SB® 175 Connectors
Up to 280 Amps
Wires sizes from 10 to 1/0 AWG (5.3 to 50 mm²) fit in
the second to largest connector in the SB® series. The
3 pole SB® 175 adds an additional position for power
or grounding. All Multipole wire connector housings
are genderless and mate to themselves minimizing
inventory and assembly complexity.
2 Pole
• Silver Plated Wire Contacts up to 1/0 (50 mm²)
3 Pole
Allows UL rated currents up to 280 amps
• Chemical Resistant Housing Option
Extends temperature range down to -40°C, while offering
enhanced UV and chemical resistance
• UL Rated for Hot Plugging up to 100 Amps
Great for battery or other applications where the ability to
interrupt circuits is required
SB® 175
SB® 175 ORDERING INFORMATION
SB® 175 Standard Housings
The second to largest SB® housings work with wire contacts up to 1/0
AWG (50 mm²) as well as busbar contacts. Genderless design mates with
itself. Mechanical keys are color-coded. NOTE: SB® 175 black housing is
keyless and can be mated with all other colors.
Description
Minimum Quantity
Yellow
Orange
Red
Gray
Blue
Black (Keyless)
Bottom View
[ 79.6 ]
3.13
Part Numbers
200
50
943-BK 943
942-BK 942
949-BK 949
940-BK 940
941-BK 941
2-7252G11 -
[ 6.5 ]
Ø 0.26
(2) PLC’S
[ 55.6]
2.19
Material ID
P = Chemical
Resistant
[ 28.6 ]
1.13
Mated Length
SB® 175 Chemical Resistant Housings
[ 133.4 ]
5.25
Same features as the Standard SB® 175 but molded in a
chemical resistant PBT/ PC blend. Suitable for use to -40°C.
Description
Minimum Quantity
Red
Gray
[ 25.4 ]
1.00
Part Numbers
200
50
P949-BK P949
P940-BK P940
SB® 175 2/0 Housing
Genderless design mates with itself. Can be cross mated with gray SB®
175 housing, but amperage capability is limited to the SB® 175 rating with
the wire and contact used.
Top View
[ 28.6 ]
1.13
[ 39.7 ]
1.56
Voltage
Description
Color-Code
Part Number
Minimum Quantity
100
Gray
36V
115107G1
Housing marking
specifying 1328G1 contact ONLY
- 88 -
www.andersonpower.com
[ 11.3 ]
0.45
[ 79.4 ]
3.13
Side View
[ 25.4 ]
1.00
All Data Subject To Change Without Notice
SB® 175 3 Pole Housings & Hardware
A three pole version of the standard SB® 175 housing has
a two piece housing with springs and hardware. Useful for
DC 2 wire plus ground and AC single phase applications.
Top View
[ 79.4 ]
3.13
Part Numbers
Description
Minimum Quantity
Gray Housing and Hardware Kit
Gray Housing Top Half
Gray Housing Bottom Half
Hardware Kit
100
2-5048
2-5049
25
902
110G34
[ 11.7 ]
0.46
[ 6.7 ]
Ø 0.27 (4)
[28.6]
1.13
[ 28.6 ]
1.13
Side View
[ 25.4 ]
1.00
[ 82.6 ]
3.25
[ 26.2 ]
1.03
SB® 175 Silver Plated Wire Contacts
Silver plated contacts offer superior electrical performance and durability up to 10,000 mating cycles.
See reducing bushings in accessory section for smaller wires.
Dimensions
Mating
Loose Piece
-A-
-B- C -
mm²
Force
Part Numbers
inches mm inches mm
Minimum Quantity
500
50
High 1382-BK 1382
1/0 53.5
1
42.4 High
1347
1347-BK
2
33.6 High
1383
1383-BK
4
21.1 High
1384
1384-BK
6
13.3 High
1348
1348-BK
2/0 *
70
Low
1328G1-BK 1328G1
-D-
inches mm
SB® 175
AWG
inches mm
2.35
59.69
0.52
13.21
0.44
11.18 1.04 26.42
2.35 59.69 0.52
13.21 0.39 9.91
1.04
26.42
2.35 59.69 0.52
13.21 0.35 8.89
1.04
26.42
2.35 59.69 0.52
13.21 0.30 7.62
1.04
26.42
2.10 53.34 0.37
9.40
0.22 5.59
0.80
26.42
2.35 59.69 0.64 16.26 0.49 12.45
1.04
26.42
[ 12.7 ]
0.50
A
D
* Use with 115107G1 only
C
B
SB® 175 Silver Plated Busbar Contacts
Provides a quick disconnect input or output busbar connection.
Busbar contacts are for mating with wire contacts only. Part number
180BBS includes lock nuts. Locknuts must be ordered separately
for 180BBS-BK.
