XP1001000-05R
XP1001000-05R
    LANTRONIX
    XP1001000-05R
XP1001000-05R 数据手册
XPort® Embedded Device Server Data Sheet General Description The Lantronix® XPort® embedded device server is the most compact, integrated solution available to web-enable any device with a serial interface. By simply adding an XPort unit to a product design, device manufacturers cut their design cycle by as much as 80% and are able to offer Ethernet connectivity in record time. x The XPort module offers the highest level of integration available in a device server. Within a compact RJ45 package is a DSTni® EX 186 controller, memory, 10/100 Ethernet transceiver, high-speed serial port, status/diagnostic LEDs, and 3 programmable I/O pins. In the space that is normally consumed by a connector, the XPort unit provides a complete networking interface. To enable access to a local network or the Internet, the XPort module integrates a fully developed TCP/IP network stack and OS. The XPort unit also includes an embedded web server used to remotely configure, monitor, or troubleshoot the attached device. 910-815I XPort Embedded Device Server Data Sheet Where there’s a need for custom user interfaces and a desire to use common and familiar tools, the XPort module can serve web pages to a web browser. The XPort unit becomes a conduit between you and your device over the network or Internet. The Lantronix DeviceInstaller™ utility is a Windows based configuration tool that simplifies installation and setup. The XPort module can also be set up locally through its serial port, or remotely over a network using Telnet or a web browser. Flash memory provides for maintenance-free nonvolatile storage of web pages, and allows future system software upgrades. Using our highly integrated hardware and software platform, you will add profit to your bottom line by significantly reducing product development time, risk, and cost. Key Features • The only complete, integrated solution in an RJ45 form factor • Complete integrated solution • Embedded web server • 10/100Mbit Ethernet – Auto-Sensing • Stable, field proven TCP/IP protocol suite and webbased application framework • Easy configuration through a web interface • Easy customization of HTML web pages and configuration screens • Interactive web pages through the use of Java applets • E-mail • 128-, 192-, or 256-bit AES Rijndael encryption (Optional) • EMI tested and compliant • Extended operating temperature: -40 to +85˚ C normal mode -40 to +75˚ C high-performance mode • High-performance processor (12 MIPS at 48 MHz, 22 MIPS at 88 MHz) • Network overhead handled by XPort unit • Password protection • Upgrade XPort module’s firmware over the network • 3.3V power • Serial-to-10/100 Ethernet conversion • 921,600 baud serial speed Copyright© 2014, Lantronix. All rights reserved. Hardware & Software Description The XPort unit is a complete solution (hardware and software) for web-enabling your edge devices. Packed into an RJ45 connector smaller than your thumb, this powerful device server comes with a 10BASET/100BASE-TX Ethernet connection, a reliable and proven operating system stored in flash memory, an embedded web server, a full TCP/IP protocol stack, and standards-based (AES) encryption. The XPort software runs on a DSTni EX controller which has 256 KB of SRAM, 16 KB of boot ROM, and a MAC with integrated 10/100BASE-TX PHY. The XPort module communicates to the edge device through a 3.3V serial interface and three generalpurpose programmable I/O pins. 512 KB of flash memory is included for storing firmware and web pages. The XPort runs on 3.3V, and has a built-in voltage supervisory circuit that will trigger a reset if the supply voltage drops to unreliable