1327G6-BK
1327G6-BK
    ANDERSON
    1327G6-BK
1327G6-BK 数据手册
SPEC Pak ® Sealed Power For Environmental Connections Marine | Machine Tool Wind Power | | Lighting Industrial Automation | | Transportation Motor | | Pumps Solar Power | | Ground Support Harsh Environments ® Anderson Power Products -1www.andersonpower.com ® Rugged and Sealed (IP68) Plugs and Receptacles For Use with APP® Powerpole® Signal, Power & Ground Contacts & Housings APP®’s SPEC Pak® Connector Series uses rugged and environmentally sealed (IP68) shells to protect existing APP® Powerpole® contacts and housings. Customer configured SPEC Pak® Connectors may be used anywhere a rugged and waterproof high-power interconnect with signal and ground capabilities is required such as in; mass transportation, off-road vehicles, factory automation, oil and petrochemical exploration, agricultural equipment, and many more. The core APP® Powerpole® technology within the SPEC Pak® is proven reliable and cost effective. The broad selection of touch safe, color-coded Powerpole® housings with power, signal and ground contacts accept a broad range of wire gauges, #24 to #10 AWG (0.25 to 4.0 mm²), giving users thousands of flexible design solutions in a single interconnect. 14 15 1 2 3 4 5 6 7 13 8 9 10 1 - Industry Standard Panel Cut Out (Same as 26482 & 5015 shell size 24) 2 - IP68 Panel Mount Sealing Gasket 3 - Touch Safe Housings (UL1977, Section 10.2) 4 - IP68 Interfacial Sealing Gasket 5 - Latch (top or bottom of plug or receptacle) 6 - Power Contacts (up to 45 amps) 12 11 9 - First Mate / Last Break Ground Contacts 10 - Color Coded Housings to Match Wire Color 11 - UV & Chemical Resistant Ruggedized Shells Additional Features Available on the Right Angle Include: 12 - Uses Industry Standard PG Gland (PG gland compatible - size 21 or 29) 7 - Signal Contacts (4 contacts per PPMX housing) 13 - Right Angle Backshell Lockable in 8 Directions for Cable Routing 8 - Uses Industry Standard Sealing Components 14 - Integrated Strain Relief (PG gland compatible - size 21) -2- www.andersonpower.com 15 - Ruggedized Right Angle Plug Shell Specifications SPEC Pak® Shell / Components Electrical UL Voltage Rating (AC/DC) Dielectric Withstanding Voltage (AC) Operating Temperature (°C) (°F) Flammability Rating of SPEC Shells 600 3000 -40° to 105° -40° to 221° UL 94V-0 Mechanical Shells / Latch Mating Cycles Connect / Disconnect (lbf) (N) IP Rating UL50 Sec 30 Sealing Requirement 1500 Min 18 Max 80 Max IP68 Pass Material Shells (Plug / Receptacle) Latch Holder PBT Nylon Polycarbonate PPMX (4800 Series) Powerpole® Signal Contact Ratings for SPEC Pak® Use Electrical UL Current Rating (Amperes) Voltage Rating (AC/DC) Contact Barrel Wire Size (AWG) (mm²) Contact Retention Force (lbf) (N) Insertion Force (lbf) (N) Operating Temperature (°C) (°F) 7 300 #20 to #24 0.5 to 0.25 12.0 53.0 4.5 Max 20.0 Max -20° to 105° -4° to 221° Mechanical Mating Cycles (No load) 1500 Material Housing Material Contact Material Contact Plating Powerpole ® Power (1327FP Series) & Ground (1827 Series) Contacts Ratings for SPEC Pak® Use Electrical UL Current Rating (Amperes) CSA (30°C Rise) (Amperes) Voltage Rating (AC/DC) Contact Barrel Wire Size (AWG) - Power - Ground (mm²) - Power - Ground Average Contact Resistance (micro-ohms) Contact Retention Force (lbf) (N) Operating Temperature (°C) (°F) Flammability Rating Mechanical Mating Cycles No Load - Tin - Silver Under Load (Hot Plug 250 mating cycles @ 120V) * (Hot Plug 250 mating cycles @ 72V) * Mechanical Shock (50 g) Vibration (10 g) 15 to 45 10 to 29 600 20 to 10 14 to 10 0.5 to 4.0 1.5 to 4.0 600 25 111 -20° to 105° -4° to 221° UL94 V-0 1,500 10,000 30A 45A Mil Standard 202 213 Cond. A Mil Standard 202 204 Cond. A Material Housing Material Touch Safe (Power / Signal Housing) Contact Material Contact Plating Polycarbonate UL1977 Sec. 10.2 Copper Tin or Silver * Hot Plug testing completed with individual Powerpole ® housings NOTE: Agency approvals - TUV (contact customer service) / Patents PBT Copper Alloy Gold, 50 Micro-inches NOTE: PPMX Contacts, up to 4 per housing www.andersonpower.com -3- Part Number Configurator PART NUMBER PLAN SPEC Pak® Series Shell Color Shell Style (1 fixed character) (1 character) (1 character) S K 2 S = SPEC Pak® Series K = Black PLUG KIT Dash RIGHT ANGLE PLUG KIT (3 characters) 053 Interfacial Sealing Gasket O-Ring Plug Holder Locking Nut Interfacial Sealing Gasket B06 = PP15/45 Housing (any type), 6 Pole PANEL MOUNT RECEPTACLE KIT Panel Mount Gasket Panel Mount Receptacle Shell Retaining Pin B06 053 = 53 mm - 6 Pole Shell A53 = 53 mm - 6 Pole Right Angle Shell, PG 21 B53 = 53 mm - 6 Pole Right Angle Shell, PG 29 Right Angle Backshell Right Angle Plug Shell Plug Powerpole® Holder Insert Arrangement - 2 = Panel Mount Receptacle 6 = Straight Plug 8 = Right Angle Plug 9 = Cover Plug Shell Retaining Pin Shell Size (mm) (3 characters) Latch RECEPTACLE COVER KIT IP68 Sealing Cover Interfacial Sealing Gasket Retaining Pin Receptacle Powerpole® Holder Lanyard NOTE: - Mounting hardware (4 each - M3.5 or #6 screws) not included - Recommended torque for mounting hardware is 3½ to 5 in-lbf (0.4 to 0.56 Nm) KIT ORDERING INFORMATION SPEC Pak® Kits Part Number SK6-053B06 SK8-A53B06 SK8-B53B06 -4- Description Plug kit - Plug shell (includes interfacial sealing gasket) - Powerpole® holder for plug - Retaining pin Right angle plug kit for PG 21 - Right angle backshell for PG 21 - Locking nut - O-ring - Plug shell - Retaining pin - Powerpole® holder for plug Right angle plug kit for PG 29 - Right angle backshell for PG 29 - Locking nut - O-ring - Plug shell - Retaining pin - Powerpole® holder for plug www.andersonpower.com SPEC Pak® Kits Part Number SK2-053B06 SK9-053 Description Receptacle kit - Panel mount gasket for receptacle - Receptacle shell with latch - Retention pin - Powerpole® holder for receptacle Cover kit (receptacle only) - Protective sealing (IP68) cover for receptacle with lanyard Component Replacement Parts Part Number 114765P1 2-8658P1 2-8654P1 114915P2 Description Panel mount gasket for receptacle 6 position latch Right angle locking nut Right angle O-ring PART NUMBER PLAN Wire Protection Housing Arrangement See pages 6 & 7 (4 characters) For more information see pages 8 & 9 (1 character) (2 characters) PS 00 = None PS = Plastic Short PF = Plastic With Flex Spring PM = Plastic Multi Hole CT = Conduit Adapter Thread CA = Conduit Adapter Push-in Dash 01 00 = None 01- 99 = Varies By Gland Type NOTE: (1) See PG Gland charts on page 6 & 7 for details. (2) Panel mount receptacle side is always “00”. (3) For right angle; only PS and PM types available. - 0 Contact 00 0 = Custom Configuration - Use Next Section A = AC, Single Phase B = AC, 3 Phase, 3 Wire C = DC, 2 Circuit, 4 Wire D = DC, 2 Circuit, 4 Wire, With Ground E = AC, 3 Phase, 4 Wire F = AC, 3 Phase, 5 Wire G = DC, 2 Circuit, 6 Wire H = DC, 2 Circuit, 4 Wire With 8 Signal J = AC, Single Phase With Signal K = AC, 3 Phase, 3 Wire With 4 Signal L = DC, 2 Circuit, 4 Wire, With 4 Signal M = AC, 3 Phase, 3 Wire With 8 Signal N = DC, 2 Circuit, 4 Wire, With Ground & 4 Signal P = AC, 3 Phase, 4 Wire With 4 Signal X = All Signal Dash APP® Content (3 characters) - A01 Custom Configuration* Contact Factory 00 = Custom Configuration - Use Next Section 01 = 261G2 Contact for #10 to #14 AWG (4.0 to 1.5 mm²) Wire 02 = 200G1L Contact for #10 to #14 AWG (4.0 to 1.5 mm²) Wire 03 = 261G1 Contact for #12 to #16 AWG (2.5 to 1.0 mm²) Wire 04 = 1331 Contact for #12 to #16 AWG (2.5 to 1.0 mm²) Wire 05 = 262G1 Contact for #16 to #20 AWG (1.0 to 0.5 mm²) Wire 06 = 1332 Contact for #16 to #20 AWG (1.0 to 0.5 mm²) Wire 07 = 200G2L Contact for #16 to #20 AWG (1.0 to 0.5 mm²) Wire 99 = All Signal Amperage Ratings are available on Page 9. Part Numbering Notes: 1) To order SPEC Pak® “Shell Kits Only” (no internal Powerpole® housings or contacts), use part numbering on page 4 only. Plug Shell Kit Example: SK6-053B06 Powerpole® housings, contacts and wire protection may be ordered separately, see pages 6, 7 and 10 for information. 2) To order complete standard configured SPEC Pak® connector kits (including internal Powerpole® housings and contacts) use Part Number Plan across the top of pages 4 and 5. Standard SPEC Pak® Plug Connector Kit Configuration Example: SK6-053B06PS01-D02 3) To order a custom configuration which is not listed on page 8 and 9, use APP® custom part number configurator on the APP® website, www.andersonpower.com, or contact factory. * Custom configurations may not be UL Recognized. www.andersonpower.com -5- Wire Protection - PG Gland SPECIFICATIONS Material (Push-in Conduit) Shell Nylon PA Gasket TPE Color Black Mechanical Operating Temp IP Rating Thread Type Material (All Others) Shell Nylon PA 