7V-25.000MAAE-T
7V-25.000MAAE-T
    TXC(台晶)
    SMD3225_4P
    无源晶振 25MHz ±30ppm 12pF 60Ω -20℃~+70℃
7V-25.000MAAE-T 数据手册
7V MHz Crystal Features Frequency range : 8MHz to 54MHz Glass sealing, ceramic SMD package External dimensions (mm) L : 3.2 x W : 2.5 x H : 0.8 RoHS compliant Contains Pb, exempted by RoHS directive Applications PC, TV, Game, Camera Notebook, Hard disk Computer peripherals Home electronics Consumer products Electrical Characteristics Item 7V Frequency Range F0 8MHz ~ 54MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±50 ppm ±30 ppm ±20 ppm ±60 ppm -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 3pF Max. Drive Level DL 1 ~ 50μW (10μW Typ.) Load Capacitance CL 6pF, 7pF, 8pF, 9pF, 10pF 12pF, 16pF, 18pF, 20pF Aging Faging ±3 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C at 25°C ± 3°C,first year Motional Resistance (ESR) Fundamental 8~9 9 ~ 10 10 ~ 12 12 ~ 16 16 ~ 54 Rev. 1.06 MHz MHz MHz MHz MHz 350Ω 200Ω 150Ω 100Ω 60Ω Max. Max. Max. Max. Max. Page 1 www.txccrystal.com 7V MHz Crystal Dimensions THK Note [1] Note: [1] THK = 0.8 ± 0.1mm except F0 = 8MHz. THK = 0.9 ± 0.1mm for F0 = 8MHz. Ordering Information 7V - 27.000M A H E Frequency in Hz - T Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E ± 30 ppm ± 20 ppm ± 10 ppm Frequency Stability (over Temp.) A D E T G H I K Rev. 1.06 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 50 ppm ± 30 ppm ± 20 ppm ± 60 ppm B Y V C Q E I J 6 pF 7 pF 8 pF 9 pF 10 pF 12 pF 16 pF 18 pF ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.txccrystal.com 7V MHz Crystal Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 5°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.06 60 sec Page 3 Time (sec) www.txccrystal.com
7V-25.000MAAE-T 价格&库存
很抱歉,暂时无法提供与“7V-25.000MAAE-T”相匹配的价格&库存,您可以联系我们找货
7V-25.000MAAE-T
  • 1000+2.28780
  • 3000+2.14885
  • 6000+2.14167
  • 9000+2.11651
  • 15000+2.10094
  • 21000+2.09256
7V-25.000MAAE-T
  • 1000+2.463041000+0.31866
  • 3000+2.314563000+0.29945
  • 6000+2.305836000+0.29832
  • 9000+2.279639000+0.29493
  • 15000+2.2621615000+0.29267
  • 21000+2.2534221000+0.29154
7V-25.000MAAE-T
  • 3000+3.837683000+0.49651
  • 6000+3.679096000+0.47599
  • 9000+3.589459000+0.46439
  • 15000+3.4796715000+0.45019
  • 21000+3.4092521000+0.44108
7V-25.000MAAE-T
