IN-S63AT5G
IN-S63AT5G
    INOLUX(英诺斯)
    发光二极管/LED 翠绿色 顶视0603贴片式 PCB型
IN-S63AT5G 数据手册
IN-S63AT series Top View SMD LED 0603 PCB Type Features • 0603 0.4mm SMD LED • High Brightness • AlInGaP / InGaN Technology • Small package • High reliability • Clear Lens Description The IN-S63AT series is a popular low profile 0603 package with versatile design capabilities. It is a PCB type molding style LED which can be used in various applications. Recommended Solder Pattern Applications • Consumer Electronics • Wearables • Automobile After Market • Industrial Equipment Figure 1. IN-S63AT Solder Pattern Package Dimensions in mm Notes. 1. All dimensions are in millimeters. 2. Tolerance is ± 0.10 mm unless otherwise noted Figure 2. IN-S63AT Package Dimensions Inolux Corporation Proprietary & Confidential Page 1 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Absolute Maximum Rating at 25oC (Note 1) Product Emission Color Pd (mW) IF (mA) IFP* (mA) 75 25 70 VR (V) TOP (oC) TST (oC) 5 -40oC~+85oC -40oC~+90oC IN-S63AT5YG Yellow Green IN-S63AT5Y Yellow IN-S63AT5A Amber IN-S63ATR Red IN-S63AT5B Blue IN-S63AT5G Green IN-S63AT5UW White 75 25 100 Notes 1. Condition for IFP is pulse of 1/10 duty and 0.1msec width ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Inolux Corporation Proprietary & Confidential Page 2 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Electrical Characteristics T A = 25°C (Note 1) λ(nm) VF(V) Product Emission Color IN-S63AT5YG Yellow Green Viewing Angel I*V(mcd) IF(mA) typ. λD λP △λ 2θ1/2 typ. 5 2.0 573 574 15 120 11.5 IN-S63AT5Y Yellow 5 2.0 589 593 30 120 35 IN-S63AT5A Amber 5 2.0 605 609 30 120 35 IN-S63ATR Red 20 2.2 622 636 30 120 120 IN-S63AT5B Blue 5 2.8 470 468 30 120 45 IN-S63AT5G Green 5 2.7 525 530 35 120 285 IN-S63AT5UW White 5 2.8 X=0.29 Y=0.29 - - 120 285 Notes 1. Performance guaranteed only under conditions listed in above tables. Inolux Corporation Proprietary & Confidential Page 3 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Chromaticity Bin (for White only) Inolux Corporation Proprietary & Confidential Page 4 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Inolux Corporation Proprietary & Confidential Page 5 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Typical Characteristic Curves – YG, Y, A, R Inolux Corporation Proprietary & Confidential Page 6 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Typical Characteristic Curves – B, G, W Inolux Corporation Proprietary & Confidential Page 7 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Typical Characteristic Curves – Radiation Pattern Ordering Information Product IN-S63AT5YG Yellow Green AllnGaP 5 11.5 2.0 IN-S63AT5YG IN-S63AT5Y Yellow AllnGaP 5 35 2.0 IN-S63AT5Y IN-S63AT5A Amber AllnGaP 5 35 2.0 IN-S63AT5A IN-S63ATR Red AllnGaP 20 120 2.2 IN-S63ATR IN-S63AT5B Blue InGaN 5 45 2.8 IN-S63AT5B IN-S63AT5G Green InGaN 5 285 2.7 IN-S63AT5G IN-S63AT5UW White InGaN 5 285 2.8 IN-S63AT5UW Inolux Corporation Proprietary & Confidential Test Current Technology IF (mA) Forward Luminous Intensity Voltage IV (mcd) VF (V) (Typ.) (Typ.) Emission Color Page 8 Orderable Part Number September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Label Specifications Inolux P/N: I N - S 6 Material Inolux SMD S = PCB Type 3 Package A T Variation Orientation 63A = 1.6 x 0.8 x 0.4mm X T = Top Mount Current (Blank) = 20mA Lens Color (Blank) = Clear U = Diffused R=622nm A=609nm Y=593nm YG=574nm G=530nm B=468nm W=White 5=5mA - X X X Customized Stamp-off Lot No.: Z Internal Tracker Inolux Corporation Proprietary & Confidential 2 0 1 7 Year (2017, 2018, …..) Page 9 X 01 24 001 Month Date Serial September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Packaging Information: 4000pcs Per Reel Tape Dimension Reel Dimension Inolux Corporation Proprietary & Confidential Page 10 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Packing Dimension 5 boxes per carton are available depending on shipment quantity. Specification Material Quantity Carrier tape Per EIA 481-1A specs Conductive black tape 4000pcs per reel Reel Per EIA 481-1A specs Conductive black Label IN standard Paper Packing bag 220x240mm Aluminum laminated bag/ no-zipper One reel per bag Carton IN standard Paper Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Inolux Corporation Proprietary & Confidential Page 11 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Reflow Soldering • Recommended tin glue specifications: melting temperature in the range of 178~192 OC • The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Lead-free Solder Profile Inolux Corporation Proprietary & Confidential Page 12 September, 01, 2021 www.inolux-corp.com IN-S63AT series Top View SMD LED 0603 PCB Type Precautions • • • • • • Avoid exposure to moisture at all times during transportation or storage. Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products. It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a reverse voltage. Avoid operation beyond the limits as specified by the absolute maximum ratings. Avoid direct contact with the surface through which the LED emits light. If possible, assemble the unit in a clean room or dust-free environment. Reworking • • • Rework should be completed within 5 seconds under 260 OC. The iron tip must not come in contact with the copper foil. Twin-head type is preferred. Cleaning Following are cleaning procedures after soldering: • An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended. • Temperature x Time should be 50oC x 30sec. or
IN-S63AT5G 价格&库存
很抱歉,暂时无法提供与“IN-S63AT5G”相匹配的价格&库存,您可以联系我们找货
IN-S63AT5G
  • 1+0.48000
库存:2921
IN-S63AT5G
  • 4000+0.684084000+0.08886
  • 8000+0.641008000+0.08327
  • 12000+0.6188812000+0.08039
  • 20000+0.5938820000+0.07715
  • 28000+0.5789928000+0.07521
  • 40000+0.5644840000+0.07333
IN-S63AT5G
  • 1+2.096541+0.27233
  • 10+1.3910310+0.18069
  • 100+1.01348100+0.13165
  • 500+0.78642500+0.10216
  • 1000+0.695081000+0.09029
  • 2000+0.608092000+0.07899
  • 4000+0.525444000+0.06826
  • 8000+0.490658000+0.06374
库存:3336
IN-S63AT5G
  • 1+3.966401+0.51530
  • 10+3.1746010+0.41240
  • 25+3.1721025+0.41210
  • 100+1.50590100+0.19570
  • 250+1.48830250+0.19340
  • 500+1.33800500+0.17390
  • 1000+1.324301000+0.17210
库存:854
IN-S63AT5G
  • 1+1.95002
  • 10+1.29386
  • 100+0.94267
  • 500+0.73150
  • 1000+0.64657
  • 2000+0.56560
  • 4000+0.48870
  • 8000+0.45636
库存:3336
IN-S63AT5G
  • 1+2.292961+0.29785
  • 10+1.5346810+0.19935
  • 100+1.07513100+0.13966
  • 500+0.86395500+0.11223
  • 1000+0.794271000+0.10318
  • 2000+0.734752000+0.09544
