941-BK
941-BK
    ANDERSON
    941-BK
941-BK 数据手册
SB® 175 Connectors Up to 280 Amps Wires sizes from 10 to 1/0 AWG (5.3 to 50 mm²) fit in the second to largest connector in the SB® series. The 3 pole SB® 175 adds an additional position for power or grounding. All Multipole wire connector housings are genderless and mate to themselves minimizing inventory and assembly complexity. 2 Pole • Silver Plated Wire Contacts up to 1/0 (50 mm²) 3 Pole Allows UL rated currents up to 280 amps • Chemical Resistant Housing Option Extends temperature range down to -40°C, while offering enhanced UV and chemical resistance • UL Rated for Hot Plugging up to 100 Amps Great for battery or other applications where the ability to interrupt circuits is required SB® 175 SB® 175 ORDERING INFORMATION SB® 175 Standard Housings The second to largest SB® housings work with wire contacts up to 1/0 AWG (50 mm²) as well as busbar contacts. Genderless design mates with itself. Mechanical keys are color-coded. NOTE: SB® 175 black housing is keyless and can be mated with all other colors. Description Minimum Quantity Yellow Orange Red Gray Blue Black (Keyless) Bottom View [ 79.6 ] 3.13 Part Numbers 200 50 943-BK 943 942-BK 942 949-BK 949 940-BK 940 941-BK 941 2-7252G11 - [ 6.5 ] Ø 0.26 (2) PLC’S [ 55.6] 2.19 Material ID P = Chemical Resistant [ 28.6 ] 1.13 Mated Length SB® 175 Chemical Resistant Housings [ 133.4 ] 5.25 Same features as the Standard SB® 175 but molded in a chemical resistant PBT/ PC blend. Suitable for use to -40°C. Description Minimum Quantity Red Gray [ 25.4 ] 1.00 Part Numbers 200 50 P949-BK P949 P940-BK P940 SB® 175 2/0 Housing Genderless design mates with itself. Can be cross mated with gray SB® 175 housing, but amperage capability is limited to the SB® 175 rating with the wire and contact used. Top View [ 28.6 ] 1.13 [ 39.7 ] 1.56 Voltage Description Color-Code Part Number Minimum Quantity 100 Gray 36V 115107G1 Housing marking specifying 1328G1 contact ONLY - 88 - www.andersonpower.com [ 11.3 ] 0.45 [ 79.4 ] 3.13 Side View [ 25.4 ] 1.00 All Data Subject To Change Without Notice SB® 175 3 Pole Housings & Hardware A three pole version of the standard SB® 175 housing has a two piece housing with springs and hardware. Useful for DC 2 wire plus ground and AC single phase applications. Top View [ 79.4 ] 3.13 Part Numbers Description Minimum Quantity Gray Housing and Hardware Kit Gray Housing Top Half Gray Housing Bottom Half Hardware Kit 100 - 2-5048 2-5049 - 25 902 110G34 [ 11.7 ] 0.46 [ 6.7 ] Ø 0.27 (4) [28.6] 1.13 [ 28.6 ] 1.13 Side View [ 25.4 ] 1.00 [ 82.6 ] 3.25 [ 26.2 ] 1.03 SB® 175 Silver Plated Wire Contacts Silver plated contacts offer superior electrical performance and durability up to 10,000 mating cycles. See reducing bushings in accessory section for smaller wires. Dimensions Mating Loose Piece -A- -B- C - mm² Force Part Numbers inches mm inches mm Minimum Quantity 500 50 High 1382-BK 1382 1/0 53.5 1 42.4 High 1347 1347-BK 2 33.6 High 1383 1383-BK 4 21.1 High 1384 1384-BK 6 13.3 High 1348 1348-BK 2/0 * 70 Low 1328G1-BK 1328G1 -D- inches mm SB® 175 AWG inches mm 2.35 59.69 0.52 13.21 0.44 11.18 1.04 26.42 2.35 59.69 0.52 13.21 0.39 9.91 