MAX3001EEUP+
MAX3001EEUP+
    MAX(迈旭)
    MAX3001EEUP+
MAX3001EEUP+ 数据手册
MAX3000E/MAX3001E/ LE MAX3002–MAX3012 AVAILAB +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators General Description The MAX3000E/MAX3001E/MAX3002–MAX3012 8-channel level translators provide the level shifting necessary to allow data transfer in a multivoltage system. Externally applied voltages, VCC and VL, set the logic levels on either side of the device. Logic signals present on the VL side of the device appear as a higher voltage logic signal on the VCC side of the device, and vice-versa. The MAX3000E/MAX3001E/MAX3002/MAX3003 use an architecture specifically designed to be bidirectional without the use of a directional pin. The MAX3000E/MAX3001E/MAX3002/MAX3004–MAX3012 feature an EN input that, when low, reduces the VCC and VL supply currents to < 2µA. The MAX3000E/MAX3001E also have ±15kV ESD protection on the I/O VCC side for greater protection in applications that route signals externally. The MAX3000E operates at a guaranteed data rate of 230kbps. The MAX3001E operates at a guaranteed data rate of 4Mbps. The MAX3002–MAX3012 operate at a guaranteed data rate of 20Mbps over the entire specified operating voltage range. The MAX3000E/MAX3001E/MAX3002–MAX3012 accept VL voltages from +1.2V to +5.5V and VCC voltages from +1.65V to +5.5V, making them ideal for data transfer between low-voltage ASICs/PLDs and higher voltage systems. The MAX3000E/MAX3001E/MAX3002– MAX3012 are available in 20-bump UCSP™, 20-pin TQFN (5mm x 5mm), and 20-pin TSSOP packages. Features ♦ Guaranteed Data Rate Options 230kbps (MAX3000E) 4Mbps (MAX3001E) 20Mbps (MAX3002–MAX3012) ♦ Bidirectional Level Translation Without Using a Directional Pin (MAX3000E/MAX3001E/MAX3002/ MAX3003) ♦ Unidirectional Level Translation (MAX3004–MAX3012) ♦ Operation Down to +1.2V on VL ♦ ±15kV ESD Protection on I/O VCC Lines (MAX3000E/MAX3001E) ♦ Ultra-Low 0.1µA Supply Current in Shutdown ♦ Low Quiescent Current (< 10µA) ♦ UCSP, TQFN, and TSSOP Packages Ordering Information TEMP RANGE PIN-PACKAGE MAX3000EEUP PART -40°C to +85°C 20 TSSOP MAX3000EEBP-T -40°C to +85°C 4 x 5 UCSP Ordering Information continued at end of data sheet. Note: All devices operate over the -40°C to +85°C operating temperature range. Typical Operating Circuit Applications Functional Diagrams CMOS Logic-Level Translation +1.8V +3.3V Cellphones SPI™ and MICROWIRE™ Level Translation Low-Voltage ASIC Level Translation Smart Card Readers Portable POS Systems Portable Communication Devices Low-Cost Serial Interfaces VCC VL Cellphone Cradles EN +1.8V SYSTEM CONTROLLER MAX3000E MAX3001E MAX3002– MAX3012 +3.3V SYSTEM GPS DATA Telecommunications Equipment UCSP is a trademark of Maxim Integrated Products, Inc. SPI is a trademark of Motorola, Inc. Pin Configurations appear at end of data sheet. MICROWIRE is a trademark of National Semiconductor. Functional Diagrams continued at end of data sheet. UCSP is a trademark of Maxim Integrated Products, Inc. I/O VL_ I/O VCC_ DATA GND Pin Configurations and Functional Diagrams appear at end of data sheet. For pricing, delivery, and ordering information, please contact Maxim Direct at 1-888-629-4642, or visit Maxim’s website at www.maximintegrated.com. 19-2672; Rev 5; 8/08 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators ABSOLUTE MAXIMUM RATINGS (All voltages referenced to GND.) VCC ...........................................................................-0.3V to +6V VL...........................................................................................-0.3V to +6V I/O VCC_......................................................-0.3V to (VCC + 0.3V) I/O VL_ ...........................................................-0.3V to (VL + 0.3V) EN, EN A/B ...............................................................-0.3V to +6V Short-Circuit Duration I/O VL_, I/O VCC_ to GND .......Continuous Continuous Power Dissipation (TA = +70°C) 20-Pin TSSOP (derate 7.0mW/°C above +70°C) .........559mW 20-Bump UCSP (derate 10mW/°C above +70°C) .......800mW 20-Pin 5mm x 5mm TQFN (derate 20.0mW/°C above +70°C) .....................................1667mW Operating Temperature Ranges MAX3001EAUP ..............................................-40°C to +125°C MAX300_EE_P .................................................-40°C to +85°C MAX30_ _E_P ..................................................-40°C to +85°C Junction Temperature ......................................................+150°C Storage Temperature Range .............................-65°C to +150°C Lead Temperature (soldering, 10s) .................................