66 (UL94 V-2)* Gasket EPDM Color Black Mechanical -30°C to 100°C (-22°F to 212°F) Operating Temp IP68 IP Rating PG UV Rating Thread Type Torque Requirements Cable Gland Body to Plug Housing - Hand tighten until snug, tighten additional 1/8 - 1/4 turn with wrench Sealing Nut to Cable -40°C to 105°C (-40°F to 221°F) - Hand tighten until snug, tighten additional 1/2 - 3/4 turn with wrench IP68 Equivalent to UL746C F1 PG * Contact factory for UL94 V-0 material NOTE: Only UL listed cable glands are UL recognized components when used with SPEC Pak® connector(s). STRAIGHT PLASTIC SHORT THREAD TYPE - STD PACK 50 / UL LISTED Straight Gland Kit Right Angle Gland Kit C1 Lock Nut APP® P/N Right Angle RPS1P21-16X RPS1P21-18X RPS1P29-22X RPS1P29-25X APP® P/N Straight PS1P21-16X PS1P21-18X N/A N/A Washer Wire Protection Designation (4 Characters) PS01 PS02 PS11 PS12 C2 PG Gland Size 21 21 29 29 Body Number of Holes 1 1 1 1 Seal Cable Range Wire Outer Dia. mm (in) 16.2 - 10.5 (0.64 - 0.41) 18.5 - 13 (0.73 - 0.51) 22 - 16 (0.86 - 0.63) 25 - 18 (0.98 - 0.71) Sealing Nut Thread O. D. C1 mm (in) 28.3 (1.11) 28.3 (1.11) 37 (1.46) 37 (1.46) Seal Panel Mounting Hole mm (in) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 37 - 37.4 (1.46 - 1.47) 37 - 37.4 (1.46 - 1.47) Claw Thread Length C2 mm (in) 12 (0.47) 12 (0.47) 12 (0.47) 12 (0.47) Sealing Nut Wrench Size Lock Nut (mm) 36 36 46 46 STRAIGHT PLASTIC WITH FLEX SPRING - STD PACK 50 / UL LISTED C1 Washer APP® P/N Straight PF1P21-16X Wire Protection Designation Cable Range (4 Characters) Wire Outer Dia. mm (in) PF01 15.8 - 10.5 (0.62 - 0.41) LOCK NUT FOR PG 21 CABLE GLANDS APP® P/N Lock Nut -6- 124G30 Wrench Size Lock Nut (mm) 36 www.andersonpower.com Std. Pkg. Size 50 C2 Body Thread O. D. C1 mm (in) 28.3 (1.11) Seal Panel Mounting Hole mm (in) 28.3 - 28.7 (1.11 - 1.13) Sealing Nut Thread Length C2 mm (in) 12 (0.47) Wrench Size Lock Nut (mm) 36 Wrench Size Sealing Nut (mm) 33 Wrench Size Sealing Nut (mm) 33 33 42 42 STRAIGHT PLASTIC MULTI-HOLE TYPE - STD PACK 50 / NOT UL LISTED Straight Gland Kit Right Angle Gland Kit C1 Lock Nut APP® P/N Right Angle RPS2P21-5X RPS2P21-6X RPS2P21-8X RPS3P21-5X RPS3P21-6X RPS3P21-8X RPS4P21-3X RPS4P21-4X RPS4P21-5X RPS4P21-7X RPS5P21-3X RPS5P21-4X RPS5P21-6X RPS6P21-3X RPS6P21-5X APP® P/N Straight PS2P21-5X PS2P21-6X PS2P21-8X PS3P21-5X PS3P21-6X PS3P21-8X PS4P21-3X PS4P21-4X PS4P21-5X PS4P21-7X PS5P21-3X PS5P21-4X PS5P21-6X PS6P21-3X PS6P21-5X Washer Wire Protection Designation (4 Characters) PM21 PM22 PM23 PM31 PM32 PM33 PM41 PM42 PM43 PM44 PM51 PM52 PM53 PM61 PM62 C2 PG Gland Size 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 Body Number of Holes 2 2 2 3 3 3 4 4 4 4 5 5 5 6 6 Seal Claw Cable Range Wire Outer Dia. mm(in) 5.2 - 3.6 (0.20 - 0.14) 6.5 - 5.1 (0.26 - 0.20) 8.7 - 6.4 (0.34 - 0.25) 5.2 - 3.6 (0.20 - 0.14) 6.2 - 4.8 (0.24 - 0.19) 8.0 - 6.2 (0.31 - 0.24) 3.1 - 2.0 (0.12 - 0.08) 4.1 - 3.0 (0.16 - 