BLM9D2327-25BZ
BLM9D2327-25BZ
    AMPLEON(安谱隆)
    PQFN20_8X8MM
    BLM9D2327-25BZ
BLM9D2327-25BZ 数据手册
BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC Rev. 1 — 1 September 2017 Product data sheet 1. Product profile 1.1 General description The BLM9D2327-25B is a 2-stage fully integrated Doherty MMIC solution using Ampleon's state of the art GEN9 LDMOS technology. The carrier and peaking device, input splitter and output combiner are integrated in a single package. This multiband device is perfectly suited as general purpose driver or small cell final in the frequency range from 2300 MHz to 2700 MHz. Available in PQFN outline. Table 1. Application performance Typical RF performance tuned in a wideband 2300 MHz to 2700 MHz application board at Tcase = 25 C; IDq = 76 mA (carrier); VGSq(peaking) = VGSq(carrier)  0.81 V. Test signal: 1-carrier LTE 20 MHz; PAR = 7.2 dB at 0.01% probability on CCDF. Test signal single carrier LTE 20 MHz f VDS PL(AV) Gp D (MHz) (V) (W) (dB) (%) 2500 28 4.9 28.5 40.3 1.2 Features and benefits         Integrated input splitter Integrated output combiner High efficiency Designed for broadband operation (frequency 2300 MHz to 2700 MHz) Independent control of carrier and peaking bias Integrated ESD protection Source impedance 50 ; high power gain Compliant to Directive 2002/95/EC, regarding restriction of hazardous substances (RoHS) 1.3 Applications  RF power MMIC for multi-carrier and multi-standard GSM, W-CDMA and LTE base stations in the 2300 MHz to 2700 MHz frequency range. BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 2. Pinning information 2.1 Pinning pin 1 index RF_OUT VDS2 n.c. n.c. 2 14 n.c. n.c. 3 13 n.c. n.c. 4 12 n.c. VDS1 5 11 9 10 7 8 RF_IN VGS(carr) 6 VGS(peak) 20 19 18 17 16 15 VGS(carr) 1 VGS(peak) n.c. VDS1 amp00274 Transparent top view The exposed backside of the package is the ground terminal of the device. Fig 1. Pin configuration 2.2 Pin description Table 2. BLM9D2327-25B Product data sheet Pin description Symbol Pin Description n.c. 1 not connected n.c. 2 not connected n.c. 3 not connected n.c. 4 not connected VDS1 5 drain-source voltage of driver stages VGS(peak) 6 gate-source voltage of peaking VGS(carr) 7 gate-source voltage of carrier RF_IN 8 RF input VGS(carr) 9 gate-source voltage of carrier VGS(peak) 10 gate-source voltage of peaking VDS1 11 drain-source voltage of driver stages n.c. 12 not connected n.c. 13 not connected n.c. 14 not connected n.c. 15 not connected RF_OUT/VDS2 16 RF output / drain-source voltage of final stages RF_OUT/VDS2 17 RF output / drain-source voltage of final stages RF_OUT/VDS2 18 RF output / drain-source voltage of final stages All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 2 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC Table 2. Pin description …continued Symbol Pin Description RF_OUT/VDS2 19 RF output / drain-source voltage of final stages RF_OUT/VDS2 20 RF output / drain-source voltage of final stages GND flange RF ground 3. Ordering information Table 3. Ordering information Type number Package BLM9D2327-25B Name Description Version PQFN20 plastic thermal enhanced quad flat package; no leads; 20 terminals; body 8.0 x 8.0 x 2.1 mm SOT1462-1 4. Block diagram VGS(peak) Bias peak VDS1 RF_IN VGS(carr) RF_OUT VDS2 Bias carr amp00275 Fig 2. Block diagram 5. