MAX3160CAP+
MAX3160CAP+
    MAX(迈旭)
    MAX3160CAP+
MAX3160CAP+ 数据手册
EVALUATION KIT AVAILABLE MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers General Description Benefits and Features The MAX3160/MAX3161/MAX3162 are programmable +3V to +5.5V RS-232/RS-485/422 multiprotocol transceivers. The MAX3160/MAX3161 are pin programmable as a 2TX/2RX RS-232 interface or a single RS-485/422 transceiver. The MAX3162 is configured as a 2TX/2RX RS-232 interface and a single RS-485/422 transceiver simultaneously. • Flexible Options for RS-232 and RS-422/485 All devices incorporate a proprietary low-dropout transmitter output stage and an on-board dual charge pump to allow RS-232 and RS-485/422 compliant performance from a +3V to +5.5V supply. These devices also feature pin-selectable transmitter slew rates for both RS-232 and RS-485/422 modes. Slew-rate limiting minimizes EMI and reduces reflections caused by improperly terminated cables, allowing error-free data transmission up to 250kbps. Disabling slew-rate limiting allows these devices to transmit at data rates up to 10Mbps in RS-485/422 mode and up to 1Mbps in RS232 mode. The MAX3160/MAX3162 offer a flow-through pinout that facilitates board layout. The MAX3160/MAX3161/ MAX3162 are available in tiny SSOP packages and operate from -40°C to +85°C. Applications Point-of-Sales Equipment Peripherals Industrial Controls Networking RS-232 to RS-485 Interface Converters Operation in One Package • Simultaneous 2TX/2RX RS-232 and Half-Duplex RS-485 Transceiver Operation (MAX3162) • Pin-Programmable as Either 2TX/2RX RS-232 or Half/Full RS-485 Transceiver (MAX3160, MAX3161) • Integrated Protection Increases Robustness • Transmitters and Receivers Protected Against Wiring Faults • True Fail-Safe Receiver Prevents False Transition on Receiver Input Short or Open • Short-Circuit Protection Over the Entire Common- Mode Voltage Range • Thermal Protection from Excessive Power Dissipation • Slew Rate Limiting Minimizes EM and Reduces Cable Reflections • Integrated Charge-Pump Circuitry Saves Board Space • Eliminates the Need for a Bipolar ±12V Supply • Enables Single-Supply Operation From +3V to +5.5V Voltage Supply • 1µA Shutdown Supply Current Saves Power • Allows Up to 256 Transceivers on the Bus Typical Operating Circuit Ordering Information +3V TO +5.5V PART MAX3160CAP+ TEMP RANGE 0°C to +70°C PIN-PACKAGE 20 SSOP MAX3160EAP+ -40°C to +85°C 20 SSOP MAX3161CAG+ 0°C to +70°C 24 SSOP MAX3161EAG+ -40°C to +85°C 1 RS485/RS232 11 TX 24 SSOP MAX3162CAI+ 0°C to +70°C 28 SSOP MAX3162EAI+ -40°C to +85°C 28 SSOP DB9 VCC 13 DI/T1IN Z(B)/T1OUT 16 RTS DE/T2IN 5 Y(A)/T2OUT MAX3160 6 A/R2IN MAX3100 11 15 RX RO/R2OUT 8 12 CTS R1OUT +Denotes a lead(Pb)-free/RoHS-compliant package. 10 13 B/R1IN 7 14 GND FAST HDPLX SHDN SPI Pin Configurations appear at end of data sheet. Selector Guide appears at end of data sheet. 19-1722; Rev 3; 5/15 µP 4 SHDN 10 12 9 RJ45 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers VCC to GND. .............................................................-0.3V to +6V V+ to GND ................................................................-0.3V to +7V V- to GND....................................................................0.3V to -7V V+ - V- (Note 1)....................................................................+13V Input Voltages T1IN, T2IN, DI, DE485, RE485, TE232, RE232, SHDN, FAST, HDPLX, RS485/RS232 to GND. ...............-0.3V to +6V A, B, R1IN, R2IN to GND ...............................................±25V Output Voltages T1OUT, T2OUT, Y, Z to GND......................................±13.2V R2OUT, R1OUT, RO to GND................-0.3V to (VCC + 0.3V) Output Short-Circuit Duration T1OUT, T2OUT, Y, Z ............................................Continuous Continuous Power Dissipation (TA = +70°C) 20-Pin SSOP (derate 11.9W/°C above +70°C) ..........952mW 24-Pin SSOP (derate 14.9W/°C above +70°C) ........1195mW 28-Pin SSOP (derate 15W/°C above +70°C) ...........1201mW Operating Temperature Ranges MAX316_CA_ ....................................................0°C to +70°C MAX316_EA_ .................................................-40°C to +85°C Storage Temperature Range .............................-65°C to +150°C Junction Temperature ......................................................+150°C Lead Temperature (soldering, 10s) .................................+300°C Note 1: V+ and V- can have maximum magnitudes of 7V, but their absolute difference cannot exceed 13V. