MP10010NMK-01
MP10010NMK-01
    LANTRONIX
    MP10010NMK-01
MP10010NMK-01 数据手册
The Ultimate in Flexibility, Security, Performance and Affordability in Embedded Wireless Networking MatchPort™ b/g enables you to build wireless networking into virtually any electronic device with a serial interface. With this full-featured, turnkey embedded device server module your products can be wirelessly accessed and controlled over the Internet! Pin-compatible Wireless/Wired Module Family MatchPort b/g is the first in a family of pin and form-factor compatible wireless and wired module solutions. The MatchPort family enables you to “future proof” your designs with a choice of flexible media-independent 802.11 b/g or Ethernet networking products. It takes the complexity out of RF design and embedded Ethernet networking, enabling you to focus on your products. And it minimizes engineering risk, reduces cost and shortens development time. Complete Wireless Network Processing Module MatchPort b/g is a dedicated co-processor module that manages wireless and network activity, permitting the device’s host microprocessor to function at maximum efficiency. Using a dual processor design (one for converting wired serial data into TCP/IP packets and providing web server capabilities, the other an 802.11 b/g baseband and radio chipset) MatchPort b/g enables 802.11 wireless connectivity and web services on any device with a serial interface on its host microcontroller. Powered by a Lantronix DSTni™ x86 class processor SoC with 256 KB of on-chip SRAM, MatchPort b/g also includes 2MB of Flash memory for web page storage and firmware. (Rijndael) encryption for true end-to-end (along the wired/wireless path) secure data transfer. Robust, Feature-Rich Software Suite Eliminating the need to negotiate the intricacies of Transmission Control Protocol (TCP) or Internet Protocol (IP), MatchPort b/g incorporates: • Robust operating system • Full-featured network protocol stack and radio system driver • Proven, ready-to-use serial-to-wireless application • Built-in web server for device communication and configuration via a standard browser • Windows-based DeviceInstaller™ – making configuring one or more units in a subnet quick and easy FCC Certified for Immediate Deployment MatchPort b/g is module certified by the U.S. Federal Communications Commission (FCC). This allows you to leverage the Lantronix FCC license grant and bypass 802.11 regulatory testing, speeding time-to-market and minimizing development and testing costs. MatchPort b/g is also pre-tested for European telecommunications regulations. Flexible, Efficient Design Designed without an attached antenna, MatchPort b/g provides the flexibility to design and place the antenna and antenna connector based on your design requirements. MatchPort b/g includes a user controlled intelligent power management option to shut the radio off during periods of inactivity minimizing unnecessary current consumption. Ethernet-to-Wireless Bridging With a separate Ethernet port, MatchPort b/g offers the unique ability to transparently bridge existing Ethernet-ready devices to a wireless network. Scan, Gather and Report Radio Parameters Bulletproof Security With IEEE 802.11i-PSK (AES-CCMP) or WPA-PSK (TKIP) security, MatchPort b/g offers the highest levels of wireless encryption. It also optionally supports 256-bit Advanced Encryption Standards With its Scan command, MatchPort b/g enables the ability to report BSSID, RSSI and SSID. The Network Status command reports BSSID, authentication and negotiated encryption types for the current association. Embedded Wireless Device Server Extremely affordable embedded 802.11 b/g wireless networking Wired Ethernet-to-wireless bridging Common platform form factor for a family of wired and wireless modules Bulletproof security with IEEE 802.11i-PSK, WPA-PSK, TKIP and