0.12) 5.2 - 3.8 (0.20 - 0.15) 7.3 - 5.6 (0.29 - 0.22) 3.6 - 2.6 (0.14 - 0.10) 4.6 - 3.6 (0.18 - 0.14) 6.0 - 4.6 (0.24 - 0.18) 3.6 - 2.6 (0.14 - 0.10) 5.2 - 3.6 (0.20 - 0.14) Sealing Nut Thread O.D. C1 mm (in) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) Seal Panel Mounting Hole mm (in) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) Claw Thread Length C2 mm (in) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) 12.5 (0.49) Sealing Nut Wrench Size Lock Nut (mm) 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 Wrench Size Sealing Nut (mm) 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 STRAIGHT CONDUIT ADAPTER THREAD TYPE - STD PACK 50 / NOT UL LISTED F1 C1 Washer APP® P/N CT1P21-21X CT1P21-26X CT1P21-28X Wire Protection Designation (4 Characters) CT02 CT03 CT04 Max. Joint F1 mm (in) 22.0 (0.87) 26.5 (1.04) 28.5 (1.12) C2 Thread O.D. C1 mm (in) 28.3 (1.11) 28.3 (1.11) 28.3 (1.11) Body Seal Sealing Nut Panel Mounting Hole mm (in) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) 28.3 - 28.7 (1.11 - 1.13) Corrugated Thread Length C2 mm (in) 12 (0.47) 12 (0.47) 12 (0.47) Wrench Size Lock Nut (mm) 36 36 36 APP® Conduit P/N NGN - 17B NGN - 22B NGN - 23B Conduit O. D. 21.2 (0.83) 26.2 (1.03) 28.5 (1.12) STRAIGHT CONDUIT PUSH-IN TYPE - STD PACK 50 / NOT UL LISTED C1 Washer APP® P/N CAP21-28X Wire Protection Designation (4 Characters) CA04 C2 Body Thread O.D. Panel Mounting C1 mm (in) Hole mm (in) 28.3 (1.11) 28.3 - 28.7 (1.11 - 1.13) Seal Thread Length C2 mm (in) 12 (0.5) Wrench Size Lock Nut (mm) 36 APP® Conduit P/N NGN - 23B TUBING CUTTER CORRUGATED NYLON PLASTIC TUBING APP® P/N NGN - 17B NGN - 22B NGN - 23B Conduit I. D. mm (in) 16.7 (0.66) 21.2 (0.83) 21.7 (0.85) Conduit O. D. mm (in) 21.2 (0.83) 26.2 (1.03) 28.5 (1.12) Conduit Size 1/2” 3/4” Trade Size (mm) OD21.2 OD28.5 Std. Pkg. Meters (Feet) 50 (164) 50 (164) 50 (164) Conduit O. D. 28.5 (1.12) APP® P/N TM0002 Description Corrugated Plastic Tubing Cutter Range (mm) Up to OD 34.5 www.andersonpower.com -7- Standard Housing Arrangements & Contacts HOUSING ARRANGEMENTS FOR POWER, SIGNAL & GROUND CONNECTORS ARRANGEMENTS REPRESENT FRONT VIEW OF RECEPTACLE Custom configurations may be created using APP’s part number configurator at www.andersonpower.com E = Empty 0 A B C D 1327 Series = Power Custom Configuration AC Single Phase 1327G6FP E 1327G7FP E 1827G1 E AC 3 Phase, 3 Wire 1327G6FP 1327G7FP 1327FP DC 2 Circuit, 4 Wire 1327G6FP E 1327FP 1327G6FP E 1327FP DC 2 Circuit, 4 Wire With Ground 1327G6FP E 1327FP 1327G6FP 1327G7FP 1327FP G 1327G6FP 1327G7FP 1327FP J 1327G8FP 1827G1 E 1327G8FP 1827G1 1327G16FP K L 1327G6FP 1327G6FP 1327G6FP M N www.andersonpower.com 1327G6FP 4827G6 1327FP 1327G6FP 4827G6 1327FP AC Single Phase With 4 Signal 1327G6FP E 1327G7FP E 1827G1 4827G6 1327G6FP 1327G7FP 1327FP E 1827G1 4827G6 DC 2 Circuit, 4 Wire With 4 Signal 1327G6FP E 1327FP 1327G6FP 4827G6 1327FP 1327FP 4827G6 