+300°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS (VCC = +1.65V to +5.5V, VL = +1.2V to VCC, EN = VL (MAX3000E/MAX3001E/MAX3002/MAX3004–MAX3012), EN A/B = VL or 0 (MAX3003), TA = TMIN to TMAX. Typical values are at VCC = +1.65V, VL = +1.2V, and TA = +25°C.) (Notes 1, 2) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS POWER SUPPLIES VL Supply Range VCC Supply Range VL 1.2 VCC V VCC 1.65 5.50 V I/O VCC_ = 0, I/O VL _ = 0 or I/O VCC_ = VCC, I/O VL _ = VL, MAX3000E/MAX3002–MAX3012 Supply Current from VCC Supply Current from VL VL Shutdown Supply Current 2 10 µA IQVCC I/O VCC_ = 0, I/O VL _ = 0 or I/O VCC_ = VCC, I/O VL _ = VL, MAX3001E 0.1 50 I/O VCC_ = 0, I/O VL _ = 0 or I/O VCC_ = VCC, I/O VL _ = VL, MAX3000E/MAX3002–MAX3012 0.1 10 µA IQVL I/O VCC_ = 0, I/O VL _ = 0 or I/O VCC_ = VCC, I/O VL _ = VL, MAX3001E VCC Shutdown Supply Current 0.1 TA = +25°C, EN = 0, MAX3000E/MAX3001E/MAX3002/ ISHDN-VCC MAX3004–MAX3012 ISHDN-VL 0.1 50 0.1 2 µA TA = +25°C, EN A/B = 0, MAX3003 0.1 2 TA = +25°C, EN = 0, MAX3000E/MAX3001E/MAX3002/ MAX3004–MAX3012 0.1 2 TA = +25°C, EN A/B = 0, MAX3003 0.1 µA 2 Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators ELECTRICAL CHARACTERISTICS (continued) (VCC = +1.65V to +5.5V, VL = +1.2V to VCC, EN = VL (MAX3000E/MAX3001E/MAX3002/MAX3004–MAX3012), EN A/B = VL or 0 (MAX3003), TA = TMIN to TMAX. Typical values are at VCC = +1.65V, VL = +1.2V, and TA = +25°C.) (Notes 1, 2) PARAMETER SYMBOL TYP MAX TA = +25°C, EN = 0, MAX3000E/MAX3001E/MAX3002/ MAX3004–MAX3012 0.1 2 TA = +25°C, EN A/B = 0, MAX3003 0.1 2 I/O VL _ Three-State Output Leakage Current EN A/B = 0, MAX3003 0.1 2 µA I/O VL _ Pulldown Resistance During Shutdown EN = 0, MAX3000E/MAX3001E/MAX3002/ MAX3004–MAX3012 8.30 kΩ EN or EN A/B Input Leakage Current TA = +25°C 1 µA 2/3 x VL V I/O VCC _ Three-State Output Leakage Current CONDITIONS MIN UNITS µA 4.59 LOGIC-LEVEL THRESHOLDS I/O VL _ Input-Voltage High Threshold VIHL I/O VL _ Input-Voltage Low Threshold VILL I/O VCC _ Input-Voltage High Threshold VIHC I/O VCC _ Input-Voltage Low Threshold VILC EN, EN A/B Input-Voltage High Threshold VIH EN, EN A/B Input-Voltage Low Threshold VIL 1/3 x VL V 2/3 x VCC 1/3 x VCC V VL - 0.4 I/O VL _ Output-Voltage High VOHL I/O VL _ source current = 20µA, I/O VCC _ ≥ VCC - 0.4V I/O VL _ Output-Voltage Low VOLL I/O VL _ sink current = 20µA, I/O VCC _ ≤ 0.4V I/O VCC _ Output-Voltage High VOHC I/O VCC_ source current = 20µA, I/O VL _ ≥ VL - 0.4V I/O VCC _ Output-Voltage Low VOLC I/O VCC sink current = 20µA, I/O VL _ ≤ 0.4V V V 0.4 V VL - 0.4 V 0.4 VCC - 0.4 V V 0.4 V ESD PROTECTION I/O VCC _ Maxim Integrated Human Body Model, MAX3000E/MAX3001E ±15 kV 3 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators TIMING CHARACTERISTICS (VCC = +1.65V to +5.5V, VL = +1.2V to VCC, EN = VL (MAX3000E/MAX3001E/MAX3002/MAX3004–MAX3012), EN A/B = VL or 0 (MAX3003), TA = TMIN to TMAX. Typical values are at VCC = +1.65V, VL = +1.2V, and TA = +25°C.) (Notes 1, 2) PARAMETER SYMBOL CONDITIONS RS = 50Ω, CVCC = 50pF, MAX3000E, Figures 1a, 1b I/O VCC_ Rise Time tRVCC MIN TYP MAX 400 800 1200 25 50 RS = 50Ω, CVCC = 50pF, MAX3001E, Figures 1a, 1b RS = 50Ω, CVCC = 50pF, MAX3002–MAX3012, Figures 1a, 1b RS = 50Ω, CVCC = 50pF, MAX3000E, Figures 1a, 1b I/O VCC_ Fall Time tFVCC 400 800 1200 25 50 RS = 50Ω, CVCC = 50pF, MAX3002–MAX3012, Figures 1a, 1b I/O VL _ Rise Time tRVL 400 800 1200 25 50 RS = 50Ω, CVL = 15pF, MAX3002–MAX3012, Figures 2a, 2b I/O VL _ Fall Time Propagation Delay (Driving I/O VL _) Propagation Delay (Driving I/O VCC_) tFVL I/OVL-VCC I/OVCC-VL RS = 50Ω, CVL = 50pF, MAX3001E, Figures 2a, 2b ns 15 RS = 50Ω, CVL = 50pF, MAX3001E, Figures 2a, 2b RS = 50Ω, CVL = 50pF, MAX3000E, Figures 2a, 2b ns 15 RS = 50Ω, CVCC = 50pF, MAX3001E, Figures 1a, 1b RS = 50Ω, CVL = 50pF, MAX3000E, Figures 2a, 2b UNITS ns 15 400 800 1200 25 65 RS = 50Ω, CVL = 15pF, MAX3002–MAX3012, Figures 2a, 2b 15 RS = 50Ω, CVCC = 50pF, MAX3000E, Figures 1a, 1b 1000 RS = 50Ω, CVCC = 50pF, MAX3001E, Figures 1a, 1b 50 RS = 50Ω, CVCC = 50pF, MAX3002–MAX3012, Figures 1a, 1b 20 RS = 50Ω, CVL = 50pF, MAX3000E, Figures 2a, 2b 1000 RS = 50Ω, CVL = 50pF, MAX3001E, Figures 2a, 2b 50 RS = 50Ω, CVL = 15pF, MAX3002–MAX3012, Figures 2a, 2b 20 ns ns ns Note 1: All units are 100% production tested at TA = +25°C. Limits over the operating temperature range are guaranteed by design and not production tested. Note 2: For normal operation, ensure that VL < VCC. During power-up, VL > VCC does not damage the device. 