Mating
Type
Thread
Minimum Quantity
Busbar
1/4-20
Lock Nut 1/4-20
Force
High
See Busbar contact drawing on
website for further detail.
Loose Piece Part Numbers
1,000
120
180BBS-BK
H1216P7 110G56
10
180BBS
110G55
[ 109.0 ]
4.29
#¼- 20 THD
[ 25.4 ]
1.0
B
[ 12.7 ]
0.5
[ 4.57 ]
0.18
Silver Plated Wire Contacts -
use with 2/0 Housing ONLY
Silver plated contacts offer superior electrical performance and durability up to 5,000 mating cycles.
Type
AWG mm²
Minimum Quantity
300
50
Individual
1328G1-BK
1328G1
2/0
70
Dimensions
-A-
inches mm
2.35 59.69
- B -
-C-
-D-
inches mm
inches mm
inches mm
0.64
0.49
D
C
16.26
12.45 1.04
26.42
A
[ 12.7 ]
0.50
B
- 89 -
SB® 175 CONNECTOR TEMPERATURE CHARTS - Temperature rise charts are based on a 25°C
ambient temperature.
Current - Temperature Derating per IEC 60512-5-2 Test 5B
SB® 175
Temperature Rise at Constant Current
60
SB® 175
Derating vs. Ambient Temperature
Temperature Rise
Above Ambient (°C)
100
75
50
50
40
30
125
SB® 175 2/0
Temperature (°C)
Temperature (°C)
SB® 175
25
5
15
SB® 175 2/0
60
50
75
50
100
150
200
250
Amperes Applied
2/0
- 90 -
12
1 AWG
4 AWG
100
25
75
10
50
Amperes Applied
1/0 AWG
1 AWG
2 AWG
4 AWG
Amperes Applied
1/0 AWG
2 AWG
5
50
75
10
5
15
5
5
25
5
30
Ambient Temperature (°C)
125
70 mm
300
40
30
100
150
200
250
Amperes Applied
2/0
70 mm
SB® 175 CONNECTOR SPECIFICATIONS
ELECTRICAL
Current Rating Amperes ¹
MECHANICAL
UL 1977
CSA
Wire-to-Wire (1/0 AWG)
280
175
Wire-to-Busbar (1/0 AWG)
200
3 Pole Wire-to-Wire (1/0 AWG)
175
600
Dielectric Withstanding Voltage
Volts AC
2,200
Avg. Mated Contact Resistance Milliohms ¹
6” of 1/0 AWG wire
0.100
Hot Plug Current Rating Amperes - Wire & Busbar
250 cycles at 120V DC 1/0 Wires
Wire Contacts with Bushings
Max. Wire Insulation Diameter
Operating Temperature ²
Voltage Rating AC/DC
UL 1977
Wire Size Range
100A
Polycarbonate
Chem. Resistant Resin
Polycarbonate / PBT
blend
Contact Retention Spring
Stainless Steel
5.3 to 53.5
in.
mm
0.600
15.240
°F
°C
-4° to 221°
-20° to 105°
Chemical Resistant
-40 to 221°
-40° to 105°
Mating Cycles No Load by Plating
Silver (Ag)
Wire and Busbar Contacts
10,000
Avg. Mating / Unmating Force
Lbf.
N
2 Pole
25
111
3 Pole
35
156
Lbf.
N
150
667
213
Condition A
50g’s
204
Condition A
10g’s
Min. Contact / Spring Retention Force
4
MIL-STD-202
Standard Plastic Resin
10 to 1/0
SB® 175
Housing
mm²
Standard
Mechanical Shock
MATERIALS
AWG
Vibration High Frequency 4
MIL-STD-202
Housing Flammability Rating
UL94
V-0
Glow Wire
960°C (GWFI) / 850°C
(GWIT)
Wire & Busbar Contacts
Base
Copper Alloy
Plating
Silver
Contact Termination Methods
Crimp ³
Wire Contacts
Hand Solder
Wire Contacts
Wrench / Socket
Busbar Contacts Only
NOTE 1: See IEC 60664-1 for working voltage.
NOTE 2: Amp ratings are stated per position and based on all positions being fully loaded.
1 - Based on: 105°C rated or better cable of the largest size. Properly calibrated APP® recommended tooling, and a 25°C ambient temperature. UL rating
not to exceed the maximum operating temperature. CSA rating below a 30°C temperature rise.
2 - Limited by the thermal properties of the connector plastic housing.
3 - Use APP® recommended tooling only. Alternate tools may adversely affect the performance of our connectors along with UL and CSA recognition.
4 - Tested with contact part number 1382.
