SURFACE MOUNT LED
RED, 0603 PACKAGE, 2mA
SM0603HCL
Industry Standard 0603 Package
RoHS Compliant
Small Package and Footprint
Low Current, 2mA
Water Clear Lens
Wide Viewing Angle
Ideal for Status Indication, Display, and Backlighting
Bivar Surface Mount 0603 package LED may be used in nearly any lighting or indication application.
The miniature package is ideal for small scale applications such as general indication and backlighting.
Low power consumption and excellent long life reliability are suitable for battery powered equipment.
Bivar offers water clear LED lens for maximum luminous intensity. Wide variety of wavelength and
intensity combinations are available to meet any illumination need. The SM0603 LED is packaged in
standard tape and reels for pick and place assemblies.
Part Number
Material
Emitted Color
Peak
Wavelength
λp(nm) TYP.
Lens
Appearance
Luminous
Intensity
(mcd) TYP.
Viewing Angle
SM0603HCL
AlGaInP
HE RED
645
Water Clear
11.5
130°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Level 4
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 05/11
Page 1 of 5
3mm
(T1) Package
LEDs
SURFACE
MOUNT Discrete
LED
AMBER
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
78 mW
Forward Current ( DC )
30 mA
Peak Forward Current 1
100 mA
Reverse Voltage
5V
Operating Temperature Range
-30 ~ +80°C
Storage Temperature Range
-40 ~ +85°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 2 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
SM0603HCL
1.9
2.3
2
Notes: 1. Tolerance of forward voltage : ±0.05V.
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MAX
MIN
TYP
MAX
MIN
TYP
MAX
TYP
10
631
7.2
11.5
130
2. Tolerance of dominant wavelength : ±1.0nm.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 05/11
Page 2 of 5
3mm
(T1) Package
LEDs
SURFACE
MOUNT Discrete
LED
AMBER
Typical Electrical / Optical Characteristics
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 05/11
Page 3 of 5
3mm
(T1) Package
LEDs
SURFACE
MOUNT Discrete
LED
AMBER
Recommended Soldering Conditions
Tape and Reel Dimensions
Note: 4000 pcs/Reel
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 05/11
Page 4 of 5
3mm
(T1) Package
LEDs
SURFACE
MOUNT Discrete
LED
AMBER
2. Standard tolerance unless otherwise noted: X.XXX ± 0.010"
X.X ± 0.1”
Packaging and Labeling Plan
Note: 1 Reel / Bag
Sealed ESD and Moisture Barrier Bag
Internal Quality Control Label
X.XXX
Humidity Indicator
Card
X.XXX
Desiccant
Bivar Standard Packaging Label
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
05/11
Page
Page 4
5 of
of 4
5
很抱歉,暂时无法提供与“SM0603HCL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.200411+0.67475
- 10+3.6040610+0.46763
- 100+2.60149100+0.33754
- 500+2.14937500+0.27888
- 1000+2.000871000+0.25962
- 2000+1.874652000+0.24324
- 国内价格
- 1+2.73672
- 200+1.09199
- 500+1.05549
- 1000+1.03745
- 国内价格 香港价格
- 4000+1.767464000+0.22933
- 8000+1.676578000+0.21754
- 12000+1.6299712000+0.21149
- 20000+1.5773720000+0.20467
- 28000+1.5460928000+0.20061
- 40000+1.5156040000+0.19665
