D
WIMA SMD-PET
Metallized Polyester (PET) SMD Film Capacitors with Box Encapsulation.
Capacitances from 0.01 mF to 6.8 mF. Rated Voltages from 63 VDC to 1000 VDC.
Size Codes from 1812 to 6054.
Special Features
Electrical Data
˜ Size codes 1812, 2220, 2824,
4030, 5040 and 6054 with PET
and encapsulated
˜ Operating temperature up to 125° C
˜ Self-healing
˜ Suitable for lead-free soldering
˜ According to RoHS 2011/65/EU
Typical Applications
For general DC-applications e.g.
˜ By-pass
˜ Blocking
˜ Coupling and decoupling
˜ Timing
Construction
Capacitance range:
0.01 mF to 6.8 mF
Rated voltages:
63 VDC, 100 VDC, 250 VDC, 400 VDC,
630 VDC, 1000 VDC
Capacitance tolerances:
±20%, ±10% (±5% available subject
to special enquiry)
Operating temperature range:
–55+ C to +125+ C
Climatic test category:
55/100/21 according to IEC
for size codes 1812 to 2824
55/100/56 according to IEC
for size codes 4030 to 6054
Insulation resistance at +20+ C:
Test voltage: 1.6 Ur, 2 sec.
Voltage derating:
A voltage derating factor of 1.25 % per K
must be applied from +85) C for DC
voltages and from +75) C for AC
voltages
Reliability:
Operational life 300 000 hours (+125° C
permitted for 1000 hours max. distributed
over the entire operating life)
Failure rate 2 fit (0.5 x U r and 40+ C)
U r Utest C 0.33 mF 0.33 mF < C T 6.8 mF
Dielectric:
Polyethylene-terephthalate (PET) film
Capacitor electrodes:
Vacuum-deposited
Internal construction:
63 VDC 50 V
100 VDC 100 V
3.75 x 103 M¸
1250 sec (M¸ x mF)
U 250 VDC 100 V
1 x 10 4 M¸
3000 sec (M¸ x mF)
Measuring time: 1 min.
Dissipation factors at +20) C: tan d
Plastic film
Vacuum-deposited
electrode
Metal contact layer
(schoopage)
Terminating plate
Encapsulation:
Solvent-resistant, flame-retardant plastic
case, UL 94 V-0
Terminations:
Tinned plates.
Marking:
Box colour: Black.
at f
1 kHz
10 kHz
100 kHz
C 0.1 mF 0.1 mF < C T 1.0 mF
C > 1.0 mF
8 x 10 -3
8 x 10 -3
10 x 10 -3
15 x 10 -3
15 x 10 -3 –
30 x 10 -3 –
Maximum pulse rise time:
Capacitance max. pulse rise time V/ msec
mF
63 VDC 100 VDC 250 VDC 400 VDC 630 VDC 1000 VDC
0.01
... 0.022
30 35 40 35 40 50
0.033 ... 0.068
20 20 40 21 25 32
0.1
... 0.22
10 10 12 14 17 –
0.33 ... 0.68
8
6
9
10
1.0 ... 2.2
3.5
4
7
3.3 ... 6.8
3
3
Dip Solder Test/Processing
Available taped and reeled in blister pack.
Detailed taping information and graphs
at the end of the catalogue.
For further details and graphs please
refer to Technical Information.
06.21
Resistance to soldering heat:
Test Tb in accordance with DIN IEC
60068-2-58/DIN EN 60384-19.
Soldering bath temperature max. 260+ C.
Soldering duration max. 5 sec.
Change in capacitance DC/C 5 %.
Soldering process:
Re-flow soldering (see temperature/time
graphs page 13).