4 Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators TIMING CHARACTERISTICS (continued) (VCC = +1.65V to +5.5V, VL = +1.2V to VCC, EN = VL (MAX3000E/MAX3001E/MAX3002/MAX3004–MAX3012), EN A/B = VL or 0 (MAX3003), TA = TMIN to TMAX. Typical values are at VCC = +1.65V, VL = +1.2V, and TA = +25°C.) (Notes 1, 2) PARAMETER Channel-to-Channel Skew Part-to-Part Skew SYMBOL tSKEW tPPSKEW Propagation Delay from I/O VL _ to I/O VCC_ after EN tEN-VCC Propagation Delay from I/O VCC_ to I/O VL _ after EN tEN-VL Maximum Data Rate CONDITIONS MIN TYP MAX RS = 50Ω, CVCC = 50pF, CVL = 50pF, MAX3000E 500 RS = 50Ω, CVCC = 50pF, CVL = 50pF, MAX3001E 10 RS = 50Ω, CVCC = 50pF, CVL = 15pF, MAX3002–MAX3012 5 RS = 50Ω, CVCC = 50pF, CVL = 50pF, ΔTA = +20°C, MAX3000E (Note 3) 800 RS = 50Ω, CVCC = 50pF, CVL = 50pF, ΔTA = +20°C, MAX3001E (Note 3) 30 RS = 50Ω, CVCC = 50pF, CVL = 15pF, ΔTA = +20°C, MAX3002–MAX3012 (Note 3) 10 CVCC = 50pF, MAX3000E/MAX3001E, MAX3002–MAX3012, Figure 3 2 CVL = 50pF, MAX3000E/MAX3001E/ MAX3002/MAX3004–MAX3012, Figure 4 2 CVL = 15pF, MAX3003, Figure 4 2 RS = 50Ω, CVCC = 50pF, CVL = 50pF, MAX3000E 230 RS = 50Ω, CVCC = 50pF, CVL = 50pF, MAX3001E 4 UNITS ns ns µs µs kbps Mbps RS = 50Ω, CVCC = 50pF, CVL = 15pF, MAX3002–MAX3012 20 Note 3: VCC from device 1 must equal VCC of device 2; VL from device 1 must equal VL of device 2. Maxim Integrated 5 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators TIMING CHARACTERISTICS—MAX3002–MAX3012 (VCC = +1.65V to +5.5V, VL = +1.2V to VCC, EN = VL (MAX3002/MAX3004–MAX3012), EN A/B = VL or 0 (MAX3003), TA = TMIN to TMAX.) (Notes 1, 2) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS +1.2V ≤ VL ≤ VCC ≤ +3.3V I/O VCC_ Rise Time tRVCC 15 ns I/O VCC_ Fall Time tFVCC 15 ns I/O VL _ Rise Time tRVL 15 ns I/O VL _ Fall Time tFVL 15 ns Propagation Delay Channel-to-Channel Skew I/OVL-VCC Driving I/O VL _ 15 I/OVCC-VL Driving I/O VCC_ Each translator equally loaded 15 tSKEW Maximum Data Rate 5 20 ns ns Mbps +2.5V ≤ VL ≤ VCC ≤ +3.3V I/O VCC_ Rise Time tRVCC 8.5 ns I/O VCC_ Fall Time tFVCC 8.5 ns I/O VL _ Rise Time tRVL 8.5 ns I/O VL _ Fall Time tFVL 8.5 ns Propagation Delay Channel-to-Channel Skew I/OVL-VCC Driving I/O VL _ 8.5 I/OVCC-VL Driving I/O VCC_ 8.5 Each translator equally loaded 10 tSKEW Maximum Data Rate 35 ns ns Mbps +1.8V ≤ VL ≤ VCC ≤ +2.5V I/O VCC_ Rise Time tRVCC 10 ns I/O VCC_ Fall Time tFVCC 10 ns I/O VL _ Rise Time tRVL 10 ns I/O VL _ Fall Time tFVL 10 ns Propagation Delay Channel-to-Channel Skew Maximum Data Rate 6 I/OVL-VCC Driving I/O VL _ 15 I/OVCC-VL Driving I/O VCC_ 10 Each translator equally loaded 5 tSKEW 30 ns ns Mbps Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Typical Operating Characteristics (TA = +25°C, unless otherwise noted.) VCC SUPPLY CURRENT vs. SUPPLY VOLTAGE (DRIVING I/O VL, VL = 1.8V) DATA RATE = 20Mbps 300 DATA RATE = 4Mbps DATA RATE = 4Mbps 4000 DATA RATE = 230kbps 2000 DATA RATE = 230kbps 100 6000 0 0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 2.0 2.5 3.0 3.5 4.0 4.5 1000 DATA RATE = 4Mbps DATA RATE = 230kbps 500 5.0 5.5 -40 -15 SUPPLY VOLTAGE (V) DATA RATE = 20Mbps 1500 DATA RATE = 4Mbps DATA RATE = 230kbps 35 60 85 VL SUPPLY CURRENT vs. CAPACITIVE LOAD ON I/O VCC (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V) 100 VL SUPPLY CURRENT (μA) 2000 MAX3000E/01E/02-12 toc04 2500 10 TEMPERATURE (°C) VCC SUPPLY CURRENT vs. TEMPERATURE (DRIVING I/O VCC, VCC = 3.3V, VL = 1.8V) VCC SUPPLY CURRENT (μA) DATA RATE = 20Mbps 0 1.5 SUPPLY VOLTAGE (V) 1000 1500 MAX3000E/01E/02-12 toc05 200 8000 2000 MAX3000E/01E/02-12 toc03 400 MAX3000E/01E/02-12 toc02 DATA RATE = 20Mbps VCC SUPPLY CURRENT (μA) VL SUPPLY CURRENT (μA) 500 10,000 MAX3000E/01E/02-12 toc01 600 VL SUPPLY CURRENT vs. TEMPERATURE (DRIVING I/O VCC, VCC = 3.3V, VL = 1.8V) VL SUPPLY CURRENT (μA) VL SUPPLY CURRENT vs. SUPPLY VOLTAGE (DRIVING I/O VL, VL = 1.8V) 80 DATA RATE = 20Mbps 60 DATA RATE = 4Mbps 40 500 20 0 0 DATA RATE = 230kbps -15 10 35 60 10 85 20 30 6000 VCC SUPPLY CURRENT (μA) 60 70 80 90 100 DATA RATE = 20Mbps 4000 3000 DATA RATE = 4Mbps DATA RATE = 230kbps 2000 RISE/FALL TIME (ns) MAX3000E/01E/02-12 toc06 7000 2000 50 MAX3000E RISE/FALL TIME vs. CAPACITIVE LOAD ON I/O VCC (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V) VCC SUPPLY CURRENT vs. CAPACITIVE LOAD ON I/O VCC (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V) 5000 40 CAPACITIVE LOAD (pF) TEMPERATURE (°C) 1500 MAX3000E/01E/02-12 toc07 -40 tLH 1000 tHL 500 1000 DATA RATE = 230kbps 0 0 10 20 30 40 50 60 70 CAPACITIVE LOAD (pF) Maxim Integrated 80 90 100 10 20 30 40 50 60 70 80 90 100 CAPACITIVE LOAD (pF) 7 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Typical Operating Characteristics (continued) (TA = +25°C, unless otherwise noted.) MAX3002–MAX3012 RISE/FALL TIME vs. CAPACITIVE LOAD ON I/O VCC (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V) MAX3001E RISE/FALL TIME vs. CAPACITIVE LOAD ON I/O VCC (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V) tLH 40 30 tHL 20 MAX3000E/01E/02-12 toc09 RISE/FALL TIME (ns) 50 8 6 RISE/FALL TIME (ns) MAX3000E/01E/02-12 toc08 60 tLH 4 tHL 2 10 DATA RATE = 20Mbps DATA RATE = 4Mbps 0 0 20 30 40 50 60 70 80 10 90 100 20 MAX3000E/01E/02-12 toc10 2000 tLH RISE/FALL