1327G6FP 1327G7FP 4827G6 1827G1 DC 2 Circuit, 4 Wire With Ground & 4 Signal 1327G6FP 4827G6 1327FP 1327G6FP 1827G1 1327FP AC 3 Phase, 4 Wire With 4 Signal P X -8- DC 2 Circuit, 4 Wire With 8 Signal AC 3 Phase, 3 Wire With 8 Signal DC 2 Circuit, 6 Wire 1327FP 1327FP 1327FP 4800 Series = Signal AC 3 Phase, 3 Wire With 4 Signal 1327G6FP 1827G1 1327FP AC 3 Phase, 5 Wire F H E 1827G1 E AC 3 Phase, 4 Wire E 1827 Series = Ground 1327G6FP 1327G7FP 1327FP 1327G8FP 1827G1 4827G6 All Signal 4827G6 4827G6 4827G6 4827G6 4827G6 4827G6 CONTINUOUS CURRENT RATINGS - POWER CONTACT CODE SELECTION NOTES: 1. Current ratings: • First number represents current rating per pole for 30°C temperature rise (29 / 40) • Second number is the maximum recommended current per pole based on a 25°C ambient (29 / 40) 2. Configuration H - P based on signal contacts crimped to #20 AWG wire and carrying 1 amp 3. Denotes wire size not appropriate for power contact 4. Shaded boxes are pending. 5. 1827G1 housing with 1830G1 or 1830G2 ground contact depending on primary contacts (see chart above). All signal housing kits (4850G6) come with two 4802G3 and two 4802G3 contacts. HOLDER LOCATIONS (VIEWS) Back Front Plug Front Back Front SPEC Pak® (6) Pole - Temperature Rise Based on 261G2 Contact Back Temperature (°C) Receptacle Front TEMPERATURE CHART Back 70 60 50 40 30 20 10 0 0 10 #10 AWG 4 Corners 20 30 Amperes #12 AWG 4 Corners 40 50 #12 AWG 6 Positions www.andersonpower.com -9- Individual Components POWERPOLE® HOUSINGS & CONTACTS Fingerproof PP15/45 Housing Only Package Quantity: Standard, 100 pieces - Bulk, 1,000 pieces Standard Part Number 1327FP 1327G5FP 1327G6FP 1327G7FP 1327G8FP 1327G16FP Bulk Part Number 1327FP-BK 1327G5FP-BK 1327G6FP-BK 1327G7FP-BK 1327G8FP-BK 1327G16FP-BK Description Red Housing Green Housing Black Housing White Housing Blue Housing Yellow Housing Standard PP 15/45 Housing Only Package Quantity: Standard, 100 pieces - Bulk, 1,000 pieces Standard Part Number 1327 1327G5 1327G6 1327G7 1327G8 1327G16 1327G17 1327G18 1327G21 1327G22 1327G23 Bulk Part Number 1327-BK 1327G5-BK 1327G6-BK 1327G7-BK 1327G8-BK 1327G16-BK 1327G17-BK 1327G18-BK 1327G21-BK 1327G22-BK 1327G23-BK Description Red Housing Green Housing Black Housing White Housing Blue Housing Yellow Housing Orange Housing Gray Housing Brown Housing Pink Housing Purple Housing Premate Ground PP15/45 Housing Only 15/45 Powerpole® Contacts Loose Piece Package Quantity: Standard, 100 pieces - Bulk, 1,000 pieces Standard Bulk Part Number Part Number #16 to #20 AWG (1.0 to 0.5 mm²) 1332 1332-BK 262G1-LPBK 262G2-LPBK - Individual-LD-Silver Plate Singulated Reel-LD-Tin Plate Singulated Reel-LD-Silver Plate #12 to #16 AWG (2.5 to 1.0 mm²) 1331 1331-BK 261G1-LPBK - Individual-LD-Silver Plate Singulated Reel-LD-Tin Plate #10 to #14 AWG (4 to 1.5 mm²) 261G2-LPBK 261G3-LPBK 200G1L-LPBK - Singulated Reel-LD-Tin Plate Singulated Reel-LD-Silver Plate