SB® 120 Connectors
Up to 240 Amps
Like the other Multipole connectors, the SB® 120 offers
color-coded mechanically keyed housings. Keys can
be used to identify and separate different circuits, or
prevent users from accidentally cross mating different
voltages. Wires sizes from 10 to 1 AWG (5.3 to 42.4 mm²)
are held in the second smallest SB® housing.
• New Extended Range Contacts Expand Wire Size up
to 1 AWG (42.4 mm²)
Allows UL rated currents up to 240 amps
• Chemical Resistant Housing Option
Extends temperature range down to -40°C, while offering
enhanced UV and chemical resistance
• Panel Mounting Grooves
SB® 120 ORDERING INFORMATION
With use of mounting clamps, can be easily mounted through panels
SB 120 Standard Housings
Bottom View
SB® 120
The second to smallest SB® housings work with wire
contacts up to 1 AWG (35 mm²) as well as busbar
contacts. Genderless design mates with itself.
Mechanical keys are color-coded.
Description
Minimum Quantity
Red
Gray
Blue
Part Numbers
250
50
6810G3-BK 6810G3
6810G1-BK 6810G1
6810G2-BK 6810G2
SB® 120 Chemical Resistant (CR) Housings
Same features as the Standard SB® 120 but molded in a chemical
resistant PBT/PC blend. Suitable for use to -40°C.
Description
Minimum Quantity
Red
Gray
[ 2.5 ]
0.10
[ 63.5 ]
2.50
[ 37.6 ]
1.48
[ 5.1 ]
Ø 0.20
(2) PLC’S
[ 46.4 ]
1.83
Material ID
P = Chemical Resistant
[ 19.1 ]
0.75
Part Numbers
250
50
P6810G3-BK P6810G3
P6810G1-BK P6810G1
[ 8.6 ]
0.34
[ 104.6 ]
4.12
[ 20.6 ]
0.81
Mated Length
SB® 120 Silver Plated Wire Contacts
Silver plated contacts offer superior electrical performance and durability up to 10,000 mating cycles.
See reducing bushings in accessory section for smaller wires.
Dimensions
Mating
-A-
-BAWG mm²
Force
Loose Piece Part Numbers
inches mm
inches mm
Minimum Quantity
600
500
50
1
42.4
Low
1323G1-BK -
1323G1
0.47 11.94 0.39 9.91
2
33.6
High
1319-BK
1319
0.44 11.18 0.34 8.64
4
21.1
High
1319G4-BK
1319G4
0.44 11.18 0.29 7.37
6
13.3
High
1319G6-BK
1319G6
0.44 11.18 0.22 5.59
_______________________________________________________________________________
1 (set) 42.4
Low
6811G7 (purchase as a set, no minimum quantity) 0.47 11.94 0.39 9.91
[ 21.3 ]
0.84
B
A
- 84 -
www.andersonpower.com
[ 50.8 ]
2.0
[ 10.4 ]
0.41
All Data Subject To Change Without Notice
SB® 120 Silver Plated Busbar Contacts
Use 2 busbar contacts per housing to provide a quick disconnect input or
output busbar connection. Busbar contacts are for mating with wire contacts only.
Part number 120BBS includes lock nuts. Locknuts must be ordered separately
for B01997P1.
Type
Thread
Mating
Force
Minimum Quantity
Busbar
10 to 24 High
Lock Nut 10 to 24 -
See Busbar contact drawing on
website for further detail.
[ 77.0 ]
3.03
1,000
300
B01997P1
H1216P8 -
#10 - 24 THD
[ 11.1 ]
0.44
[ 9.5 ]
0.38
120BBS
110G54
[ 2.5 ]
0.10
SB® 120 CONNECTOR TEMPERATURE CHARTS - Temperature rise charts are based on a 25°C
ambient temperature.
Current - Temperature Derating per IEC 60512-5-2 Test 5B
SB® 120
Temperature Rise at Constant Current
125
Temperature Rise
Above Ambient (°C)
40
30
100
75
50
25
50 75 100 125 150 175 200 225
SB® 120
Ambient Temperature (°C)
60
50
SB® 120
Derating vs. Ambient Temperature
0 25
Amperes Applied
1 AWG
2 AWG
4 AWG
6 AWG
50 75 100 125 150 175 200 225 250
Amperes Applied
1 AWG
2 AWG
4 AWG
6 AWG
SB® 120 CONNECTOR SPECIFICATIONS
MATERIALS
MECHANICAL
Wire Size Range
Housing
AWG
mm²
10 to 1
5.3 to 42.4
Standard Plastic Resin
Polycarbonate
in.
mm
Chem. Resistant Resin
Polycarbonate / PBT blend
0.600
15.240
Contact Retention Spring
Stainless Steel
°F
°C
Standard
-4° to 221°
-20° to 105°
Chemical Resistant
-40 to 221°
-40° to 105°
Wire Contacts with Bushings
Max. Wire Insulation Diameter
Operating Temperature ²
Mating Cycles No Load by Plating
Wire and Busbar Contacts
Avg. Mating / Unmating Force
Wire to Wire
Min. Contact / Spring Retention Force
Silver (Ag)
Housing Flammability Rating
UL94
V-0
Glow Wire
960°C (GWFI) / 800°C
(GWIT)
Wire & Busbar Contacts
10,000
Lbf.