TIME (ns) 40 50 1500 tHL MAX3001E RISE/FALL TIME vs. CAPACITIVE LOAD ON I/O VL (DRIVING I/O VCC, VCC = 3.3V, VL = 1.8V) 60 50 tHL RISE/FALL TIME (ns) MAX3000E RISE/FALL TIME vs. CAPACITIVE LOAD ON I/O VL (DRIVING I/O VCC, VCC = 3.3V, VL = 1.8V) 1000 30 CAPACITIVE LOAD (pF) CAPACITIVE LOAD (pF) MAX3000E/01E/02-12 toc11 10 40 30 tLH 20 500 10 DATA RATE = 4Mbps DATA RATE = 230kbps 0 0 20 30 40 60 50 70 80 90 100 10 20 30 MAX3000E/01E/02-12 toc12 RISE/FALL TIME (ns) 4 tHL 2 1 50 tLH 70 80 90 100 500 400 tPLH 300 tPHL 200 100 DATA RATE = 20Mbps DATA RATE = 230kbps 0 0 10 15 20 25 CAPACITIVE LOAD (pF) 8 60 MAX3000E PROPAGATION DELAY vs. CAPACITIVE LOAD ON I/O VCC (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V) PROPAGATION DELAY (ns) MAX3002–MAX3012 RISE/FALL TIME vs. CAPACITIVE LOAD ON I/O VL (DRIVING I/O VCC, VCC = 3.3V, VL = 1.8V) 3 40 CAPACITIVE LOAD (pF) CAPACITIVE LOAD (pF) MAX3000E/01E/02-12 toc13 10 30 10 20 30 40 50 60 70 80 90 100 CAPACITIVE LOAD (pF) Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Typical Operating Characteristics (continued) 15 tPHL tPLH 8 tPHL 500 6 4 tPHL 2 5 400 200 100 DATA RATE = 20Mbps DATA RATE = 4Mbps DATA RATE = 230kbps 0 0 10 20 30 40 0 10 50 15 20 MAX3001E PROPAGATION DELAY vs. CAPACITIVE LOAD ON I/O VL (DRIVING I/O VCC, VCC = 3.3V, VL = 1.8V) 30 10 20 30 40 5 tPHL PROPAGATION DELAY (ns) 12 50 60 70 80 90 100 CAPACITIVE LOAD (pF) MAX3002–MAX3012 PROPAGATION DELAY vs. CAPACITIVE LOAD ON I/O VL (DRIVING I/O VCC, VCC = 3.3V, VL = 1.8V) MAX3000E/01E/02-12 toc17 15 PROPAGATION DELAY (ns) 25 CAPACITIVE LOAD (pF) CAPACITIVE LOAD (pF) 9 6 tPLH 3 4 tPHL 3 2 tPLH 1 DATA RATE = 4Mbps DATA RATE = 20Mbps 0 0 10 20 30 40 50 10 15 CAPACITIVE LOAD (pF) 25 30 MAX3002–MAX3012 RAIL-TO-RAIL DRIVING (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V, CVCC = 50pF, DATA RATE = 20Mbps) MAX3000E/01E/02-12 toc20 MAX3000E/01E/02-12 toc19 1μs/div 20 CAPACITIVE LOAD (pF) MAX3001E RAIL-TO-RAIL DRIVING (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V, CVCC = 50pF, DATA RATE = 4Mbps) MAX3000E RAIL-TO-RAIL DRIVING (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V, CVCC = 50pF, DATA RATE = 230kbps) Maxim Integrated tPLH 300 MAX3000E/01E/02-12 toc18 10 600 PROPAGATION DELAY (ns) tPLH 20 10 MAX3000E PROPAGATION DELAY vs. CAPACITIVE LOAD ON I/O VL (DRIVING I/O VCC, VCC = 3.3V, VL = 1.8V) MAX3000E/01E/02-12 toc15 PROPAGATION DELAY (ns) 25 12 PROPAGATION DELAY (ns) MAX3000E/01E/02-12 toc14 30 MAX3002–MAX3012 PROPAGATION DELAY vs. CAPACITIVE LOAD ON I/O VCC (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V) MAX3000E/01E/02-12 toc16 (TA = +25°C, unless otherwise noted.) MAX3001E PROPAGATION DELAY vs. CAPACITIVE LOAD ON I/O VCC (DRIVING I/O VL, VCC = 3.3V, VL = 1.8V) MAX3000E/01E/02-12 toc21 I/O VL_ 1V/div I/O VL_ 1V/div I/O VL_ 1V/div GND GND GND I/O VCC_ 2V/div I/O VCC_ 2V/div I/O VCC_ 2V/div GND GND GND 40ns/div 10ns/div 9 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Pin Description MAX3000E/MAX3001E/MAX3002 PIN NAME FUNCTION TSSOP UCSP TQFN 1 B1 19 I/O VL1 2 A1 20 VL 3 A2 1 I/O VL2 Input/Output 2, Referenced to VL 4 B2 2 I/O VL3 Input/Output 3, Referenced to VL 5 A3 3 I/O VL4 Input/Output 4, Referenced to VL 6 B3 4 I/O VL5 Input/Output 5, Referenced to VL 7 A4 5 I/O VL6 Input/Output 6, Referenced to VL 8 B4 6 I/O VL7 Input/Output 7, Referenced to VL 9 A5 7 I/O VL8 Input/Output 8, Referenced to VL 10 B5 8 EN 11 C5 9 GND 12 D5 10 I/O VCC8 Input/Output 8, Referenced to VCC 13 C4 11 I/O VCC7 Input/Output 7, Referenced to VCC 14 D4 12 I/O VCC6 Input/Output 6, Referenced to VCC 15 C3 13 I/O VCC5 Input/Output 5, Referenced to VCC 16 D3 14 I/O VCC4 Input/Output 4, Referenced to VCC 17 C2 15 I/O VCC3 Input/Output 3, Referenced to VCC 18 D2 16 I/O VCC2 Input/Output 2, Referenced to VCC 19 D1 17 VCC 20 C1 18 I/O VCC1 — — EP EP 10 Input/Output 1, Referenced to VL Logic Input Voltage, +1.2V ≤ VL ≤ VCC. Bypass VL to GND with a 0.1µF capacitor. Enable Input. If EN is pulled low, I/O VCC1 to I/O VCC8 are in three-state, while I/O VL1 to I/O VL8 have internal 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. Ground VCC Input Voltage, +1.65V ≤ VCC ≤ +5.5V. Bypass VCC to GND with a 0.1µF capacitor. Input/Output 1, Referenced to VCC Exposed Pad. Connect to GND. Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Pin Description (continued) MAX3003 PIN NAME FUNCTION TSSOP UCSP TQFN 1 B1 19 I/O VL1A 2 A1 20 VL 3 A2 1 I/O VL2A Input/Output 2A, Referenced to VL 4 B2 2 I/O VL3A Input/Output 3A, Referenced to VL 5 A3 3 I/O VL4A Input/Output 4A, Referenced to VL 6 B3 4 I/O VL1B Input/Output 1B, Referenced to VL 7 A4 5 I/O VL2B Input/Output 2B, Referenced to VL 8 B4 6 I/O VL3B Input/Output 3B, Referenced to VL 9 A5 7 I/O VL4B Input/Output 4B, Referenced to VL 10 B5 8 EN A/B 11 C5 9 GND 12 D5 10 I/O VCC4B Input/Output 4B, Referenced to VCC 13 C4 11 I/O VCC3B Input/Output 3B, Referenced to VCC 14 D4 12 I/O VCC2B Input/Output 2B, Referenced to VCC 15 C3 13 I/O VCC1B Input/Output 1B, Referenced to VCC 16 D3 14 I/O VCC4A Input/Output 4A, Referenced to VCC 17 C2 15 I/O VCC3A Input/Output 3A, Referenced to VCC 18 D2 16 I/O VCC2A Input/Output 2A, Referenced to VCC 19 D1 17 VCC 20 C1 18 I/O VCC1A — — EP EP Maxim Integrated Input/Output 1A, Referenced to VL Logic Input Voltage, +1.2V ≤ VL ≤ VCC. Bypass VL to GND with a 0.1µF capacitor. Enable Input. If EN A/B is pulled low, channels 1B through 4B are active, and channels 1A through 4A are in three-state. If EN A/B is driven high to VL, channels 1A through 4A are active, and channels 1B through 4B are in three-state. Ground VCC Input Voltage, +1.65V ≤ VCC ≤ +5.5V. Bypass VCC to GND with a 0.1µF capacitor. Input/Output 1A, Referenced to VCC Exposed Pad. Connect to GND. 11 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Pin Description (continued) MAX3004–MAX3012 NAME VCC VL GND FUNCTION (Note 1) VCC Input Voltage, +1.65V < VCC < +5.5V. Bypass VCC to GND with a 0.1µF capacitor. Logic Input Voltage, +1.2V ≤ VL ≤ VCC. Bypass VL to GND with a 0.1µF capacitor. Ground EN (MAX3004) Enable Input. If EN is pulled low, OVCC1–OVCC8 are in three-state, while IVL1–IVL8 have 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. EN (MAX3005) Enable Input. If EN is pulled low, IVCC1 and OVCC2–OVCC8 are in three-state, while OVL1 and IVL2–IVL8 have 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. EN (MAX3006) Enable Input. If EN is pulled low, IVCC1, IVCC2, and OVCC3–OVCC8 are in three-state, while OVL1, OVL2, and IVL3–IVL8 have 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. EN (MAX3007) Enable Input. If EN is pulled low, IVCC1, IVCC2, IVCC3, and OVCC4–OVCC8 are in three-state, while OVL1, OVL2, OVL3, and IVL4–IVL8 have 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. EN (MAX3008) Enable Input. If EN is pulled low, IVCC1–IVCC4 and OVCC5–OVCC8 are in three-state, while OVL1–OVL4 and IVL5–IVL8 have 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. EN (MAX3009) Enable Input. If EN is pulled low, IVCC1–IVCC5, OVCC6, OVCC7, and OVCC8 are in three-state, while OVL1–OVL5, IVL6, IVL7, and IVL8 have 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. EN (MAX3010) Enable Input. If EN is pulled low, IVCC1–IVCC6, OVCC7, and OVCC8 are in three-state, while OVL1–OVL6, IVL7, and IVL8 have 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. EN (MAX3011) Enable Input. If EN is pulled low, IVCC1–IVCC7 and OVCC8 are in three-state, while OVL1–OVL7 and IVL8 have 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. EN (MAX3012) Enable Input. If EN is pulled low, IVCC1–IVCC8 are in three-state, while OVL1–OVL8 have 6kΩ pulldown resistors. Drive EN high (VL) for normal operation. IVL1–IVL8 Inputs Referenced to VL, Numbers 1 to 8 OVL1–OVL8 Outputs Referenced to VL, Numbers 1 to 8 IVCC1–IVCC8 Inputs Referenced to VCC, Numbers 1 to 8 OVCC1–OVCC8 Outputs Referenced to VCC, Numbers 1 to 8 Note 1: For specific pin numbers, see the Pin Configurations. 12 Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators ______________________________________________Test Circuits/Timing Diagrams tRISE/FALL ≤ 3ns I/O VL VL VCC MAX3000E/MAX3001E/ EN MAX3002/MAX3003 90% 50% 10% I/OVL-VCC I/O VL I/OVL-VCC I/O VCC I/O VCC SOURCE RS CVCC 90% 50% 10% tFVCC tRVCC Figure 1b. Timing for Driving I/O VL Figure 1a. Driving I/O VL tRISE/FALL ≤ 3ns I/O VCC VL 90% VCC MAX3000E/MAX3001E/ EN MAX3002/MAX3003 50% 10% I/OVCC-VL I/OVCC-VL RS I/O VL CVL I/O VCC SOURCE I/O VL 90% 50% 10% tFVL Figure 2a. Driving I/O VCC Maxim Integrated tRVL Figure 2b. Timing for Driving I/O VCC 13 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators _________________________________Test Circuits/Timing Diagrams (continued) VL EN MAX3000E/MAX3001E/ MAX3002/MAX3003 SOURCE EN t'EN-VCC VL I/O VCC I/O VL 0 I/O VL 0 VL CVCC VCC I/O VCC VL EN EN MAX3000E/MAX3001E/ MAX3002/MAX3003 SOURCE VCC 2 t"EN-VCC 0 VL I/O VL I/O VCC I/O VL 0 VL CVCC VCC I/O VCC 2 VCC 0 tEN-VCC IS WHICHEVER IS LARGER BETWEEN t'EN-VCC AND t"EN-VCC Figure 3. Propagation Delay from I/O VL to I/O VCC After EN VL EN MAX3000E/MAX3001E/ MAX3002/MAX3003 SOURCE EN t'EN-VL VCC I/O VCC I/O VL 0 I/O VCC 0 VCC CVL I/O VL VL VL 2 0 VL EN SOURCE MAX3000E/MAX3001E/ MAX3002/MAX3003 EN t"EN-VL 0 VCC I/O VL CVL I/O VCC I/O VCC 0 VCC I/O VL VL 2 VL 0 tEN-VL IS WHICHEVER IS LARGER BETWEEN t'EN-VL AND t"EN-VL Figure 4. Propagation Delay from I/O VCC to I/O VL After EN 14 Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Detailed Description The MAX3000E/MAX3001E/MAX3002–MAX3012 logiclevel translators provide the level shifting necessary to allow