VAF505
VAF505
    COSEL
    DIP5
    VAF505
VAF505 数据手册
AC-DC Power Supplies PCB Mount Type VAF5 Ordering information VAF 1 5 2 05 3 1 Series name 2 Output wattage 3 Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT VAF503 3.3 VOLTAGE[V] 3.3 CURRENT[A] 1.0 (Peak 1.2) VAF505 5.0 5 1.0 (Peak 1.2) VAF512 5.4 12 0.45 (Peak 0.54) VAF515 5.25 15 0.35 (Peak 0.42) VAF524 5.28 24 0.22 (Peak 0.27) SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] INPUT ACIN 100V ACIN 200V FREQUENCY[Hz] ACIN 100V ACIN 200V LEAKAGE CURRENT[mA] EFFICIENCY[%] VOLTAGE[V] *1 CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +55C *2 RIPPLE[mVp-p] -10 - 0C *2 Io=100 - 120% *2 0 to +55C *2 OUTPUT RIPPLE NOISE[mVp-p] -10 - 0C *2 Io=100 - 120% *2 TEMPERATURE COEFFICIENT[mV] -10 to +55C *3 DRIFT[mV] OUTPUT VOLTAGE SETTING[V] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] START-UP TIME[ms] HOLD-UP TIME[ms] PROTECTION OVERCURRENT PROTECTION CIRCUIT OVERVOLTAGE PROTECTION INPUT-OUTPUT ISOLATION INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AND AGENCY APPROVALS NOISE REGULATIONS CONDUCTED NOISE CASE SIZE/WEIGHT OTHERS COOLING METHOD INRUSH CURRENT[A] VAF503 VAF505 VAF512 VAF515 VAF524 AC85 - 264 1f or DC110 - 370 0.15typ (Io=100%) 0.10typ (Io=100%) 47 - 440 or DC 15typ (Io=100%) 30typ (Io=100%) 0.5max (60Hz, According to IEC62368-1 and DEN-AN) 68typ 77typ 78typ 78typ 81typ 3.3 5 12 15 24 1.0 (Peak 1.2) 1.0 (Peak 1.2) 0.45 (Peak 0.54) 0.35 (Peak 0.42) 0.22 (Peak 0.27) 20max 20max 48max 60max 96max 40max 40max 100max 120max 150max 80max 80max 120max 120max 150max 140max 140max 160max 160max 200max 180max 180max 200max 200max 240max 120max 120max 150max 150max 200max 160max 160max 180max 180max 230max 200max 200max 220max 220max 260max 100max 50max 120max 150max 300max 20max 20max 48max 60max 96max 3.19 - 3.47 4.90 - 5.30 11.40 - 12.60 14.25 - 15.75 23.0 - 25.0 Fixed 700max (ACIN 85V, Io=100%) 10typ (ACIN 85V, Io=100%), 20typ (ACIN 100V, Io=100%) Works over 125% of rating and recovers automatically Works over 115% of rating (By zener diode clamping) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) -10 to +71C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 19.6m/s2 10 - 55Hz, 3minutes period, 60minutes each along X, Y and Z axis (Non operating) 196.1m/s2 11ms, once each X, Y and Z axis (Non operating) UL60950-1, C-UL, EN62368-1 Complies with DEN-AN and IEC62368-1 Complies with FCC-B, VCCI-B, CISPR22-B, EN55022-B 32X20X72.5mm [1.26X0.79X2.85 inches] (WXHXD) / 30g max Convection *1 Peak load for 10sec. or less in acceptable if the total wattage is less than the rated wattage. *2 This is the value that measured on measuring board with capasitor of 22mF. Measuared by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. VAF-2 January 20, 2022 VAF5 External view Recommended size for processing PCB (TOP VIEW) 72.5 [2.85] 65.5 3.5 65.5 [0.14] [2.58] bottom cover [0.16] [0.79] 