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Electrical Characteristics (VCC = +3V to +5.5V, C1–C4 = 0.1µF when tested at +3.3V ±10%; C1 = 0.047µF and C2, C3, C4 = 0.33µF when tested at +5V ±10%; TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) PARAMETER DC CHARACTERISTICS VCC Standby Current VCC Shutdown Current SYMBOL ICC ICC CONDITIONS MIN TYP MAX MAX3160/MAX3161, no load, RS485/ RS232 = GND 1.2 2.5 MAX3160/MAX3161, no load, RS485/ RS232 = VCC 2.5 5.5 MAX3162 No Load 3.0 6 1 10 SHDN = GND, receiver inputs open or grounded UNITS mA µA RS232) TRANSMITTER AND LOGIC INPUTS (DI, T1IN, T2IN, DE485, RE4 8 5, TE232, R E 2 32 , FAST, HDPLX, SHDN, RS485/R Logic Input Low Logic Input High VIL VIH 0.8 VCC = +3.3V 2.0 VCC = +5V 2.4 V V Logic Input Leakage Current IINL ±0.01 Transmitter Logic Hysteresis VHYS 0.5 ±1 µA V RS-232 AND RS-485/422 RECEIVER OUTPUTS (R1OUT, R2OUT, RO) Receiver Output Voltage Low VOL IOUT = 2.5mA Receiver Output Voltage High VOH IOUT = -1.5mA Receiver Output Short Circuit Current IOSR 0 < VO < VCC Receiver Output Leakage Current IOZR Receivers disabled www.maximintegrated.com 0.4 VCC - 0.6 V V ±20 ±60 mA ±0.05 ±1 µA Maxim Integrated | 2 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers Electrical Characteristics (continued) (VCC = +3V to +5.5V, C1–C4 = 0.1µF when tested at +3.3V ±10%; C1 = 0.047µF and C2, C3, C4 = 0.33µF when tested at +5V PARAMETER SYMBOL RS-232 RECEIVER INPUTS (R1IN, R2IN) CONDITIONS MIN Input Voltage Range TYP -25 Input Threshold Low Input Threshold High VCC = +3.3V 0.6 VCC = +5V 0.8 MAX UNITS 25 V V VCC =+3.3V 2.0 VCC = +5V 2.4 Input Hysteresis 0.5 Input Resistance 3 5 V V 7 kΩ RS-485/422 RECEIVER INPUTS (NOTE 2) Input Resistance RIN -7V < VCM < +12V MAX3160 Input Current IIN MAX3161/MAX3162 Input Differential Threshold Input Hysteresis MAX3160 48 MAX3161/ MAX3162 96 kΩ VCM = +12V 0.25 VCM = -7V -0.15 VCM = +12V 0.125 VCM = -7V VTH -0.075 -50 -200 ΔVTH mA mV 30 mV V RS-232 TRANSMITTER OUTPUTS (T1OUT, T2OUT) Both transmitter outputs loaded with 3kΩ to GND ±5 ±5.4 Output Resistance VCC = V+ = V- = 0V, VT1OUT = VT2OUT = +2V 300 10M Output Short-Circuit Current T_OUT = GND Output Leakage Current VOUT = ±12V TE232 = GND or SHDN = GND Output Voltage Swing ±30 Ω ±60 MAX3160/ MAX3161 ±125 MAX3162 ±25 mA µA RS-485/422 TRANSMITTER OUTPUTS (Y, Z) Differential Output Voltage VOD 1.5 R = 50Ω (RS-422) 2 V Figure 1 Change in Magnitude of Differential Output Voltage for Complementary Output States ΔVOD R = 27Ω or 50Ω, Figure 1 Common Mode Output Voltage VOC Change in Magnitude of Common Mode Output Voltage for Complementary Output States Δ VOC www.maximintegrated.com R = 27Ω (RS-485) -0.2 0.2 V R = 27Ω or 50Ω, Figure 1 3 V R = 27Ω or 50Ω, Figure 1 0.2 V Maxim Integrated | 3 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers Electrical Characteristics (continued) (VCC = +3V to +5.5V, C1–C4 = 0.1µF when tested at +3.3V ±10%; C1 = 0.047µF and C2, C3, C4 = 0.33µF when tested at +5V ±10%; TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Output Short-Circuit Current ISC VY or VZ = +12V to –7V ±250 mA Output Leakage Current IO VY or VZ = +12V, DE485 = GND or SHDN = GND MAX3160/ MAX3161 ±125 MAX3162 ±25 µA RS-232 TIMING CHARACTERISTICS (FAST = GND, 250kbps, ONE TRANSMITTER SWITCHING) Maximum Data Rate RL = 3kΩ, CL = 1000pF Receiver Propagation Delay R_IN to R_OUT, CL = 150pF 250 Receiver Output Enable Time Receiver Output Disable Time kbps 0.15 µs 200 ns 200 ns Transmitter Skew |tPHL - tPLH| 100 ns Receiver Skew |tPLH - tPHL| 50 ns Transition-Region Slew Rate VCC = +3.3V, TA = +25°C, RL =3kΩ to 7kΩ, measured from +3.0V or –3.0V to +3.0V CL = 150pF to 1000pF 6 30 CL = 150pF to 2500pF 4 30 V/µs RS-232 TIMING CHARACTERISTICS (FAST = VCC, 1Mbps, ONE TRANSMITTER SWITCHING) VCC = +3V to +4.5V, RL = 3kΩ, CL = 250pF 1 Maximum Data Rate VCC = +4.5V to +5.5V, RL = 3kΩ, CL = 1000pF 1 Receiver Propagation Delay R_IN to R_OUT, CL = 150pF Mbps 0.15 µs Receiver Output Enable Time 200 ns Receiver Output Disable Time 200 ns Transmitter Skew |tPHL - tPLH| 25 ns Receiver Skew |tPLH - tPHL| 50 ns Transition-Region Slew Rate VCC = +3.3V, TA = +25°C, RL =3kΩ to 7kΩ, CL = 150pF to 1000pF, measured from +3.0V or –3.0V to +3.0V 24 150 V/μs RS-485/422 TIMING CHARACTERISTICS (FAST = GND) 250kbps Driver Propagation Delay tDPHL, tDPLH RDIFF = 54Ω, CL = 50pF, Figures 3, 5 200 400 800 ns Driver Rise and Fall Time tDPHL, tDPLH RDIFF = 54Ω, CL = 50pF, Figures 3, 5 200 400 800 ns Driver Propagation Delay Skew tDSKEW RDIFF = 54Ω, CL = 50pF, Figure 3, 5 200 ns Driver Output Enable Time tDZH, tRZL RDIFF = 54Ω, CL = 50pF, Figures 4, 6 400 800 ns Driver Output Disable Time tDLZ, tDHZ RDIFF = 54Ω, CL = 50pF, Figure 4, 6 200 400 ns Receiver Propagation Delay tRPLH, tRPHL CL = 15pF, Figures 7, 9 80 150 ns Receiver Propagation Delay Skew tRSKEW CL = 50pF, Figures 7, 9 10 ns www.maximintegrated.com 25 Maxim Integrated | 4 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers MAX3160/MAX3161/MAX3162 Electrical Characteristics (continued) (VCC = +3V to +5.5V, C1–C4 = 0.1µF when tested at +3.3V ±10%; C1 = 0.047µF and C2, C3, C4 = 0.33µF when tested at +5V ±10%; TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Receiver Output Enable Time tRZL, tRZH CL = 50pF, Figures 2, 8 100 ns Receiver Output Disable Time tRLZ, tRHZ CL = 50pF, Figures 2, 8 100 ns RS-485/RS-422 TIMING CHARACTERISTICS (FAST = VCC, 10Mbps) Driver Propagation Delay tDPHL, tDPLH RDIFF = 54Ω, CL = 50pF, Figures 3, 5 60 Driver Rise And Fall Times tDR, tDF RDIFF = 54Ω, CL = 50pF, Figures 3, 5 10 Driver Propagation Delay Skew tDSKEW RDIFF = 54Ω, CL = 50pF, Figures 3, 5 tDZL tDLZ, tDHZ tRPLH, tRPHL RDIFF = 54Ω, CL = 50pF, Figures 4, 6 Driver Output Enable Time Driver Output Disable Time Receiver Propagation Delay Receiver Propagation Delay Skew Receiver Output Enable Time Receiver Output Disable Time 120 ns 25 ns 10 ns 400 800 ns RDIFF = 54Ω, CL = 50pF, Figures 4, 6 200 400 ns CL = 15pF, Figures 7, 9 80 150 ns 10 ns tRSKEW CL = 50pF, Figures 7, 9 tRZL, tRZH tRLZ, tRHZ CL = 50pF, Figures 2, 8 CL = 15pF, Figures 2, 8 100 