BG302-06-A-L-G
BG302-06-A-L-G
    GCT
    BG302-06-A-L-G
BG302-06-A-L-G 数据手册
H 5.70±0.15 2.54 (non-accum.) ø1.02 RECOMMENDED PCB LAYOUT Specifications 规格 General Tolerance: ±0.05 1.25 Material 物料 Insulator 绝缘体: Polymer 聚合物, LCP , Natural, UL94V-0 Contact 接触: Copper Alloy 3.20±0.20 A±0.30 1.60 REF. Minimum Insertion Depth 2.50±0.15 F E 2.54±0.10 4.25 G B±0.20 Plating 电镀 Underplating 底层电镀: 50µ”-100µ" Nickel all over Contact Area 接触部分: See ordering grid Electrical 电气 Current Rating 电流额定值: 3A per pin Contact Resistance 接触电阻值: 20 mΩ max. Insulating Resistance 绝缘电阻值: 1000 MΩ min. Dielectric Withstand Voltage 耐电压: 1000V AC D 1.60 PIN 0.64X0.40 (Typ.) 2.54±0.10 Mechanical & Environmental 机械 & 环境 Operating Temperature 工作温度: -40°C to +105°C Soldering Process 可焊性: Wave 波峰焊: 250°C for 5-10 secs Manual Solder 人工焊接: 350°C for 3-5 secs C Mates with 配套之公头: Use BG303 for perfect horizontal mating. (Standard mating pin length 3.00mm) 配套卧式公头为BG303 (标准插入针长3.00mm) Ordering Grid BG302 CONTACTS B No. of Contacts 02 to 06 Contact Plating A = Gold Flash All Over DIMENSIONS A B 2 5.58 2.54 3 8.12 5.08 X XX (Other plating options available on request) L X Request Samples and Quotation Packing Options G = Plastic Box (Standard) MOQ 1000pcs D = Tube Insulator Material L = LCP (Natural) 4 10.66 7.62 5 13.20 10.16 Part Number Product Description 6 15.74 12.70 BG302 Drawing Date 2.54mm Pitch Socket, Single Row, Through-hole, Horizontal, Natural LCP A 7th December 2011 By 1 NOTES备注: Maximum mating pin length 4.25mm 最大容许插入针长4.25mm Standard black version of BG302 is BG145 BG302的标准黑色塑胶版本为料号为BG145 2 3 4 Detail CC Drawing Release Revision Date A1 30/11/16 5 Tolerances (Except as Noted) Length Angle X.X ± 0.30 X.XX ± 0.20 Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CM 8 Sheet No. 1/1
BG302-06-A-L-G 价格&库存
很抱歉,暂时无法提供与“BG302-06-A-L-G”相匹配的价格&库存,您可以联系我们找货
BG302-06-A-L-G