4 20 (21 max.) 12 [0.47] 10 ]= inches Input/Output Pin 4 º1.7 bottom cover [0.07] [0.16] 5-º1.0 [0.04] (stopper º 1.7 [0.07] ) [0.61] (15.5) ¶ Dimensions in mm, [ ¶ Unit: 2mm [0.39] 27 [1.06] 10 (TOP VIEW) [0.1] 2.5 AC(L) 2.5 -V C16 [0.1] +V Name Plate 32 FG 12 27 [1.06] AC(N) Outline [0.05] [1.26] [1.95] 5-º1.3 49.5 [1.95] 29.5 [0.14] [2.58] [1.16] 49.5 [0.39] [0.47] 3.5 º1.0 [0.04] ¶Weight: 30g max ¶Tolerance: ±0.5 [±0.02] ¶PCB material: CEM-3 ¶PCB thickness: t=1.0 [0.04] ¶Pin material: CPW with solder plated ¶Recommended hole dia. to PCB: º1.3 ¶Dimensions in mm, [ ]= inches Performance data ¡STATIC CHARACTERISTICS (VAF512) ¡RISE TIME (VAF512) AC 85V AC170V AC264V 12.20 OUTPUT VOLTAGE 5V/DIV 12.30 12.10 DC Output 12.00 ACIN 85V Io=100% AC Input 11.90 0 0.2 0.4 50ms/DIV 0.6 OUTPUT CURRENT ¡OVERCURRENT CHARACTERISTICS (VAF512) ¡DERATING CURVE 14 100 10 75 LOAD FACTOR OUTPUT VOLTAGE 12 8 6 AC 85V AC170V AC264V 4 25 2 0 0.5 1.0 1.5 2.0 OUTPUT CURRENT 0 -10 0 10 20 30 40 50 60 71 AMBIENT TEMPERATURE January 20, 2022 VAF-3 AC-DC Power Supplies PCB Mount Type VAF10 Ordering information VAF 10 1 2 05 3 1 Series name 2 Output wattage 3 Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT VAF1003 6.6 VOLTAGE[V] 3.3 CURRENT[A] 2.0 (Peak 2.4) VAF1005 10.0 5 2.0 (Peak 2.4) VAF1012 10.8 12 0.9 (Peak 1.08) VAF1015 10.5 15 0.7 (Peak 0.84) VAF1024 10.8 24 0.45 (Peak 0.54) SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] INPUT ACIN 100V ACIN 200V FREQUENCY[Hz] ACIN 100V ACIN 200V LEAKAGE CURRENT[mA] EFFICIENCY[%] VOLTAGE[V] *1 CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +55C *2 RIPPLE[mVp-p] -10 - 0C *2 Io=100 - 120% *2 0 to +55C *2 OUTPUT RIPPLE NOISE[mVp-p] -10 - 0C *2 Io=100 - 120% *2 TEMPERATURE COEFFICIENT[mV] -10 to +55C *3 DRIFT[mV] OUTPUT VOLTAGE SETTING[V] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] START-UP TIME[ms] HOLD-UP TIME[ms] PROTECTION OVERCURRENT PROTECTION CIRCUIT OVERVOLTAGE PROTECTION INPUT-OUTPUT ISOLATION INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AND AGENCY APPROVALS NOISE REGULATIONS CONDUCTED NOISE CASE SIZE/WEIGHT OTHERS COOLING METHOD INRUSH CURRENT[A] VAF1003 VAF1005 VAF1012 VAF1015 VAF1024 AC85 - 264 1f or DC110 - 370 0.3typ (Io=100%) 0.2typ (Io=100%) 47 - 440 or DC 15typ (Io=100%) 30typ (Io=100%) 0.5max (60Hz, According to IEC62368-1 and DEN-AN) 65typ 74typ 78typ 78typ 81typ 3.3 5 12 15 24 2.0 (Peak 2.4) 2.0 (Peak 2.4) 0.9 (Peak 1.08) 0.7 (Peak 0.84) 0.45 (Peak 0.54) 20max 20max 48max 60max 96max 40max 40max 100max 120max 150max 80max 80max 120max 120max 150max 140max 140max 160max 160max 200max 180max 180max 200max 200max 240max 120max 120max 150max 150max 200max 160max 160max 180max 180max 230max 200max 200max 220max 220max 260max 100max 50max 120max 150max 300max 20max 20max 48max 60max 96max 3.19 - 3.47 4.90 - 5.30 11.40 - 12.60 14.25 - 15.75 23.0 - 25.0 Fixed 700max (ACIN 85V, Io=100%) 10typ (ACIN 85V, Io=100%), 20typ (ACIN 100V, Io=100%) Works over 125% of rating and recovers automatically Works over 115% of rating (By zener diode clamping) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) -10 to +71C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 19.6m/s2 10 - 55Hz, 3minutes period, 60minutes each along X, Y and Z axis (Non operating) 196.1m/s2 11ms, once each X, Y and Z axis (Non operating) UL60950-1, C-UL, EN62368-1 Complies with DEN-AN and IEC62368-1 Complies with FCC-B, VCCI-B, CISPR22-B, EN55022-B 36X21X78mm [1.42X0.83X3.07 inches] (WXHXD) / 40g max Convection *1 Peak load for 10sec. or less in acceptable if the total wattage is less than the rated wattage. *2 This is the value that measured on measuring board with capasitor of 22mF. Measuared by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *3 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. VAF-4 January 20, 2022 VAF10 External view Recommended size for processing PCB (TOP VIEW) 78 [3.07] 71 12 [0.47] 12 (TOP VIEW) 71 3.5 [2.8] ¶ Dimensions in mm, [ ¶ Unit: 2mm ]= inches Input/Output Pin 4 º1.7 bottom cover [0.07] [0.16] bottom cover [0.16] [0.83] [0.65] 4 21 (22 max.) (16.5) [0.14] 5-º1.0 [0.04] (stopper º 1.7 [0.07] ) Outline [0.05] [0.47] 27 [1.06] 4.5 [0.18] 36 [1.42] [1.24] 31.5 -V C16 AC(L) +V 12 27 FG Name Plate [0.18] 4.5 [1.06] AC(N) [0.47] [2.17] 12 [0.14] [2.17] [0.47] 55 5-º1.3 55 [2.8] 3.5 º1.0 [0.04] ¶ Weight: 40g max ¶ Tolerance: ±0.5 [±0.02] ¶ PCB material: CEM-3 ¶ PCB thickness: t=1.0 [0.04] ¶ Pin material: CPW with solder plated ¶ Recommended hole dia. to PCB: º1.3 ¶ Dimensions in mm, [ ]= inches Performance data ¡STATIC CHARACTERISTICS (VAF1012) ¡RISE TIME (VAF1012) AC 85V AC170V AC264V 12.20 OUTPUT VOLTAGE 5V/DIV 12.30 12.10 DC Output 12.00 ACIN 85V Io=100% AC Input 11.90 0 0.2 0.4 0.6 0.8 1.0 50ms/DIV 1.2 OUTPUT CURRENT ¡OVERCURRENT CHARACTERISTICS (VAF1012) ¡DERATING CURVE 14 100 10 75 LOAD FACTOR OUTPUT VOLTAGE 12 8 6 AC 85V AC170V AC264V 4 25 2 0 1.0 2.0 3.0 OUTPUT CURRENT 0 10 20 30 AMBIENT TEMPERATURE January 20, 2022 Powered by TCPDF (www.tcpdf.org) 0 -10 40 50 60 71 (A, B, C mounting) VAF-5
VAF505
物料型号: - VAF503 3.3W 3.3V - VAF505 5W 5V - VAF512 5.4W 12V - VAF515 5.25W 15V - VAF524 5.28W 24V
器件简介: 文档描述的是COSEL品牌的AC-DC电源模块,这些模块是PCB安装型的。
引脚分配: 文档提供了输入/输出引脚的布局图,包括AC(N)、AC(L)、FG、+V和-V等。
参数特性: - 输入电压范围:AC85-264V或DC110-370V - 频率范围:47-440Hz或DC - 效率:68%到81%不等 - 输出电压和电流:根据型号不同而有所变化 - 过流保护、过压保护等
功能详解: 文档提供了详细的电气特性,包括静态特性、过流特性、温升曲线等。
应用信息: 文档没有明确提供应用信息,但通常这类电源模块可用于需要稳定直流电源的各种电子设备。
封装信息: - 尺寸:根据不同型号,尺寸有所不同,例如VAF5系列为32x20x7.2mm,VAF10系列为36x21x78mm - 重量:VAF5系列最大30g,VAF10系列最大40g - 冷却方式:自然对流
VAF505 价格&库存
很抱歉,暂时无法提供与“VAF505”相匹配的价格&库存,您可以联系我们找货
VAF505
    • 1+142.521521+17.30697
    • 5+97.215555+11.80528
    • 10+91.5578310+11.11824
    • 30+87.7830730+10.65986
    • 50+87.0228250+10.56754
    • 60+86.8371760+10.54499
    • 100+86.45705100+10.49883
    库存:28
