 3.5 N Actuating travel 3 mm Rebound time Typ. < 100 μs Shock resistance (Single impacts, semi-sinusoidal) 15 g for 11 ms, as per IEC 60512-4-3, IEC 60068-2-27 Vibration resistance (sinusoidal) 10 g at 0 – 2000 Hz, amplitude 1.5 mm, as per IEC 60512-4-4, IEC 60068-2-6 Climate resistance Standard condition, as per IEC 60068-2-3 and 2-30 Changing condition, as per IEC 60068-2-14 and 2-33 25 31 Technical data Buzzer 31-810.005 Buzzer system Electronic non-contacting buzzer with IC oscillator 88 dB (A) ±8 dB at a distance of 0.1 m Volume variable with a 1 MΩ potentiometer or corresponding fixed resistor Material Operation Voltage/Current Typ. 10 VAC … 55 VAC, 25 mA Typ. 10 VDC … 75 VDC, 15 mA Alarm buzzer case Polyetherimide Environmental conditions Front bezel Polyamide Storage temperature -40 °C … +85 °C Mechanical characteristics Service temperature -25 °C … +55 °C Terminals Soldering terminal Protection degree IP 40 Tightening torque for fixing nut max. 50 Ncm Approvals Electrical characteristics Approbations Germanischer Lloyd Frequency (tone) Approx. 2.8 kHz Declaration of conformity CE Interval frequency approx. 3 Hz Sound pressure Buzzer 31-801.002 Buzzer system Electronic non-contacting buzzer with IC oscillator Material Alarm buzzer case Polyetherimide Front bezel Polyamide Mechanical characteristics Terminals Plug-in terminal 2.8 x 0.5 mm Tightening torque for fixing nut max. 50 Ncm Electrical characteristics Frequency (tone) ca. 2.0 kHz 26 Interval frequency 2 Hz Sound pressure 88 db (A) ±8 dB at a distance of 0.1 m Operation Voltage/Current 10 VDC … 26 VDC, ≤ 20 mA Environmental conditions Storage temperature -40 °C … +85 °C Service temperature -25 °C … +55 °C Protection degree IP 40 Approvals Approbations Germanischer Lloyd Declaration of conformity CE Marking 31 General notes 3. Film inserts Instead of using engraving the lenses can be fitted with transparent film inserts, as an alternative. For this purpose, though, it is advisible to use transparent lenses. In the case of use of a smoke-black lens the fitted film becomes readable only if the lamp is on. To insert the film, the feet of the lens holder have to be pushed together far enough to enable the lens to be lift off easily. The film thickness is 0.2 mm. Important : Consider pushbutton mounting orientation befor specifying engraving characters ! 1. Engraving In addition to the most commonly used world languages, in DIN1451-3 close spacing, other typefaces are available as Scandinavian, Slavic, Greek, Russian and Polish. Red, blue and black lenses are filled with white colour. Other colour lenses arefilled in black. Standard height of letters is 2 mm. If the height is not specified, we will supply 2 mm engraved letters. 2. Hot stamping For larger series it is worth considering markings by means of hot stamping We will pleased to advise you. For letters and figures, typefaces with 2.5 mm, 3 mm and 4 mm are available. Alle Dimensionen in mm Front size (Lens) Film insert max. size Height of letters h Number of lines Number of capital letters per line (target value) 18 x 18 (15.2 x 15.2) 12.7 x 12.7 2.5 4 7–8 12.7 x 18.7 3 6–7 7 B3 2 4–5 5 B3 5.0 2 3–4 4 B3 6.0 1 3 3–4 B3 8.0 1 2–3 2–3 B3 2.5 4 11 12 B1 5 7–8 8 B2 3.0 3 9 – 10 10 – 11 B1 4 6–7 7 B2 4.0 2 7 7–8 B1 3 4–5 5 B2 2 5–6 6 B1 3–4 4 B2 6.0 8.0 Ø 12.8 B3 3.0 5.0 Ø 18 (Ø 15.8) Image 8 4.0 1 4–5 5 B1 2 3 3–4 B2 1 3–4 3–4 B1 2–3 2–3 B2 2.5 3 6 6 B4 3.0 2 5 6 B4 4.0 2 3 4 B4 5.0 1 2 3 B4 6.0 1 2 2 B4 8.0 1 2 2 B4 B1 B2 B3 B4 AB abc AB abc AB AB abc Film h 18 x 24 (15.2 x 21.2) Number of small letters per line (target value) abc 27 31 Application guidelines Suppressor circuits When switching inductive loads such as relays, DC motors, and DC solenoids, it is always important to absorb surges (e. g. with a diode) to protect the contacts. When these inductive loads are switched off, a counter emf can severely damage switch contacts and greatly shorten lifetime. Fig. 1 shows an inductive load with a free-wheeling diode connected in parallel. This free-wheeling diode provides a path for the inductor current to flow