RECE.20369.001E.01
RECE.20369.001E.01
    TAOGLASLIMITED
    SMD
    内针 IPEX
RECE.20369.001E.01 数据手册
TXR™ 3 Series SMD W.FL Compatible Receptacle Part No: RECE.20369.001E.01 Description: TXR™ 3 W.FL Compatible Receptacle Compatible with I-PEX MHFIII, Hirose W.FL, Hirose W.FL2 Features: Mating Height: 1.6mm Max 5000pcs per reel Dimensions: 2 x 2 x 0.85 mm Diameter: 1.4mm RoHS & Reach Compliant SPE-16-8-033-C 1. Introduction 3 2. Specifications 4 3. Connector Data 6 4. Mechanical Drawing 7 5. Footprint 8 6. Solder Reflow Profile 9 7. Packaging 10 Changelog 12 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-16-8-033-C www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction the Taoglas TXR™ Series of receptacles, the TXR™ 3 RECE.20369.001E.01 is a 3-pad type wire-to1.Part ofIntroduction board SMD Receptacle solution that is ultra-small, lightweight and low profile (1.6mm MAX.) with an operational frequency range of DC to 6 GHz. Taoglas TXR™ 3 RECE.20369.001E.01 is gold plated to have superior performance and allow easy mounting of the male RF connector. on tape and reel, this receptacle is designed to be placed with automatic “pick and place” 1.Packaged Introduction equipment for ease of installation. The TXR™ 3 RECE.20369.001E.01 acts as a 50 Ohm transmission line to connect the micro-miniature RF connector to the printed circuit board. It is fully compatible with I-PEX MHFIII, Hirose W.FL and all other available W.FL compatible connectors . 1. Introduction Applicable Technologies: TXR™ 3 RECE.20369.001E.01 receptacles are commonly integrated into GSM module, GPS module, Wireless LAN modules. 1. Introduction For further information, please contact your regional Taoglas customer support team. SPE-16-8-033-C www.taoglas.com 3 2. Specifications Electrical 3. Operation Frequency Antenna Characteristics2. DC to 6 GHz Specifications 1.3 Max at DC~3 GHz VSWR 1.4 Max at 3~6 GHz 3. 4. Nominal Impedance Antenna Characteristics 50 Ohm Rated Voltage 60V AC Rated Current 1A Max. Subject mated contacts assembled in housing to Contact Resistance Antenna Radiation Patterns3.Antenna 20mV Max. open circuit at 10mA Max Withstand Voltage Characteristics2. Specifications Insulation Resistance AC 200V/minute Impressed voltage 100V DC for 1min Initial:500MΩ Min. Final:100MΩ Min. Dielectric Withstanding Voltage 3. 200V AC for 1 minute Current leakage Antenna Characteristics2. 0.5mA Max Specifications Temperature 3. 4. -40 to +90°C Antenna Characteristics Outer Contact Material Copper Alloy (Au plating) Centre Contact Copper Alloy (Au plating) Insulator LCP UL94-V0 Antenna Radiation Patterns3.Antenna Environmental Characteristics 4. Durability per EIA-364-09C (2-3 cycles per min @ 30 cycles) Vibration 10Hz -> 100Hz -> 10Hz for 20 mins. Peak value of acceleration 1.5mm or 59m/s2 (6G) Antenna Radiation Patterns Direction 3 axis 5 Cycles Mechanical Shock Accelerate Velocity 4. 735m/s2 (75G) Antenna Radiation Patterns3.AntennaHalf-sine shock plus. Waveform Duration Characteristics 4. 11m sec. Direct Current 1mA Direction In ±X,±Y and ±Z axes. Cycle 3 cycles for each direction, totally 18 cycles Antenna Radiation Patterns3.Antenna Characteristics2. SPE-16-8-033-C Specifications www.taoglas.com 4 Thermal Shock (40°C for 30mins to 5~35°C for 5 minutes to 90°C for 30mins to 5~35°C for 5 minutes) Transition Time 5 minutes Cycles 5 Humidity 90~95% RH Temperature 40+/- 2°C Duration 96 hours Salt Water Spray Temperature 35+/- 2°C Salt Water Density 5+/-1% (by weight) Duration 48 Hours High temperature life 90+/- 2°C for 96 hours Cold temperature life -40+/- 2°C for 96 hours H2S gas Temperature 40+/-2°C Relative Humidity 80 +/-5% RH Gas H2S 3+/-1 ppm Duration 96 Hours Moisture Sensitivity Level 3 SPE-16-8-033-C www.taoglas.com 5 3. Connector Data 3.1 6. VSWR Packaging5. Mechanical Drawing 3.0 6. 7. Packaging 2.0 Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. 1.0 0.50 1.00 1.50 Mechanical Drawing 2.00 2.50 3.00 3.50 4.00 4.50 5.00 5.50 6.00 Frequency [GHz] Sample_S11 6. 3.2 Sample_S22 Packaging Insertion Loss 1 7. 7. 7. 7. Application Note6. Packaging 0 -1 -2 Application Note Application Note6. Packaging Application Note6. Packaging5. Mechanical 0.50 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 Drawing 6. Packaging5. SPE-16-8-033-C 5.00 5.50 6.00 Frequency [GHz] Sample_S12 Mechanical Drawing www.taoglas.com 6 4. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-8-033-C Mechanical Drawing www.taoglas.com 7 5. Footprint 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-16-8-033-C www.taoglas.com 8 6. Solder Reflow 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-16-8-033-C www.taoglas.com 9 8. 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-8-033-C Mechanical Drawing www.taoglas.com 10 SPE-16-8-033-C www.taoglas.com 11 Changelog for the datasheet SPE-16-8-033 - RECE.20369.001E.01 Revision: C (Current Version) Date: Changes: Changes Made by: 2021-07-15 Updated Solder Reflow Diagram & Adding MSL. Gary West Previous Revisions Revision: B Date: Changes: Changes Made by: 2021-02-03 Following EC-20-8-036 Jack Conroy Revision: A (Original First Release) Date: 2016-04-21 Notes: Author: SPE-16-8-033-C Jack Conroy www.taoglas.com 12 www.taoglas.com SPE-16-8-033-C © Taoglas 13 www.taoglas.com
RECE.20369.001E.01 价格&库存
很抱歉,暂时无法提供与“RECE.20369.001E.01”相匹配的价格&库存,您可以联系我们找货
RECE.20369.001E.01
    RECE.20369.001E.01
    • 5000+5.005935000+0.64952
    • 10000+4.7671810000+0.61854
    • 15000+4.6328715000+0.60112
    库存:51802
    RECE.20369.001E.01
    • 1+9.179821+1.19108
    • 10+7.7676210+1.00785
    • 25+7.2768225+0.94416
    • 50+6.9292750+0.89907
    • 100+6.59826100+0.85612
    • 250+6.18459250+0.80245
    • 500+5.88907500+0.76411
    • 1000+5.607831000+0.72762
    • 2500+5.256682500+0.68205
    库存:51802
