Power Supplies
SCP Series, 30 Watt; Single, Dual and Triple
Selection Table
E137632
The SolaHD SCP switchers are compact, rugged power
supplies designed to power many of your industrial control
and instrumentation devices and equipment, with high reliability and tight regulation through the most difficult factory
floor conditions around the globe. “User friendly” applies
to these unique power supplies that feature easy-to-install
DIN rail and chassis mounting. Terminations are also easy
to access (AC and DC terminations are well separated) and
simple to wire. Safety is another aspect where the SCP
distinguishes itself. The encapsulated design meets IP20
specifications, and the wide range of voltages will reliably
support almost any low power device in your cabinet or
system for years
to come.
Features
• International approvals for global use
• DIN Rail or Chassis Mount
• Rugged, encapsulated design to resist environment
• IP20 protection
• Many output voltages, 3.3-48 Volts; single, dual, triple
• Five year limited warranty
Output Voltages
Low Profile
Catalog
Number
Description
Vdc
A
Vdc
A
Vdc
A
Min
Load
V1
A
SCP 30S3.3-DN
3.3 V
3.3
6.0
≥ 62
SCP 30S5-DN
5V
5
6.0
≥ 70
SCP 30S12-DN
12 V
12
2.5
≥ 75
SCP 30S15-DN
15 V
15
2.0
≥ 75
SCP 30S24-DN
24 V
24
1.3
≥ 77
SCP 30S48-DN
48 V
48
0.6
≥ 77
SCP 30D12-DN
Dual O/P +/- 12 V
12
1.2
-12
1.2
0.12
≥ 68
SCP 30D15-DN
Dual O/P +/- 15 V
V1
V2
V3
Efficiency
15
1.0
-15
1.0
0.15
≥ 68
SCP 30D512-DN Dual O/P 5 V & 12 V
5
3.0
12
1.2
0.3
≥ 68
SCP 30D524-DN Dual O/P 5 V & 24 V
5
3.0
24
0.6
0.3
≥ 68
SCP 30T512-DN Triple O/P 5/12/12 V
5
3.0
-12
0.6
12
0.6
0.3
≥ 68
SCP 30T515-DN Triple O/P 5/15/15 V
5
3.0
-15
0.5
15
0.5
0.3
≥ 68
Please order using the following model number suffixes:
-DN: Low Profile – DIN Rail or Chassis Mount
(ie: SCP30S3.3-DN).
B-DN: Slim Line – DIN Rail Mount Availability Only
(ie: SCP30S3.3B-DN).
Note:
Slim line version not available on SCP30D512-DN
Options and Accessories
• SCP-MDC – Pair of metal DIN clips
• SCP-PDC – 1 plastic DIN clip with lever for
removal from rail
Certifications and Compliances
UL Recognized Component, ITE, E137632
UL 60950
E137632
CUL/CSA-C22.2
No. 234-M90
- IEC/EN 60950-1, 2nd Edition
• IP20
• RoHS Compliant
Packaging and Mounting Specifications
• Simple snap-on for DIN Rail TS35/7.5 or TS35/15
• M3 screw clamp terminations
• Chassis mounting possible on -DN Low Profile versions
by removing DIN clips (simply unscrew at the back of
the unit).
Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions.
© December 2018
149
Power Supplies
Specifications
Low Profile DIN Rail (-DN) or Chassis Mount *
Condition
Value
AC Input Voltage
Input
85 - 264 Vac
DC Input Voltage
100 - 375 Vdc
Input Frequency
50/60 HZ
Filtering EMI/RFI
EN 55011/B, 55022/B
Switching Frequency
Typ. 100 kHz
Input Fusing Required
Use 2.0 A Slow Fuse
D = .16 (4.2)
2 1
≤1%, Vout
Noise
Vin=min, Iout=max, 25°C
≤2%, Vout
Line Regulation
Vin=min/max 25°C
Iout = max, 25°C
≤+0.5%, Vout
Load Regulation
Iout = 10 to 90 to 10%,
25°C Vin = 230 Vac, 25°C
≤+0.5%, Vout
Overcurrent Protection
105 to 130% Inom
Load Regulation Timing
10 to 90 to 10%, 25°C
50 ms
2.08 (53.0)
2.55 (65.0)
* Unscrew DIN connector for chassis mounting.
-25 to +65°C
Tamb = 25°C
45 to +85°C
45 K max
Slim Line DIN Rail Mount only (B-DN)
1 2 3 4 5
acc. MIL-HDBK-217F
800,000 hrs
EN61000-4-2, 3, 4, 5
Convection
0.7 (.34)
0.8 (.38)
Case Material/Potting
UL94-VO
Protection
IP20
Visual Indicators
Green LED indicates
DC OK for B-DN Slim
Line versions only
Weight - lbs (kg)
.24
(6.0)
Front View
Side View
4.00 (102.0)
Storage Temperature
1.29 (33.0)
Tamb >50°C
Operating Temperature
7
4.43 (113.0)
Holdup Time
6
3.53 (90.0)
Derating Single/Dual/Triple
Front View
Continuous
Overload/Short Circuit
4.16 (106.0)
Ripple
2.26 (57.5)
V1 ≤ ±1%, V2/3 ≤ ±3%
Side View
Output
Vin = 230 V, Iout = max, 25°C
Output Voltage Accuracy
4.71 (120.0)
5 4 3
4.51 (115.0)
Parameter
Dimensional Diagram – in (mm)
6 7
Dimensions (H x W x D)
• Low Profile “-DN”
4.72 x 2.55 x 1.29 in (120.0 x 65.0 x 33.0 mm)
(Takes up 2.55 in or 65.0 mm on DIN rail)
• Slim Line “B-DN”
4.72 x 1.29 x 2.68 in (120.0 x 33.0 x 68.0 mm)
(Takes up 1.29 in or 33.0 mm on DIN rail)
2.67 (68.0)
Pin-Out
SCP 30
1
2
3
4
5
6
7
RETURN
+V1
IN
IN
-V2
COM
+V1
IN
IN
COM (V1)
+V1
COM V3
+V3
IN
IN
COM (V1)
COM (V2/3)
+V1
+V3
IN
IN
Single
Dual sym
Dual asym
Triple
150
1.37 (35.0)
-V2
© December 2018
很抱歉,暂时无法提供与“SCP30D512-DN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2471.165221+320.04100
- 10+2171.9193110+281.28562