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Min Max Unit drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C Tj junction temperature - 175 C [1] BLM9D2327-25B Product data sheet Conditions [1] Continuous use at maximum temperature will affect the reliability. For details refer to the online MTF calculator. All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 3 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 6. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) [1] Conditions thermal resistance from junction to case Value Unit Tcase = 90 C; PL = 4 W [1] 11 K/W Tcase = 90 C; PL = 2.5 W [1] 12 K/W When operated with a 1-carrier W-CDMA with PAR = 9.9 dB. 7. Characteristics Table 6. DC characteristics Tcase = 25 C. Symbol Parameter Conditions Min Typ Max Unit VGSq gate-source quiescent voltage VDS = 28 V; ID = 75 mA 1.7 2.1 2.7 V IGSS gate leakage current VGS = 1 V; VDS = 0 V - - 140 nA gate leakage current VGS = 1 V; VDS = 0 V - - 140 nA VGS = 0 V; VDS = 28 V - - 1.4 A VGS = 0 V; VDS = 28 V - - 1.4 A Typ Max Unit Carrier Peaking IGSS Final stages IDSS drain leakage current Driver stages IDSS drain leakage current Table 7. RF Characteristics Typical RF performance at Tcase = 25 C; VDS = 28 V; IDq = 75 mA (carrier); VGSq(peaking) = VGSq(carrier)  0.7 V; PL(AV) = 5 W. Symbol Parameter Conditions Min Test signal: pulsed CW Gp power gain f = 2700 MHz 25.5 27 28.5 dB D drain efficiency PL = 5 W (37 dBm) 34 38 - % 50 54.5 - % RLin input return loss - 20 dB PL(3dB) output power at 3 dB gain compression 44 44.6 - PL = PL(3dB) BLM9D2327-25B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 10 dBm © Ampleon Netherlands B.V. 2017. All rights reserved. 4 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 8. Application information Table 8. Typical performance Tcase = 25 C; VDS = 28 V; IDq = 76 mA (carrier and peaking). Test signal: 1-carrier LTE; PAR = 7.2 dB at 0.01 % probability CCDF; unless otherwise specified, typical performance in an Ampleon f = 2300 MHz to 2700 MHz frequency band symmetrical Doherty application circuit. Symbol Parameter Conditions Min Typ Max Unit PL(3dB) output power at 3 dB gain compression f = 2500 MHz [1] - 44.9 - dBm [2] s21/s21(norm) normalized phase response at 3 dB compression point; f = 2500 MHz - 5.9 -  D drain efficiency 8 dB OBO (PL(AV) = 36.9 dBm); f = 2500 MHz - 40.3 - % Gp power gain PL(AV) = 36.9 dBm; f = 2500 MHz - 28.5 - dB Bvideo video bandwidth PL(AV) = 36 dBm set to obtain IMD3 = 30 dBc; 2-tone CW; f = 2500 MHz - 420 - MHz Gflat gain flatness PL(AV) = 36.9 dBm; f = 2300 MHz to 2700 MHz - 0.6 - dB ACPR20M adjacent channel power ratio (20M) PL(AV) = 36.9 dBm; f = 2500 MHz - 34.9 - dBc G/T gain variation with temperature f = 2500 MHz [3] - 0.04 - dB/C Rollett stability factor Tcase = 40 C; f = 0.2 GHz to 4.5 GHz [3] - >2.2 - K [1] Pulsed CW power sweep measurement ( = 10 %, tp = 100 s). [2] 25 ms CW power sweep measurement. [3] Small signal CW measurements. BLM9D2327-25B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 5 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 40 mm R4 R1 C3 C12 C1 C5 C6 R2 40 mm C9 C11 C14 