M6E-M
M6E-M
    THINGMAGIC
    M6E-M
M6E-M 数据手册
Micro High Performance Multi-Protocol Embedded UHF RFID Module The 2-port Micro delivers the size, operating efficiency, RF power, and flexibility needed to embed UHF RFID in best-in-class fixed position, portable, and hand held applications where small form factor is important. The Micro reads up to 750 tags/second and features low power consumption needed for battery operated applications. Micro’s wide RF output range (-5 dBm to +30 dBm) is a key requirement for RFID enabled printers, tag commissioning stations, and point of sales readers. Edge connections allow the Micro to be soldered directly to a motherboard as a standard component. The on-board connectors allow the module to be mated to a motherboard. Ordering Information Power Module M6E-M DC Power Required Development K it M6E-M-DEVKIT DC Voltage: 3.5 to 5.25 V** DC power consumption @ RF level: 5.5 W @ +30 dBm*** 3.5 W @ +27 dBm 2.5 W @ +23 dBm 2.0 W @ 0 dBm 0.32 W Tag / Transponder Protocols Power Consumption when not transmit ting RFID Protocol Support Idle Power Saving Options Standby: 0.06 W Sleep: 0.008 W Shutdown: 0.0003 W Physical Dimensions 46 mm L x 26 mm W x 4.0 mm H (1.8 in L x 1.0 in W x 0.16 in H) EPCglobal Gen 2 (ISO 18000-6C) with DRM IP-X and ISO 18000-6B optional RF Interface Antenna Connector Two 50 Ω connections (board-edge or U.FL) supporting two monostatic antennas RF Power Output Separate read and write levels, commandadjustable from -5 dBm to 30 dBm* in 0.5 dB steps, accurate to +/- 1 dBm Regulatory Pre-configured for the following regions: • FCC (NA, SA) 902-928 MHz • ETSI (EU, India) 865.6-867.6 MHz • TRAI (Inida) 865-867 MHz • KCC (Korea) 917-920.8 MHz • ACMA (Australia) 920-926 MHz • SRRC-MII (P.R.China) 920-925 MHz • MIC (Japan) 916.8-923.4 MHz • ‘Open’ (Customizable channel plan; 865-868 MHz and 902-928 MHz) Data/Control Interface Physical 28 board-edge connections or Molex low profile connector (53748-0208) providing DC power, com munication, control and GPIO signals Control/Data Interfaces • UART; 3.3V logic levels 9.6 to 921.6 kbps • USB 2.0 interface (12 Mbps) GPIO Sensors and Indicators Two 3.3V bidirectional ports configurable as input (sensor) ports or output (indicator) ports API support C#/.NET, Java, C Environment Certification FCC 47 CFR Ch. 1 Part 15 Industrie Canada RSS-21 0 ETSI EN 302 208 v1.4.1 Operating Temp. -20C to +60C (case temperature) Storage Temp. -40C to +85C Shock and Vibra tion Survives 1 meter drop during handling Performance Max Read Rate Up to 750 tags/second using high-performance settings MaxTag Read Distance Over 30 feet (9 m) with 6 dBiL antenna (36 dBm EIRP) Specifications subject to change without notice *Duty cycle restrictions, based on temperature, apply at power levels above +23 dBm **Will operate below +3.5 V with reduced input line noise immunity ***Best case with good antenna matching MAKING RFID EASY TO USE ThingMagic is dedicated to driving the barriers to deploying RFID technology as low as possible. We design our products to be easy to use out-of-the box and to deliver predictable, reliable, and repeatable performance. Our development tools require little RFID expertise, enabling you to rapidly design, test, and deploy your RFID solutions. Developers Kit Mercury API Universal Reader Assistant Included with every ThingMagic reader Developer Kit, the MercuryAPI supports the entire line of ThingMagic finished readers and embedded RFID modules A common development platform, supporting an extensive variety of hardware to connect, configure, and control ThingMagic readers. A utility for advanced demo, testing, and tuning of all ThingMagic readers. Reduces complexity for novice users while permitting low-level control for advanced developers. - Test chassis - Cables - Antenna - Sample Tags - Full schematics to help you design your own complimentary components M6e Reader DevKit shown ISO 9001 : 2008 REGISTERED FIRM ISO 13485 : 2003 REGISTERED FIRM © 2015 JADAK LLC 01.20.17 USA Office European Office +1 315.701.0678 Phone +1 315.701.0679 Fax email: info@jadaktech.com +31 (0)76.522.5588 Phone +31 (0)76.522.4747 Fax email: info@jadak.eu 7279 William Barry Blvd. North Syracuse, NY 13212-3349 Emmastraat 16 4811 AG Breda The Netherlands Asia Pacific Office Building 8 Gangtian Industrial Square GangTian Road Suzhou Industrial Park JiangSu, China 215024 +86 512.6283.7080 Phone email: info@jadaktech.com www.jadaktech.com
M6E-M 价格&库存
很抱歉,暂时无法提供与“M6E-M”相匹配的价格&库存,您可以联系我们找货
