TUHS5F12
TUHS5F12
    COSEL
    插件,28.7x17.5mm
TUHS5F12 数据手册
AC-DC Power Supplies PCB Mount Type World wide Isolated Safety Approvals OCP OVP TUHS-series Feature P.C.board mount AC-DC Converter Design flexibility for Hold-Up time and expected life Small size Built-in overcurrent and overvoltage protection circuits High efficiency by synchronous rectification technology (TUHS25) Not built-in aluminum and tantalum electrolytic capacitor CE marking Low voltage directive RoHS Directive Safety Approval UL60950-1, C-UL, EN62368-1 5-year warranty January 31, 2022 TUHS-1 Ordering information AC-DC Power Supplies PCB Mount Type TUHS3 TUH 1 S 2 3 3 F 05 4 5 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage R ClassⅡ *Avoid short circuit between +BC and -BC. It may cause the failure of inside components. *To use TUHS, external components are required. Refer to the instruction manual for details. MODEL TUHS3F05 TUHS3F12 TUHS3F15 TUHS3F24 MAX OUTPUT WATTAGE[W] 3.00 3.00 3.00 3.12 DC OUTPUT 5V 0.6A 12V 0.25A 15V 0.2A 24V 0.13A MODEL TUHS3F05 TUHS3F12 TUHS3F15 TUHS3F24 VOLTAGE[V] AC85 - 264 1f DC120 - 370 SPECIFICATIONS CURRENT[A] INPUT 0.08typ (Io=100%) ACIN 200V 0.05typ (Io=100%) FREQUENCY[Hz] EFFICIENCY[%] OUTPUT ACIN 100V 50/60 (47 - 63) ACIN 100V 79typ 81typ 81typ 81typ ACIN 200V 78typ 79typ 79typ 79typ INRUSH CURRENT Limited by external components VOLTAGE[V] 5 12 15 24 CURRENT[A] 0.6 0.25 0.2 0.13 LINE REGULATION[mV] 20max 48max 60max 96max LOAD REGULATION[mV] 40max 100max 120max 150max 30 to 100% Load *1 RIPPLE[mVp-p] 0 to 30% Load AC85V - 240V *1 30 to 100% Load *1 RIPPLE 0 to 30% Load NOISE[mVp-p] AC85V - 240V *1 0 to +85C TEMPERATURE REGULATION[mV] -40 to +85C 120max 160max 160max 200max 400max 480max 480max 580max 160max 200max 200max 240max 480max 560max 560max 660max 100max 180max 240max 360max 150max 270max 360max 480max DRIFT[mV] 20max 48max 60max 96max 11.40 - 12.60 14.25 - 15.75 23.00 - 25.00 16.50 - 24.00 26.40 - 38.40 *2 OUTPUT VOLTAGE SETTING[V] 4.90 - 5.30 Works over 105% of rating and recover automatically PROTECTION CIRCUIT OVERCURRENT PROTECTION AND OTHERS OVERVOLTAGE PROTECTION[V] 5.50 - 8.00 13.20 - 19.20 ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis AGENCY APPROVALS UL60950-1, C-UL (CSA60950-1), EN62368-1 CONDUCTED NOISE Complies with FCC-B,VCCI-B,CISPR-B,EN55022-B *3 HARMONIC ATTENUATOR Complies with IEC61000-3-2 (Class A) (Not built-in to active filter) CASE SIZE/WEIGHT 28.7X12.7X17.5mm[1.13X0.50X0.69 inches] (WXHXD) / 15g max COOLING METHOD Convection / Forced air *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated value. *3 Do not ground secondly circuit, in case of a standard adapted. * Measured with 18μF capasitor as Cbc. TUHS-2 January 31, 2022 TUHS3 External view Name Plate +BC -BC ¶Recommending size for processing PCB (TOP VIEW) +Vout AC2 -Vout 5.08 [0.2] 0.5 5.08 [0.2] ¶ Dimensions in : [0.09] 2.3 [0.09] 5.08 [0.2] 7.82 6.4 [0.25] ¶ Div. : 0.2inch [0.31] [0.5] [0.02] 24.1 [0.95] 1±0.1 2.3 3.5 [0.14] 12.9 17.5 [0.69] [0.51] 12.7 12.9 [0.51] 6.4 [0.25] AC1 mm [inch] ¶ Tolerance : ±0.5 [±0.02] ¶ Weight : 15g max ¶ Case material : PBT ¶ Pin material : Copper ¶ Plating treatment of pin : Lead free plating ¶ Dimensions in mm, [ ]=inches 5.08 [0.2] 24.1 [0.95] 28.7 [1.13] January 31, 2022 TUHS-3 Ordering information AC-DC Power Supplies PCB Mount Type TUHS5 TUH 1 S 2 5 3 F 05 4 5 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage R ClassⅡ *Avoid short circuit between +BC and -BC. It may cause the failure of inside components. *To use TUHS, external components are required. Refer to the instruction manual for details. MODEL TUHS5F05 TUHS5F12 TUHS5F15 TUHS5F24 MAX OUTPUT WATTAGE[W] 5.00 5.40 5.10 5.28 DC OUTPUT 5V 1A 12V 0.45A 15V 0.34A 24V 0.22A MODEL TUHS5F05 TUHS5F12 TUHS5F15 TUHS5F24 VOLTAGE[V] AC85 - 264 1f DC120 - 370 SPECIFICATIONS CURRENT[A] INPUT 0.13typ (Io=100%) ACIN 200V 0.08yp (Io=100%) FREQUENCY[Hz] EFFICIENCY[%] OUTPUT ACIN 100V 50/60 (47 - 63) ACIN 100V 78typ 82typ 82typ 83typ ACIN 200V 79typ 82typ 82typ 83typ INRUSH CURRENT Limited by external components VOLTAGE[V] 5 12 15 24 CURRENT[A] 1 0.45 0.34 0.22 LINE REGULATION[mV] 20max 48max 60max 96max LOAD REGULATION[mV] 40max 100max 120max 150max 30 to 100% Load *1 RIPPLE[mVp-p] 0 to 30% Load AC85V - 240V *1 30 to 100% Load *1 RIPPLE 0 to 30% Load NOISE[mVp-p] AC85V - 240V *1 0 to +80C TEMPERATURE REGULATION[mV] -40 to +80C 120max 160max 160max 200max 400max 480max 480max 580max 160max 200max 200max 240max 480max 560max 560max 660max 100max 180max 240max 360max 150max 270max 360max 480max DRIFT[mV] 20max 48max 60max 96max 11.40 - 12.60 14.25 - 15.75 23.00 - 25.00 16.50 - 24.00 26.40 - 38.40 *2 OUTPUT VOLTAGE SETTING[V] 4.90 - 5.30 Works over 105% of rating and recover automatically PROTECTION CIRCUIT OVERCURRENT PROTECTION AND OTHERS OVERVOLTAGE PROTECTION[V] 5.50 - 8.00 13.20 - 19.20 ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis AGENCY APPROVALS UL60950-1, C-UL (CSA60950-1), EN62368-1 CONDUCTED NOISE Complies with FCC-B,VCCI-B,CISPR-B,EN55022-B *3 HARMONIC ATTENUATOR Complies with IEC61000-3-2 (Class A) (Not built-in to active filter) CASE SIZE/WEIGHT 28.7X12.7X17.5mm[1.13X0.50X0.69 inches] (WXHXD) / 15g max COOLING METHOD Convection / Forced air *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated value. *3 Do not ground secondly circuit, in case of a standard adapted. * Measured with 22μF capasitor as Cbc. TUHS-4 January 31, 2022 TUHS5 External view Name Plate +BC -BC ¶Recommending size for processing PCB (TOP VIEW) +Vout AC2 -Vout 5.08 [0.2] 0.5 5.08 [0.2] ¶ Dimensions in : [0.09] 2.3 [0.09] 5.08 [0.2] 7.82 6.4 [0.25] ¶ Div. : 0.2inch [0.31] [0.5] [0.02] 24.1 [0.95] 1±0.1 2.3 3.5 [0.14] 12.9 17.5 [0.69] [0.51] 