1.04 26.42 2.35 59.69 0.52 13.21 0.35 8.89 1.04 26.42 2.35 59.69 0.52 13.21 0.30 7.62 1.04 26.42 2.10 53.34 0.37 9.40 0.22 5.59 0.80 26.42 2.35 59.69 0.64 16.26 0.49 12.45 1.04 26.42 [ 12.7 ] 0.50 A D * Use with 115107G1 only C B SB® 175 Silver Plated Busbar Contacts Provides a quick disconnect input or output busbar connection. Busbar contacts are for mating with wire contacts only. Part number 180BBS includes lock nuts. Locknuts must be ordered separately for 180BBS-BK. Mating Type Thread Minimum Quantity Busbar 1/4-20 Lock Nut 1/4-20 Force High - See Busbar contact drawing on website for further detail. Loose Piece Part Numbers 1,000 120 - 180BBS-BK H1216P7 110G56 10 180BBS 110G55 [ 109.0 ] 4.29 #¼- 20 THD [ 25.4 ] 1.0 B [ 12.7 ] 0.5 [ 4.57 ] 0.18 Silver Plated Wire Contacts - use with 2/0 Housing ONLY Silver plated contacts offer superior electrical performance and durability up to 5,000 mating cycles. Type AWG mm² Loose Piece Part Numbers Minimum Quantity 300 50 Individual 1328G1-BK 1328G1 2/0 70 Dimensions -A- inches mm 2.35 59.69 - B - -C- -D- inches mm inches mm inches mm 0.64 0.49 D C 16.26 12.45 1.04 26.42 A [ 12.7 ] 0.50 B All Data Subject To Change Without Notice www.andersonpower.com - 89 - SB® 175 CONNECTOR TEMPERATURE CHARTS - Temperature rise charts are based on a 25°C ambient temperature. Current - Temperature Derating per IEC 60512-5-2 Test 5B SB® 175 Temperature Rise at Constant Current 60 SB® 175 Derating vs. Ambient Temperature Temperature Rise Above Ambient (°C) 100 75 50 50 40 30 20 10 125 SB® 175 2/0 Derating vs. Ambient Temperature Temperature (°C) Temperature (°C) SB® 175 0 5 25 0 22 5 20 0 17 15 SB® 175 2/0 Temperature Rise at Constant Current 60 50 75 50 0 50 100 150 200 250 Amperes Applied 2/0 - 90 - 12 0 1 AWG 4 AWG 100 25 75 10 50 0 25 Amperes Applied 1/0 AWG 1 AWG 2 AWG 4 AWG Amperes Applied 1/0 AWG 2 AWG 5 0 25 0 25 50 75 10 0 12 5 15 0 17 5 20 0 22 5 25 0 27 5 30 0 Ambient Temperature (°C) 125 www.andersonpower.com 70 mm 300 40 30 20 10 0 0 50 100 150 200 250 Amperes Applied 2/0 70 mm All Data Subject To Change Without Notice SB® 175 CONNECTOR SPECIFICATIONS ELECTRICAL Current Rating Amperes ¹ MECHANICAL UL 1977 CSA Wire-to-Wire (1/0 AWG) 280 175 Wire-to-Busbar (1/0 AWG) 200 3 Pole Wire-to-Wire (1/0 AWG) 175 600 Dielectric Withstanding Voltage Volts AC 2,200 Avg. Mated Contact Resistance Milliohms ¹ 6” of 1/0 AWG wire 0.100 Hot Plug Current Rating Amperes - Wire & Busbar 250 cycles at 120V DC 1/0 Wires Wire Contacts with Bushings Max. Wire Insulation Diameter Operating Temperature ² Voltage Rating AC/DC UL 1977 Wire Size Range 100A Polycarbonate Chem. Resistant Resin Polycarbonate / PBT blend Contact Retention Spring Stainless Steel 5.3 to 53.5 in. mm 0.600 15.240 °F °C -4° to 221° -20° to 105° Chemical Resistant -40 to 221° -40° to 105° Mating Cycles No Load by Plating Silver (Ag) Wire and Busbar Contacts 10,000 Avg. Mating / Unmating Force Lbf. N 2 Pole 25 111 3 Pole 35 156 Lbf. N 150 667 213 Condition A 50g’s 204 Condition A 10g’s Min. Contact / Spring Retention Force 4 MIL-STD-202 Standard Plastic Resin 10 to 1/0 SB® 175 Housing mm² Standard Mechanical Shock MATERIALS AWG Vibration High Frequency 4 MIL-STD-202 Housing Flammability Rating UL94 V-0 Glow Wire 960°C (GWFI) / 850°C (GWIT) Wire & Busbar Contacts Base Copper Alloy Plating Silver Contact Termination Methods Crimp ³ Wire Contacts Hand Solder Wire Contacts Wrench / Socket Busbar Contacts Only NOTE 1: See IEC 60664-1 for working voltage. NOTE 2: Amp ratings are stated per position and based on all positions being fully loaded. 