IN-S126ASUW
IN-S126ASUW
    INOLUX(英诺斯)
    SMD-3P,3.2x1.5mm
    发光二极管/LED 白色 1206贴片式侧面发光
IN-S126ASUW 数据手册
IN-S126AS series Side View SMD LED 1206 PCB Type Features • 1206 side view SMD LED • High Brightness • AlInGaP / InGaN Technology • Small package • High reliability • Clear Lens Description The IN-S126AS series is a popular low profile 1206 package with versatile design capabilities. It is a PCB type molding style LED which can be used in various applications. Recommended Solder Pattern Applications • Consumer Electronics • Wearable • Automobile After Market • Industrial Equipment Figure 1. IN-S126AS Solder Pattern Package Dimensions in mm Figure 2. IN-S126AS Package Dimensions Inolux Corporation Proprietary & Confidential March 16, 2017 Page 1 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Absolute Maximum Rating at 25oC (Note 1) Product Emission Color Pd (mW) IF (mA) IN-S126ASYG Yellow Green 75 25 IN-S126ASY Yellow 75 25 IFP* (mA) VR (V) TOP (oC) TST (oC) 5 -30 C~+85 C 70 IN-S126ASA Amber 75 25 IN-S126ASR Red 75 25 IN-S126AS5B Blue 75 25 IN-S126ASG Green 75 25 IN-S126ASUW White 75 25 o o o o -40 C~+90 C 100 Notes 1. Condition for IFP is pulse of 1/10 duty and 0.1msec width ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Inolux Corporation Proprietary & Confidential March 16, 2017 Page 2 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Electrical Characteristics T A = 25°C (Note 1) VF(V) Product Emission Color IN-S126ASYG Yellow Green Viewing λ(nm) Angle IF(mA) I*V(mcd) min max λD λP △λ 2θ1/2 typ. 20 1.8 2.6 572 576 15 120 56 IN-S126ASY Yellow 20 1.8 2.6 589 595 15 120 140 IN-S126ASA Amber 20 1.8 2.6 603 604 20 120 115 IN-S126ASR Red 20 1.8 2.6 622 625 20 120 140 IN-S126AS5B Blue 5 2.7 3.1 467 473 30 120 45 IN-S126ASG Green 20 2.8 3.6 521 527 17 120 720 IN-S126ASUW White 20 2.8 3.3 X=0.3 Y=0.3 - - 120 720 Notes 1. Performance guaranteed only under conditions listed in above tables. Inolux Corporation Proprietary & Confidential March 16, 2017 Page 3 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Chromaticity Bin (for White only) Inolux Corporation Proprietary & Confidential March 16, 2017 Page 4 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Inolux Corporation Proprietary & Confidential March 16, 2017 Page 5 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Typical Characteristic Curves – YG, Y, A, R Inolux Corporation Proprietary & Confidential March 16, 2017 Page 6 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Typical Characteristic Curves – B, G, W Inolux Corporation Proprietary & Confidential March 16, 2017 Page 7 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Typical Characteristic Curves – Radiation Pattern Ordering Information Product Technolog Test Current Emission Color y IF (mA) IN-S126ASYG Yellow Green Forward Luminous Intensity Voltage IV (mcd) VF (V) (Typ.) (Typ.) Orderable Part Number AllnGaP 20 56 2.2 IN-S126ASYG IN-S126ASY Yellow AllnGaP 20 140 2.2 IN-S126ASY IN-S126ASA Amber AllnGaP 20 115 2.2 IN-S126ASA IN-S126ASR Red AllnGaP 20 140 2.2 IN-S126ASR IN-S126AS5B Blue InGaN 5 45 3.0 IN-S126AS5B IN-S126ASG Green InGaN 20 720 3.2 IN-S126ASG IN-S126ASUW White InGaN 20 720 3.0 IN-S126ASUW Inolux Corporation Proprietary & Confidential March 16, 2017 Page 8 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Label Specifications Inolux P/N: I N - P 3 Material Inolux SMD S = PCB Type 2 Package A T Variation Orientation 126A = 3.0 x 1.0 x 1.5 mm X S = Side Mount Current (Blank) = 20mA Lens Color (Blank) = Clear U = Diffused R=625nm A=604nm Y=595nm YG=576nm G=527nm B=473nm W=White 5=5mA - X X X X Customized Stamp-off Lot No.: Z Internal Tracker Inolux Corporation Proprietary & Confidential 2 0 1 7 Year (2017, 2018, …..) 01 24 001 Month Date Serial March 16, 2017 Page 9 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Packaging Information: 3000pcs Per Reel Tape Dimension Reel Dimension Inolux Corporation Proprietary & Confidential March 16, 2017 Page 10 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Packing Dimension 5 boxes per carton are available depending on shipment quantity. Specification Material Quantity Carrier tape Per EIA 481-1A specs Conductive black tape 3000pcs per reel Reel Per EIA 481-1A specs Conductive black Label IN standard Paper Packing bag 220x240mm Aluminum laminated bag/ no-zipper One reel per bag Carton IN standard Paper Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Inolux Corporation Proprietary & Confidential March 16, 2017 Page 11 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Reflow Soldering • Recommended tin glue specifications: melting temperature in the range of 178~192 OC • The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Lead-free Solder Profile Inolux Corporation Proprietary & Confidential March 16, 2017 Page 12 www.inolux-corp.com IN-S126AS series Side View SMD LED 1206 PCB Type Precautions • • • • • • Avoid exposure to moisture at all times during transportation or storage. Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products. It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a reverse voltage. Avoid operation beyond the limits as specified by the absolute maximum ratings. Avoid direct contact with the surface through which the LED emits light. If possible, assemble the unit in a clean room or dust-free environment. Reworking • • • Rework should be completed within 5 seconds under 260 OC. The iron tip must not come in contact with the copper foil. Twin-head type is preferred. Cleaning Following are cleaning procedures after soldering: • An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended. • Temperature x Time should be 50oC x 30sec. or
IN-S126ASUW 价格&库存
很抱歉,暂时无法提供与“IN-S126ASUW”相匹配的价格&库存,您可以联系我们找货
IN-S126ASUW
  • 1+2.995211+0.38824
  • 10+2.0806610+0.26970
  • 100+1.46766100+0.19024
  • 500+1.19086500+0.15436
  • 1000+1.099541000+0.14253
库存:27916
IN-S126ASUW
    库存:3000
    IN-S126ASUW
    • 5+1.26760
    • 50+1.10798
    • 150+1.03950
    • 500+0.95418
    • 3000+0.91617
    • 6000+0.89338
    库存:8393
    IN-S126ASUW
      IN-S126ASUW
      • 50+0.77000
      • 1000+0.73500
      库存:2900
      IN-S126ASUW
        IN-S126ASUW
        • 3000+0.981783000+0.12726
        • 6000+0.921656000+0.11947
        • 9000+0.890779000+0.11546
        • 15000+0.8558915000+0.11094
        • 21000+0.8351221000+0.10825
        • 30000+0.8148630000+0.10562
        库存:27916