when the current is interrupted by the switch. Without this free-wheeling diode, the voltage across the coil will be limited only by dielectric breakdown voltages of the circuit or parasitic elements of the coil. This voltage can be kilovolts in amplitude even when nominal circuit voltages are low (e. g. 12 VDC) see Fig. 2. The free-wheeling diode should be chosen so that the reverse breakdown voltage is greater than the voltage driving the inductive load. The DC blocking voltage (VR) of the free-wheeling diode can be found in the datasheet of a diode. The forward current should be equal or greater than the maximum current flowing through the load. To get an efficient protection, the free-wheeling diode must be connected as close as possible to the inductive load! Counter EMF over load without free-wheeling diode Fig. 2 Switching with inductive load Fig. 1 Switch ON OFF 0 VDC 28 + _ Free-wheeling diode Inductive load Several hundred to several thousend volts di __ e = L dt 31 Index Index from Part No. Part No. Page 01-906...................... 22 01-907...................... 21 01-925...................... 13 01-926...................... 14 01-927...................... 14 01-928...................... 17 01-929...................... 17 01-947.0................... 15 01-948.0................... 15 01-949.0................... 15 02-904.0................... 19 02-904.1................... 19 02-904.3................... 19 02-904.7................... 19 02-905...................... 21 02-912.1................... 20 02-912.2................... 20 02-912.3................... 20 02-912.4................... 20 10-1306.1349........... 19 10-1307.1369........... 19 10-1309.1309........... 19 10-1310.1319........... 19 10-1311.1249........... 19 10-1312.1229........... 19 10-1313.1209........... 19 10-1313.1249........... 19 10-1316.1179........... 19 10-1316.1209........... 19 10-1319.1179........... 19 10-1319.1199........... 19 10-2J06.3142........... 18 10-2J06.3144........... 18 10-2J06.3145........... 18 10-2J06.3146........... 18 10-2J06.3149........... 18 10-2J09.1062........... 18 10-2J09.1064........... 18 10-2J09.1065........... 18 10-2J09.1066........... 18 10-2J09.1069........... 18 10-2J12.1062........... 18 10-2J12.1064........... 18 10-2J12.1065........... 18 10-2J12.1066........... 18 10-2J12.1069........... 18 10-2J13.1062........... 18 10-2J13.1064........... 18 10-2J13.1065........... 18 10-2J13.1066........... 18 10-2J13.1069........... 18 10-2J19.1042........... 18 10-2J19.1044........... 18 10-2J19.1045........... 18 10-2J19.1046........... 18 10-2J19.1049........... 18 10-A312.314A........... 19 31-030.002................. 5 31-030.005................. 5 31-031.006................. 5 31-040.002................. 4 31-040.005................. 4 31-041.006................. 4 31-050.002................. 4 31-050.005................. 4 31-051.006................. 4 31-121.022................. 8 31-121.0252............... 8 31-122.0252............... 8 31-123.0252............... 8 31-124.0252............... 8 31-131.022................. 8 31-131.0252............... 8 31-132.0252............... 9 31-133.0252............... 9 31-134.0252............... 9 31-151.022................. 7 Part No. Page 31-151.0252............... 7 31-152.0252............... 7 31-153.0252............... 7 31-154.0252............... 8 31-261.022................. 8 31-261.0252............... 8 31-262.0252............... 8 31-263.0252............... 8 31-264.0252............... 8 31-271.022................. 8 31-271.0252............... 8 31-272.0252............... 9 31-273.0252............... 9 31-274.0252............... 9 31-281.022................. 7 31-281.0252............... 7 31-282.0252............... 7 31-283.0252............... 7 31-284.0252............... 8 31-421.036................. 8 31-422.036................. 8 31-423.036................. 8 31-425.036................. 8 31-426.036................. 8 31-431.036................. 8 31-432.036................. 8 31-433.036................. 8 31-435.036................. 8 31-436.036................. 