1 - Based on: 105°C rated or better cable of the largest size. Properly calibrated APP® recommended tooling, and a 25°C ambient temperature. UL rating not to exceed the maximum operating temperature. CSA rating below a 30°C temperature rise. 2 - Limited by the thermal properties of the connector plastic housing. 3 - Use APP® recommended tooling only. Alternate tools may adversely affect the performance of our connectors along with UL and CSA recognition. 4 - Tested with contact part number 1382. All Data Subject To Change Without Notice www.andersonpower.com - 91 - SB® 175 CONNECTOR IEC INFORMATION Creepage / Clearance Material Configurations per IEC Group 60950-1 ATTRIBUTES SB® 175 AMP Rating AC/DC 175 Voltage Rating AC/DC (Steady State) 500 V AC/DC (Operational) Unmated 5.73 mm Breaking Capacity - AMP Rating / Cycles 175 Amp / 10 Cycles Mated 5.73 mm Voltage Rating (Breaking Capacity) 220 VDC Finger Safety - Mated Only IEC 60529 - IP20 PROTECTION Wire Size Tested 50 mm² Touch Safety with Wire Contacts Contact Series Tested 1382 Climatic Testing (Cold, Heat & MFG) IEC 60512 Test -11j, 11i & 11g Cycle Life IEC 60512 Test 9a - 5000 Cycles Mechanical Strength Impact IEC 60512-5 @ 29.5 Inches Dropped 8 Times Temperature Range -20 °C to 105 °C Connector Series SB® 175 IEC 60529 IIIa IP10 unmated Environmental Sealing with Boots IEC 60529 IP64 SB® 175 -4 °F to 221 °F SB® 175 2/0 CONNECTOR SPECIFICATIONS ELECTRICAL MECHANICAL Current Rating (Amperes) UL 1977 CSA 2/0 AWG 340 200 70 mm² 315 185 1 Voltage Rating (AC/DC) Contact Wire Range (AWG) (mm²) AVG Contact Resistance (milli-ohms) 2,200 1 0.045 70 MAX Wire Insulation Diameter (in) 0.67 (mm) 600 Dielectric Withstanding Voltage (AC) 2/0 17.04 Operating Temperature 2 PC Housing °C °F -20° to 105° -4° to 221° AVG Contact Retention Force for Standard PC Housing (lbf) (N) MATERIALS Standard Housing PC Flammability Rating UL94 V-0 Wire Power Contact Copper Alloy, Silver Plate Contact Termination Methods 150 lbf 667 n Mating Cycles (no load) Connector AVG Connect / Disconnect 5,000 (lbf) 55 (N) 245 Crimp 3 Hand Solder ¹ Based on: 105°C rated or better cable of the largest size. Properly calibrated APP® recommended tooling, and a 25°C ambient temperature. UL rating not to exceed the maximum operating temperature. CSA rating below a 30°C temperature rise. ² Limited by the thermal properties of the connector plastic housing. ³ Use APP® recommended tooling only. Alternate tools may adversely affect the performance of our connectors along with UL and CSA recognition. - 92 - www.andersonpower.com All Data Subject To Change Without Notice SB® 175 ACCESSORIES Cable Clamps Durable metal cable clamps securely hold cables to prevent accidental strain or pulls from dislodging wire or contacts from the