C10 R3 C7 C8 C4 R5 C2 C13 amp00424 Printed-Circuit Board (PCB): Rogers 4350; thickness = 0.508 mm. Fig 3. Component layout Table 9. Demo test circuit list of components See Figure 3 for component layout. Component Description Value Remarks C1, C2, C3, C4 multilayer ceramic chip capacitor 10 F, 35 V TDK: C2012X5R1V106M085ACL C5, C6, C7, C8 multilayer ceramic chip capacitor 1 F, 25 V AVX: 06033D105KAT2A C9, C10 multilayer ceramic chip capacitor 1.8 pF Murata: GQM1875C2E1R6BB12 C11 multilayer ceramic chip capacitor 1.6 pF Murata: GQM1875C2E5R6BB12 C12, C13 multilayer ceramic chip capacitor 9.1 pF Murata: GQM1875C2E5R6BB12 C14 multilayer ceramic chip capacitor 0.5 pF Murata: GQM1875C2E5R6BB12 J1 SMA Coaxial panel connector male Hubner & Suhner: 13_SMA-50-0-2/111_N J2 SMA Coaxial panel connector female R1 SMD resistor 0 , 1 % Multicomp: MC805 R2, R3 SMD resistor 5.1 , 1 % Multicomp: MC805 R4 SMD resistor 820 , 1 % Multicomp: MC805 R5 SMD resistor 10 , 1 % Multicomp: MC805 T1, T2, T3, T4 PCB Terminal 6.35 mm  0.81 mm, 4.1 mm TE connectivity BLM9D2327-25B Product data sheet Hubner & Suhner: 23_SMA-50-0-2/111_N All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 6 of 16 xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxx x x x xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xx xx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxx x x xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxx xxx BLM9D2327-25B Product data sheet VDS 28V C1 C12 R3 C7 VGS(peak) R2 VGS(carr) T1 5 R5 C8 4 3 2 1 20 7 19 RF_IN 8 18 VGS(carr) 9 17 VGS(peak) VGS(peak) 6 n.c. C5 10 16 11 12 13 14 15 RF_OUT/VDS2 J2 C9 RF_OUT/VDS2 RF_OUT/VDS2 RF_OUT/VDS2 RF_OUT/VDS2 C11 C14 C10 n.c. T4 C6 n.c. n.c. R4 n.c. VGS(carr) n.c. J1 n.c. VDS1 C3 VDS1 Rev. 1 — 1 September 2017 All information provided in this document is subject to legal disclaimers. R1 n.c. T3 C4 C2 C13 T2 Electrical schematic BLM9D2327-25B 7 of 16 © Ampleon Netherlands B.V. 2017. All rights reserved. Fig 4. amp00425 LDMOS 2-stage integrated Doherty MMIC GND BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 8.1 Ruggedness in a Doherty operation The BLM9D2327-25B is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 32 V; IDq = 75 mA (carrier); VGSq(peaking) = VGSq(carrier)  0.7 V; Pi corresponding to PL(3dB) under ZS = 50  load; f = 2700 MHz (1-carrier W-CDMA; PAR = 9.9 dB); Tcase = 25 C. 8.2 Impedance information Table 10. Typical impedance for optimum Doherty operation Measured load-pull data per section; test signal: pulsed CW; Tcase = 25 C; VDS = 28 V; IDq = 70 mA (carrier); VGSq(peaking) = VGSq(carrier)  0.7 V; tp = 100 s;  = 10 %. tuned for optimum Doherty operation BLM9D2327-25B Product data sheet f ZL PL(3dB) Gp(max) add [1] add [2] (MHz) () (dBm) (dB) (%) (%) 2300 5.30  j2.38 45.30 28.60 53.10 42.80 2400 5.62  j3.81 45.30 29.00 55.00 44.10 2500 6.34  j4.52 45.20 29.40 57.00 45.00 2600 7.67  j4.10 45.00 29.40 59.10 43.50 2700 7.25  j2.89 44.90 28.70 58.90 40.70 [1] at 44.5 dBm. [2] at 36.5 dBm. All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 8 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 8.3 Graphs amp00426 30 (1) Gp (dB) 0 amp00427 5 RLin ____ φs21/φs21(norm) (dB) (deg) 15 -10 (2) 0 (2) (3) 0 -20 -5 -15 -30 -10 -40 3000 -15 -30 1500 1800 2100 2400 2700 f (MHz) (1) 33 35 37 39 41 43 PL (dBm) Tcase = 25 C; VDS = 28 V; IDq1 + IDq2 = 76 mA (carrier stages); VGS = 2.46 V (carrier stage); VGS = 1.65 V (peaking stage). Tcase = 25 C; VDS = 28 V; IDq1 + IDq2 = 76 mA (carrier stages); VGS = 2.46 V (carrier stage); VGS = 1.65 V (peaking stage). Test signal: CW. Test signal: 25 ms CW power sweep. (1) magnitude of Gp (1) f = 2300 MHz (2) magnitude of RLin (2) f = 2500 MHz 45 (3) f = 2700 MHz Fig 5. Wideband power gain and input return loss as function of frequency; typical values BLM9D2327-25B Product data sheet Fig 6. Normalized phase response as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 9 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC amp00428 30.5 Gp (dB) 29.5 ηD (%) (1) (2) (3) Gp 60 50 28.5 40 27.5 30 (1) (2) (3) 26.5 ηD 20 25.5 10 24.5 0 24 28 32 36 40 44 PL (dBm) 48 Tcase = 25 C; VDS = 28 V; IDq1 + IDq2 = 76 mA (carrier stages); VGS = 2.46 V (carrier stage); VGS = 1.65 V (peaking stage). Test signal: pulsed CW power sweep ( = 10 %; tp = s). (1) f = 2300 MHz (2) f = 2500 MHz (3) f = 2700 MHz Fig 7. Power gain and drain efficiency as function of output power; typical values amp00429 -10 IMD (dBc) -20 (1) (2) IMD3 -30 -40 (1) (2) IMD7 -50 IMD5 (1) (2) -60 -70 1 10 102 tone spacing (MHz) 103 Tcase = 25 C; VDS = 28 V; IDq1 + IDq2 = 76 mA (carrier stages); VGS = 2.46 V (carrier stage); VGS = 1.65 V (peaking stage); PL(AV) = 4 W. Test signal: 2-tone CW; fc = 2500 MHz. (1) IMD low (2) IMD high Fig 8. Intermodulation distortion as a function of tone spacing; typical values BLM9D2327-25B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 10 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC amp00430 30 Gp (dB) 29 ηD (%) (1) (1) (2) (2) (3) (3) Gp 55 45 amp00431 -20 ACPR20M (dBc) -30 (1) (2) (3) ACPR20M -40 28 -25 35 -50 27 -35 (1) (2) (3) 25 -60 26 ηD 15 25 28 32 36 40 PL (dBm) -45 ACPR40M -70 5 24 -55 -80 44 -65 24 28 32 36 40 PL (dBm) 44 Tcase = 25 C; VDS = 28 V; IDq1 + IDq2 = 76 mA (carrier stages); VGS = 2.46 V (carrier stage); VGS = 1.65 V (peaking stage). Tcase = 25 C; VDS = 28 V; IDq1 + IDq2 = 76 mA (carrier stages); VGS = 2.46 V (carrier stage); VGS = 1.65 V (peaking stage). Test signal: 1-carrier LTE; PAR = 7.2 dB at 0.01 % probability CCDF. Test signal: 1-carrier LTE; PAR = 7.2 dB at 0.01 % probability CCDF. (1) f = 2300 MHz (1) f = 2300 MHz (2) f = 2500 MHz (2) f = 2500 MHz (3) f = 2700 MHz (3) f = 2700 MHz Fig 9. -5 ACPR40M (dBc) -15 Power gain and drain efficiency as function of output power; typical values Fig 10. Adjacent channel power ratio as a function of output power; typical values amp00432 8.5 PARO (dB) PARO 7.5 50 PL(M) (dBm) 46 (1) (2) (3) 6.5 42 (1) (2) (3) 5.5 38 PL(M) 4.5 34 3.5 30 24 28 32 36 40 PL (dBm) 44 Tcase = 25 C; VDS = 28 V; IDq1 + IDq2 = 76 mA (carrier stages); VGS = 2.46 V (carrier stage); VGS = 1.65 V (peaking stage). Test signal: 1-carrier LTE; PAR = 7.2 dB at 0.01 % probability CCDF. (1) f = 2300 MHz (2) f = 2500 MHz (3) f = 2700 MHz Fig 11. Output peak-to-average ratio and peak output power as function of output power; typical values BLM9D2327-25B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 11 