100 ns ns Note 2: Applies to A, B for MAX3162 and MAX3160/MAX3161 with HDPLX = GND, or Y, Z for MAX3160/MAX3161 with HDPLX = VCC. Typical Operating Characteristics (VCC = +3.3V, 250kbps data rate, 0.1µF capacitors, all RS-232 transmitters (RS-232 mode) loaded with 3kΩ to ground, TA = +25°C, 2.5 0 -2.5 -5.0 -7.5 -10.0 7.5 5.0 2.5 0 -2.5 1000 2000 3000 4000 LOAD CAPACITANCE (pF) www.maximintegrated.com 5000 14 12 10 8 6 -5.0 4 -7.5 2 0 -10.0 0 16 SLEW RATE (V/μs) 5.0 18 MAX3160/2 TOC2 7.5 10.0 TRANSMITTER OUTPUT VOLTAGE (V) MAX3160/2 TOC1 TRANSMITTER OUTPUT VOLTAGE (V) 10.0 RS-232 TRANSMITTER SLEW RATE vs. LOAD CAPACITANCE (FAST = GND) RS-232 TRANSMITTER OUTPUT VOLTAGE vs. LOAD CAPACITANCE (FAST = VCC) MAX3160/2 TOC3 RS-232 TRANSMITTER OUTPUT VOLTAGE vs. LOAD CAPACITANCE (FAST = GND) 0 500 1000 1500 LOAD CAPACITANCE (pF) 2000 0 1000 2000 3000 4000 5000 LOAD CAPACITANCE (pF) Maxim Integrated | 5 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers MAX3160/MAX3161/MAX3162 Typical Operating Characteristics (continued) (VCC = +3.3V, 250kbps data rate, 0.1µF capacitors, all RS-232 transmitters (RS-232 mode) loaded with 3kΩ to ground, TA = +25°C, unless otherwise noted.) MAX3160/MAX3161 OPERATING SUPPLY CURRENT vs. RS-232 TRANSMITTER SLEW RATE NO-LOAD SUPPLY CURRENT vs. LOAD CAPACITANCE WHEN vs. LOAD CAPACITANCE (FAST = VCC) TEMPERATURE TRANSMITTING DATA (RS-232 MODE) 60 50 40 30 20 1Mbps 2.5 SUPPLY CURRENT (mA) 70 40 250kbps 30 20 20kbps MAX3160/2 TOC6 50 SUPPLY CURRENT (mA) 80 3.0 MAX3160/2 TOC5 90 SLEW RATE (V/μs) 60 MAX3160/2 TOC4 100 RS-485 MODE 2.0 1.5 RS-232 MODE 1.0 10 10 0 0 0 500 1000 1500 2000 2000 3000 4000 5000 -40 -15 10 35 60 LOAD CAPACITANCE (pF) TEMPERATURE (°C) SHUTDOWN CURRENT vs. TEMPERATURE RS-485/422 OUTPUT CURRENT vs. DRIVER OUTPUT VOLTAGE RS-485/422 OUTPUT CURRENT vs. DRIVER OUTPUT HIGH VOLTAGE 100 80 60 40 100 80 60 40 MAX3160/2 TOC9 160 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 120 120 85 180 MAX3160/2 TOC8 140 MAX3160/2 TOC7 140 140 120 100 80 60 40 20 20 0 0 -40 -15 10 35 60 20 0 0 85 2 4 6 8 10 12 -7 -5 -3 -1 1 3 TEMPERATURE (°C) OUTPUT LOW VOLTAGE (V) OUTPUT HIGH VOLTAGE (V) RS-485/422 DRIVER OUTPUT CURRENT vs. DIFFERENTIAL OUTPUT VOLTAGE RS-485/422 DRIVER DIFFERENTIAL OUTPUT vs. TEMPERATURE OUTPUT CURRENT vs. RECEIVER OUTPUT LOW VOLTAGE 1 0.1 0.01 3.2 3.1 3.0 2.9 2.8 2.7 30 5 MAX3160/2 TOC12 3.3 OUTPUT VOLTAGE (V) 10 R = 50Ω 3.4 25 OUTPUT CURRENT (mA) 3.5 MAX3160/2 TOC10 100 MAX3160/2 TOC11 SHUTDOWN CURRENT (nA) 1000 LOAD CAPACITANCE (pF) 160 OUTPUT CURRENT (mA) 0 0 20 15 10 5 2.6 0.001 2.5 0 0.5 1.0 1.5 2.0 2.5 3.0 OUTPUT VOLTAGE (V) www.maximintegrated.com 3.5 4.0 0 -40 -15 10 35 TEMPERATURE (°C) 60 85 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 OUTPUT LOW VOLTAGE (V) Maxim Integrated | 6 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers MAX3160/MAX3161/MAX3162 Typical Operating Characteristics (continued) (VCC = +3.3V, 250kbps data rate, 0.1µF capacitors, all RS-232 transmitters (RS-232 mode) loaded with 3kΩ to ground, TA = +25°C, unless otherwise noted.) RS-485/422 RECEIVER PROPAGATION DELAY vs. TEMPERATURE 10 8 6 4 100 RISING FALLING 60 40 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 70 65 60 55 0 0 R = 50Ω 80 75 80 20 2 85 MAX3160/2 TOC18 CL = 50pF TIME (ns) OUTPUT CURRENT (mA) 12 120 PROPAGATION DELAY (ns) MAX3160/2 TOC13 14 RS-485/422 DRIVER PROPAGATION DELAY vs.TEMPERATURE (FAST) MAX3160/2 TOC16 OUTPUT CURRENT vs. RECEIVER OUTPUT HIGH VOLTAGE 50 -40 -15 10 35 60 85 -40 -15 10 35 60 OUTPUT HIGH VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C) RS-485/422 DRIVER PROPAGATION DELAY vs. TEMPERATURE (SLOW) RS-485/422 DRIVER PROPAGATION (FAST, 10Mbps) RS-485/422 DRIVER PROPAGATION (FAST, 10Mbps) MAX3160/2 TOC21 MAX3160/2 TOC20 480 MAX3160/2 TOC19 500 R = 50Ω 460 85 DI 5V/di DI 5V/div 440 TIME (ns) 420 400 VY-V 2V/d 380 VY-VZ 2V/div 360 340 320 300 -40 -15 10 35 60 20ns/div 1.0μs/div RS-485/422 RECEIVER PROPAGATION (FAST, 5Mbps) RS-485/422 DRIVER DISABLE/ENABLE TO DRIVER OUTPUT 85 TEMPERATURE (°C) I-V OUTPUT IMPEDANCE CURVE IN RS-232 SHUTDOWN MODE MAX3160/2 TOC24 MAX3160/2 TOC22 MAX3160-A 400 200 0 CURRENT (μA) DE48 2V/d VY-VZ 2V/div R = 50Ω CL = 82pF -200 -400 CL = 50pF RO 2V/div -600 VY - V 2V/d -800 -1000 -20 -15 -10 -5 0 5 10 15 20 40ns/div 100ns/div VOLTS (V) www.maximintegrated.com Maxim Integrated | 7 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers Pin Description PIN MAX3160 MAX3161 MAX3162 NAME FUNCTION 1 1 1 C1+ Positive Terminal of the Positive Flying Capacitor 2 2 2 VCC Positive Supply Voltage 3 3 3 C1- Negative Terminal of the Positive Flying Capacitor 4 4 4 GND — 5 5 T1OUT 5 — — Z(B)/T1OUT — — 6 Z — 6 — Z(B) 6 — — Y(A)/T2OUT — — 7 Y — 7 — Y(A) 7 9 9 R1OUT Ground RS-232 Driver Output Inverting RS-485/422 Driver Output in Full-Duplex Mode (and Inverting RS-485/422 Receiver Input in Half-Duplex Mode)/RS-232 Driver Output Inverting RS-485/422 Driver Output Inverting RS-485/422 Driver Output in Full-Duplex Mode (and Inverting RS-485/422 Receiver Input in Half-Duplex Mode) Noninverting RS-485/422 Driver Output in Full-Duplex Mode (and Noninverting RS-485/422 Receiver Input in Half-Duplex Mode)/RS-232 Driver Output Noninverting RS-485/422 Driver Output Noninverting RS-485/422 Driver Output in Full-Duplex Mode (and Noninverting RS-485/422 Receiver Input in Half-Duplex Mode) RS-232 Receiver Output — 8 8 T2OUT 8 10 — RO/R2OUT RS-485/422 Receiver Output/RS-232 Receiver Output 9 11 13 SHDN Active-Low Shutdown-Control Input. Drive low to shut down transmitters and charge pump. — — 10 R2OUT RS-232 Driver Output 10 12 14 FAST — — 11 RO 11 13 — RS485/RS232 — — 12 RE485 RS-485/422 Receiver Enable. Logic-level low enables RS-485/422 receivers. 