12.7 12.9 [0.51] 6.4 [0.25] AC1 mm [inch] ¶ Tolerance : ±0.5 [±0.02] ¶ Weight : 15g max ¶ Case material : PBT ¶ Pin material : Copper ¶ Plating treatment of pin : Lead free plating ¶ Dimensions in mm, [ ]=inches 5.08 [0.2] 24.1 [0.95] 28.7 [1.13] January 31, 2022 TUHS-5 Ordering information AC-DC Power Supplies PCB Mount Type TUHS10 TUH 1 S 2 10 3 F 05 4 5 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage R ClassⅡ *Avoid short circuit between +BC and -BC. It may cause the failure of inside components. *To use TUHS, external components are required. Refer to the instruction manual for details. MODEL TUHS10F05 TUHS10F12 TUHS10F15 TUHS10F24 MAX OUTPUT WATTAGE[W] 10.00 10.80 10.10 10.80 DC OUTPUT 5V 2A 12V 0.9A 15V 0.67A 24V 0.45A MODEL TUHS10F05 TUHS10F12 TUHS10F15 TUHS10F24 VOLTAGE[V] AC85 - 264 1f DC120 - 370 SPECIFICATIONS CURRENT[A] INPUT 0.25typ (Io=100%) ACIN 200V 0.14typ (Io=100%) FREQUENCY[Hz] EFFICIENCY[%] OUTPUT ACIN 100V 50/60 (47 - 63) ACIN 100V 81typ 85typ 85typ 86typ ACIN 200V 82typ 85typ 85typ 87typ INRUSH CURRENT Limited by external components VOLTAGE[V] 5 12 15 24 CURRENT[A] 2 0.9 0.67 0.45 LINE REGULATION[mV] 20max 48max 60max 96max LOAD REGULATION[mV] 40max 100max 120max 150max 30 to 100% Load *1 RIPPLE[mVp-p] 0 to 30% Load AC85V - 240V *1 30 to 100% Load *1 RIPPLE 0 to 30% Load NOISE[mVp-p] AC85V - 240V *1 0 to +70C TEMPERATURE REGULATION[mV] -40 to +70C 120max 160max 160max 200max 400max 480max 480max 580max 160max 200max 200max 240max 480max 560max 560max 660max 100max 180max 240max 360max 150max 270max 360max 480max DRIFT[mV] 20max 48max 60max 96max 11.40 - 12.60 14.25 - 15.75 23.00 - 25.00 16.50 - 24.00 26.40 - 38.40 *2 OUTPUT VOLTAGE SETTING[V] 4.90 - 5.30 Works over 105% of rating and recover automatically PROTECTION CIRCUIT OVERCURRENT PROTECTION AND OTHERS OVERVOLTAGE PROTECTION[V] 5.50 - 8.00 13.20 - 19.20 ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis AGENCY APPROVALS UL60950-1, C-UL (CSA60950-1), EN62368-1 CONDUCTED NOISE Complies with FCC-B,VCCI-B,CISPR-B,EN55022-B *3 HARMONIC ATTENUATOR Complies with IEC61000-3-2 (Class A) (Not built-in to active filter) CASE SIZE/WEIGHT 33.0X15.0X22.0mm[1.3X0.59X0.86 inches] (WXHXD) / 25g max COOLING METHOD Convection / Forced air *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated value. *3 Do not ground secondly circuit, in case of a standard adapted. * Measured with 47μF capasitor as Cbc. TUHS-6 January 31, 2022 TUHS10 External view Name Plate +BC -BC ¶Recommending size for processing PCB (TOP VIEW) AC1 +Vout AC2 5.08 [0.2] 28 [1.1] 7.62 [0.3] 0.5 [0.02] 2.5 2.5 [0.1] 7.62 [0.3] 9.38 [0.37] 6.4 [0.25] ¶ Dimensions in : [0.1] 12.9 [0.51] 22 [0.87] 3.5 [0.14] 15 [0.59] 17 [0.67] 12.9 [0.51] 6.4 [0.25] -Vout ¶ Div. : 0.2inch mm [inch] ¶ Tolerance : ±0.5 [±0.02] ¶ Weight : 25g max ¶ Case material : PBT ¶ Pin material : Copper ¶ Plating