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 9. Package outline PQFN20: plastic thermal enhanced quad flat package; no leads; 20 terminals; body 8.0 x 8.0 x 2.1 mm terminal 1 index area D B SOT1462-1 A E A A1 C detail X e1 v w b e A B C C C y1 C k1 6 y 10 L 5 11 e e2 Eh 1 15 k terminal 1 index area 20 16 X Dh 0 10 mm scale Dimensions Unit A(1) A1 b C D(1) max 2.20 0.05 0.60 8.1 nom 2.10 0.50 0.508 8.0 7.9 min 2.00 0.00 0.40 mm Dh E(1) 4.72 4.62 4.52 8.1 8.0 7.9 Eh e 4.72 4.62 1.15 4.52 e1 e2 4.6 4.6 k 0.99 k1 L v w y y1 0.1 0.05 0.1 0.1 0.99 0.8 0.7 0.6 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version References IEC JEDEC JEITA sot1462-1_po European projection Issue date 15-10-12 17-06-23 SOT1462-1 Fig 12. Package outline SOT1462-1 (PQFN20) BLM9D2327-25B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 12 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 10. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. Table 11. ESD sensitivity ESD model Class Charged Device Model (CDM); According to ANSI/ESDA/JEDEC standard JS-002 C2A [1] Human Body Model (HBM); According to ANSI/ESDA/JEDEC standard JS-001 1B [2] [1] CDM classification C2A is granted to any part that passes after exposure to an ESD pulse of 500 V, but fails after exposure to an ESD pulse of 750 V. [2] HBM classification 1B is granted to any part that passes after exposure to an ESD pulse of 500 V, but fails after exposure to an ESD pulse of 1000 V. 11. Abbreviations Table 12. Abbreviations Acronym Description 3GPP 3rd Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge GEN9 Ninth Generation GSM Global System for Mobile Communications LDMOS Laterally Diffused Metal Oxide Semiconductor LTE Long Term Evolution MMIC Monolithic Microwave Integrated Circuit MTF Median Time to Failure OBO Output Back Off PAR Peak-to-Average Ratio SMD Surface Mounted Device VSWR Voltage Standing-Wave Ratio W-CDMA Wideband Code Division Multiple Access 12. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes BLM9D2327-25B v.1 20170901 Product data sheet - - BLM9D2327-25B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 13 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLM9D2327-25B Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 14 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’s standard warranty and Ampleon’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 14. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLM9D2327-25B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 1 September 2017 © Ampleon Netherlands B.V. 2017. All rights reserved. 15 of 16 BLM9D2327-25B LDMOS 2-stage integrated Doherty MMIC 15. Contents 1 1.1 1.2 1.3 2 2.1 2.2 3 4 5 6 7 8 8.1 8.2 8.3 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Block diagram . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 5 Ruggedness in a Doherty operation . . . . . . . . . 8 Impedance information . . . . . . . . . . . . . . . . . . . 8 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Handling information. . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2017. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2017 Document identifier: BLM9D2327-25B
BLM9D2327-25BZ 价格&库存
很抱歉,暂时无法提供与“BLM9D2327-25BZ”相匹配的价格&库存,您可以联系我们找货
