NBH-10-432
NBH-10-432
    COSEL
    NBH-10-432
NBH-10-432 数据手册
Ordering information Single phase input type (2-Stage filter) NBH series NBH -10 -432 1 2 -O 3 4 1 Model Name 2 Rated Current 3 Line to ground capacitor code:Refer to table 1.1. R table1.1 Line to ground capacitor code Line to ground capacitor Test voltage Leakage Current (Input 125/250V 60Hz) (nominal value) (Terminal- Mounting Plate) CY1 CY2 5 A/ 10 A max Not Provided Not Provided 100pF Not Provided 12.5 A/ 25 A max 25 A/ 50 A max 220pF Not Provided 4,000VAC 37.5 A/ 75 A max 330pF Not Provided 50 A/ 100 A max 470pF Not Provided 75.5 A/ 150 A max 680pF Not Provided 1000pF Not Provided 0.13 mA/ 0.25mA max 0.25 mA/ 0.5 mA max 1000pF 1000pF 2,500VAC 0.38 mA/ 0.75mA max 2200pF 1000pF 0.5 mA/ 1.0 mA max 3300pF 1000pF Code DIN rail installation type is option 000 101 221 331 471 681 102 202 322 432 The terminal cover is retracted inside the unit *When the line to ground capacitor code is different, the attenuation characteristic is different. 4 Option D :DIN rail installation type * The dimensions change when the option is set. Refer to External view. Features of NBH series Ultra high-attenuation type from 9kHz to 10MHz (2-Stage filter) -Single Phase 250VAC -Withstand voltage 4,000 VAC (Line to ground capacitor code -000 to -471) - Quick and easy push-down terminal Just connect the wires, push-down and tighten the screws with a screwdriver Specifications No. 1 Items NBH-06-432 Rated Voltage[V] AC 1f 250 / DC250 2 Rated Current[A] 3 Test Voltage (Terminal-Mounting Plate) 6 *1 NBH-10-432 10 NBH-16-432 NBH-20-432 NBH-30-432 16 20 30 2,500 VAC (Cutoff Current = 20mA), 1minute at room temperature and humidity 4 Isolation Resistance (Terminal-Mounting Plate) 500 VDC 100MW min at room temperature and humidity 5 Leakage current 125/250V 60Hz 0.5mA/1.0mA max 6 Voltage drop 1.0V max 7 Safety agency approval temperatures -25 to +85C (Refer to Derating Curve A) -25 to +85C (Refer to Derating Curve B) 8 Operating temperature -40 to +85C (Refer to Derating Curve A) -40 to +85C (Refer to Derating Curve B) 9 Operating humidity 20 to 95%RH (Non condensing) 10 Storage temperature/humidity -40 to +85C/20 to 95%RH (Non condensing) 11 Vibration 10 to 55Hz, 19.6m/s2 (2G), 3min. Period, 1hour each X, Y and Z axis 12 Impact 196.1m/s2 (20G), 11ms Once each X, Y and Z axis 13 Safety agency approvals UL1283, CSA C22.2 No.8 (C-UL), DIN EN60939 VDE0565 Teil3-1, ENEC (At only AC input) 14 Case size (without projection) /Weight 53X43X104 mm [2.09X1.69X4.09 inches] (WXHXD) /320g max (Option : -D refer to external view) *1 When the line to ground capacitor code is different, the test voltage characteristic is different. (Refer to table 1.1) Circuit Diagram Derating Curve Derating Curve (A) 6,10A Load Factor [%] Case 3 LINE L INE 2 CY1 C Y1 CY2 C Y2 CY1 C Y1 CY2 C Y2 CY1,CY2 C Y1,CY2 : Line to ground capacitor NB-1 LOAD L OAD 4 : Mounting Plate 100 80 60 40 20 0 -40 -30 -20 50 60 70 40 Ambient Temperature [C] 80 85 90 Derating Curve (B) 16 to 30A Load Factor [%] 1 100 80 60 40 20 0 -40 September 16, 2021 -30 -20 60 70 40 45 50 Ambient Temperature [C] 80 85 90 NBH series External view This product is shipped in the following condition, because it is equipped with push-down terminals. 1The terminal cover is retracted inside the unit. 2The screws for connecting the terminals are held in the up right position. Standard Type 104 [4.09] 2.5 94 ±0.5 [3.7] 2-f4.8 [0.19] Mounting Hole 30.5 [1.2] [0.1] 2-Protection Earth 92 8 [0.31] [3.62] 12 Output Terminal Input Terminal 6-M4 53 [1.77] Mounting Plate Terminal cover 2 [0.08] Terminal cover [0.47] 15 [0.59] 45 ±0.5 Output Terminal Name Plate [2.09] Input Terminal ¶ Closed the terminal cover ¶ Tolerance : ±1 [±0.04] 43 [1.69] ¶ Weight : 320g max ¶ Mounting Plate : Iron (surface finishing:nickel plating) t=1.0 [0.04] ¶ Case : PBT ¶ Dimensions in mm, [ ]=inches ¶ Terminal block screw tightening torque M4:1.6N-m (16.9kgf-cm) max DIN rail installation Type 104 8.2 ±1.5 [4.09] 2.5 [0.32] 92 2-Protection Earth [3.62] 30.5 [1.2] 8 Output Terminal 6-M4 Mounting Plate 2 [0.08] Terminal cover 12 Output Terminal Input Terminal [0.47] 53 15 [0.59] Name Plate [2.09] [0.31] Input Terminal Terminal cover [0.1] 43 [1.69] ¶ Closed the terminal cover ¶ Tolerance : ±1 [±0.04] ¶ Weight : 320g max ¶ Mounting Plate : Iron (surface finishing:nickel plating) t=1.0 [0.04] 7 [0.28] ¶ Dimensions in mm, [ [0.35] (9) ¶ Case : PBT DIN rail ¡Note when installing the EMI/EMC Filter on a DIN rail. When the EMI/EMC Filter is grounded through the DIN rail, the proper noise attenuation may not be achieved. Be sure to connect the protection earth (PE) of the EMI/EMC Filter body to the earth. At least one PE connection is required. ]=inches ¶ Terminal block screw tightening torque M4:1.6N-m (16.9kgf-cm) max DIN rail Name Plate September 16, 2021 NB-2
NBH-10-432 价格&库存
很抱歉,暂时无法提供与“NBH-10-432”相匹配的价格&库存,您可以联系我们找货
NBH-10-432
    • 1+813.46680
    • 200+324.58320
    • 500+313.74000
