IN-PI55TBTPRPGPB
IN-PI55TBTPRPGPB
    INOLUX(英诺斯)
    IN-PI55TBTPRPGPB
IN-PI55TBTPRPGPB 数据手册
IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC Features • • • • • • • • • • Description 5050 with integrated high quality constant current IC and RGB LED chip. Built-in IC, with high precision of constant current and internal RGB chips spectral processing in advance. Single line data transmission (return to zero code). Specific Shaping Transmit Technology - number of LED stacked is not restricted. Cascading Enhancement Technology - any 2 LED spacing can be up to 10 meters Data transfer rate of 800 kbp/s at 30 frames per second. RGB output port PWM control can achieve 256 grey level adjustments. Upon powering up, IC performs self-inspection then lights connection on the pin B lamp. SA-I Anti-interference patent technology for single line data transmission. Built-in power supply reverse connect protection module, reversed power input will not damage the IC. The IN-PI55TBTPRPGPB is 5.0*5.0*1.6mm RGB LED with integrated IC. It is a SMD type LED which can be used in various applications. Applications • • • • • • • Full color LED string light LED full color module LED guardrail tube LED scene lighting LED point light LED pixel screen LED shaped screen Package Outline Dimensions & Pin Configuration Figure 1. IN-PI55TBTPRPGPB Package Outline Dimensions Inolux Corporation Proprietary & Confidential Page 1 July 1, 2018 www.inolux-corp.com IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC Pin Configuration Figure 2. IN-PI55TBTPRPGPB Pin Configuration Notes: 1. Dimension in millimeter, tolerance is ±0.1mm unless otherwise noted. Number Symbol Function Description 1 DO Display data cascaded output (800k bps) 2 DI Display data cascaded input (800k bps) 3 VDD Power Supply 4 NC 5 VCC Power supply 6 VSS Ground Soldering Pad Size Inolux Corporation Proprietary & Confidential Page 2 July 1, 2018 www.inolux-corp.com IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC Absolute Maximum Rating (Ta = 25 ℃, VSS=0V) Parameter Symbol Range Unit Logic supply voltage VDD +3.5~+5.5 V Logic input voltage VIN -0.5 ~VDD+0.5 V Operating temperature TOPT −45 ~ +85 °C Storage temperature TSTG −50 ~ +150 °C ESD pressure(HBM) VESD 4K V ESD pressure(DM) VESD 200 V LED Characteristics (Ta = 25°C) (Ta=-25oC, unless otherwise specified) Light Wavelength(nm) color Light intensity(mcd) Working current(mA) Working voltage(V) R 620-625 500-1000 12 1.8-2.2 G 520-525 1000-1700 12 2.8-3.2 B 465-470 500-1000 12 2.8-3.2 Inolux Corporation Proprietary & Confidential Page 3 July 1, 2018 www.inolux-corp.com IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC Recommended Operating Ranges (unless otherwise specified, TA=-20 ~ +70 ℃, VDD=4.5 ~ 5.5V,VSS=0V) Parameter Symbol Min. Typ. Max Unit Test conditions VDD - 5.2 - V - VDS, MAX - - 26 V - DOUT drive capability IDOH - 49 - mA maximum source current DOUT drive capability IDOL - -50 - mA maximum sink current High level input voltage VIH 3.4 - V VDD=5.0V Low level input voltage VIL - - 1.6 V VDD=5.0V The frequency of PWM FPWM - 1.2 - KHZ - IDD - 1 - mA - Supply voltage R/G/B port pressure Static power consumption Inolux Corporation Proprietary & Confidential Page 4 July 1, 2018 www.inolux-corp.com IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC Switching Characteristics (unless otherwise specified, TA=25 ℃) Parameter The speed of data transmission Symbol Min. Typ. Max Unit Test conditions fDIN - 800 - KHZ The duty ratio of 67% (data 1) TPLH - - 500 ns DOUT transmission delay TPHL - - 500 Tr - 100 - IOUT Rise/Drop Time Tf - 100 - DIN→DOUT ns ns VDS=1.5 IOUT=5/13mA ns Timing Waveforms 1. Input Code 2. The data transmission time (TH+TL=1.25µs±600ns): Inolux Corporation Proprietary & Confidential Name Description Typ. value error T0H 0 code, high level time 0.3μs ±0.15μs T0L 0 code, low level time 0.6μs ±0.15μs T1H 1 code, high level time 0.9μs ±0.15μs T1L 1 code, low level time 0.6μs ±0.15μs Trst Reset code, low level time 80μs Page 5 July 1, 2018 www.inolux-corp.com IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC 3. Connection Scheme 4. Data Transfer Format Note: the D1 sends data for MCU, D2, D3, D4 for data forwarding automatic shaping cascade circuit. 