N
Lbf.
N
75
333.6
Base
Copper Alloy
Plating
Silver
Contact Termination Methods
Crimp ³
Wire Contacts
Hand Solder
Wire Contacts
Wrench / Socket
Busbar Contacts Only
Specifications continued on next page
- 85 -
IEC INFORMATION
ELECTRICAL
Current Rating Amperes ¹
UL 1977
CSA
Wire-to-Wire (1 AWG)
240
130
Wire-to-Busbar (2 AWG)
120
Voltage Rating AC/DC
UL 1977
600
Dielectric Withstanding Voltage
Volts AC
2,200
Avg. Mated Contact Resistance Milliohms ¹
5 1/2” of 2 AWG Wire
0.136
Hot Plug Current Rating Amperes - Wire & Busbar
SB® 120
250 cycles at 120V DC
60A
NOTE 1: See IEC 60664-1 for working voltage.
NOTE 2: Amp ratings are stated per position and based on all positions being
fully loaded.
1 - Based on: 105°C rated or better cable of the largest size. Properly calibrated
APP® recommended tooling, and a 25°C ambient temperature. UL rating
not to exceed the maximum operating temperature. CSA rating below a 30°C
temperature rise.
2 - Limited by the thermal properties of the connector plastic housing.
3 - Use APP® recommended tooling only. Alternate tools may adversely affect the
performance of our connectors along with UL and CSA recognition.
SB® 120 ACCESSORIES
Mounting Clamp for SB® 120
Mounting clamps can be used for fastening a SB® 120 series
housings to a panel. Fastening hardware not included.
Description
Part Number
Minimum Quantity
20 sets of 2
Panel Mount Bracket
1467G1
2.38
1.75
ATTRIBUTES
SB®120
AMP Rating AC/DC
120
(Steady State)
400 V AC/DC (Operational)
Breaking Capacity - AMP
Rating / Cycles
120 Amp / 10 Cycles
Voltage Rating
(Breaking Capacity)
220 VDC
Finger Safety Mated Only
IEC 60529 - IP20
Wire Size Tested
50 mm²
Contact Series Tested
1323
Climatic Testing
Cold, Heat & MFG)
IEC 60512 Test -11j, 11i & 11g
Cycle Life
IEC 60512 Test 9a - 5,000 Cycles
Mechanical Strength Impact IEC 60512-5 @ 29.5 Inches Dropped 8 Times
Temperature Range
-20°C to 105°C
-4°F to 221°F
Creepage /
Clearance Material
Configurations
per IEC
Group
60950-1
Connector
Series
SB® 120
Unmated
4.10 mm
Mated
4.10 mm
IIIa
PROTECTION
Touch Safety with Wire Contacts
IEC 60529
IP10 unmated
Environmental Sealing with Boots
IEC 60529
IP64
1.82
1.44
0.16 DIA.
4 Places
0.88 High X 1.88 Wide
Panel Cutout
Cable Clamps *
Durable metal cable clamps securely hold cables to prevent accidental strain or pulls
from dislodging wire or contacts from the housing. Cable clamps are recommended
for solder terminated wires.
Cable Size
Min / Max
Min / Max
Description
Inches O.D.
mm O.D.
Part Numbers
Minimum Quantity
50
Bolt on for Discrete Conductor 0.70 to 0.23
17.7 to 5.8
981G1
Bolt on for Bundled Conductor 0.73 to 0.29
18.5 to 7.3
981G2
The given wire O.D. information is an estimate.
Cable clamps should be evaluated for
performance with the actual wire to
be used.
981G1
* Torque value 21 (in lbs) / 2.4 (Nm) NOTE: For assembly of clamp to housing only
981G2
- 86 -
“A” Frame Handle for SB® 120 *
Handle makes mating and unmating the connector easier.
The non-conductive gray plastic material is strong and safe.
Machine screws and locknuts included.