- 91 -
SB® 175 CONNECTOR IEC INFORMATION
Creepage /
Clearance Material
Configurations
per IEC
Group
60950-1
ATTRIBUTES
SB® 175
AMP Rating AC/DC
175
Voltage Rating AC/DC (Steady State)
500 V AC/DC (Operational)
Unmated
5.73 mm
Breaking Capacity - AMP Rating / Cycles
175 Amp / 10 Cycles
Mated
5.73 mm
Voltage Rating (Breaking Capacity)
220 VDC
Finger Safety - Mated Only
IEC 60529 - IP20
PROTECTION
Wire Size Tested
50 mm²
Touch Safety with Wire Contacts
Contact Series Tested
1382
Climatic Testing (Cold, Heat & MFG)
IEC 60512 Test -11j, 11i & 11g
Cycle Life
IEC 60512 Test 9a - 5000 Cycles
Mechanical Strength Impact
IEC 60512-5 @ 29.5 Inches Dropped 8 Times
Temperature Range
-20 °C to 105 °C
Connector
Series
SB® 175
IEC 60529
IIIa
IP10 unmated
Environmental Sealing with Boots
IEC 60529
IP64
SB® 175
-4 °F to 221 °F
SB® 175 2/0 CONNECTOR SPECIFICATIONS
ELECTRICAL
MECHANICAL
Current Rating (Amperes)
UL 1977
CSA
2/0 AWG
340
200
70 mm²
315
185
1
Voltage Rating (AC/DC)
Contact Wire Range (AWG)
(mm²)
AVG Contact Resistance (milli-ohms)
2,200
1
0.045
70
MAX Wire Insulation Diameter (in)
0.67
(mm)
600
Dielectric Withstanding Voltage (AC)
2/0
17.04
Operating Temperature 2
PC Housing
°C
°F
-20° to 105°
-4° to 221°
AVG Contact Retention Force for Standard PC Housing
(lbf)
(N)
MATERIALS
Standard Housing
PC
Flammability Rating
UL94 V-0
Wire Power Contact
Copper Alloy, Silver Plate
150 lbf
667 n
Mating Cycles (no load)
Connector AVG Connect / Disconnect
5,000
(lbf)
55
(N)
245
Crimp 3
Hand Solder
¹ Based on: 105°C rated or better cable of the largest size. Properly calibrated APP® recommended tooling, and a 25°C ambient temperature. UL rating not to
² Limited by the thermal properties of the connector plastic housing.
³ Use APP® recommended tooling only. Alternate tools may adversely affect the performance of our connectors along with UL and CSA recognition.
- 92 -
SB® 175 ACCESSORIES
Cable Clamps
Durable metal cable clamps securely hold cables to prevent accidental strain or pulls from dislodging wire or contacts from
the housing. Only Bolt On type clamps can be used with the handles. Cable clamps are recommended for solder terminated
wires. Not for use with 3 pole housing.
Cable Size
Max / Min In. Max / Min mm
Description
Inches O.D. mm O.D.
Part Numbers
100
50
Minimum Quantity
Self Attaching for Discrete Conductor 0.55 to 0.24 14 to 6
105G3
945
0.66 to 0.24 16.7 to 6.2
945G3-BK 945G3
Bolt On for Discrete Conductor
Bolt On for Bundled Conductor
0.75 to 0.29 18.3 to 7.3
946G1-BK 946G1
* Torque value 30 (in - lbs) / 3.4 (Nm)
NOTE: For assembly of clamp to housing only
"A" Frame Handle
(not included).
945
SB® 175
946G1
"A" Frame Handle
(not included).
945G3
The given wire O.D. information is an
estimate. Cable clamps should be
evaluated for performance with the
actual wire to be used.
Handles
Handles are made out of durable PC plastic. Hardware to
attach to connector body included in kits. Not for use with
3 pole housing.
Description
Part Numbers
25
Minimum Quantity
100
Gray Handle Kit
995G1
Red Handle Kit
995G3
Handle Only, Gray
3-5074P1
Handle Only, Red
3-5074P3
Handle Only, Black
3-5074P5
Hardware Bag
105G8
995G1
* Torque value 30 (in lbs) / 3.4 (Nm)
Dust Cover
Prevents dust and dirt from entering the mating interface
of the connector when unmated. NOTE: Not a Hermetic Seal.
Description
Part Numbers
Minimum Quantity
500
50
Dust Cover with Lanyard Strap, Red
113890P2 134G2
Slide cover over
mating end.
- 93 -
SB® Environmental Boots
SB® Environmental Boots provide water, dirt, chemical and UV protection for SB® 175
connectors. The durable boots shield the connectors from water and dirt to IP64* in
both the mated and unmated condition.
Dimensions
-A-BPart Numbers
Description
in.
Minimum Quantity
250
25
SB® 175 Environmental Boot, Load
SB® 175 Environmental Boot, Source
* IP64 test pending
3-6037P1-BK
3-6036P1-BK
3-6037P1
3-6036P1
mm
9.5 241
9.5 241
in.
mm
3.2 80
3.2 80
-Cin.
mm
9.3
9.3
236
236
A
C
B
SB® 175 Lockout
SB® 175
Works with standard lockout - tagout equipment to prevent access
to the mating interface of the connector. Made from durable PC plastic.