Packing
17
D
WIMA SMD-PET
Continuation
General Data
63 VDC/40 VAC*
100 VDC/63 VAC*
Capacitance Size H
Size H
Part number
Part number
code ± 0.3
code ± 0.3
0.01 mF
1812 3.0 SMDTC02100KA00_ _ _ _ 1812 3.0 SMDTD02100KA00_ _ _ _
2220 3.5 SMDTC02100QA00_ _ _ _ 2220 3.5 SMDTD02100QA00_ _ _ _
2824 3.0 SMDTC02100TA00_ _ _ _ 2824 3.0 SMDTD02100TA00_ _ _ _
0.015 „
1812 3.0 SMDTC02150KA00_ _ _ _ 1812 3.0 SMDTD02150KA00_ _ _ _
2220 3.5 SMDTC02150QA00_ _ _ _ 2220 3.5 SMDTD02150QA00_ _ _ _
2824 3.0 SMDTC02150TA00_ _ _ _ 2824 3.0 SMDTD02150TA00_ _ _ _
0.022 „
1812 3.0 SMDTC02220KA00_ _ _ _ 1812 3.0 SMDTD02220KA00_ _ _ _
2220 3.5 SMDTC02220QA00_ _ _ _ 2220 3.5 SMDTD02220QA00_ _ _ _
2824 3.0 SMDTC02220TA00_ _ _ _ 2824 3.0 SMDTD02220TA00_ _ _ _
0.033 „
1812 3.0 SMDTC02330KA00_ _ _ _ 1812 3.0 SMDTD02330KA00_ _ _ _
2220 3.5 SMDTC02330QA00_ _ _ _ 2220 3.5 SMDTD02330QA00_ _ _ _
2824 3.0 SMDTC02330TA00_ _ _ _ 2824 3.0 SMDTD02330TA00_ _ _ _
0.047 „
1812 3.0 SMDTC02470KA00_ _ _ _ 1812 3.0 SMDTD02470KA00_ _ _ _
2220 3.5 SMDTC02470QA00_ _ _ _ 2220 3.5 SMDTD02470QA00_ _ _ _
2824 3.0 SMDTC02470TA00_ _ _ _ 2824 3.0 SMDTD02470TA00_ _ _ _
0.068 „
1812 3.0 SMDTC02680KA00_ _ _ _ 1812 3.0 SMDTD02680KA00_ _ _ _
2220 3.5 SMDTC02680QA00_ _ _ _ 2220 3.5 SMDTD02680QA00_ _ _ _
2824 3.0 SMDTC02680TA00_ _ _ _ 2824 3.0 SMDTD02680TA00_ _ _ _
0.1 mF
1812 4.0* SMDTC03100KB00_ _ _ _ 1812 4.0* SMDTD03100KB00_ _ _ _
2220 3.5 SMDTC03100QA00_ _ _ _ 2220 3.5 SMDTD03100QA00_ _ _ _
2824 3.0 SMDTC03100TA00_ _ _ _ 2824 3.0 SMDTD03100TA00_ _ _ _
0.15 „
1812 4.0* SMDTC03150KB00_ _ _ _ 1812 4.0 SMDTD03150KB00_ _ _ _
2220 3.5 SMDTC03150QA00_ _ _ _ 2220 3.5 SMDTD03150QA00_ _ _ _
2824 3.0 SMDTC03150TA00_ _ _ _ 2824 3.0 SMDTD03150TA00_ _ _ _
0.22 „
1812 4.0* SMDTC03220KB00_ _ _ _ 1812 4.0 SMDTD03220KB00_ _ _ _
2220 3.5 SMDTC03220QA00_ _ _ _ 2220 3.5 SMDTD03220QA00_ _ _ _
2824 3.0 SMDTC03220TA00_ _ _ _ 2824 3.0 SMDTD03220TA00_ _ _ _
0.33 „
1812 4.0 SMDTC03330KB00_ _ _ _ 2220 4.5 SMDTD03330QB00_ _ _ _
2220 4.5* SMDTC03330QB00_ _ _ _ 2824 5.0 SMDTD03330TB00_ _ _ _
2824 5.0* SMDTC03330TB00_ _ _ _ 4030 5.0 SMDTD03330VA00_ _ _ _
0.47 „
1812 4.0 SMDTC03470KB00_ _ _ _ 2220 4.5 SMDTD03470QB00_ _ _ _
