DCK-3R3E224U-E
DCK-3R3E224U-E
    ELNA(伊娜)
    CAP_D6.8X2.6MM_SM
    超级电容器 DIP 220mF -20~+80% 3.3V
DCK-3R3E224U-E 数据手册
DC,DCK Coin Cell Capacitors ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP” GREEN 60˚C CAP 70˚C • Small-sized, but large capacity. • Unlike batteries, unlimited charge/discharge cycles; ideal for solar watches, solar calculators, solar remote control units, camaras and the like. Coin Cell DB DC For higher voltage tolerant DCK Specifications Item Performance Series Name DC series Rated voltage (V) 2.5 DCK series 3.3 Category temperature range (˚C) −25 to +70 −10 to +60 Tolerance at rated capacitance (%) −20 to +80 −20 to +80 Rated Capacitance (F) Internal resistance(Ω) at 1 kHz 0.22 0.22 100 200 Characteristics at high Percentage of capacitance change Within ±30% of the value at 20˚C Percentage of capacitance change Within ±50% of the value at 20˚C and low temperature Internal resistance Less than five times of the value at 20˚C Internal resistance Within five times the initial specified value Test temperature 70˚C Test temperature 60˚C Test time 1000 hours Test time 1000 hours Percentage of capacitance change Within ±30% of the initial measured value Percentage of capacitance change Within ±30% of the initial measured value Internal resistance Within four times of the initial specified value Internal resistance Within four times of the initial specified value Endurance Test time :1000 hours ; Same as endurance. Shelf life Outline Drawing Unit: mm Terminal shaped: D Terminal shaped: E 2.6MAX 2.3MAX 6.8 L±0.2 D±0.2 Sn+Cu plated 1.7±0.3 2.5± 0.3 0.5 0.15±0.05 0.5±0.1 2.0±0.3 Part numbering system (example: 2.5V0.22F, terminal shaped: E) DC — 2R5 Rated voltage symbol Series code E Part numbering system (example: 3.3V0.22F, terminal shaped: E) — E 224 Rated capacitance symbol DCK Additional symbol — 3R3 Rated voltage symbol Series code E — E 224 Rated capacitance symbol Additional symbol Part number is refer to below table. Standard Ratings Max. operating voltage(V) Rated capacitance(F) ELNA Parts No. ø DxL(mm) DC-2R5D224 2.5 0.22 6.8x2.1 DC-2R5E224U-E DCK-3R3D224 3.3 0.22 6.8x2.1 DCK-3R3E224U-E CAT.No.2005/2006E(2005.10.1) 148 NOTE Design, Specifications are subject to change without notice. Ask factory for technical specifications before purchase and/or use.
DCK-3R3E224U-E
1. 物料型号:文档提到了两种型号的电容器,分别是DC系列和DCK系列。 2. 器件简介:电容器具有小尺寸大容量的特点,不同于电池,它们可以无限次充放电,适用于太阳能手表、计算器、遥控器、相机等。 3. 引脚分配:引脚形状有D型和E型,尺寸和公差也有具体说明。 4. 参数特性: - DC系列:额定电压25V,容量0.22F,工作温度范围-25°C至+70°C。 - DCK系列:额定电压3.3V,容量0.22F,工作温度范围-10°C至+60°C。 - 两种系列的电容器在高低温下的特性变化、内部电阻以及耐久性测试都有详细描述。 5. 功能详解:电容器在不同温度下的性能变化、内部电阻以及耐久性测试结果。 6. 应用信息:适用于太阳能设备,如手表、计算器、遥控器和相机。 7. 封装信息:提供了电容器的外形图,包括尺寸和引脚镀层信息,以及部分编号系统。
DCK-3R3E224U-E 价格&库存
很抱歉,暂时无法提供与“DCK-3R3E224U-E”相匹配的价格&库存,您可以联系我们找货