8 31-451.036................. 7 31-452.036................. 7 31-453.036................. 7 31-455.036................. 7 31-456.036................. 7 31-461.036................. 8 31-463.036................. 8 31-465.036................. 8 31-466.036................. 8 31-471.036................. 8 31-473.036................. 8 31-475.036................. 8 31-481.036................. 7 31-483.036................. 7 31-485.036................. 7 31-701.006................. 4 31-702.006................. 4 31-703.006................. 4 31-704.006................. 4 31-705.0292............... 8 31-706.0292............... 8 31-707.0292............... 8 31-708.0292............... 8 31-709.0292............... 7 31-710.0292............... 7 31-713.0292............... 8 31-714.0292............... 8 31-715.0292............... 8 31-716.0292............... 8 31-718.0292............... 7 31-744.0292............... 8 31-748.0292............... 8 31-801.002................. 6 31-810.005................. 6 31-901.0................... 12 31-901.2................... 11 31-901.3................... 11 31-901.4................... 12 31-901.5................... 12 31-901.6................... 12 31-901.8................... 12 31-901.9................... 12 31-902.0................... 12 31-902.2................... 12 31-902.3................... 12 31-902.4................... 12 31-902.5................... 12 31-902.6................... 12 Part No. Page 31-902.8................... 12 31-902.9................... 12 31-903.1................... 11 31-903.2................... 11 31-903.3................... 11 31-903.4................... 11 31-903.5................... 11 31-903.6................... 11 31-903.7................... 11 31-904.2................... 12 31-904.3................... 12 31-904.4................... 12 31-904.5................... 12 31-904.6................... 12 31-904.7................... 12 31-905.2................... 12 31-905.4................... 12 31-905.5................... 12 31-905.7................... 12 31-920...................... 13 31-923...................... 13 31-924.2................... 13 31-928...................... 17 31-929...................... 17 31-931.0................... 12 31-931.2................... 12 31-931.3................... 12 31-931.4................... 12 31-931.5................... 12 31-931.6................... 12 31-931.9................... 12 31-933.1................... 12 31-933.2................... 12 31-933.3................... 12 31-933.4................... 12 31-933.5................... 12 31-933.6................... 12 31-933.7................... 12 31-935.2................... 12 31-935.5................... 12 31-935.7................... 12 31-940...................... 16 31-941...................... 16 31-942...................... 16 31-945...................... 17 31-946...................... 17 31-951.0................... 11 31-951.2................... 11 31-951.3................... 11 31-951.4................... 11 31-951.5................... 11 31-951.6................... 11 31-951.8................... 11 31-951.9................... 11 31-952.0................... 11 31-953.1................... 11 31-953.2................... 11 31-953.3................... 11 31-953.4................... 11 31-953.5................... 11 31-953.6................... 11 31-953.7................... 11 31-954.2................... 11 31-954.3................... 11 31-954.4................... 11 31-954.5................... 11 31-954.6................... 11 31-954.7................... 11 31-955.2................... 11 31-955.4................... 11 31-955.5................... 11 31-955.7................... 11 61-9740.0................. 21 29
31-903.3 价格&库存
很抱歉,暂时无法提供与“31-903.3”相匹配的价格&库存,您可以联系我们找货
  • 1+34.768991+4.50673
  • 250+31.31874250+4.05951
  • 500+29.54791500+3.82997
  • 1000+27.776901000+3.60042
库存:52
31-903.3
    • 1+27.01350
    • 10+25.94087
    • 25+24.34756
    • 50+22.96251
    • 100+21.80658
    库存:71
    31-903.3
      • 1+37.44360
      • 200+14.94720
      • 500+14.43960