levels (2.7V). A built-in 1.8V regulator drives the processing core of the EX controller. Table 1 - PCB Interface Signals Signal Name Pin GND 1 Circuit Ground Vcc 2 +3.3V Power In Reset (In) 3 External Reset In Data OUT 4 Serial Data Out Data IN 5 Serial Data In CP1 can be configured as follows: CP1 6 FLASH Tx Rx CP2 can be configured as follows: CP2 7 CMOS IO RESET CP3 can be configured as follows: • Flow control: CTS (Clear to Send) input read by DSTni’s built-in UART for connection to RTS of attached device. CP3 8 RJ45 DSTni EX Ethernet Interface The 10/100 Ethernet magnetics, network status LEDs, and RJ45 connector are integrated into the XPort unit. Table 2 - Ethernet Interface Signals Signal Name TX+ DIR Out Contact 1 TX- Out 2 RX+ In 3 Receive Data + RX- In 6 Receive Data – Primary Function Transmit Data + Transmit Data – Not Used 4 Terminated Not Used 5 Terminated Not Used 7 Terminated Not Used 8 Terminated SHIELD 910-815I XPort Embedded Device Server Data Sheet • Modem control: DCD (Data Carrier Detect) input read by DSTni’s built-in UART for connection to DTR of attached device. • Programmable input/output: CP3 can be driven or read through software control, independent of serial port activity. +3.3VDC PCB Interface The 8-pin PCB interface consists of 3.3V CMOS Serial In/Out, 3 Flow Control/Handshake/PIO pins, reset input, +3.3V power, and signal ground. The serial pins and CP pins are 5V tolerant. RESET and Power are 3.3V tolerant. • Modem control: DTR (Data Terminal Ready) output driven by DSTni’s builtin UART for connection to DCD of attached device. • Programmable input/output: CP2 can be driven or read through software control, independent of serial port activity. LEDs 25MHz • Flow control: RTS (Request to Send) output driven by DSTni’s built-in UART for connection to CTS of attached device. • Programmable input/output: CP1 can be driven or read through software control, independent of serial port activity. An RJ45 Ethernet cable connects directly into an XPort unit. Ethernet magnetics, status LEDs, and shielding are built in. The XPort module was designed to meet class B emissions levels, which makes the electromechanical integration very simple. MAGNETICS Function Chassis Ground Copyright© 2014, Lantronix. All rights reserved. Protocol Support The XPort module uses Internet Protocol (IP) for network communications and Transmission Control Protocol (TCP) to assure that no data is lost or duplicated, and that everything sent arrives correctly at the target. Dimensions The dimensions of the XPort module are shown in the following drawings: 18.25 [0.719] FRONT VIEW 16.25 [0.640] DIMS = mm (in) 11.55 [0.455] Other supported protocols are listed below: • • • • • 7.15 [0.281] ARP, UDP, TCP, ICMP, Telnet, TFTP, AutoIP, DHCP, HTTP, and SNMP for network communications. TCP, UDP, and Telnet for connections to the serial port. TFTP for firmware updates. IP for addressing, routing, and data block handling over the network. User Datagram Protocol (UDP) for typical datagram applications in which devices interact with other devices without maintaining a point-to-point connection. * For a complete discussion of protocol support, see the XPort user manual for the XPort embedded device server. LEDs The device contains two bi-color LEDs built into the front of the XPort connector. (See dimension drawing for location.) Link LED (Left Side) Activity LED (Right Side) Color Meaning Color Meaning Off No Link Off No Activity Amber 10 Mbps Amber Half-Duplex Green 100 Mbps Green Full-Duplex Recommended PC Board Layout The hole pattern and mounting dimensions for the XPort unit are shown in the following drawing: O 0.90 O [ 0.035] O 3.25 O [ 0.128] 16.05 [0.632] 1.27 [0.050] 8 FRONT 12.30 [0.484] SHIELD TAB O 1.60[ 0.063] 7 2.54 [0.100] DIMS = mm (in) 3.58 [0.141] 2 1 10.84 [0.427] 2.54 [0.100] TOLERANCE .XX+/-0.05[0.002] 6.35 [0.250] 11.90 [0.468] For proper heat dissipation, the PCB should have approximately 1 square inch of copper attached to the shield tabs. The shield tabs are an important source of heat sinking for the device. 