8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
3963
UPDATE GENERAL TOL IN TITLE BOX & NOTE 8,
UPGRADE NYLON MTL (FROM 6T TO 9T), UPDATE
TAIL-TO-TAIL & TAIL PITCH/ROW SPACING DIM TO
REF, ADD REF TO INSERTION DEPTH
1/3/2019
JH
ADD LCP
8/20/2019
K
F
L
4099
F
JH
B .014[ 0.35]
A .008[ 0.20]
.100 2.54
E
E
DUAL ROWS
.100 2.54
B .014[ 0.35]
SINGLE ROW
D
.090 2.29
D
.236 6.00
.200 5.08
.100 2.54
.335 8.50
C
C
.126±.012 3.20±0.30
.100 2.54
.030±.002 0.75±0.05
.016±.002 0.40±0.05
A
02-20, .008[0.20] MAX.
21-30, .012[0.30] MAX.
31-40, .016[0.40] MAX.
A
.100 2.54
.100 2.54
7
B
.100 2.54
.040±.002 1.02±0.05
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
RECOMMENDED PCB LAYOUT
2. CONTACT MATERIAL: .PHOSPHOR BRONZE.
SINGLE ROW
3. CONTACT PLATING: SEE PART NUMBER CODING.
TOLERANCE: .002[ 0.05]
4. CURRENT RATING: 3 AMPS.
5. VOLTAGE RATING: 250V AC
6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 1000 VAC.
9. OPERATING TEMPERATURE: SEE PART NUMBER CODING
10. PROCESSING TEMP.: SEE PART NUMBER CODING.
11. MATES WITH SULLINS .100 [2.54] CONTACT CENTER MALE HEADER
SERIES. (.025 [0.64] SQUARE POSTS)
8
.100 2.54
A .004[ 0.10]
A .004[ 0.10]
B
.016±.002 0.40±0.05
.126±.008 3.20±0.20
6
5
.040±.002 1.02±0.05
DUAL ROWS
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
12/15/2008 JH
TOLERANCES:
ANGULAR:
5
DECIMALS
.XX= .012 [.3]
.XXX= .008 [.20]
.XXXX= .0039 [.100]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER FEMALE, 2.54mm CC, ST
PART NUMBER
SIZE
C
2
_P_C_ _ _LFBN-RC
CAGE CODE
54453
SCALE: 16:1
3
A
DWG. NO.
10492
SHEET 1 OF 1
1
REV
L
FILE NAME: 10492, _ _P_C_ _ _LFBN-RC
很抱歉,暂时无法提供与“PPPC061LFBN-RC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.138441+0.53531