12 14 — HDPLX Software-Programmable Pin Functionality. Operates in full-duplex mode when low; operates in half-duplex mode when high. www.maximintegrated.com RS-232 Driver Output Select slew rate limiting for both RS-232 and RS485/422. Slew rate limits with a logic-level low. RS-485/422 Receiver Output Software-Programmable Pin Functionality. Operates as RS-485/422 with a logic-level high; operates as RS-232 with a logic-level low. Maxim Integrated | 8 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers Pin Description (continued) PIN NAME FUNCTION MAX3160 MAX3161 MAX3162 13 — — A/R2IN Noninverting RS-485/422 Receiver Input/RS-232 Receiver Input 14 — — B/R1IN Inverting RS-485/422 Receiver Input/RS-232 Receiver Input — — 15 RE232 RS-232 Receiver Enable. Logic-level low enables RS232 receivers. — 15 17 A 15 19 — DE485/T2IN — — 16 TE232 — 16 18 B 16 20 — DI/T1IN — 17 19 R2IN 17 21 25 V- Noninverting RS-485/422 Receiver Input RS-485/RS-422 Driver Enable/RS-232 Driver Input RS-232 Transmitter Output Enable Inverting RS-485/422 Receiver Input RS-485/RS-422 Driver Input/RS-232 Driver Input RS-232 Receiver Input Negative Charge-Pump Rail — 18 20 R1IN 18 22 26 C2- Negative Terminal of the Negative Flying Capacitor 19 23 27 C2+ Positive Terminal of the Negative Flying Capacitor 20 24 28 V+ — — 21 T2IN — — 22 DE485 — — 23 DI — — 24 T1IN www.maximintegrated.com RS-232 Receiver Input Positive Charge-Pump Rail RS-232 Driver Input RS-485/RS-422 Driver Enable RS-485/RS-422 Driver Input RS-232 Driver Input Maxim Integrated | 9 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers MAX3160/MAX3161/MAX3162 Functional Diagrams MAX3160 RS-232 MODE RS-485 MODE VCC VCC 1 C1+ V+ 20 1 C3 C1 2 3 VCC C2+ CHARGE PUMP C1- C1 19 2 C2 C2- 3 18 CBYPASS CBYPASS 4 GND V- 4 17 C1+ V+ VCC C2+ C1- 5 6 LOGIC OUTPUTS 7 8 9 SHDN 10 FAST www.maximintegrated.com T1 T2 R1 R2 5 16 15 LOGIC INPUTS 13 HDPLX 12 RS485/RS232 11 RS-485 OUTPUTS VZ 6 RS-232 INPUTS C3 18 17 9 SHDN 10 FAST C4 16 LOGIC INPUTS Y R0 LOGIC OUTPUT 8 C2 19 D 15 DE B 7 14 C2- GND C4 RS-232 OUTPUTS CHARGE PUMP 20 R A 14 RS-485 INPUTS 13 12 HALF/FULL DUPLEX RS485/RS232 11 Maxim Integrated | 10 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers Functional Diagrams (continued) MAX3161 RS-232 MODE RS-485 MODE VCC VCC 1 C1+ V+ 1 24 C3 C1 2 3 VCC C2+ CHARGE PUMP C1- 23 2 3 22 CBYPASS CBYPASS 4 GND V- 4 21 V+ VCC C2+ 24 C3 C1 C2 C2- C1+ CHARGE PUMP C1- C2- GND V- 23 C2 22 21 C4 RS-232 OUTPUT RS-232 OUTPUT 5 T1 6 19 7 18 8 9 LOGIC OUTPUTS 10 11 SHDN 12 FAST www.maximintegrated.com T2 R1 R2 5 20 17 16 15 HDPLX 14 RS485/RS232 13 LOGIC INPUTS 6 RS-485 OUTPUTS 20 LOGIC INPUTS Z 19 D 7 RS-232 INPUTS C4 Y 18 DE 8 17 B 9 R0 LOGIC OUTPUT 10 11 SHDN 12 FAST R A 16 RS-485 INPUTS 15 14 HALF/FULL DUPLEX RS485/RS232 13 Maxim Integrated | 11 MAX3160/MAX3161/MAX3162 Functional Diagrams (continued) +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers Test Circuits MAX3162 Y R VOD VCC 1 C1+ V+ R 28 VOC C3 C1 2 3 VCC C2+ CHARGE PUMP C1- C2- Z 27 C2 Figure 1. RS-485/422 Driver DC Test Load 26 CBYPASS 4 GND V- 6 7 C4 T1 RS-232 5 OUTPUT RS-485 OUTPUTS 25 24 Z 23 D Y DE485 LOGIC INPUTS RECEIVER OUTPUT 22 1k TEST POINT VCC S1 CL 1k T2 RS-232 8 OUTPUT 211 S2 R1 9 LOGIC OUTPUTS 10 20 RS-232 INPUTS R2 B 11 RO 12 Figure 2. RS-485/422 Receiver Enable/Disable Timing Test Load 19 RE485 13 SHDN 14 FAST 18 RS-485 INPUTS R A 17 3V TE232 16 DE485 CL 15 DI Y VOD RDIFF Z CL Figure 3. RS-485/422 Driver Timing Test Circuit www.maximintegrated.com Maxim Integrated | 12 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers Test Circuits (continued) 3V DI 1.5V 0 500Ω OUTPUT UNDER TEST 1.5V tDPHL tDPLH 1/2 VO VCC S1 Z VO Y CL S2 VDIFF VO 0 -VO 1/2 VO 10% VDIFF = Vy - Vz 90% 90% TDR 10% TDF tDSKEW = | tDPLH - tDPHL | Figure 4. RS-485/422 Driver Enable/Disable Timing Test Load 3V DE485 0 1.5V 1.5V tDZL tDLZ RO Y, Z 2.3V OUTPUT NORMALLY LOW VOL tDZH 1V A -1V B VCC/2 VCC/2 OUTPUT tRPHL tRPLH INPUT tDHZ Figure 6. RS-485/422 Driver Enable and Disable Times 1.5V Figure 7. RS-485/422 Receiver Propagation Delays 1.5V tRZL B tRLZ 1.5V OUTPUT NORMALLY LOW VOL + 0.5V OUTPUT NORMALLY HIGH RO VOL VOH -0.5V 2.3V 0 VCC RO VOH VOL +0.5V OUTPUT NORMALLY HIGH Y, Z 3V RE485 0 Figure 5. RS-485/422 Driver Propagation Delays VID R A RO CL VOH - 0.5V 1.5V 0 tRZH tRHZ Figure 8. MAX3162 RS-485/422 Receiver Enable and Disable Times www.maximintegrated.com Figure 9. RS-485/422 Receiver Propagation Delays Test Circuit Maxim Integrated | 13 MAX3160/MAX3161/MAX3162 Detailed Description The MAX3160/MAX3161/MAX3162 3V/5V, multiprotocol transceivers can be pin configured in a number of RS232 and RS-485/422 interface combinations. These circuit configurations are ideal for the design of RS-232 to RS-485 converters, multiprotocol buses, or any application that requires both RS-232 and RS-485 transceivers. The slew rate of these