2220 4.5* SMDTC03470QB00_ _ _ _ 2824 5.0 SMDTD03470TB00_ _ _ _
2824 5.0* SMDTC03470TB00_ _ _ _ 4030 5.0 SMDTD03470VA00_ _ _ _
0.68 „
2220 4.5 SMDTC03680QB00_ _ _ _ 2824 5.0 SMDTD03680TB00_ _ _ _
2824 5.0* SMDTC03680TB00_ _ _ _ 4030 5.0 SMDTD03680VA00_ _ _ _
4030 5.0 SMDTC03680VA00_ _ _ _ 5040 6.0 SMDTD03680XA00_ _ _ _
1.0 mF
2220 4.5 SMDTC04100QB00_ _ _ _ 2824 5.0 SMDTD04100TB00_ _ _ _
2824 5.0* SMDTC04100TB00_ _ _ _ 4030 5.0 SMDTD04100VA00_ _ _ _
4030 5.0 SMDTC04100VA00_ _ _ _ 5040 6.0 SMDTD04100XA00_ _ _ _
1.5 „
2824 5.0 SMDTC04150TB00_ _ _ _ 4030 5.0 SMDTD04150VA00_ _ _ _
4030 5.0 SMDTC04150VA00_ _ _ _ 5040 6.0 SMDTD04150XA00_ _ _ _
2.2 „
2824 5.0 SMDTC04220TB00_ _ _ _ 5040 6.0 SMDTD04220XA00_ _ _ _
4030 5.0 SMDTC04220VA00_ _ _ _
3.3 „
4030 5.0 SMDTC04330VA00_ _ _ _ 5040 6.0 SMDTD04330XA00_ _ _ _
4.7 „
5040 6.0 SMDTC04470XA00_ _ _ _ 6054 7.0 SMDTD04470YA00_ _ _ _
6.8 „
6054 7.0 SMDTC04680YA00_ _ _ _
250 VDC/160 VAC*
Size H
Part number
code ± 0.3
2220 3.5 SMDTF02100QA00_ _ _ _
2824 3.0 SMDTF02100TA00_ _ _ _
2220
2824
3.5 SMDTF02150QA00_ _ _ _
3.0 SMDTF02150TA00_ _ _ _
2220
2824
3.5 SMDTF02220QA00_ _ _ _
3.0 SMDTF02220TA00_ _ _ _
2220 3.5
2824 3.0
4030 5.0
2220 3.5
2824 3.0
4030 5.0
2220 4.5*
2824 3.0
4030 5.0
2220 4.5*
2824 5.0
4030 5.0
2824 5.0
4030 5.0
SMDTF02330QA00_ _ _ _
SMDTF02330TA00_ _ _ _
SMDTF02330VA00_ _ _ _
SMDTF02470QA00_ _ _ _
SMDTF02470TA00_ _ _ _
SMDTF02470VA00_ _ _ _
SMDTF02680QB00_ _ _ _
SMDTF02680TA00_ _ _ _
SMDTF02680VA00_ _ _ _
SMDTF03100QB00_ _ _ _
SMDTF03100TB00_ _ _ _
SMDTF03100VA00_ _ _ _
SMDTF03150TB00_ _ _ _
SMDTF03150VA00_ _ _ _
2824
4030
5.0 SMDTF03220TB00_ _ _ _
5.0 SMDTF03220VA00_ _ _ _
2824
4030
5040
4030
5040
5.0
5.0
6.0
5.0
6.0
5040
6.0 SMDTF03680XA00_ _ _ _
6054
7.0 SMDTF04100YA00_ _ _ _
SMDTF03330TB00_ _ _ _
SMDTF03330VA00_ _ _ _
SMDTF03330XA00_ _ _ _
SMDTF03470VA00_ _ _ _
SMDTF03470XA00_ _ _ _
* Version according to catalogue 2013
still available
Part number completion:
Tolerance: 20 % = M
10 % = K
5 % = J
Packing:
bulk = S
Pin length: none = 00
Taped version see page 160.
* AC voltage: f = 50 Hz; 1.4 x Urms + UDC Ur
06.21
Dims. in mm.
Rights reserved to amend design data without prior notification.