data transfer in a multivoltage system. Externally applied voltages, VCC and VL, set the logic levels on either side of the device. Logic signals present on the VL side of the device appear as a higher voltage logic signal on the VCC side of the device, and vice-versa. The MAX3000E/MAX3001E/MAX3002/MAX3003 are bidirectional level translators allowing data translation in either direction (VL ↔ VCC) on any single data line. These devices use an architecture specifically designed to be bidirectional without the use of a direction pin. The MAX3004–MAX3012 unidirectional level translators level shift data in one direction (VL → VCC or V CC → V L ) on any single data line. The MAX3000E/MAX3001E/ MAX3002–MAX3012 accept VL from +1.2V to +5.5V. All devices have VCC ranging from +1.65V to +5.5V, making them ideal for data transfer between low-voltage ASICs/PLDs and higher voltage systems. The MAX3000E/MAX3001E/MAX3002/MAX3004– MAX3012 feature an output enable mode that reduces VCC supply current to less than 2µA, and VL supply current to less than 2µA when in shutdown. The MAX3000E/MAX3001E have ±15kV ESD protection on the VCC side for greater protection in applications that route signals externally. The MAX3000E operates at a guaranteed data rate of 230kbps; the MAX3001E operates at a guaranteed data rate of 4Mbps and the MAX3002–MAX3012 are guaranteed with a data rate of 20Mbps of operation over the entire specified operating voltage range. Level Translation For proper operation, ensure that +1.65V ≤ VCC ≤ +5.5V, +1.2V ≤ VL ≤ +5.5V, and VL ≤ VCC. During power-up sequencing, VL ≥ VCC does not damage the device. During power-supply sequencing, when VCC is floating and V L is powering up, up to 10mA current can be sourced to each load on the VL side, yet the device does not latch up. The maximum data rate also depends heavily on the load capacitance (see the Typical Operating Characteristics), output impedance of the driver, and the operational voltage range (see the Timing Characteristics table). Input Driver Requirements The MAX3001E/MAX3002–MAX3012 architecture is based on a one-shot accelerator output stage. See Figure 5. Accelerator output stages are always in three- Maxim Integrated state except when there is a transition on any of the translators on the input side, either I/O VL or I/O VCC. When there is such a transition, the accelerator stages become active, charging (discharging) the capacitances at the I/Os. Due to its bidirectional nature, both stages become active during the one-shot pulse. This can lead to some current feeding into the external source that is driving the translator. However, this behavior helps to speed up the transition on the driven side. For proper full-speed operation, the output current of a device that drives the inputs of the MAX3000E/ MAX3001E/MAX3002–MAX3012 should meet the following requirements: • MAX3000E (230kbps): i > 1mA, Rdrv < 1kΩ • MAX3001E (4Mbps): i > 107 x V x (C + 10pF) • MAX3002–MAX3012 (20Mbps): i > 108 x V x (C + 10pF) where i is the driver output current, V is the logic-supply voltage (i.e., VL or VCC) and C is the parasitic capacitance of the signal line. Enable Output Mode (EN, EN A/B) The MAX3000E/MAX3001E/MAX3002 and the MAX3004– MAX3012 feature an EN input, and the MAX3003 has an EN A/B input. Pull EN low to set the MAX3000E/ MAX3001E/MAX3002/MAX3004–MAX3012s’ I/O VCC1 through I/O VCC8 in three-state output mode, while I/O VL1 through I/O VL8 have internal 6kΩ pulldown resistors. Drive EN to logic-high (VL) for normal operation. The MAX3003 is intended for bus multiplexing or bus switching applications. Drive EN A/B low to place channels 1B through 4B in active mode, while channels 1A through 4A are in three-state mode. Drive EN A/B to logic-high (VL) to enable channels 1A through 4A, while channels 1B through 4B remain in three-state mode. ±15kV ESD Protection As with all Maxim devices, ESD-protection structures are incorporated on all pins to protect against electrostatic discharges encountered during handling and assembly. The I/O V CC lines have extra protection against static discharge. Maxim’s engineers have developed state-of-the-art structures to protect these pins against ESD of ±15kV without damage. The ESD structures withstand high ESD in all states: normal operation, three-state output mode, and powered down. After an ESD event, Maxim’s E versions keep working without latchup, whereas competing products can latch and must be powered down to remove latchup. 