devices is on-the-fly pin programmable, allowing reduced EMI data rates, or up to 10Mbps RS-485 communications. Power consumption can be reduced to 1µA by using the shutdown function, but the RS-232 receivers remain active allowing other devices to query the interface controller. A flow-through pinout and the space-saving SSOP packages (available in the commercial and extended temperature ranges) facilitate board layout. Device Selection The MAX3160/MAX3161/MAX3162 contain RS-232 transceivers and an RS-485/422 transceiver. The primary difference between the devices is the multiplexing of the I/O pins. The MAX3160 has common transmitter outputs and receiver inputs for its RS-232 and RS-485/422 transceivers, and common digital I/O pins. The MAX3160 is optimized for multiprotocol operation on a single interface bus and comes in a 20-pin SSOP. The MAX3161 has separate transmitter outputs and receiver inputs for its RS-232 and RS-485/422 transceivers, and common digital I/O pins. The MAX3161 is optimized for multiplexing a single UART across two interface buses and comes in a 24-pin SSOP. The MAX3162 has separate transmitter outputs and receiver inputs for its RS-232 and RS-485/422 transceivers, and separate digital I/O pins. The MAX3162 is optimized for protocol translation between two interface buses and comes in a 28-pin SSOP. See Tables 1–12, Functional Diagrams, and the following descriptions for details on each device. MAX3160 The MAX3160 is a 2TX/2RX RS-232 transceiver in RS232 mode, capable of RS-232-compliant communication. Assertion of RS-485/RS232 converts the device to a single RS-485 transceiver by multiplexing the RS-232 I/O pins to an RS-485 driver and receiver pair. The logic inputs now control the driver input and the driver enable. One logic output carries the RS-485 receiver output, and the other is three-stated. The receiver input impedance is dependent on the device mode and is www.maximintegrated.com +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers 1/4-unit load for RS-485 operation and 5kΩ for RS-232 operation. MAX3161 The MAX3161 is a 2TX/2RX RS-232 transceiver in RS232 mode or a single RS-485/422 transceiver in RS-485 mode. When in RS-485 mode, the unused RS-232 transmitter and receiver output pins are disabled. When in RS232 mode, the RS-485 transmitter outputs are disabled and the RS-232 receiver inputs are 5kΩ to GND. The RS485 receiver inputs are always 1/8-unit load. Logic lines are shared between the two protocols and are used for signal inputs and as an RS-485 driver enable. MAX3162 The MAX3162 is a 2TX/2RX RS-232 transceiver and a single RS-485/422 transceiver simultaneously. All drivers, receivers, and transmitters can be enabled or disabled by pin configuration. All outputs are high-Z when not activated. RS-232 receiver inputs are 5kΩ when enabled, and RS-485 receiver inputs are 1/8-unit load. FAST Mode operation The FAST control pin is used to select the slew-rate limiting of the RS-232 transmitters and the RS-485/422 drivers. With FAST unasserted, the RS-232 transmitters and the RS-485/422 driver are slew-rate limited to reduce EMI. RS-232 data rates up to 1Mbps and RS485/422 data rates up to 10Mbps are possible when FAST is asserted. FAST can be changed during operation without interrupting data communications. Half-Duplex RS-485/422 Operation Asserting HDPLX places the MAX3160/MAX3161 in half-duplex mode. The RS-485 receiver inputs are internally connected to the driver outputs. The RS-485 driver outputs can be disabled by pulling DE485 low. HDPLX has no affect on RS-232 operation. Low-Power Shutdown The MAX3160/MAX3161/MAX3162 have an active-low shutdown control input, SHDN. When driven low, the charge pump and transmitters are shut down and supply current is reduced to 1µA. The RS-232 receiver outputs remain active if in RS-232 mode. The chargepump capacitors must be recharged when coming out of shutdown before resuming operation in either RS-232 or RS-485/422 mode (Figure 10). Dual Charge-Pump Voltage Converter The MAX3160/MAX3161/MAX3162s’ internal power supply consists of a regulated dual charge pump that provides output voltages of +5.5V (doubling charge pump) and -5.5V (inverting charge pump) for input voltages (VCC) over the 3.0V to 5.5V range. The charge Maxim Integrated | 14 MAX3160/MAX3161/MAX3162 pumps operate in a discontinuous mode: if the magnitude of either output voltage is less than 5.5V, the charge pumps are enabled; if the magnitude of both output voltages exceeds 5.5V, the charge pumps are disabled. Each charge pump requires a flying capacitor (C1, C2) and a reservoir capacitor (C3, C4) to generate the V+ and V- supplies (see Functional Diagrams). RS-485/422 Transceivers The MAX3160/MAX3161/MAX3162 RS-485/422 transceivers feature fail-safe circuitry that guarantees a logic-high receiver output when the receiver inputs are open or shorted, or when they are connected to a terminated transmission line with all drivers disabled (see Fail-Safe). The MAX3160/MAX3161/MAX3162 also feature pin-selectable reduced slew-rate drivers that minimize EMI and reduce reflections caused by improperly terminated cables, allowing error-free data transmission up to 250kbps (see RS-485/422 Reduced EMI and Reflections). The transmitters may operate at speeds up to 10Mbps