optional 256-bit AES end-to-end encryption Full TCP/IP stack, web server and Windows deployment software Two serial channels; up to 921 Kbps data rate FCC Class B, UL and EN EMC and safety-compliant Compact: 45mm x 45mm with 40-pin 2 mm header MatchPort b/g MatchPort b/g Wireless Device Server Features and Specifications MatchPort b/g Wireless Specifications Wireless Standards: IEEE 802.11b; 802.11g Channel Frequency Range: 2.412 – 2.484 GHz Maximum Output Power: 14dBm +2.0 dBm/-1.5 dBm (does not include antenna gain) Maximum Receive Sensitivity: -91dBm @ 1Mbps Data Rates With Automatic Fallback 54Mbps – 1Mbps Range: Up to 328 feet indoors Modulation Techniques: OFDM, DSSS, CCK, DQPSK, DBPSK, 64 QAM, 16 QAM Packaging Included Software Dimensions: 44.4 x 44.4 x 10.4 mm (1.75 x 1.75 x .41 in) Weight: 14g Material: Plastic shell, 260°C tolerant Windows® 98/NT/2000/XP/Vista based DeviceInstaller configuration software and Com Port Redirector™, Web-Manager Warranty 2-year limited warranty Embedded Wireless Device Server Serial Interface Two Serial Ports Interface: CMOS (Asynchronous) 3.3V-level signals, rate is software selectable (300 bps to 921,000 bps) Serial Line Formats: 7 or 8 data bits, 1-2 Stop bits Parity: odd, even, none Modem Control: DTR, DCD Flow Control: XON/XOFF (software), CTS/RTS (hardware), none The included DeviceInstaller software makes configuration quick and easy! Network Interface Interface: Wireless 802.11b and 802.11g Protocols Supported: ARP, UDP, TCP, Telnet, ICMP, SNMP, DHCP, BOOTP, Auto IP, HTTP, SMTP, TFTP Management Internal web server SNMP (read only) Serial login Telnet login DeviceInstaller software MatchPort b/g Demonstration Kit Security The demonstration kit contains the key accessories to evaluate a MatchPort b/g product: IEEE 802.11i - PSK with AES-CCMP Encryption WPA - PSK TKIP Encryption 64/128-bit WEP Internal Web Server Serves web pages Storage capacity: 1.2 MB • MatchPort b/g demonstration board • RS-232 cable, DB9F, null modem • Cat5e UTP RJ45M/M Ethernet cable • 3.3V power supply • Antenna Note: MatchPort b/g sample must be purchased separately. Ordering Information Architecture CPU, Memory: Lantronix DSTni-EX x86 CPU, on-chip 256 KB zero wait static SRAM, 2,048 KB Flash, 16 KB Boot ROM, 8 GPIO Firmware: Upgradeable via TFTP and serial port Part Number Description MP1001000G-01 – MatchPort b/g bulk pack – Minimum order quantity 50 units MP1002000G-01 – MatchPort b/g AES bulk pack – Minimum order quantity 50 units MP100200SG-01 – MatchPort b/g AES sample case – One (6 in.)Antenna cable U.FL to R-SMA (p/n 500-180-R-ACC) – One MatchPort b/g enclosed – Free 30-day Secure Com Port Redirector™ evaluation license – Order quantities of up to 10 MP10010NMK-01 930-033-R 500-180-R-ACC 500-181-R-ACC – MatchPort b/g Demonstration Kit – Accessory antenna – Antenna cable (6 in.) U.FL to R-SMA (10 pack) – Antenna cable (6 in.) U.FL to U.FL (10 pack) Power Consumption Average Power Consumption: Data Transfer • 740 mW (Low cpu); active • 250 mW (Low cpu); inactive Peak Supply Current: 360 mA Data Transfer Environmental Operating range, WLAN: -40° to 70°C (-40° to 158°F) Storage range: -40° to 85°C (-40° to 185°F) Lantronix Corporate Headquarters 167 Technology Drive Irvine CA 92618 t: 800.422.7055 sales@lantronix.com NASDAQ: LTRX European Headquarters t: +31 (0) 76 52 36 74 4 EMEA@lantronix.com Asia/Pacific Headquarters t: +852 3428 2338 asiapacific_sales@lantronix.com ©2013 Lantronix is a registered trademark, and MatchPort, DSTni, Secure Com Port Redirector and DeviceInstaller are trademarks of Lantronix, Inc. All other trademarks are the property of their respective owners. Specifications subject to change without notice. All rights reserved. 910-514 Japan Headquarters t: +81.3.6277.8802 japan_sales@lantronix.com
MP10010NMK-01 价格&库存
很抱歉,暂时无法提供与“MP10010NMK-01”相匹配的价格&库存,您可以联系我们找货