Description
Minimum Quantity
Screws
Part Number
200
Gray “A” Handle & Hardware
Handle
Connector
Housing not
Included
997G1
Locknuts
* Torque value 21 (in - lbs) / 2.4 (Nm)
“T” Handle *
The “T” handle makes mating and unmating the connector easier. The
non-conductive red plastic material is strong and safe. (2) Self tapping
screws are used to secure the handle to the connector housing.
Description
Part Numbers
Minimum Quantity
1,000
50
SB120-HDL-RED
Red “T” Handle + Hardware Bag
Red “T” Handle Only
113899P1
#8 x 7/8” Screw (Order 2 Per Handle) H1120P43
SB® 120
Dust Cover
Prevents dust and dirt from entering the mating interface of the connector
when unmated. NOTE: Not a Hermetic Seal.
Description
Part Numbers
Minimum Quantity
100
50
Dust Cover with Lanyard Strap, Black
B02019P1 134G4
Slide cover over
mating end.
Housing not included.
Shown with the SB® 50
SB® 120 Environmental Boots
Environmental Boots provide water, dirt, chemical and UV protection for SB® 120
connectors. The durable boots shield the connectors from water and dirt to IP64 in
both the mated and unmated condition.
Description
Part Numbers
Minimum Quantity
SB® 120 Environmental Boot, Load
SB® 120 Environmental Boot, Source
250
3-6035P1-BK
3-6034P1-BK
25
3-6035P1
3-6034P1
A
Dimensions
-A-
-B-
-C-
in.
mm
in.
mm
in.
mm
7.9
201
2.8
71
8.0
203
C
B
Reducing Bushings
Use with contact part number 1319-BK to allow a smaller wire to be used with the
connector. Electrical capability is derated with smaller wire.
Dimensions
Wire Size
- ID Contact Barrel Size
AWG mm²
AWG
Minimum Quantity
2
33.6
4
2
33.6
6
2
33.6
10 to 8
mm²
21.2
16
5.3 to 8.4
Part Numbers
2,000
1,000
5919-BK
5920-BK
5921-BK
100
5919
5920
5921
inches mm
0.28
0.23
0.18
7.11
5.84
4.57
[ 21.4 ]
0.84
ID
Wire Entrance
- 87 -
SB® Tooling Information
Wire Size
AWG
mm²
Loose Piece Part
Number
Silver Plating
Loose Piece Contact Crimp Tools
Hand Tool
OR
Pneumatic
Tool
Die
Locator
Number of
Crimps
SB® 50
6
13.3
8
8.4
1307
5900
5952
1388G6
1309G4
1387G1
Single
5953
10 to 12
5.3 to 3.3
1
42.4
1323G1
2
33.6
1319
4
21.2
1319G4
6
13.3
1319G6
1389G6
1388G7
5915
1389G7
SB® 120
1388G3
1368 Series
1387G1
1388G4
1389G4
Single
SB® TOOLING
SB® 175
1/0
53.5
1382
1
42.4
1347
2
33.6
1383
4
21.1
1384
6
13.3
1348
1368 Series
1387G2
1303G13
1304G32
Double
1387G1
1388G4
1389G3
Single
SB® 350
350 mcm
185
910
300 mcm
152
910
4/0
107.2
908
3/0
85
916
2/0
67.4
907
1/0
53.5
917
N/A
1303G3
1368 Series
1387G2
Double
1304G31
1303G12
NOTE: See website for the most current information.
SB® 2/0 Tooling Information
Wire Size
Loose Piece Part
Number
AWG
mm²
Silver Plating
Hand Tool
2/0
53.5
1328G1
1368
OR
Pneumatic
Tool
1387G2
Die
1303G12
Locator
Number of
Crimps
1304G32
Double
Your Best Connection™
2020-0055 DS-SB120
REV C7
Anderson™ will use reasonable efforts to include accurate and up-to-date content in the data sheet. All product information contained in the data sheet including ordering information,
illustrations, specifications, and dimensions, are believed to be reliable as of the date of publishing, but is subject to change without notice. Anderson™ makes no warranty or representation as
to its accuracy. Content in the data sheet may contain technical inaccuracies, typographical errors and may be changed or updated without notice. Anderson™ may also make improvements
and/or changes to the products and/or to the programs described in the content at any time without notice. Current sales drawings and specifications are available upon request.
©2020 Anderson Power Products, Inc. All rights reserved. APP®, A®, Anderson Power Products®, SB® and the APP Logo are registered trademarks of Anderson Power Products, Inc. Anderson™ and
Your Best Connection™ are trademarks of Anderson Power Products, Inc.
- 101 -
很抱歉,暂时无法提供与“6810G2-BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+60.921191+7.31701
- 10+52.7910710+6.34053
- 25+46.5841225+5.59504
- 50+41.6805250+5.00609
- 100+36.54910100+4.38977