Can be used with 3 pole housing to lockout positive and negative
positions only.
Description
Part Number
Minimum Quantity
Red Lockout - Tagout Kit
25
SB175-LOCKOUT
SB® 175 Connector not included.
Manual Release Bracket - Mounting Side *
Works with the Locking Side to ease mating and unmating connectors.
Description
Part Number
Minimum Quantity
Mounting Plate and Hardware Kit
10
924G1
Mounting Plate
NOTE: For assembly of bracket to housing only
Hardware
Manual Release Bracket - Locking Side *
Works with the Mounting Side to ease mating and unmating
connectors. Not for use with 3 pole housing.
Cable Size
Max / Min
Max / Min
Description
Inches O.D.
Minimum Quantity
Locking plate, handle, clamp and hardware kit.
0.50 to 0.21
mm O.D.
Part Number
12.6 to 5.4
10
923G1
The given wire O.D. information is an estimate. Cable clamps should be evaluated for
performance with the actual wire to be used.
- 94 -
[ 90 ]
3.5
Reducing Bushings: for Use with Contact Part Number 1382
Use with contact part number 1382-BK to allow a smaller wire to be used with the connector. Electrical capability is derated with smaller wire.
Dimensions
Wire Size
- ID Contact Barrel Size
AWG
AWG
mm²
Minimum Quantity
1/0
53.5
1
2
1/0
53.5
1/0
53.5
4
6
1/0
53.5
1/0
53.5
10 to 8
[ 25.4 ]
1.00
mm²
Part Numbers
1,500
1,000
42.4 - -
33.6
5690-BK -
21.2
5693-BK
13.3
5663-BK
5.3 to 8.4
5648-BK
500
5687-BK
inches
100
5687
5690
5693
5663
5648
0.39
0.34
0.27
0.22
0.19
mm
9.91
8.64
6.86
5.59
4.83
ID
Wire Entrance
SB® 175
- 95 -
SB® Tooling Information
Wire Size
AWG
mm²
Loose Piece Part
Number
Silver Plating
Loose Piece Contact Crimp Tools
Hand Tool
OR
Pneumatic
Tool
Die
Locator
Number of
Crimps
SB® 50
6
13.3
8
8.4
1307
5900
5952
1388G6
1309G4
1387G1
Single
5953
10 to 12
5.3 to 3.3
1
42.4
1323G1
2
33.6
1319
4
21.2
1319G4
6
13.3
1319G6
1389G6
1388G7
5915
1389G7
SB® 120
1388G3
1368 Series
1387G1
1388G4
1389G4
Single
SB® TOOLING
SB® 175
1/0
53.5
1382
1
42.4
1347
2
33.6
1383
4
21.1
1384
6
13.3
1348
1368 Series
1387G2
1303G13
1304G32
Double
1387G1
1388G4
1389G3
Single
SB® 350
350 mcm
185
910
300 mcm
152
910
4/0
107.2
908
3/0
85
916
2/0
67.4
907
1/0
53.5
917
N/A
1303G3
1368 Series
1387G2
Double
1304G31
1303G12
NOTE: See website for the most current information.
SB® 2/0 Tooling Information
Wire Size
Loose Piece Part
Number
AWG
mm²
Silver Plating
Hand Tool
2/0
53.5
1328G1
1368
OR
Pneumatic
Tool
1387G2
Die
1303G12
Locator
Number of
Crimps
1304G32
Double
Your Best Connection™
2020-0055 DS-SB175
REV C7
Anderson™ will use reasonable efforts to include accurate and up-to-date content in the data sheet. All product information contained in the data sheet including ordering information,
illustrations, specifications, and dimensions, are believed to be reliable as of the date of publishing, but is subject to change without notice. Anderson™ makes no warranty or representation as
to its accuracy. Content in the data sheet may contain technical inaccuracies, typographical errors and may be changed or updated without notice. Anderson™ may also make improvements
and/or changes to the products and/or to the programs described in the content at any time without notice. Current sales drawings and specifications are available upon request.
©2020 Anderson Power Products, Inc. All rights reserved. APP®, A®, Anderson Power Products®, SB® and the APP Logo are registered trademarks of Anderson Power Products, Inc. Anderson™ and
Your Best Connection™ are trademarks of Anderson Power Products, Inc.
- 101 -
很抱歉,暂时无法提供与“940-BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+19.90010
- 100+17.91020
- 200+16.11940
- 国内价格 香港价格
- 1+87.921731+11.27217
- 10+76.1982610+9.76914
- 25+67.2327525+8.61970
- 50+60.1543150+7.71220
- 100+52.75132100+6.76308