treatment of pin : Lead free plating ¶ Dimensions in mm, [ ]=inches 5.08 [0.2] 28 [1.1] 33 [1.3] January 31, 2022 TUHS-7 Ordering information AC-DC Power Supplies PCB Mount Type TUHS15 TUH 1 S 2 15 3 F 12 4 5 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage R ClassⅡ *Avoid short circuit between +BC and -BC. It may cause the failure of inside components. *To use TUHS, external components are required. Refer to the instruction manual for details. MODEL TUHS15F12 TUHS15F15 TUHS15F24 MAX OUTPUT WATTAGE[W] 15.00 15.00 15.12 DC OUTPUT 12V 1.25A 15V 1A 24V 0.63A MODEL TUHS15F12 TUHS15F15 TUHS15F24 VOLTAGE[V] AC85 - 264 1f DC120 - 370 SPECIFICATIONS CURRENT[A] INPUT 0.35typ (Io=100%) ACIN 200V 0.18typ (Io=100%) FREQUENCY[Hz] EFFICIENCY[%] OUTPUT ACIN 100V 50/60 (47 - 63) ACIN 100V 85typ 85typ 86typ ACIN 200V 85typ 85typ 87typ INRUSH CURRENT Limited by external components VOLTAGE[V] 12 15 24 CURRENT[A] 1.25 1 0.63 LINE REGULATION[mV] 48max 60max 96max LOAD REGULATION[mV] 100max 120max 150max 30 to 100% Load *1 RIPPLE[mVp-p] 0 to 30% Load AC85V - 240V *1 30 to 100% Load *1 RIPPLE 0 to 30% Load NOISE[mVp-p] AC85V - 240V *1 0 to +50C TEMPERATURE REGULATION[mV] -40 to +50C 160max 160max 200max 480max 480max 580max 200max 200max 240max 560max 560max 660max 180max 240max 360max 270max 360max 480max DRIFT[mV] 48max 60max 96max 14.25 - 15.75 23.00 - 25.00 *2 OUTPUT VOLTAGE SETTING[V] 11.40 - 12.60 Works over 105% of rating and recover automatically PROTECTION CIRCUIT OVERCURRENT PROTECTION AND OTHERS OVERVOLTAGE PROTECTION[V] 13.20 - 19.20 16.50 - 24.00 ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis AGENCY APPROVALS UL60950-1, C-UL (CSA60950-1), EN62368-1 CONDUCTED NOISE Complies with FCC-B,VCCI-B,CISPR-B,EN55022-B *3 HARMONIC ATTENUATOR Complies with IEC61000-3-2 (Class A) (Not built-in to active filter) CASE SIZE/WEIGHT 33.0X15.0X22.0mm[1.3X0.59X0.86 inches] (WXHXD) / 25g max COOLING METHOD Convection / Forced air *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated value. *3 Do not ground secondly circuit, in case of a standard adapted. * Measured with 68μF capasitor as Cbc. TUHS-8 26.40 - 38.40 INPUT-OUTPUT January 31, 2022 TUHS15 External view Name Plate +BC -BC ¶Recommending size for processing PCB (TOP VIEW) AC1 +Vout AC2 5.08 [0.2] 28 [1.1] 7.62 [0.3] 0.5 [0.02] 2.5 2.5 [0.1] 7.62 [0.3] 9.38 [0.37] 6.4 [0.25] ¶ Dimensions in : [0.1] 12.9 [0.51] 22 [0.87] 3.5 [0.14] 15 [0.59] 17 [0.67] 12.9 [0.51] 6.4 [0.25] -Vout ¶ Div. : 0.2inch mm [inch] ¶ Tolerance : ±0.5 [±0.02] ¶ Weight : 25g max ¶ Case material : PBT ¶ Pin material : Copper ¶ Plating treatment of pin : Lead free plating ¶ Dimensions in mm, [ ]=inches 5.08 [0.2] 28 [1.1] 33 [1.3] January 31, 2022 TUHS-9 Ordering information AC-DC Power Supplies PCB Mount Type TUHS25 TUH 1 S 2 25 3 F 05 4 5 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage R ClassⅡ *Avoid short circuit between +BC and -BC. It may cause the failure of inside components. *To use TUHS, external components are required. Refer to the instruction manual for details. MODEL TUHS25F05 TUHS25F12 TUHS25F15 TUHS25F24 MAX OUTPUT WATTAGE[W] 25.00 25.20 25.50 26.40 DC OUTPUT 5V 5A 12V 2.1A 15V 1.7A 24V 1.1A MODEL TUHS25F05 TUHS25F12 TUHS25F15 TUHS25F24 VOLTAGE[V] AC85 - 264 1f DC120 - 370 SPECIFICATIONS CURRENT[A] INPUT 0.55typ (Io=100%) ACIN 200V 0.35typ (Io=100%) FREQUENCY[Hz] EFFICIENCY[%] OUTPUT ACIN 100V 50/60 (47 - 63) ACIN 100V 87typ 88typ 88typ 89typ ACIN 200V 87typ 88typ 88typ 90typ INRUSH CURRENT Limited by external components VOLTAGE[V] 5 12 15 24 CURRENT[A] 5 2.1 1.7 1.1 LINE REGULATION[mV] 20max 48max 60max 96max LOAD REGULATION[mV] 40max 100max 120max 150max 30 to 100% Load *1 RIPPLE[mVp-p] 0 to 30% Load AC85V - 240V *1 30 to 100% Load *1 RIPPLE 0 to 30% Load NOISE[mVp-p] AC85V - 240V *1 0 to +50C TEMPERATURE REGULATION[mV] -40 to +50C 120max 160max 160max 200max 400max 480max 480max 580max 160max 200max 200max 240max 480max 560max 560max 660max 100max 180max 240max 360max 150max 270max 360max 480max DRIFT[mV] 20max 48max 60max 96max 11.40 - 12.60 14.25 - 15.75 23.00 - 25.00 16.50 - 24.00 26.40 - 38.40 *2 OUTPUT VOLTAGE SETTING[V] 4.90 - 5.30 Works over 105% of rating and recover automatically PROTECTION CIRCUIT OVERCURRENT PROTECTION AND OTHERS OVERVOLTAGE PROTECTION[V] 5.50 - 8.00 13.20 - 19.20 ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS INPUT-OUTPUT AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) OPERATING TEMP.,HUMID.AND ALTITUDE -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max VIBRATION 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis AGENCY APPROVALS UL60950-1, C-UL (CSA60950-1), EN62368-1 CONDUCTED NOISE Complies with FCC-B,VCCI-B,CISPR-B,EN55022-B *3 HARMONIC ATTENUATOR Complies with IEC61000-3-2 (Class A) (Not built-in to active filter) CASE SIZE/WEIGHT 36.0X16.5X25.4mm[1.42X0.65X1.0 inches] (WXHXD) / 40g max COOLING METHOD Convection / Forced air *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated value. *3 Do not ground secondly circuit, in case of a standard adapted. * Measured with 120μF capasitor as Cbc. TUHS-10 January 31, 2022 TUHS25 External view Name Plate +BC -BC ¶Recommending size for processing PCB (TOP VIEW) AC1 7.62 [0.3] +Vout 30.48 [1.2] -Vout [0.02] [0.65] 16.5 0.5 7.62 [0.3] 20.32 [0.8] 10.16 [0.4] AC2 ¶ Dimensions in : 2.76 7.62 [0.11] [0.3] 7.62 [0.3] 10.16 [0.4] [0.4] [0.1] 10.16 2.54 3.5 [0.14] [0.8] [1.0] 20.32 25.4 ¶ Div. : 0.2inch mm [inch] ¶ Tolerance : ±0.5 [±0.02] ¶ Weight : 40g max ¶ Case material : PBT ¶ Pin material : Copper ¶ Plating treatment of pin : Lead free plating ¶ Dimensions in mm, [ ]=inches 30.48 [1.2] 36 [1.42] January 31, 2022 TUHS-11 TUHS-series Pin Configuration ¿TUHS3/TUHS5 AC2 - Vout AC1 +BC No. +Vout