15 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators VL VCC I/O VL_ TO I/O VCC_ PATH P ONE-SHOT 6kΩ I/O VL I/O VCC N ONE-SHOT P ONE-SHOT 6kΩ N ONE-SHOT I/O VCC_ TO I/O VL_ PATH Figure 5. MAX3001E/MAX3002–MAX3012 Simplified Functional Diagram (1 I/O Line) ESD protection can be tested in various ways. The I/O VCC lines of the MAX3000E/MAX3001E are characterized for protection to ±15kV using the Human Body Model. IIN ESD Test Conditions ESD performance depends on a variety of conditions. Contact Maxim for a reliability report that documents test setup, test methodology, and test results. VTH_IN / 6kΩ Human Body Model Figure 7a shows the Human Body Model and Figure 7b shows the current waveform it generates when discharged into a low impedance. This model consists of a 100pF capacitor charged to the ESD voltage of interest, which is then discharged into the test device through a 1.5kΩ resistor. Machine Model The Machine Model for ESD tests all pins using a 200pF storage capacitor and zero discharge resistance. Its objective is to emulate the stress caused by contact that occurs with handling and assembly during manufacturing. Of course, all pins require this protection during manufacturing, not just inputs and outputs. Therefore, after PCB assembly, the Machine Model is less relevant to I/O ports. 16 0 VIN VTH_IN VS -(VS - VTH_IN) / 6kΩ WHERE VS = VCC OR VL Figure 6. Typical IIN vs. VIN Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Applications Information Power-Supply Decoupling To reduce ripple and the chance of transmitting incorrect data, bypass VL and VCC to ground with a 0.1µF capacitor. To ensure full ±15kV ESD protection, bypass VCC to ground with a 1µF capacitor. Place all capacitors as close to the power-supply inputs as possible. I2C Level Translation For I2C level translation for I2C applications, please refer to the MAX3372E–MAX3379E/MAX3390E–MAX3393E datasheet. Maxim Integrated Unidirectional vs. Bidirectional Level Translator The MAX3000E/MAX3001E/MAX3002/MAX3003 bidirectional translators can operate as a unidirectional device to translate signals without inversion. The MAX3004–MAX3012 unidirecitional level translators, level-shift data in one direction (VL → VCC or VCC → VL) on any single data line (see the Ordering Information.) These devices provide the smallest solution (UCSP package) for unidirectional level translation without inversion. 17 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators RC 1MΩ CHARGE-CURRENTLIMIT RESISTOR HIGHVOLTAGE DC SOURCE CS 100pF RD 1500Ω IP 100% 90% DISCHARGE RESISTANCE Ir PEAK-TO-PEAK RINGING (NOT DRAWN TO SCALE) AMPERES 36.8% DEVICE UNDER TEST STORAGE CAPACITOR 10% 0 0 TIME tRL tDL CURRENT WAVEFORM Figure 7a. Human Body ESD Test Model Figure 7b. Human Body Current Waveform Selector Guide PART EN EN A/B Tx/Rx* DATA RATE ESD PROTECTION (kV) MAX3000E √ — 8/8 230kbps ±15 MAX3001E √ — 8/8 4Mbps ±15 MAX3002 √ — 8/8 ** ±2 MAX3003 — √ 8/8 ** ±2 MAX3004 √ — 8/0 ** ±2 MAX3005 √ — 7/1 ** ±2 MAX3006 √ — 6/2 ** ±2 MAX3007 √ — 5/3 ** ±2 MAX3008 √ — 4/4 ** ±2 MAX3009 √ — 3/5 ** ±2 MAX3010 √ — 2/6 ** ±2 MAX3011 √ — 1/7 ** ±2 MAX3012 √ — 0/8 ** ±2 *Tx = VL → VCC; Rx = VCC → VL **See Table 1. Table 1. Data Rate 18 VL ↔ VCC (V) MAX3002–MAX3012 GUARANTEED DATA RATE (Mbps) 1.2 ↔ 5.5 40 1.2 ↔ 3.3 20 2.5 ↔ 3.3 35 1.8 ↔ 2.5 30 1.2 ↔ 2.5 20 1.2 ↔ 1.8 20 Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators MAX3000E/MAX3001E/MAX3002 Functional Diagram VL VCC EN MAX3000E/ MAX3001E/MAX3002 I/O VL1 I/O VCC1 I/O VL2 I/O VCC2 I/O VL3 I/O VCC3 I/O VL4 I/O VCC4 I/O VL5 I/O VCC5 I/O VL6 I/O VCC6 I/O VL7 I/O VCC7 I/O VL8 I/O VCC8 GND Maxim Integrated 19 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators MAX3003 Functional Diagram VL VCC EN A/B MAX3003 I/O VL1A I/O VCC1A I/O VL2A I/O VCC2A I/O VL3A I/O VCC3A I/O VL4A I/O VCC4A I/O VL1B I/O VCC1B I/O VL2B I/O VCC2B I/O VL3B I/O VCC3B I/O VL4B I/O VCC4B GND 20 Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Pin Configurations MAX3000E/MAX3001E/MAX3002 MAX3004–MAX3012 MAX3003 1 2 3 4 5 VCC I/O VCC2 I/O VCC4 I/O VCC6 I/O VCC8 I/O VCC1 I/O VCC3 I/O VCC5 I/O VCC7 GND I/O VL1 I/O VL3 I/O VL5 I/O VL7 EN VL I/O VL2 I/O VL4 I/O VL6 I/O VL8 D 1 2 VCC I/O VCC2A I/O VCC4A I/O VCC2B I/O VCC4B I/O VCC1A I/O VCC3A I/O VCC1B I/O VCC3B GND I/O VL1A I/O VL3A I/O VL1B I/O VL3B EN A/B VL I/O VL2A I/O VL4A I/O VL2B I/O VL4B 3 4 5 D C C B B A A 20 UCSP (Bottom View) 20 UCSP (Bottom View) MAX3000E/MAX3001E/MAX3002 MAX3003 TOP VIEW 20 I/O VCC1 I/O VL1 1 20 I/O VCC1A I/O VL1A 1 19 VCC VL 2 19 VCC VL 2 I/O VL2 3 18 I/O VCC2 I/O VL2A 3 18 I/O VCC2A I/O VL3 4 17 I/O VCC3 I/O VL3A 4 17 I/O VCC3A I/O VL4 5 16 I/O VCC4 I/O VL4A 5 16 I/O VCC4A I/O VL5 6 15 I/O VCC5 I/O VL1B 6 15 I/O VCC1B I/O VL6 7 14 I/O VCC6 I/O VL2B 7 14 I/O VCC2B I/O VL7 8 13 I/O VCC7 I/O VL3B 8 13 I/O VCC3B I/O VL8 9 12 I/O VCC8 I/O VL4B 9 12 I/O VCC4B EN A/B 10 11 GND 11 GND TSSOP I/O VCC1A VCC I/O VCC2A 17 16 VL I/O VL1A 19 I/O VCC2 16 14 I/O VCC4A I/O VL4 3 13 I/O VCC5 I/O VL4A 3 I/O VL5 4 12 I/O VCC6 I/O VL1B 4 I/O VL6 5 *EXPOSED