PPTC022LFBN-RC
PPTC022LFBN-RC
    SULLINS
    插件,P=2.54mm
    排母 间距:2.54mm 2x2P 直插
PPTC022LFBN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY 3963 UPDATE GENERAL TOL IN TITLE BOX & NOTE 8, UPGRADE NYLON MTL (FROM 6T TO 9T), UPDATE TAIL-TO-TAIL & TAIL PITCH/ROW SPACING DIM TO REF, ADD REF TO INSERTION DEPTH 1/3/2019 JH ADD LCP 8/20/2019 K F L 4099 F JH B .014[ 0.35] A .008[ 0.20] .100 2.54 E E DUAL ROWS .100 2.54 B .014[ 0.35] SINGLE ROW D .090 2.29 D .236 6.00 .200 5.08 .100 2.54 .335 8.50 C C .126±.012 3.20±0.30 .100 2.54 .030±.002 0.75±0.05 .016±.002 0.40±0.05 A 02-20, .008[0.20] MAX. 21-30, .012[0.30] MAX. 31-40, .016[0.40] MAX. A .100 2.54 .100 2.54 7 B .100 2.54 .040±.002 1.02±0.05 NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. RECOMMENDED PCB LAYOUT 2. CONTACT MATERIAL: .PHOSPHOR BRONZE. SINGLE ROW 3. CONTACT PLATING: SEE PART NUMBER CODING. TOLERANCE: .002[ 0.05] 4. CURRENT RATING: 3 AMPS. 5. VOLTAGE RATING: 250V AC 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING: 1000 VAC. 9. OPERATING TEMPERATURE: SEE PART NUMBER CODING 10. PROCESSING TEMP.: SEE PART NUMBER CODING. 11. MATES WITH SULLINS .100 [2.54] CONTACT CENTER MALE HEADER SERIES. (.025 [0.64] SQUARE POSTS) 8 .100 2.54 A .004[ 0.10] A .004[ 0.10] B .016±.002 0.40±0.05 .126±.008 3.20±0.20 6 5 .040±.002 1.02±0.05 RECOMMENDED PCB LAYOUT DUAL ROWS TOLERANCE: .002[ 0.05] Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 12/15/2008 JH TOLERANCES: ANGULAR: 5 DECIMALS .XX= .012 [.3] .XXX= .008 [.20] .XXXX= .0039 [.100] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER FEMALE, 2.54mm CC, ST PART NUMBER SIZE C 2 _P_C_ _ _LFBN-RC CAGE CODE 54453 SCALE: 16:1 3 A DWG. NO. 10492 SHEET 1 OF 1 1 REV L FILE NAME: 10492, _ _P_C_ _ _LFBN-RC
PPTC022LFBN-RC 价格&库存
很抱歉,暂时无法提供与“PPTC022LFBN-RC”相匹配的价格&库存,您可以联系我们找货
PPTC022LFBN-RC
  • 1+5.026881+0.65335
  • 10+4.2360310+0.55056
  • 100+3.60004100+0.46790
  • 500+3.21298500+0.41759
  • 1000+3.059491000+0.39765
  • 5000+2.730955000+0.35495
  • 10000+2.6006710000+0.33801
库存:3633
PPTC022LFBN-RC
    • 1+1.98893
    • 200+0.76972
    • 500+0.74272
    • 1000+0.72933