with the slew-rate limiting disabled. Drivers are short-circuit current limited and thermally limited to protect them against excessive power dissipation. Half-duplex communication is enabled by driving HDPLX high. Fail-Safe The MAX3160/MAX3161/MAX3162 guarantee a logichigh RS-485 receiver output when the receiver inputs are shorted or open, or when they are connected to a terminated transmission line with all drivers disabled. This is done by having the receiver threshold between -50mV and -200mV. If the differential receiver input voltage (A-B) is greater than or equal to -50mV, RO is logic high. If A-B is less than or equal to -200mV, RO is logic low. In the case of a terminated bus with all transmitters disabled, the receiver’s differential input voltage is pulled to GND by the termination. This results in a logic high with a 50mV minimum noise margin. Unlike other fail-safe devices, the -50mV to -200mV threshold complies with the ±200mV EIA/TIA-485 standard. RS-232 Transceivers The MAX3160/MAX3161/MAX3162 RS-232 transmitters are inverting-level translators that convert CMOS-logic levels to ±5.0V EIA/TIA-232-compliant levels. The transmitters are guaranteed at a 250kbps data rate in slewrate limited mode (FAST = GND) with worst-case loads of 3kΩ in parallel with 1000pF. Data rates up to 1Mbps can be achieved by asserting FAST. When powered down or in shutdown, the MAX3160/ MAX3161/MAX3162 outputs are high impedance and can be driven to ±12V. The transmitter inputs do not www.maximintegrated.com +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers have pullup resistors. Connect unused inputs to ground or VCC. The receivers convert RS-232 signals to CMOS-logic output levels. All receivers have inverting outputs that remain active in shutdown. The MAX3160/MAX3161/ MAX3162 permit their receiver inputs to be driven to Dia ±25V. Floating receiver input signals are pulled to ground through internal 5kΩ resistors, forcing the outputs to a logic high. The MAX3162 has transmitter and receiver enable pins that allow its outputs to be three-stated. Applications Information Capacitor Selection The capacitor type used for C1–C4 is not critical for proper operation; polarized or nonpolarized capacitors can be used. Ceramic chip capacitors with an X7R dielectric provide the best combination of performance, cost, and size. The charge pump requires 0.1µF capacitors for 3.3V operation. For other supply voltages, see Table 13 for required capacitor values. Do not use values smaller than those listed in Table 13. Increasing the capacitor values reduces ripple on the transmitter outputs and slightly reduces power consumption. C2, C3, and C4 can be changed without changing C1’s value. However, do not increase C1 without also increasing the values of C2, C3, C4, and CBYPASS to maintain the proper ratios to the other capacitors. When using the minimum required capacitor values, make sure the capacitance value does not degrade excessively with temperature or voltage. This is typical of Y5V and Z5U dielectric ceramic capacitors. If in doubt, use capacitors with a larger nominal value. The capacitor’s equivalent series resistance (ESR), which usually rises at low temperatures, influences the amount of ripple on V+ and V-. Power-Supply Decoupling In applications that are sensitive to power-supply noise, decouple VCC to ground with a capacitor of the same value as reservoir capacitors C2, C3, and C4. Connect the bypass capacitor as close to the IC as possible. RS-232 Transmitter Outputs when Exiting Shutdown Figure 10 shows two transmitter outputs when exiting shutdown mode. As they become active, the two transmitter outputs are shown going to opposite RS-232 levels (one transmitter input is high, the other is low). Each transmitter is loaded with 3kΩ in parallel with 1000pF. The transmitter outputs display no ringing or undesirable transients as they come out of shutdown. Note that the transmitters are enabled only when V- exceeds approximately -3V. Maxim Integrated | 15 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers Truth Tables RS-232 Transmitters RS-232 Receivers Table 1. MAX3160 Table 4. MAX3160 INPUTS OUTPUTS INPUTS OUTPUTS SHDN RS485 RS232 DI/T1IN, DE485/T2IN Z(B)/T1OUT, Y(A)/T2OUT SHDN RS-485/ RS-232 B/R1IN, A/R2IN R1OUT, RO/R2OUT 0 X X 1/8 Unit Load X 0 0 1 1 0 0 1 X 0 1 0 1 0 1 0 X 0 Inputs Open 1 1 X RS-485 Mode X Table 2. MAX3161 INPUTS OUTPUTS SHDN RS-485/ RS-232 DI/T1IN, DE485/T2IN T1OUT, T2OUT 0 X X High-Z 1 0 0 1 1 0 1 1 1 X 1 X SHDN TE232 T1IN,T2IN 0 X 1 1 X 0 1 1 X X 0 1 INPUTS OUTPUTS SHDN RS-485/ RS-232 R1IN, R2IN R1OUT, RO/R2OUT 0 X 0 0 1 High-Z X 0 1 0 X 0 Inputs Open 1 OUTPUTS T1OUT, T2OUT High-Z High-Z 1 0 High Data Rates The MAX3160/MAX3161/MAX3162 maintain the RS-232 ±5.0V required minimum transmitter output voltage even at high data rates. Figure 11 shows a transmitter loopback test circuit. Figure 12 shows a loopback test result at 250kbps, and Figure 13 shows the same test at 1000kbps. Figure 12 demonstrates a single slew-rate limited transmitter driven at 250kbps (FAST = GND) into an RS-232 load in parallel with 1000pF. Figure 13 shows a single transmitter driven at 1Mbps (FAST asserted), loaded with an RS-232 receiver in parallel with 1000pF. These transceivers maintain the RS-232 ±5.0V minimum transmitter output voltage at data rates up to 1Mbps. www.maximintegrated.com RO/R2OUT in RS-485 mode Table 5. MAX3161 Table 3. MAX3162 INPUTS 1 R1OUT High-Z, X 1 X R1OUT High-Z, RO/R2OUT in RS-485 mode Table 6. MAX3162 INPUTS OUTPUTS SHDN RE232 R1IN, R2IN R1OUT, R2OUT X 1 X High-Z X 0 0 1 X 0 1 0 X 0 Inputs open 1 256 Transceivers on the Bus The standard RS-485 receiver input impedance is 12kΩ (one-unit load), and the standard driver can drive up to 32-unit loads. The MAX3160 has a 1/4-unit load receiver input impedance (48kΩ), allowing up to 128 transceivers to be connected in parallel on one communication line. The MAX3161/MAX3162 have a 1/8-unit load receiver input impedance (96kΩ), allowing up to 256 transceivers to be connected in parallel on Maxim Integrated | 16 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers MAX3160/MAX3161/MAX3162 Truth Tables (continued) RS-485/422 Drivers Table 7. MAX3160 INPUTS OUTPUTS SHDN RS232 RS485/R DE485/T2IN DI/T1IN Z(B)/T1OUT Y(A)/T2OUT 0 1 X X 1/8 Unit Load 1/8 Unit Load 1 1 0 X 1/8 Unit Load 1/8 Unit Load 1 1 1 0 1 0 1 1 1 1 0 1 X 0 X X RS-232 Mode Table 8. MAX3161 INPUTS OUTPUTS SHDN RS232 RS485/R DE485/T2IN DI/T1IN Z(B) Y(A) 0 X X X 1/8 Unit Load 1/8 Unit Load X 0 X X 1/8 Unit Load 1/8 Unit Load X X 0 X 1/8 Unit Load 1/8 Unit Load 1 1 1 0 1 0 1 1 1 1 0 1 Table 9. MAX3162 INPUTS OUTPUTS SHDN DE485 DI Z Y 0 X X High-Z High-Z X 0 X High-Z High-Z 1 1 0 1 0 1 1 1 0 1 RS-485/422 Receivers Table 10. MAX3160 INPUTS OUTPUT RS485/RS232 SHDN HDPLX A - B* Y - Z* RO/R2OUT 1 0 X X X High-Z Up to VCC 1 1 0 ≥-50mV X 1 1 1 0 ≤-200mV X 0 1 1 0 Floating X 1 1 1 1 X ≥-50mV 1 1 1 1 X ≤-200mV 0 1 1 1 X Floating 1 0 X X X X RS-232 Mode *Y and Z correspond to pins Y(A)/T2OUT and Z(B)/T1OUT. A and B correspond to pins A/R2IN and B/R1IN. www.maximintegrated.com Maxim Integrated | 17 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers MAX3160/MAX3161/MAX3162 Truth Tables (continued) Table 11. MAX3161 INPUTS OUTPUT RS485/RS232 SHDN HDPLX A-B Y(A) - Z(B) RO/R2OUT 1 0 X X X High-Z up to VCC 1 1 0 -50mV X 1 1 1 0 -200mV X 0 1 1 0 Floating X 1 1 1 1 X -50mV 1 1 1 1 X -200mV 0 1 1 1 X Floating 1 0 X X X X RS-232 Mode Table 12. MAX3162 INPUTS OUTPUT SHDN RE485 A-B RO 0 X X High-Z X 1 X High-Z 1 0 -50mV 1 1 0 -200mV 0 1 0 Inputs Open 1 one communication line. Any combination of these devices and/or other RS-485 transceivers with a total of 32-unit loads or fewer can be connected to the line. The MAX3160/MAX3161/MAX3162 RS-485 driver outputs are 1/8-unit load when disabled This impedance may be reduced if the D1 pin is toggled at a high frequency. With no power applied (VCC = GND), the RS485 transmitter output impedances typically go to 1/2unit load on the MAX3161/MAX3162, and to one-unit load on the MAX3160. Driver Output Protection Two mechanisms prevent excessive output current and power dissipation caused by faults or by bus contention. The first, a foldback current limit on the output stage, provides immediate protection against short circuits over the whole common-mode voltage range (see Typical Operating Characteristics). The second, a ther- www.maximintegrated.com Table 13. Required Minimum Capacitance Values SUPPLY VOLTAGE (V) C1 (µF) C2, C3, C4, CBYPASS (µF) +3.0 TO +3.6 0.1 0.1 +4.5 TO +5.5 0.047 0.33 +3.0 TO +5.5 0.1 0.47 mal shutdown circuit, forces the driver outputs into a high-impedance state if the die temperature becomes excessive. Protection Against Wiring Faults EIA/TIA-485 standards require a common input voltage range of -7V to +12V to prevent damage to the device. The MAX3160/MAX3161/MAX3162 inputs are protected to RS-232 levels of ±25V for the receiver inputs and ±13.2V for the transmitter/driver outputs. This provides additional protection for the RS-485 transceivers against ground differential or faults due to miswiring. RS-485/422 Reduced EMI and Reflections The MAX3160/MAX3161/MAX3162 can be configured for slew-rate limiting by pulling FAST low. This minimizes EMI and reduces reflections caused by improperly terminated cables. Operation in slew-rate limited mode reduces the amplitudes of high-frequency harmonics. Maxim Integrated | 18 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers MAX 3160-2 FIG10 MAX 3160-2 FIG12 SHDN 5V/division TIN T1OUT 2V/div TOUT GND 5V/div T2OUT 2V/div ROUT 40μs/div 1μs/div Figure 10. MAX3160 RS-232 Transmitter Outputs When Exiting Shutdown Figure 12. RS-232 Loopback Test Result at 250kbps, FAST = Low MAX 3160-2 FIG13 VCC CBYPASS TIN VCC C1+ TOUT V+ C1 C3 C1C2+ C2 C2- MAX3160 MAX3161 MAX3162 5V/div VC4 ROUT T_ OUT T_ IN 200ns/div Figure 13. RS-232 Loopback Test Result at 1000kbps, FAST = High R_ IN R_ OUT 1000pF 5k VCC SHDN GND Figure 11. Loopback Test Circuit RS-485/422 Line Length vs. Data Length The RS-485/422 standard covers line lengths up to 4000 feet. For line lengths greater than 4000 feet, use the repeater application shown in Figure 14. RS-232/RS-485 Protocol Translator Figure 15 shows the MAX3162 configured as an RS232/RS-485 protocol translator. The direction of transla- tion is controlled through the RTS signal (R1IN). The single-ended RS-232 receiver input signal is translated to a differential RS-485 transmitter output. Similarly, a differential RS-485 receiver input signal is translated to a