PADDLE 11 I/O VCC7 I/O VL2B 5 MAX3003 6 7 8 9 10 I/O VL4B EN A/B GND I/O VCC4B *EXPOSED PADDLE I/O VL3B 9 I/O VL3A 2 MAX3000E/ MAX3001E/ MAX3002 I/O VCC4 10 14 GND I/O VCC3A 2 I/O VCC8 15 I/O VL3 8 1 EN I/O VL2A 7 I/O VCC3 6 15 I/O VL8 1 I/O VL7 I/O VL2 5mm ✕ 5mm THIN QFN Maxim Integrated 20 I/O VCC1 VCC 17 19 TSSOP 18 VL I/O VL1 20 TOP VIEW 18 EN 10 13 I/O VCC1B 12 I/O VCC2B 11 I/O VCC3B 5mm ✕ 5mm THIN QFN 21 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Pin Configurations (continued) TOP VIEW MAX3004 20 O VCC1 I VL1 1 VL 2 I VL2 3 I VL3 4 19 VCC VL 2 18 O VCC2 17 O VCC3 I VL3 4 I VL4 5 16 O VCC4 I VL5 6 I VL6 7 MAX3006 20 I VCC1 O VL1 1 I VL2 3 19 VCC 20 I VCC1 O VL1 1 VL 2 19 VCC 18 O VCC2 O VL2 3 18 I VCC2 17 O VCC3 I VL3 4 17 O VCC3 I VL4 5 16 O VCC4 I VL4 5 16 O VCC4 15 O VCC5 I VL5 6 15 O VCC5 I VL5 6 15 O VCC5 14 O VCC6 I VL6 7 14 O VCC6 I VL6 7 14 O VCC6 I VL7 8 13 O VCC7 I VL7 8 13 O VCC7 I VL7 8 13 O VCC7 I VL8 9 12 O VCC8 I VL8 9 12 O VCC8 I VL8 9 12 O VCC8 EN 10 11 GND EN 10 11 GND EN 10 11 GND TSSOP TSSOP TSSOP MAX3007 MAX3008 MAX3009 20 I VCC1 O VL1 1 19 VCC VL 2 20 I VCC1 O VL1 1 19 VCC VL 2 20 I VCC1 O VL1 1 19 VCC VL 2 O VL2 3 18 I VCC2 O VL2 3 18 I VCC2 O VL2 3 18 I VCC2 O VL3 4 17 I VCC3 O VL3 4 17 I VCC3 O VL3 4 17 I VCC3 I VL4 5 16 O VCC4 O VL4 5 16 I VCC4 O VL4 5 16 I VCC4 I VL5 6 15 O VCC5 I VL5 6 15 O VCC5 O VL5 6 15 I VCC5 I VL6 7 14 O VCC6 I VL6 7 14 O VCC6 I VL6 7 14 O VCC6 I VL7 8 13 O VCC7 I VL7 8 13 O VCC7 I VL7 8 13 O VCC7 I VL8 9 12 O VCC8 I VL8 9 12 O VCC8 I VL8 9 12 O VCC8 EN 10 11 GND TSSOP 22 MAX3005 EN 10 11 GND TSSOP EN 10 11 GND TSSOP Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Pin Configurations (continued) TOP VIEW MAX3010 MAX3011 20 I VCC1 O VL1 1 20 I VCC1 O VL1 1 19 VCC VL 2 O VL2 3 O VL2 3 O VL3 4 O VL4 5 20 I VCC1 O VL1 1 19 VCC VL 2 18 I VCC2 MAX3012 19 VCC VL 2 18 I VCC2 O VL2 3 18 I VCC2 17 I VCC3 O VL3 4 17 I VCC3 O VL3 4 17 I VCC3 16 I VCC4 O VL4 5 16 I VCC4 O VL4 5 16 I VCC4 O VL5 6 15 I VCC5 O VL5 6 15 I VCC5 O VL5 6 15 I VCC5 O VL6 7 14 I VCC6 O VL6 7 14 I VCC6 O VL6 7 14 I VCC6 I VL7 8 13 O VCC7 O VL7 8 13 I VCC7 O VL7 8 13 I VCC7 I VL8 9 12 O VCC8 I VL8 9 12 O VCC8 O VL8 9 12 I VCC8 EN 10 EN 10 11 GND TSSOP 11 GND EN 10 11 GND TSSOP TSSOP Ordering Information (continued) TEMP RANGE PIN-PACKAGE TEMP RANGE PIN-PACKAGE MAX3001EEUP PART -40°C to +85°C 20 TSSOP MAX3007EUP -40°C to +85°C 20 TSSOP MAX3001EEBP-T* -40°C to +85°C 4 x 5 UCSP MAX3007EBP-T* -40°C to +85°C 4 x 5 UCSP PART MAX3001EETP -40°C to +85°C 20 TQFN MAX3008EUP -40°C to +85°C 20 TSSOP MAX3001EAUP -40°C to +125°C 20 TSSOP MAX3008EBP-T* -40°C to +85°C 4 x 5 UCSP MAX3002EUP -40°C to +85°C 20 TSSOP MAX3009EUP -40°C to +85°C 20 TSSOP MAX3002EBP-T* -40°C to +85°C 4 x 5 UCSP MAX3009EBP-T* -40°C to +85°C 4 x 5 UCSP MAX3002ETP -40°C to +85°C 20 TQFN MAX3010EUP -40°C to +85°C 20 TSSOP MAX3003EUP -40°C to +85°C 20 TSSOP MAX3010EBP-T* -40°C to +85°C 4 x 5 UCSP MAX3003EBP-T* -40°C to +85°C 4 x 5 UCSP MAX3011EUP -40°C to +85°C 20 TSSOP MAX3003ETP -40°C to +85°C 20 TQFN MAX3011EBP-T* -40°C to +85°C 4 x 5 UCSP MAX3004EUP -40°C to +85°C 20 TSSOP MAX3012EUP -40°C to +85°C 20 TSSOP MAX3004EBP-T* -40°C to +85°C 4 x 5 UCSP MAX3012EBP-T* -40°C to +85°C 4 x 5 UCSP MAX3005EUP -40°C to +85°C 20 TSSOP *Future product—contact factory for availability. -T = Tape-and-reel package. MAX3005EBP-T* -40°C to +85°C 4 x 5 UCSP MAX3006EUP -40°C to +85°C 20 TSSOP MAX3006EBP-T* -40°C to +85°C 4 x 5 UCSP Chip Information TRANSISTOR COUNT: 1184 PROCESS: BiCMOS Maxim Integrated 23 MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Package Information For the latest package outline information and land patterns, go to www.maxim-ic.com/packages. 24 PACKAGE TYPE PACKAGE CODE DOCUMENT NO. 20 TSSOP U20-3 21-0066 20 TQFN T2055-4 21-0140 4 x 5 UCSP B20-1 21-0095 Maxim Integrated MAX3000E/MAX3001E/MAX3002–MAX3012 +1.2V to +5.5V, ±15kV ESD-Protected, 0.1µA, 35Mbps, 8-Channel Level Translators Revision History REVISION NUMBER REVISION DATE 4 12/06 Added TQFN packages 5 8/08 Changed pin description and package drawing DESCRIPTION PAGES CHANGED 1, 2, 3, 10, 11, 15, 16, 21, 23–26 1, 10, 11, 23 Maxim cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in a Maxim product. No circuit patent licenses are implied. Maxim reserves the right to change the circuitry and specifications without notice at any time. The parametric values (min and max limits) shown in the Electrical Characteristics table are guaranteed. Other parametric values quoted in this data sheet are provided for guidance. Maxim Integrated 160 Rio Robles, San Jose, CA 95134 USA 1-408-601-1000 ©  Maxim Integrated 25 The Maxim logo and Maxim Integrated are trademarks of Maxim Integrated Products, Inc.
MAX3001EEUP+ 价格&库存
很抱歉,暂时无法提供与“MAX3001EEUP+”相匹配的价格&库存,您可以联系我们找货