18
Continuation page 19
D
WIMA SMD-PET
Continuation
General Data
400 VDC/200 VAC*
630 VDC/300 VAC*
1000 VDC/400 VAC*
Capacitance Size
H
Size
H
Size
H
Part number
Part number
Part number
code ± 0.3
code ± 0.3
code ± 0.3
0.01 mF
2824 3.0 SMDTG02100TA00_ _ _ _ 4030 5.0 SMDTJ02100VA00_ _ _ _
4030 5.0 SMDTG02100VA00_ _ _ _
0.015 „
2824 3.0 SMDTG02150TA00_ _ _ _ 4030 5.0 SMDTJ02150VA00_ _ _ _ 5040 6.0 SMDTO12150XA00_ _ _ _
4030 5.0 SMDTG02150VA00_ _ _ _
0.022 „
2824 5.0* SMDTG02220TB00_ _ _ _ 5040 6.0 SMDTJ02220XA00_ _ _ _ 5040 6.0 SMDTO12220XA00_ _ _ _
4030 5.0 SMDTG02220VA00_ _ _ _
0.033 „
2824 5.0 SMDTG02330TB00_ _ _ _ 5040 6.0 SMDTJ02330XA00_ _ _ _ 5040 6.0 SMDTO12330XA00_ _ _ _
4030 5.0 SMDTG02330VA00_ _ _ _
0.047 „
2824 5.0 SMDTG02470TB00_ _ _ _ 5040 6.0 SMDTJ02470XA00_ _ _ _ 6054 7.0 SMDTO12470YA00_ _ _ _
4030 5.0 SMDTG02470VA00_ _ _ _
0.068 „
4030 5.0 SMDTG02680VA00_ _ _ _ 5040 6.0 SMDTJ02680XA00_ _ _ _
5040 6.0 SMDTG02680XA00_ _ _ _
0.1 mF
4030 5.0 SMDTG03100VA00_ _ _ _ 6054 7.0 SMDTJ03100YA00_ _ _ _
5040 6.0 SMDTG03100XA00_ _ _ _
0.15 „
4030 5.0 SMDTG03150VA00_ _ _ _ 6054 7.0 SMDTJ03150YA00_ _ _ _
5040 6.0 SMDTG03150XA00_ _ _ _
0.22 „
5040 6.0 SMDTG03220XA00_ _ _ _ 6054 7.0 SMDTJ03220YA00_ _ _ _
0.33 „
5040 6.0 SMDTG03330XA00_ _ _ _
0.47 „
6054 7.0 SMDTG03470YA00_ _ _ _
* Version according to catalogue 2013 still available
Solder pad recommendation
W
b
H
Tolerance: 20 % = M
10 % = K
5 % = J
Packing:
bulk = S
a
d
Dims. in mm.
L
c
d
Bonding slit
Size L W d a b c
code ±0.3 ±0.3 min. min. max.
06.21
1812 4.8 3.3 0.5
2220 5.7 5.1 0.5
2824 7.2 6.1 0.5
4030 10.2 7.6 0.5
5040 12.7 10.2 0.7
6054 15.3 13.7 0.7
1.2
1.2
1.2
2.5
2.5
2.5
3.5 3.5
4 4.5
4 6.5
6 9
6 11.5
6 14
19
WIMA SMD-PET
D
Continuation
Impedance change with frequency
(general guide).
07.21
Permissible AC voltage in relation to frequency at 10) C internal temperature rise
(general guide).
19a
D
Recommendation for Processing
and Application of SMD Capacitors
Layout Form
Soldering Process
The components can generally be
positioned on the carrier material as
desired. In order to prevent soldering
shadows or ensure regular temperature
distribution, extreme concentration of the
components should be avoided. In practice, it has proven best to keep a
minimum distance of the soldering
surfaces between two WIMA SMDs of
twice the height of the components.
Re-flow soldering
Solder Pad Recommendation
W
b
H
a
d
c
L
d
Bonding slit
Size
code
1812
2220
2824
4030
5040
6054
L
± 0.3
4.8
5.7
7.2
10.2
12.7
15.3
W
± 0.3
3.3
5.1
6.1
7.6
10.2
13.7
d
0.5
0.5
0.5
0.5
0.7
0.7
a
b
c
min. min. max.
1.2 3.5 3.5
1.2 4
4.5
1.2 4
6.5
2.5 6
9
2.5 6 11.5
2.5 6 14
The solder pad size recommendations
given for each individual series are to be
understood as minimum dimensions which
can at any time be adjusted to the layout
form.
Processing
The processing of SMD components
– assembling
– soldering
– electrical final inspection/calibrating
Due to versatile procedures exact processing parameters for re-flow soldering
processes cannot be specified. The graph
depicted is to be understood as a recommendation to help establishing a suitable
soldering profile fulfilling the requirements
in practice at the user. During processing
a max. temperature of T=210° C inside the
component should not be exceeded. Due
to the differing heat absorption the length
of the soldering process should be kept as
short as possible for smaller size codes.
SMD Handsoldering
WIMA SMD capacitors with plastic
film dielectric are generally suitable for
hand-soldering, e. g. for lab purposes, with
a soldering iron where, however, similar to
automated soldering processes, a certain
duration and temperature should not be
exceeded. These parameters are dependent
on the physical size of the components and
the relevant heat absorption involved.
Size code
1812
2220
2824
4030
5040
6054
Temperature ° C / ° F
250 / 482
250 / 482
260 / 500
260 / 500
260 / 500
260 / 500
The below data are to be regarded as
guideline values and should serve to avoid
damage to the dielectric caused by excessive heat during the soldering process. The
soldering quality depends on the tool used
and on the skill and experience of the person with the soldering iron in hand.