5. 24-bit data format G7 G6 G5 G4 G3 G2 G1 G0 R7 R6 R5 R4 R3 R2 R1 R0 B7 B6 B5 B4 B3 B2 B1 B0 Note: The data is sent in the sequence of GRB, and the MSB is sent first. Inolux Corporation Proprietary & Confidential Page 6 July 1, 2018 www.inolux-corp.com IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC Constant Current Characteristic With excellent constant current characteristics, (1) The differences of current between Channel is less than ±1.5℅ (2) The differences of current between Chip is less than ±3℅ (3) When the voltage of the load change, the output current is not affected, as shown in the figure below (4) Below output port of the current Iout and add on the port voltage Vds curve relationship. The smaller the Iout current, the smaller in the condition of constant current need of Vds. Typical Application Circuit Product signal input and output must be connected in series with protection resistor R1. R1 depends on the size of the cascade amount, the greater the number of cascade, the smaller R1. The general recommended value is between 200-2KΩ, usually the recommended value is typical 500Ω. Inolux Corporation Proprietary & Confidential Page 7 July 1, 2018 www.inolux-corp.com IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC LED Performance Graph Inolux Corporation Proprietary & Confidential Page 8 July 1, 2018 www.inolux-corp.com IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC Ordering Information Product Emission Color IV(mcd) R 500-1000 G 1000-1700 B 500-1000 IN-PI55TBTPRPGPB Orderable Part Number IN-PI55TBTPRPGPB Label Specifications Inolux P/N: I N PI - Product Inolux 55 T B T (X) R (X) G (X) B Package Die Qty. Variation Orientation Current Color Current Color Current Color T = Top Mount P=12mA R = 624 nm P=12mA G= 520 nm P=12mA B= 470 nm PI- Single trace IC 55TB = 5.0 x 5.0 x 1.6 mm (6 pins) PC- Clock Function IC - X X X Customized Stamp-off Lot No.: Z Internal Tracker Inolux Corporation Proprietary & Confidential 2 0 1 7 Year (2017, 2018, …..) Page 9 01 24 001 Month Date Serial July 1, 2018 www.inolux-corp.com X IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC Precautions Please read the following notes before using the product: 1. Storage 1.1 Do not open moisture proof bag before the products are ready to use. 1.2 Before opening the package, the LEDs should be kept at 30℃ or less and 80%RH or less. 1.3 The LEDs should be used within a year. 1.4 After opening the package, the LEDs should be kept at 30℃ or less and 60%RH or less. 1.5 The LEDs should be used within 24 hours (1 days) after opening the package. 1.6 If the moisture adsorbent material has fabled away or the LEDs have exceeded the storage time, baking treatment should be performed using the following conditions. Baking treatment: 60±5℃ for 24 hours. Inolux Corporation Proprietary & Confidential Page 10 July 1, 2018 www.inolux-corp.com IN-PI55TBTPRPGPB 5050 RGB LED 6-Pin with Integrated IC 2. Soldering Condition Recommended soldering conditions: Profile Feature Lead-Free Solder Average Ramp-Up Rate (Ts max to Tp ) 3℃/second max. Preheat: Temperature Min (Ts min) 150℃ Preheat: Temperature Min (Ts max) 200℃ Preheat: Time ( ts min to ts max ) 60-180 seconds Time Maintained Above: Temperature (TL) 217 ℃ Time Maintained Above: Time (t L) 60-150 seconds Peak/Classification Temperature (T P) 240 ℃ Time Within 5℃ of Actual Peak Temperature ( tp)
IN-PI55TBTPRPGPB
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为Anode、Cathode、Collector、Emitter、Gate和Source。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特性。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装。
IN-PI55TBTPRPGPB 价格&库存
很抱歉,暂时无法提供与“IN-PI55TBTPRPGPB”相匹配的价格&库存,您可以联系我们找货
IN-PI55TBTPRPGPB
    IN-PI55TBTPRPGPB
      IN-PI55TBTPRPGPB
