SS210ATR
SS210ATR
    SMCDIODESOLUTIONS(桑德斯)
    SS210ATR
SS210ATR 数据手册
SS22A THRU SS225A Technical Data Data Sheet N1816, Rev. A SS22A THRU SS225A SCHOTTKY RECTIFIER Features Schottky Brrier Chip Low Power Loss, High Efficiency Ideally Suited for Automatic Assembly Surge Overload Rating to 50A Peak Plastic Case Material has UL Flammability Classification Rating 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request        SMA  Circuit Diagram Mechanical Data Case: SMA, Molded plastic Terminals: Plated leads solderable per MIL-STD-750, Method 2026 guaranteed Polarity: Color band denotes cathode end Mounting Position: Any     Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Symbol SS 22A SS SS SS 23A 24A 245A SS SS SS SS SS SS SS Units 25A 26A 28A 210A 215A 220A 225A Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VDC 20 30 40 45 50 60 80 100 150 200 250 V RMS Reverse Voltage VRMS 14 21 28 31 35 42 56 70 140 175 V Type Number Average forward rectified output current @TA = 90°C 105 IO 2 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 50 A Forward Voltage (per element) VFM @IF =2.0A 0.55 0.7 0.85 V IRM Typical Junction Capacitance(per leg) (Note 1) CJ 28 pF RθJL 88 °C/W TJ, TSTG -55 to +150 °C Operating and Storage Temperature Range 0.05 5 0.95 Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 100°C Typical Thermal Resistance (per leg) (Note 2) 0.1 10 0.92 Note: 1. VR = 5V, TC = 25 C, fSIG = 1MHz 2. mounted on P.C. Board with 5.0mm2 copper pad areas.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  mA SS22A THRU SS225A Technical Data Data Sheet N1816, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SS22A THRU SS225A Technical Data Data Sheet N1816, Rev. A Mechanical Dimensions SMA SYMBOL Ordering Information Device SS22A - SS225A Package SMA (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 2.40 2.84 0.094 0.112 B 3.99 4.75 0.157 0.187 C 1.05 1.70 0.041 0.067 D 0.15 0.51 0.006 0.020 E 4.80 5.66 0.189 0.223 F 1.90 2.95 0.075 0.116 G 0.05 0.25 0.002 0.010 H 0.76 1.52 0.030 0.600 Marking Diagram Where XXXXX is YYWWL Shipping SS22A YY WW L 5000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Part Name = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification SMA SYMBOL A B C d E F P P0 P1 T W Millimeters Min. Max. 2.97 5.70 2.32 1.40 1.40 5.60 3.90 3.90 1.90 0.25 3.17 5.90 2.52 1.60 1.60 5.70 4.10 4.10 2.10 0.35 11.80 12.20  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SS22A THRU SS225A Technical Data Data Sheet N1816, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SS210ATR 价格&库存
很抱歉,暂时无法提供与“SS210ATR”相匹配的价格&库存,您可以联系我们找货
SS210ATR
    • 10+0.7734610+0.10057
    • 100+0.56141100+0.07300
    • 1000+0.497101000+0.06464
    • 5000+0.445825000+0.05797
    库存:13289
    SS210ATR
    • 10+0.71916
    • 100+0.52200
    • 1000+0.46223
    • 5000+0.41456
    库存:13289
    SS210ATR
      SS210ATR
        SS210ATR