Superflex, Sing. Reel-LD-Tin Plate Description Reel - 15/45 Powerpole® Contacts Package Quantity 5,000 Part Number Description #16 to #20 AWG (1.0 to 0.5 mm²) 262G1 Reel-LD-Tin Plate 262G2 Reel-LD-Silver Plate Package Quantity: Standard, 100 pieces - Bulk, 1,000 pieces #12 to #16 AWG (2.5 to 1.0 mm²) 261G1 Reel-LD-Tin Plate Standard Part Number 1827G1 #10 to #14 AWG (4 to 1.5 mm²) 261G2 Reel-LD-Tin Plate 261G3 Reel-LD-Silver Plate Bulk Part Number 1827G1-BK Description Green Housing Premate Ground Contacts Loose Piece Package Quantity 100 Part Number Description #10 to #14 AWG (4 to 1.5 mm²) 1830G1-LPBK Singulated-LD-Tin Plate 1830G2-LPBK Singulated-LD-Silver Plate #10 to #14 AWG (6 to 1.5mm²) 200G1L SuperFlex, Reel-LD-Tin Plate NOTE: LD - Low Detent For additional housing colors please contact customer service. CONTACT STYLES Reel Package Quantity 5,000 Part Number Description #10 to #14 AWG (4 to 1.5 mm²) 1830G1 Reel-LD-Tin Plate 1830G2 Reel-LD-Silver Plate - 10 - www.andersonpower.com Individual Singulated Open Barrel On a Reel PP15/45 POWERPOLE® HOUSING STYLES PPMX (4800 SERIES) HOUSING & CONTACTS PPMX Housing Powerpole® Fingerproof Housing Rib Feature Package Quantity Standard, 25 pieces - Bulk, 1,000 pieces Standard Part Number 4827G6 Bulk Part Number 4827G6-BK 1327FP Series Description Black two piece housing PPMX Contacts Powerpole® Standard Housing Closed Nose Package Quantity Standard, 50 pieces - Bulk, 2,000 pieces 1327 Series Loose Piece #20 to #24 AWG (0.50 to 0.25 mm²) Standard Part Number 4802G3 4803G3 Bulk Part Number 4802G3-BK 4803G3-BK Powerpole® Premate Ground Housing Open Nose Description Socket, Gold, 50 Micro-inches Pin, Gold, 50 Micro-inches PPMX Housing & Contact Kits PPMX Housing 2 Socket & 2 Pin Contacts Open Nose Package Quantity Standard, 100 pieces 1827 Series 4800 Series 1 Black two piece housing, 2 Male Contacts, 2 Female Contacts Standard Part Number 4850G6 Bulk Part Number - Description 50 Micro-inches Gold Plated Contacts - Pin & Socket APPLICATION TOOLING - POWERPOLE® 15 / 45 CONTACTS Loose Piece Tin Part Number Loose Piece Silver Part Number N/A 1332 N/A 1331 262G1-LPBK 262G2-LPBK 200G2L-LPBK 200G4L-LPBK 261G1-LPBK 261G4-LPBK 261G2-LPBK 261G3-LPBK 200G1L-LPBK 200G3L-LPBK 1830G1-LPBK 1830G2-LPBK Hand Tool or 1309G2 or 1309G8 1309G3 or 1309G8 Reeled Tin Part Number Pneumatic Tool 1367G1 N/A 1309G6 or 1309G8 Reeled Silver Part Number ATS Applicator N/A N/A N/A N/A N/A N/A 261G1 262G2 1385520 200G2L 200G4L TBD 261G1 261G4 1385520 261G2 261G3 1385458 200G1L 200G3L 1385460 1830G1 1830G2 1385460 * All Hand and Pneumatic Tools for use with Loose Piece contacts only. All reeled contacts can be ordered singulated, (Loose Piece) with the suffix “- LPBK” ** 1309G8 is a hand tool kit- includes dies and locators to make up 1309G2, 1309G3, &1309G6 APPLICATION TOOLING - PPMX CONTACTS Contact Part Number 4802G3 4803G3 APP® Hand Tool or PM1000G1 Mil Std.Hand Tool (APP Part #) M22520/1-01 (TM0001) + Positioner No Mil Std. (TL0005) Pneumatic Tool for Locator / + Turret TP0001 www.andersonpower.com - 11 - Dimensions PLUG 6 POSITION FOR PP15/45 HOUSINGS Top View Front View [ 42.2 ] 1.66 Side View INTERFACIAL GASKET [ 76.2 ] 3.00 Mated Side View [ 103.1 ] 4.01 [ 48.0 ] 1.89 [ 57.2 ] 2.25 [ 53.3 ] 2.10 RIGHT ANGLE PLUG 6 POSITION FOR PP15/45 - GLAND SIZE PG 21 Top View Front View Side View [ 42.2 ] 1.66 Mated Side View [ 118.7 ] 4.67 PR [ 91.6 ] 3.60 A B PG -AGland mm in. PG 21 104.7 4.12 PG 29 105.5 4.15 [ 53.2 ] 2.10 -Bmm in. 36.4 1.43 47.4 1.86 R1.73 LATCH SWEEP For PG 29 dimensions, please see APP website RECEPTACLE 6 POSITION FOR PP15/45 HOUSINGS Panel Cut Out [ 34.9 ] 1.38 [ 34.9 ] 1.38 Front View Side View [ 49.8 ] 1.96 [ 3.73 ] Ø 0.147 (4) CL [ 39.7 ] Ø 1.56 [ 53.3 ] 2.10 [ 44.5 ] 1.75 [ 44.0 ] R1.73 LATCH SWEEP [ 55.1 ] 2.17 [ 41.7 ] 1.64 CL PANEL CUT OUT CL (SAME AS 26482 & 5015 SHELL SIZE 24) Back View [ 36.6 ] 1.44 [ 44.5 ] 1.75 [ 39.1 ] 1.54 [ 38.1 ] Ø 1.50 [ 46.0 ] 1.81 NOTE: Mounting hardware #6 screw / torque receptacle to panel 3½ to 5 in-lbf (0.4 to 0.56 Nm) PG GLANDS PS CT Plastic Short [ 107 ] 4.2 PF Thread Conduit Adapter [ 107 ] 4.2 Plastic Flex PG Push-in Conduit Adapter [ 112 ] 4.4 [ 178 ] 7.0 [ 48.0 ] 1.89 [ 48.0 ] 1.89 CA [ 48.0 ] 1.89 [ 48.0] 1.89 RECEPTACLE COVER KIT Front View Side View Mated Side View [ 17.3 ] 0.68 [ 42.2 ] 1.66 [ 50.4 ] 1.98 [ 55.6 ] 2.19 [ 59.7 ] 2.35 [ 24.9 ] 0.98 [ 53.3 ] 2.10 All Data Subject To Change Without Notice Patents 15052 HEADQUARTERS: Anderson Power Products®, 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128 DS-SPAK REV06 EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203 ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036 CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218 - 12 - www.andersonpower.com TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460 www.andersonpower.com
1327G6-BK
物料型号: - SPEC Pak® Shell Size Insert Arrangement - 例如:SK6-053B06 表示SPEC Pak®系列,黑色6极直插式插座壳体,带有PP15/45插座座(任何类型),6极。
器件简介: - APP®的SPEC Pak®连接器系列使用坚固且环境密封(IP68)的外壳来保护现有的APP®Powerpole®接触件和壳体。 - 适用于需要坚固且防水的高功率互连,带有信号和接地能力的场合,例如:大规模交通、越野车辆、工厂自动化、石油和石化勘探、农业设备等。
引脚分配: - Power Contacts(电源接触件):最高45安培 - Signal Contacts(信号接触件):每个PPMX壳体4个接触件 - Ground Contacts(接地接触件):第一/最后断开/连接接地接触件
参数特性: - 电气特性包括UL电压等级(AC/DC)600V,介电强度(AC)3000V,工作温度范围-40°C至105°C,SPEC壳体的阻燃等级为UL94V-0。 - 机械特性包括壳体/锁扣配对周期至少1500次,连接/断开力最大18N。
功能详解: - SPEC Pak®提供了坚固的连接器,适用于恶劣环境下的高功率互连。 - 提供了颜色编码的插座以匹配电线颜色,增加了用户设计的灵活性。 - 还提供了额外的特性,如使用行业标准的PG腺体(PG gland compatible - size 21或29),直角背壳可锁定8个方向用于电缆布线,集成的应力消除等。
应用信息: - 适用于多种行业和应用,如工业自动化、太阳能、恶劣环境等。
封装信息: - 提供了多种封装选项,包括直插式和直角式连接器,以及相应的配件和安装套件。
1327G6-BK 价格&库存
很抱歉,暂时无法提供与“1327G6-BK”相匹配的价格&库存,您可以联系我们找货
1327G6-BK
    库存:1494
    1327G6-BK
      • 1+4.950481+0.59552
      • 10+4.2861710+0.51560
      • 25+3.7856825+0.45540
      • 50+3.3853150+0.40724
      • 100+2.96669100+0.35688
      库存:37485