Bottom View 1 2 3 4 5 6 - BC ¿TUHS10/TUHS15 6 - Vout AC2 2 + BC 3 Function AC input +BC -BC +DC -DC output output output output 5 + Vout Bottom View AC1 1 Pin Connection AC1 AC2 +BC -BC +VOUT -VOUT 4 - BC ¿TUHS25 AC2 2 6 - Vout Bottom View AC1 1 5 + Vout 4 - BC + BC 3 Implementation・Mounting Method Mounting method ¡The unit can be mounted in any direction. When two or more power supplies are used side by side, position them with proper intervals to allow enough air ventilation. The temperature around each power supply should not exceed the temperature range shown in derating curve. ¡Avoid placing the AC input line pattern layout underneath the unit.It will increase the line conducted noise. Make sure to leave an ample distance between the line pattern layout and the unit. Also avoid placing the DC output line pattern underneath the unit because it may increase the output noise. Lay out the pattern away from the unit. ¡Avoid placing the signal line pattern layout underneath the unit because the power supply might become unstable. Lay out the pattern away from the unit. Stress to the pins ¡Applying excessive stress to the input or output pins of the power module may damage internal connections. Avoid applying stress in excess of that shown in right figure. Less than 19.6N(2kgf) ¡Input/output pin are soldered to the PCB internally. Do not pull or bend a lead powerfully. ¡If it is expected that stress is applied to the input/output pin due to vibration or impact, reduce the stress to the pin by taking such measures as fixing the unit to the PCB by sili- Less than 19.6N(2kgf) Less than 19.6N(2kgf) cone rubber, etc. Soldering ¡Flow soldering: 260C for up to 15 seconds. ¡Soldering iron (26W): 450C for up to 5 seconds. Derating ¿Derating curve for input voltage 100 Load[%] Load[%] 100 50 40 AC50V DC70V AC85V DC120V in Vin AC85V V DC120V (b)TUHS5,TUHS10,TUHS15,TUHS25 (a)TUHS3 TUHS-12 AC50V DC70V January 31, 2022 TUHS-series Derating ¿TUHS3F Ambient temperature derating curve (Reference value) Load factor[%] 100 80 60 40 20 Convection (0.2m/s),Forced air (2.0m/s) 0 -40 -20 0 20 40 60 85 80 100 Ambient temperature[C] ¿TUHS5F Ambient temperature derating curve ¿TUHS5F Ambient temperature derating curve at forced air (Reference value) 100 100 80 80 Load factor[%] Load factor[%] at convection cooling (Reference value) 75 60 40 20 Convection(0.2m/s) 1TUHS5F05,TUHS5F12,TUHS5F15 2TUHS5F24 0 -40 -20 0 20 40 60 75 85 80 60 40 20 Forced air(2.0m/s) 0 -40 100 -20 0 ¿TUHS10F Ambient temperature derating curve 100 80 80 60 -40 Convection(0.2m/s) 1TUHS10F05,TUHS10F15 2TUHS10F12,TUHS10F24 -20 0 20 40 55 60 85 80 40 20 Forced air(2.0m/s) 1TUHS10F05,TUHS10F15 2TUHS10F12,TUHS10F24 0 -40 100 -20 0 at convection cooling (Reference value) 75 85 80 100 at forced air (Reference value) 1 3 2 Load factor[%] Load factor[%] 60 100 80 60 -40 40 ¿TUHS15F