BR05-1516LB
BR05-1516LB
    BELLNIX
    插件,51.3x51.3mm
BR05-1516LB 数据手册
Ultra Low Noise, Small Size, Isolated Type DC-DC Converter World Standard Analog Equipment 5 Watt BR-LB Series RoHS Ultra Low Noise Compliance 3mVpp Ultra Low Noise 3mVpp, Isolated Type DC-DC Converter Input: 5V    Output: ±12V, ±15V 25.6 2.54 +Input +Output 1 Bellnix 25.6 3 External capacitors are not required, but noise can be lowered by reducing power line impedance, and load line impedance. CL COM 4 5.08 10.16 10.16 51.3 max. 6 8 1.8 9.8 max. Output +V/I, -V/I - Ultra Low Noise 3mVp-p Models Input V Line Reg Load Reg Ripple/ Noise Efficiency +Vdc/mA, -Vdc/mA % (typ.) % (typ.) mVpp(max.) % (typ.) - Analog, Digital Optimum BR-LB Series Vdc - Short Circuit, Over-Current +12/208, -12/-208 BR05-1220LB Protection +12/250, -12/-125 BR05-1225LB 4.75-6 0.03 0.18 3 64 - No Electrolytic Capacitor, +15/167, -15/-167 BR05-1516LB No Tantalum Capacitor +15/200, -15/-100 BR05-1520LB - 5-Side Metallic shield structure Note 1: Derating required for input voltages 5.25V or greater. - EMI Line Filter 51.3 max. - Over-Heat Protection +Vin +Vout 1 3 - Long-Life with TCT Patent Load C2 Circuit COM BR-LB C1 4 - Isolation Voltage DC500V Input C3 φ1.1 Load - Low Drift 50mV/8H φ0.6 5 2 - Temp Coefficient ±0.02%/°C -Vin -Vout CL - Operating Temp Range -20°C to +70°C - Recommended Capacitor ISOLATED DC-DC (Temp Derating Required)   C1=100µF -Output CONVERTER 5 - RoHS Compliance   C2,C3=1µF -Input 2 JAPAN The loop area should be small as possible +Vin +Vin 10.16 25.6 20.32 51.3 max. BOTTOM VIEW Units:mm Weight:31g typ. Pin 1 2 3 4 5 Function +Vin -Vin +Vout Common -Vout +Vin +Vout The loop area should be small as possible +Vout Load BR-LB Series C1 -Vin Make the lead short -Vout C3 C2 Make the lead short -Vin BR05-1516LB Horizontal FCC Class B 20 0 BR05-1516LB ES1 +5V ±15V 167mA Peak 30MHz - 1000MHz 3 Meas Mode : D Horizontal , Vertical TR4172,TR14307 dBµV/m 40 60 80 Model Name Serial No. Input Load DET.Mode Limits Band Number Antenna Mode Test Equip. 100 RADIATED EMISSION FCC Class B 30 50 dBµV/m 40 60 80 100 < BR05-1516LB> Output Noise +15V167mA 1.4mVp-p 100% 10mV/div 2µs/div 70 100 FREQUENCY MHz 200 300 BR05-1516LB Vertical FCC Class B 1.7mVp-p This catalogue is an outline of the 10mV/div products. When designing, be sure 2µs/div to refer to the data sheets. DC-DC CONVERTERS 0% 0 - Note! 20 -15V167mA 10mV 2usec 30 50 70 100 FREQUENCY MHz 200 300 BR05-1516LB BDD2008.12A
BR05-1516LB
PDF文档中包含的物料型号为:ATMEL的AT91SAM9261-EK,是一款基于ARM926EJ-S内核的系统芯片(SoC)。
器件简介显示它适用于各种应用,如数字电视、IPTV、PVR、STB和GPS。
引脚分配部分详细列出了芯片的各个引脚及其功能,例如: - UART引脚用于串行通信 - SPI引脚用于高速串行通信 - USB引脚用于连接USB设备 - JTAG引脚用于测试和调试
参数特性包括: - 工作电压范围:0.85V至1.2V - 支持的存储类型:NAND、NOR、RAM - 温度范围:-40°C至+85°C
功能详解部分深入介绍了芯片的各个功能模块,如: - CPU核心 - 存储接口 - 通信接口 - 外设和GPIO
应用信息提供了该芯片在实际应用中的示例,如: - 用于数字电视和机顶盒 - 用于GPS导航系统
封装信息说明了芯片的物理尺寸和引脚布局,封装类型为LQFP(塑料四边扁平封装)。
这些信息对于设计和开发基于AT91SAM9261的电子产品至关重要。
BR05-1516LB 价格&库存
很抱歉,暂时无法提供与“BR05-1516LB”相匹配的价格&库存,您可以联系我们找货
