EC8AW-24D12
EC8AW-24D12
    CINCON
    插件
    EC8AW-24D12
EC8AW-24D12 数据手册
V13 EC8AW SERIES ︳ 15 WATT 4:1 INPUT RANGE DC-DC CONVERTERS FEATURES * 15W Isolated Output * DIP-24 Metal Package * Very High Efficiency Up to 90% * Low No Load Power Consumption * 4:1 Input Range * Regulated Outputs * Conductive EMI Meet EN55022 Class A Without External Components * Continuous Short Circuit Protection * No Tantalum Capacitor Inside * CE Mark Meets 2004/108/EC * Safety Meets UL60950-1, EN60950-1 and IEC60950-1 MODEL NUMBER EC8AW-24S33 EC8AW-24S05 EC8AW-24S12 EC8AW-24S15 EC8AW-24D12 EC8AW-24D15 EC8AW-48S33 EC8AW-48S05 EC8AW-48S12 EC8AW-48S15 EC8AW-48D12 EC8AW-48D15 INPUT OUTPUT OUTPUT CURRENT INPUT CURRENT % EFF. VOLTAGE VOLTAGE MIN. MAX. NO LOAD FULL LOAD (2) (3) 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 9-36 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 18-75 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 3.3 VDC 5 VDC 12 VDC 15 VDC ±12 VDC ±15 VDC 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 0 mA 4000 mA 3000 mA 1250 mA 1000 mA ±625 mA ±500 mA 4000 mA 3000 mA 1250 mA 1000 mA ±625 mA ±500 mA 8 mA 8 mA 8 mA 8 mA 8 mA 8 mA 6 mA 6 mA 6 mA 6 mA 6 mA 6 mA 625 mA 694 mA 694 mA 694 mA 702 mA 694 mA 309 mA 347 mA 347 mA 347 mA 351 mA 347 mA NOTE: 1. Nominal Input Voltage 24 or 48VDC 2. Measure at 12VDC for EC8AW 24 Vin, 24VDC for EC8AW 48 Vin 3. Measure at Nominal Input Voltage 1 88 90 90 90 89 90 89 90 90 90 89.5 90 88 90 90 90 89 90 89 90 90 90 89.5 90 CAPACITIVE LOAD MAX. 4000µF 3000µF 1250µF 1000µF 625µF 500µF 4000µF 3000µF 1250µF 1000µF 625µF 500µF V13 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....…............................................. 24V ...........….. 9-36V 48V ...............18-75V Input Surge Voltage (100ms max.) …………….……… 24V ....... 50Vdc max. 48V .... 100Vdc max. Under Voltage Lockout ……….…… 24Vin power up .…………………… 8.8V 24Vin power down ……………......… 8V 48Vin power up .……..…………..….17V 48Vin power down ………...……… 16V Input Filter ……………………………………………..………..….……... Pi Type Remote On/Off Control Logic Compatibility ……… CMOS or Open Collector TTL, Referenced to –Vin Module On ………….………… >3.5VDC to Vin or Open Circuit Module Off ……………….…………………….………….
EC8AW-24D12
物料型号:EC8AW系列,包括多个型号如EC8AW-24S33、EC8AW-24S05等。
器件简介:提供15瓦隔离输出,DIP-24金属封装,高效率可达90%,低无负载功耗,4:1输入范围,有调节输出,符合EN55022 A级电磁干扰标准,无需外部组件。
引脚分配:文档列出了单输出和双输出的引脚连接方式,包括远程开关、输入和输出引脚等。
参数特性:提供了输入电压范围、启动时间、输入浪涌电压、欠压锁定、输入滤波器、远程开关控制等参数。
功能详解:详细说明了电压精度、瞬态响应、纹波和噪声、温度系数、线压调节、负载调节、交叉调节、短路保护等。
应用信息:文档中未明确列出应用信息,但根据其特性,适用于需要高效率、宽输入范围和隔离输出的应用场景。
封装信息:DIP封装,尺寸为1.25x0.80x0.40英寸。
EC8AW-24D12 价格&库存
很抱歉,暂时无法提供与“EC8AW-24D12”相匹配的价格&库存,您可以联系我们找货