housing. Only Bolt On type clamps can be used with the handles. Cable clamps are recommended for solder terminated wires. Not for use with 3 pole housing. Cable Size Max / Min In. Max / Min mm Description Inches O.D. mm O.D. Part Numbers 100 50 Minimum Quantity Self Attaching for Discrete Conductor 0.55 to 0.24 14 to 6 105G3 945 0.66 to 0.24 16.7 to 6.2 945G3-BK 945G3 Bolt On for Discrete Conductor Bolt On for Bundled Conductor 0.75 to 0.29 18.3 to 7.3 946G1-BK 946G1 * Torque value 30 (in - lbs) / 3.4 (Nm) NOTE: For assembly of clamp to housing only "A" Frame Handle (not included). 945 SB® 175 946G1 "A" Frame Handle (not included). 945G3 The given wire O.D. information is an estimate. Cable clamps should be evaluated for performance with the actual wire to be used. Handles Handles are made out of durable PC plastic. Hardware to attach to connector body included in kits. Not for use with 3 pole housing. Description Part Numbers 25 Minimum Quantity 100 Gray Handle Kit - 995G1 Red Handle Kit - 995G3 Handle Only, Gray 3-5074P1 Handle Only, Red 3-5074P3 Handle Only, Black 3-5074P5 Hardware Bag - 105G8 995G1 * Torque value 30 (in lbs) / 3.4 (Nm) NOTE: For assembly of clamp to housing only Dust Cover Prevents dust and dirt from entering the mating interface of the connector when unmated. NOTE: Not a Hermetic Seal. Not for use with 3 pole housing. Description Part Numbers Minimum Quantity 500 50 Dust Cover with Lanyard Strap, Red 113890P2 134G2 Slide cover over mating end. All Data Subject To Change Without Notice www.andersonpower.com - 93 - SB® Environmental Boots SB® Environmental Boots provide water, dirt, chemical and UV protection for SB® 175 connectors. The durable boots shield the connectors from water and dirt to IP64* in both the mated and unmated condition. Dimensions -A-BPart Numbers Description in. Minimum Quantity 250 25 SB® 175 Environmental Boot, Load SB® 175 Environmental Boot, Source * IP64 test pending 3-6037P1-BK 3-6036P1-BK 3-6037P1 3-6036P1 mm 9.5 241 9.5 241 in. mm 3.2 80 3.2 80 -Cin. mm 9.3 9.3 236 236 A C B SB® 175 Lockout SB® 175 Works with standard lockout - tagout equipment to prevent access to the mating interface of the connector. Made from durable PC plastic. Can be used with 3 pole housing to lockout positive and negative positions only. Description Part Number Minimum Quantity Red Lockout - Tagout Kit 25 SB175-LOCKOUT SB® 175 Connector not included. Manual Release Bracket - Mounting Side * Works with the Locking Side to ease mating and unmating connectors. Not for use with 3 pole housing. Description Part Number Minimum Quantity Mounting Plate and Hardware Kit 10 924G1 * Torque value 30 (in - lbs) / 3.4 (Nm) Mounting Plate NOTE: For assembly of bracket to housing only Hardware Manual Release Bracket - Locking Side * Works with the Mounting Side to ease mating and unmating connectors. Not for use with 3 pole housing. Cable Size Max / Min Max / Min Description Inches O.D. Minimum Quantity Locking plate, handle, clamp and hardware kit. 0.50 to 0.21 mm O.D. Part Number 12.6 to 5.4 10 923G1 * Torque value 30 (in - lbs) / 3.4 (Nm) NOTE: For assembly of bracket to housing only The given wire O.D. information is an estimate. Cable clamps should be evaluated for performance with the actual wire to be used. - 94 - www.andersonpower.com [ 90 ] 3.5 All Data Subject To Change Without Notice Reducing Bushings: for Use with Contact Part Number 1382 Use with contact part number 1382-BK to allow a smaller wire to be used with the connector. Electrical capability is derated with smaller wire. Dimensions Wire Size - ID Contact Barrel Size AWG AWG mm² Minimum Quantity 1/0 53.5 1 2 1/0 53.5 1/0 53.5 4 6 1/0 53.5 1/0 53.5 10 to 8 [ 25.4 ] 1.00 mm² Part Numbers 1,500 1,000 42.4 - - 33.6 5690-BK - 21.2 - 5693-BK 13.3 5663-BK - 5.3 to 8.4 - 5648-BK 500 5687-BK - - - - inches 100 5687 5690 5693 5663 5648 0.39 0.34 0.27 0.22 0.19 mm 9.91 8.64 6.86 5.59 4.83 ID Wire Entrance SB® 175 All Data Subject To Change Without Notice www.andersonpower.com - 95 - SB® Tooling Information Wire Size AWG mm² Loose Piece Part Number Silver Plating Loose Piece Contact Crimp Tools Hand Tool OR Pneumatic Tool + Die + Locator Number of Crimps SB® 50 6 13.3 8 8.4 1307 5900 5952 1388G6 1309G4 1387G1 Single 5953 10 to 12 5.3 to 3.3 1 42.4 1323G1 2 33.6 1319 4 21.2 1319G4 6 13.3 1319G6 1389G6 1388G7 5915 1389G7 SB® 120 1388G3 1368 Series 1387G1 1388G4 1389G4 Single SB® TOOLING SB® 175 1/0 53.5 1382 1 42.4 1347 2 33.6 1383 4 21.1 1384 6 13.3 1348 1368 Series 1387G2 1303G13 1304G32 Double 1387G1 1388G4 1389G3 Single SB® 350 350 mcm 185 910 300 mcm 152 910 4/0 107.2 908 3/0 85 916 2/0 67.4 907 1/0 53.5 917 N/A 1303G3 1368 Series 1387G2 Double 1304G31 1303G12 NOTE: See website for the most current information. SB® 2/0 Tooling Information Wire Size Loose Piece Part Number Loose Piece Contact Crimp Tools AWG mm² Silver Plating Hand Tool 2/0 53.5 1328G1 1368 OR Pneumatic Tool 1387G2 + Die 1303G12 + Locator Number of Crimps 1304G32 Double NOTE: See website for the most current information. Your Best Connection™ 2020-0055 DS-SB175 REV C7 Anderson™ will use reasonable efforts to include accurate and up-to-date content in the data sheet. All product information contained in the data sheet including ordering information, illustrations, specifications, and dimensions, are believed to be reliable as of the date of publishing, but is subject to change without notice. Anderson™ makes no warranty or representation as to its accuracy. Content in the data sheet may contain technical inaccuracies, typographical errors and may be changed or updated without notice. Anderson™ may also make improvements and/or changes to the products and/or to the programs described in the content at any time without notice. Current sales drawings and specifications are available upon request. ©2020 Anderson Power Products, Inc. All rights reserved. APP®, A®, Anderson Power Products®, SB® and the APP Logo are registered trademarks of Anderson Power Products, Inc. Anderson™ and Your Best Connection™ are trademarks of Anderson Power Products, Inc. All Data Subject To Change Without Notice www.andersonpower.com - 101 -
941-BK 价格&库存
很抱歉,暂时无法提供与“941-BK”相匹配的价格&库存,您可以联系我们找货
941-BK
    • 1+112.750561+13.42655
    • 10+97.7110610+11.63562
    • 25+86.2199725+10.26724
    • 50+77.1465750+9.18676
    • 100+67.65030100+8.05593
    库存:122