Ambient temperature derating curve 100 0 20 Ambient temperature[C] ¿TUHS15F Ambient temperature derating curve 20 100 60 Ambient temperature[C] 40 85 80 at forced air (Reference value) 100 0 60 ¿TUHS10F Ambient temperature derating curve Load factor[%] Load factor[%] at convection cooling (Reference value) 20 40 Ambient temperature[C] Ambient temperature[C] 40 20 Convection(0.2m/s) 1TUHS15F12 2TUHS15F15 3TUHS15F24 -20 0 20 40 45 60 85 80 80 60 40 20 Forced air(2.0m/s) 1TUHS15F12,TUHS15F15 2TUHS15F24 0 100 Ambient temperature[C] -40 -20 0 20 40 60 75 85 80 100 Ambient temperature[C] January 31, 2022 TUHS-13 TUHS-series Derating ¿TUHS25F Ambient temperature derating curve at convection cooling (Reference value) ¿TUHS25F Ambient temperature derating curve at forced air (Reference value) 100 3 80 2 1 60 40 20 0 -40 Load factor[%] Load factor[%] 100 Convection(0.2m/s) 1TUHS25F05 2TUHS25F12,TUHS25F24 3TUHS25F15 -20 0 20 40 60 85 80 80 75 60 40 20 Forced air(2.0m/s) 1TUHS25F05,TUHS25F15 2TUHS25F12,TUHS25F24 0 -40 100 -20 Ambient temperature[C] 0 40 20 60 75 85 80 100 Ambient temperature[C] ¡Derating curve is shown below. Note: In the hatched area, the specification of Ripple, Ripple Noise is different from other area. ¡Please have sufficient ventilation to keep the temperature of point A in Instruction Manual6. Please also make sure that the ambient temperature does not exceed 85C. Instruction Manual ◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product. Instruction Manual Before using our product https://en.cosel.co.jp/technical/caution/index.html https://en.cosel.co.jp/product/powersupply/TUHS/ TUHS NOTICE Basic Characteristics Data Model TUHS3F Circuit method Switching frequency [kHz] Inrush Input current current protection [A] circuit Series/Parallel operation availability PCB/Pattern Material Single Double Series Parallel sided sided operation operation Flyback converter 80-250 *3 *1 Resistor glass fabric base,epoxy resin Yes Yes *2 TUHS5F Flyback converter 80-250 *3 *1 Resistor glass fabric base,epoxy resin Yes Yes *2 TUHS10F Flyback converter 80-250 *3 *1 Resistor glass fabric base,epoxy resin Yes Yes *2 Resistor glass fabric base,epoxy resin Yes Yes *2 Thermistor glass fabric base,epoxy resin Yes Yes *2 TUHS15F Flyback converter 80-250 *3 *1 TUHS25F Flyback converter 80-250 *3 *1 *1 R  efer to Specification.  efer to instruction manual. *2 R *3 The value changes depending on input and load. TUHS-14 January 31, 2022
TUHS5F12 价格&库存
很抱歉,暂时无法提供与“TUHS5F12”相匹配的价格&库存,您可以联系我们找货
TUHS5F12
  • 1+113.01096
  • 10+111.68841
  • 50+107.85611
库存:10
TUHS5F12
    • 1+181.019461+23.44524
    • 3+144.591783+18.72721
    • 4+140.041434+18.13786
    • 5+137.306245+17.78360
    • 9+132.449229+17.15453
    • 10+131.8441610+17.07617
    • 20+129.1089820+16.72191
    库存:318
    TUHS5F12
      • 1+107.24400
      • 10+104.01480
      库存:3