single-ended RS-232 transmitter output. RS-232 data received on R2IN is transmitted as an RS-485 signal on Z and Y. RS-485 signals received on A and B are transmitted as an RS-232 signal on T1OUT. Multiprotocol Bus The Typical Operating Circuit shows a standard application for the MAX3160. The MAX3160’s output pins are multiplexed between RS-232 and RS-485 protocols by a microprocessor (µP). The µP also directs the shutdown functions, enable lines, and the duplex of the MAX3160. Data is transmitted to the MAX3100 UART SPI is a trademark of Motorola, Inc. www.maximintegrated.com Maxim Integrated | 19 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers 3.3V MAX3160 MAX3161 MAX3162 CBYPASS 100nF A 120Ω RO R RE485 DATA IN B 2 27 C2 100nF DE485 Z DI D 26 120Ω Y 13 DATA OUT 5 RCV 10 23 NOTE: RE485 ON MAX3162 ONLY 19 TX 20 RTS 15 Figure 14. RS-485 Line Repeater 16 14 through an SPI™ port. The UART asynchronously transfers data through the MAX3160 to the pin-selected RS-232 or RS-485 protocol; see Table 14 for commonly used cable connections. 28 C2+ VCC C1+ 1 C1 100nF MAX3162 C1- 3 C2SHDN T1OUT T1IN 24 R2IN 11 RO 9 R1OUT 12 RE485 22 DE485 R1IN A RE232 B TE232 Z FAST Y R2OUT DI V+ C3 100nF GND 4 V- 17 18 6 7 25 C4 100nF Multiprotocol Bus Multiplexer The Typical Application Circuit shows the MAX3161 configured as a multiprotocol bus multiplexer. The MAX3161 separates the RS-232 and RS-485 lines, but shares the logic pins between modes. This application allows the µP to monitor a point-to-point RS-232 bus, and a multidrop RS-485 interface. The MAX3100 UART asynchronously transfers data through the MAX3161 to the pin-selected RS-232 or RS-485 protocol. www.maximintegrated.com Figure 15. Protocol Translator Maxim Integrated | 20 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers MAX3160/MAX3161/MAX3162 Table 14. Cable Connections Commonly Used for EIA/TIA-232 and V.24 Asynchronous Interfaces EIA/TIA-232 STANDARD CONNECTOR PIN DCD MAX3160 MAX3161 MAX3162 EQUIVALENT PIN NUMBER MAX3160 MAX3161 FUNCTION (as seen by DTE) MAX3162 1 Data Carrier Detect RD 2 R2IN 13 17 19 TD 3 T1OUT 5 5 5 Received Data DTR 4 SG 5 DSR 6 RTS 7 T2OUT 6 8 8 Request to Send (= DTE ready) CTS 8 R1IN 14 18 20 Clear to Send (= DCE ready) RI 9 Transmitted Data Data Terminal Ready GND 4 4 4 Signal Ground Data Set Ready Ring Indicator Typical Application Circuit + 2 VCC TX 13 MAX3100 UART RX 12 RTS DB9 T1OUT 5 DI/T1IN 20 RO/R2OUT 10 DE/T2IN 11 MAX3161 R1OUT 9 18 1 SPI GND 4 μP RS-232 R2IN 17 T2OUT 8 R1IN 19 CTS 10 14 HDPLX FAST 12 SHDN Y(A) 7 Z(B) 6 RS-485 RJ45 RS-485/RS-232 SHDN www.maximintegrated.com Maxim Integrated | 21 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers MAX3160/MAX3161/MAX3162 Pin Configurations TOP VIEW + + + C1+ 1 20 V+ C1+ 1 24 V+ C1+ 1 28 V+ VCC 2 19 C2+ VCC 2 23 C2+ VCC 2 27 C2+ C1- 3 18 C2- C1- 3 22 C2- C1- 3 26 C2- 21 V- GND 4 25 V- GND 4 Z(B)/T1OUT 5 GND 4 17 V- MAX3160 Y(A)/T2OUT 6 16 DI/T1IN 15 DE485/T2IN T1OUT 5 MAX3161 20 DI/T1IN Z(B) 6 19 DE485/T2IN T1OUT 5 24 T1IN MAX3162 Z 6 23 DI 22 DE485 R1OUT 7 14 B/R1IN Y(A) 7 18 R1IN Y 7 RO/R2OUT 8 13 A/R2IN T2OUT 8 17 R2IN T2OUT 8 21 T2IN SHDN 9 12 HDPLX R1OUT 9 16 B R1OUT 9 20 R1IN FAST 10 11 RS-485/RS-232 RO/R2OUT 10 15 A R2OUT 10 19 R2IN 20-PIN SSOP SHDN 11 14 HDPLX FAST 12 13 RS-485/RS-232 24-PIN SSOP RO 11 18 B RE485 12 17 A SHDN 13 16 TE232 FAST 14 15 RE232 28-PIN SSOP Selector Guide Chip Information PART DUAL-MODE FLOWTHROUGH PIN-OUT RS-485 INPUT UNIT LOADS MAX3160 No Yes 1/4 MAX3161 No No 1/8 MAX3162 Yes Yes 1/8 www.maximintegrated.com PROCESS: BiCMOS Package Information For the latest package outline information and land patterns (footprints), go to www.maximintegrated.com/packages. Note that a “+”, “#”, or “-” in the package code indicates RoHS status only. Package drawings may show a different suffix character, but the drawing pertains to the package regardless of RoHS status. PACKAGE TYPE PACKAGE CODE DOCUMENT NO. 20 SSOP A20+1 21-0056 24 SSOP A24+3 21-0056 28 SSOP A28+3 21-0056 Maxim Integrated | 22 MAX3160/MAX3161/MAX3162 +3.0V to+5.5V, 1µA, RS-232/ RS-485/422 Multiprotocol Transceivers Revision History REVISION NUMBER 2 3 REVISION DATE 12/09 5/15 PAGES CHANGED DESCRIPTION Corrected the “Continuous Power Dissipation” specifications under the Absolute Maximum Ratings. 2 Changed pin labels in the Functional Diagrams. 11 Deleted “TRANSISTOR COUNT: 1580” and added “PROCESS: BiCMOS” to the Chip Information. 22 Updated the General Description and Benefits and Features sections 1 For pricing, delivery, and ordering information, please contact Maxim Direct at 1-888-629-4642, or visit Maxim Integrated’s website at www.maximintegrated.com. Maxim Integrated cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in a Maxim Integrated product. No circuit patent licenses are implied. Maxim Integrated reserves the right to change the circuitry and specifications without notice at any time. The parametric values (min and max limits) shown in the Electrical Characteristics table are guaranteed. Other parametric values quoted in this data sheet are provided for guidance. Maxim Integrated and the Maxim Integrated logo are trademarks of Maxim Integrated Products, Inc. © 2015 Maxim Integrated Products, Inc. | 23
MAX3160CAP+ 价格&库存
很抱歉,暂时无法提供与“MAX3160CAP+”相匹配的价格&库存,您可以联系我们找货
