COM-14731
COM-14731
    SPARKFUNELECTRONICS
    COM-14731
COM-14731 数据手册
iPixel LEDLight Light Co. Co. , ,Ltd iPixel LED Ltd iPix el LED Ultra Thin Side View LED Strip www.ipixelleds.co m Product Description - After we developed the ultra thin side emitting bar ( http://www.ipixelleds.com/index.php?id=376 ). - The flexible side view stripe came out under customer's strong request. - It's 60 LEDs per meter and 5 meters in a reel. w w w .i p ix e ll e d s .c om - Same as our other addressable tapes, it's cut-able every unit. Front view - Just be aware that the solder pad very small so suggest you choose a 22AWG wire for om c . s d e ll e ix ip . w w w re-connection. - Each chip has 4 pin even it's quite thin size, and the Pin almost covered by the LED's body, so it's hard to replace LED if any of broken, cut Back view the unit LED on PCB will be a better option. iPixel LEDLight Light Co. Co. , ,Ltd iPixel LED Ltd iPix el LED Product Datasheet Product Number S60SK6812SIDEV5 Light Source SK6812SIDE Beam Angle 120° LED Quantity 60leds/m (mm) Size Emitting L 5000* W 8 mm Full color Color Operating Voltage DC5V Power (W) 18±1w/m Control (IC) SK6812 Waterproof Rating IP20 Luminance(MCD) R:90000mcd G:132000mcd B:6000mcd Application w w w .i p ix e ll e d s .c o m se. cdo ms .c o m d e l l e x ll i e p ix i ww wwww. .i p 1. Hotels, restaurants, nights clubs. 2. Back lighting, edge lighting. 3. Advertising signs, brightening. 4. Dancefloor background. Outline Dimension 100mm 16.6mm w com +5V DO GND leds. +5V DI GND +5V DI GND ixel w w. i p +5V DO GND +5V DO GND +5V DI GND +5V DI GND +5V DO GND com +5V DI GND lleds. +5V DO GND +5V DI GND +5V DO GND +5V DI GND ipixe w w w. +5V DI GND com +5V DO GND lleds. +5V DO GND +5V DI GND +5V DO GND +5V DI GND +5V DI GND +5V DO GND ipixe w w w. 5000mm 3P JST SM connector 10mm N D D O G G N D N D G I O D D 8mm + 5 V V V 5 5 + + 5 + V 5 + V D D I O G G N D N D D N D G I O V 5 5 + + V D D I D V D V 5 5 + + G N G N G O I D V 5 + D N D D N D G N G O D V 5 + 5 + V 5 + V D D I O G G N D N D D I D V 5 + 5 + D N G V D D O O V G G N + 5 N D 2.5mm iPixel LEDLight Light Co. Co. , ,Ltd iPixel LED Ltd iPix el LED DC5V+ COM- Power cable DC5V+ DAT GND 3 Pin JST cable Connection Drawing www This strip 60Pixels (IC) per m,5m/roll (300Pixel), .ipixe T-1000controller support 2000Pixel Max, lleds www .ipixe .com lleds .com lleds .com 1 Roll strip total power is 90W (5m),each 5V 70A (350W) works 3 rolls of strip . You also could use T4000、T8000 SD controller www .ipixe for more LED pixels 1st .ipixe N L (AC) 3rd www .com 4th 5th .ipixe 6th 7th 8th 9th 10th 5V 70A 5V 70A www NOTICE: +V +V +V +V G G G G 2nd lleds NOTICE: +V +V +V +V G G G G lleds .com N (AC) L www .ipixe 5pcsx5m www lleds .ipixe .com lleds .com SD SD .i p ix e www ll e d s L AC 110 / 220V NO.1 .i p ix e .c o m L www 5pcsx5m ll e d s .c o m NO.2 N L Add: A2 Building Ming Jin hai Industrial Park,Zhou shi Rd ,Shiyan,Baoan,Shenzhen,China. 518108 Tel: 0086-755-85257292 Web: www.ipixelleds.com Fax:0086-755-85257292 E-mail: inquiry@ipixelleds.com
COM-14731 价格&库存
很抱歉,暂时无法提供与“COM-14731”相匹配的价格&库存,您可以联系我们找货
