2756
2756
    ADAFRUIT
2756 数据手册
      Teensy 3.2 + header PRODUCT ID: 2756     Description Teensy 3.2 is a small, breadboard‐friendly development board designed by Paul Stoffregen and PJRC.  Teensy 3.2 brings a low‐cost 32 bit ARM Cortex‐M4 platform to hobbyists, students and engineers,  using an adapted version of the Arduino IDE (Teensyduino) or programming directly in C language.  Teensy 3.2 is an upgrade over 3.1! Teensy 3.2 is a drop‐in replacement upgrade for 3.1 and can run any  sketches designed for 3.1.  This latest version of this complete USB‐based microcontoller development system now adds a more  powerful 3.3V regulator, as well as accepts a wider voltage input range. This board has the same size,  shape and pinout as well as full compatibility with all shields and add‐on boards made for the Teensy  3.1, plus double the Flash memory as the Teensy 3.0.  Let's get started!  Please note: Teensy 3 and 2 are not official Arduino‐brand products. Although the Teensyduino IDE has  been adapted so that many simple Arduino projects will work with the Teensy, there will still be a lot of  libraries and shields that will not work with this device! If you're new to microcontrollers, we suggest  going with a classic Arduino UNO since all Arduino projects, examples and libraries will work with it.  Once headers are installed they can be fitted into 0.6" wide sockets    Technical Specifications:  o o o o o o o o o o o o o o o o o o 32 bit ARM Cortex‐M4 72MHz CPU (M4 = DSP extensions) Here is Freescale's reference  manual for the chip (warning 1227 pages) as well as the Datasheet and User Guide!  http://cache.freescale.com/files/32bit/doc/ref_manual/K20P64M50SF0RM.pdf  http://cache.freescale.com/files/32bit/doc/data_sheet/K20P64M50SF0.pdf  http://cache.freescale.com/files/32bit/doc/quick_ref_guide/KQRUG.pdf  256K Flash Memory, 64K RAM, 2K EEPROM  21* High Resolution Analog Inputs (13 bits usable, 16 bit hardware)  34* Digital I/O Pins (21 shared with analog)  12 PWM outputs  1 12‐bit DAC output  8 Timers for intervals/delays, separate from PWM  USB with dedicated DMA memory transfers  CAN bus  3 UARTs (serial ports)  SPI, I2C, I2S, IR modulator  I2S (for high quality audio interface)  Real Time Clock (with user‐added 32.768 crystal and battery)  16 general purpose DMA channels (separate from USB)  Touch Sensor Inputs     Technical Details  o o Dimensions: 18mm x 37mm x 4mm / 1.4" x 0.7"  Teensy 3 schematic https://cdn‐shop.adafruit.com/product‐files/2756/2756+schem.gif        https://www.adafruit.com/product/2756 9‐8‐17
很抱歉,暂时无法提供与“2756”相匹配的价格&库存,您可以联系我们找货