910-815I XPort Embedded Device Server Data Sheet LEFT LED RIGHT LED CONTACT 8 CONTACT 1 14.50 [0.571] 4.03 [0.158] 5.85 [0.230] 13.50 [0.531] SHIELD TAB 1.27 [0.050] TOLERANCE 0.40 [0.016] .XX+/-0.20[0.008] SHIELD TAB 3.30 [0.130] 1.85 [0.073] 3.25 [0.128] 1.00 [0.039] 33.90 [1.335] INTERFACE PINS FRONT SHIELD GROUND 0.60 [0.024] SHIELD TAB 0.35 [0.014] 10.84 [0.427] 2.54 [0.100] TOLERANCE .XX+/-0.20[0.008] 3.20 [0.126] 6.35 [0.250] 11.90 [0.468] DIMS = mm (in) OEM License Agreement With the purchase of an XPort module, the OEM agrees to terms and conditions of an OEM License Agreement whereby Lantronix grants to the OEM (subject to the complete terms and conditions of the OEM License Agreement) a limited, nonexclusive, non-transferable, royalty-free, revocable license to (i) use the software in object code form solely for OEM’s use, without any modification, on the XPort embedded device server, or for OEM’s internal use in the development and integration of the XPort unit with OEM’s products, (ii) market or sublicense the software as a part of a combination of the XPort unit with OEM’s products, and (iii) reproduce and distribute the software in object code form only. The foregoing is a summary of the OEM License Agreement and is not intended to be a complete substitute for the OEM License Agreement. Additional terms and conditions apply. The full OEM License Agreement is available from Lantronix. Copyright© 2014, Lantronix. All rights reserved. XPort Technical Data Category CPU, Memory Firmware Reset Circuit Serial Interface Serial Line Formats Modem Control Flow Control Programmable I/O Network Interface Compatibility Protocols Supported LEDs Management Security Internal Web Server Weight Material Temperature Relative Humidity Shock/Vibration Warranty Included Software Emissions Immunity Description Lantronix DSTni EX 186 CPU, 256 KB zero wait state SRAM 512 KB Flash, 16 KB Boot ROM Upgradeable via TFTP and serial port Internal 200ms power-up reset pulse. Power-drop reset triggered at 2.6V. External reset input causes an internal 200 ms reset. CMOS (Asynchronous) 3.3V-level signals. Rate is software selectable (300 bps to 921600 bps) 7 or 8 data bits, 1-2 Stop bits, Parity: odd, even, none DTR/DCD, CTS, RTS XON/XOFF (software), CTS/RTS (hardware), none 3 PIO pins (software selectable) sink or source 4mA max. RJ45 Ethernet 10BASE-T or 100BASE-TX (auto-sensing) Ethernet: Version 2.0/IEEE 802.3 ARP, UDP/IP, TCP/IP, Telnet, ICMP, SNMP, DHCP, BOOTP, TFTP, Auto IP, and HTTP 10BASE-T & 100BASE-TX Link Activity, Full/half duplex. Software generated status & diagnostic signals can optionally drive external LEDs through CP1 & CP3 (see Int. Guide). Internal web server, SNMP, Serial login, Telnet login Password protection, locking features, optional Rijndael 128-, 192-, or 256-bit encryption Serves web pages Storage capacity: 384 KB 9.6 grams (0.34 oz) Metal shell, thermoplastic case Extended Temp RoHS product: -40°C to +85°C (-40°F to 185°F) Storage range: -40°C to +85°C (-40°F to 185°F) Operating: 5% to 95% non-condensing Non-operational shock: 500 g's, Non-operational vibration: 20 g's 2-year limited warranty Windows based DeviceInstaller configuration software & Windows based Com Port Redirector Supported Windows OS • x86 based Platforms: XP/2003 Server/Vista/Windows 7/Windows 8/2008 Server • x64 based Platforms: Vista/Windows 7/Windows 8/2008 Server FCC Part 15 Subpart B Industry Canada ICES-003 Issue 4 February 2004 CISPR 22: 2005 Information Technology Equipment VCCI V-3/200904 AS/NZS CISPR 22: 2006 EN 55022: 2006 +A1:2007 EN 61000-3-2:2006 EN 61000-3-3: 2008 EN 55024: 1998 +A1: 2001 +A2: 2003 EN 61000-4-2: 1995 + A2: 2001 EN 61000-4-3: 2006 + A1: 2008 EN 61000-4-4: 2004 EN 61000-4-5: 2006 EN 61000-4-6: 2007 EN 61000-4-8: 1994 + A1:2001 EN 61000-4-11: 2004 Recommended Operating Conditions Parameter Supply Voltage Supply Voltage Ripples Power Reset Threshold RESET Pin Input Low Voltage RESET Pin Input High Voltage CPx, RX Input Low Voltage CPx, RX Input High Voltage CPx, TX Output Low Voltage CPx, TX Output High Voltage Input Leakage Current Supply Current (idle)@ 48 MHz Supply Current (10BASE-T activity)@ 48 MHz Supply Current (10BASE-T activity)@ 88 MHz Supply Current (100BASE-T activity)@ 48 MHz Supply Current (100BASE-T activity)@ 88 MHz 910-815I XPort Embedded Device Server Data Sheet Symbol VCC VCC PP Min Typical Max Units 3.14 3.3 3.46 2.0 Vdc % Vdc Vdc Vdc Vdc Vdc Vdc Vdc µA mA mA mA mA mA 2.7 VRES IL VRES IL VCP_IL VCP_IH VCP OL VCP OH II ICC ICC ICC ICC lCC 0.36 3.46 0.8 5.5 0.4 2.0 2.0 2.4 1 119 224 267 190 233 Copyright© 2014, Lantronix. All rights reserved. Development Kit Introduction A development kit for the XPort embedded device server is available to provide a simple, quick, and cost-effective way to evaluate the XPort unit. Use the development kit to integrate the XPort module to your product design, and give your newly networked product a test drive. Block Diagram • • • • TP8 PIO TP9 +5 VDC IN 3.3V J1 POWER RTS DTR CTS/DCD LEDs Features of the Development Kit • D2 PWR LED JP4 TP13 TP11 SLOW TMR Complete, ready to use XPort unit and supporting evaluation board +5VDC Universal Power Supply RS-232 cable, DB9M/F CAT5e UTP RJ45M/M Ethernet cable Serial adapter, 25-pin to 9-pin DB-9F RXD/TXD XPort RESET RESET SWITCH SW2 PLD DIP SWITCH RS232 DTR, CTS RTS, DCD PADS JP3 PLD HEADER SW1 Features of the Evaluation Board The evaluation board for the XPort unit includes an XPort module integrated with the following features: • • • • • • • RS-232 (DCE) serial interface DIP switch configuration LED indication for power, RS-232 transmit / receive and PIO status Reset circuit with pushbutton Header connector for the PIO signals CP1, CP2, and CP3 Test points to monitor the XPort unit’s serial interface signals Timer Ordering Information XPort XE XP1001000-05R Standard XPort module Min. order: 50 units XPort SE XP1002000-05R Standard XPort module with 256-bit AES encryption Min. order: 50 units XPort SE SMPL XP100200S-05R XPort Sample with encryption One XPort module enclosed XPort Dev. Kit XP10010NMK-01 XPort Development Kit with encryption XP1002000-05R For details contact your local Lantronix representative or Lantronix directly: Asia Pacific Region via e-mail at AsiaPacific_sales@lantronix.com Europe via e-mail at eu_sales@lantronix.com Japan via e-mail at japan_sales@lantronix.com United States via e-mail at sales@lantronix.com or call OEM sales support at 800-526-8764 ©2014 Lantronix, Inc. All rights reserved. Lantronix, XPort, with its patented technology (US Patents 6,881,096, 7,018,242; 8,010,789; 8,788,814;), and DSTni are registered trademarks and DeviceInstaller is a trademark of Lantronix, Inc. All other trademarks are the property of their respective owners. Specifications subject to change without notice. All rights reserved. 910-815I XPort Embedded Device Server Data Sheet Copyright© 2014, Lantronix. All rights reserved.
XP1001000-05R 价格&库存
很抱歉,暂时无法提供与“XP1001000-05R”相匹配的价格&库存,您可以联系我们找货
XP1001000-05R
  • 1+502.755121+65.03905
库存:9967