Time duration
2 sec plate 1
3 sec plate 1
3 sec plate 1
5 sec plate 1
5 sec plate 1
5 sec plate 1
5
5
5
5
5
5
sec
sec
sec
sec
sec
sec
off
off
off
off
off
off
2
3
3
5
5
5
sec
sec
sec
sec
sec
sec
plate
plate
plate
plate
plate
plate
2
2
2
2
2
2
06.21
must be regarded as a complete process.
The soldering of the printed circuit board,
for example, can constitute considerable
stress on all the electronic components.
The manufacturer‘s instructions on the processing of the components are mandatory.
Temperature/time graph for the permissible processing temperature of the
WIMA SMD film capacitor for typical convection soldering processes.
13
D
(Continuation)
Solder Paste
To achieve reliable soldering results one of
the following solder alloys have from case
to case proven being workable:
Lead free solder paste
Sn - Bi
Sn - Zn (Bi)
Sn - Ag - Cu (suitable for SMD-PET 5040/
6054, SMD-PEN and SMD-PPS)
Solder paste with lead
Sn - Pb - Ag (Sn60-Pb40-A, Sn63-Pb37-A)
Washing
WIMA SMD components with plastic
encapsulation - like all other components
of similar construction irrespective of the
make - cannot be regarded as hermetically sealed. Due to today’s common
washing substances, e. g. on aqueous
basis instead of the formerly used halogenated hydrocarbons, with enhanced
washing efficiency it became obvious that
assembled SMD capacitors may show an
impermissibly high deviation of the electrical parameters after a corresponding
washing process. Hence it is recommended
to refrain from applying industrial washing
processes for WIMA SMD capacitors in
order to avoid possible damages.
Initial Operation/Calibration
Due to the stress which the components
are subjected to during processing, reversible parameter changes occur in almost all
electronic components. The capacitance
recovery accuracy to be expected with
careful processing is within a scope
of
advisable to prolong the storage time to
number of other outstanding qualities:
t U 10 days
” favourable pulse rise time
” low ESR
” low dielectric absorption
” available in high voltage series
” large capacitance spectrum
” stand up to high mechanical
stress
” good long-term stability
In this way ageing effects of the capacitor
structure can be anticipated. Parameter
changes due to processing are not to be
expected after this period of time
Humidity Protection Bags
Taped WIMA SMD capacitors are shipped
in humidity protection bags according to
JEDEC standard (ESD/EMI-shield/watervapour proof).
Under controlled conditions the components can be stored two years and more
in the originally sealed bag. Opened
packing units should immediately be used
up for processing. If storage is necessary
the opened packing units should be stored
air-tight in the original plastic bag.
Reliability
Taking account of the manufacturer‘s
guidelines and compatible processing,
the WIMA SMD stand out for the same
high quality and reliability as the
analogous through-hole WIMA series. The
technology of metallized film capacitors
used e.g. in WIMA SMD-PET achieves
the best values for all fields of application.
The expected value is about:
Û0 T 2 fit
As regards technical performance as well
as quality and reliability, the WIMA
SMD series offer the possibility to cover
nearly all applications of conventionally
through-hole film capacitors with SMD
components. Furthermore, the WIMA SMD
series can now be used for all the demanding capacitor applications for which, in
the past, the use of through-hole components was mandatory:
” measuring techniques
” oscillator circuits
” differentiating and integrating
circuits
” A/D or D/A transformers
” sample and hold circuits
” automotive electronics
With the WIMA SMD programme available today, the major part of all plastic
film capacitors can be replaced by WIMA
SMD components. The field of application
ranges from standard coupling capacitors
to use in switch-mode power supplies as
filter or charging capacitors with high voltage and capacitance values, as well as
in telecommunications e.g. the well-known
telephone capacitor 1mF/250VDC.
Furthermore the production of all WIMA
components is subject to the regulations
laid down by ISO 9001:2015 as well
as the guidelines for component specifications set out by IEC quality assessment
system (IECQ) for electronic components.
DC/CT 5 %.
For the initial operation of the device a
minimum storage time of
t U 24 hours
Basically the WIMA SMD series have the
same electrical characteristics as the analogous through-hole WIMA capacitors.
Compared to ceramic or tantalum
dielectrics WIMA SMD capacitors have a
06.21
is to be taken into account. With calibrated devices or when the application
is largely dependent on capacitance it is
Electrical Characteristics and
Fields of Application
14
D
Blister Tape Packaging and Packing Units
of the WIMA SMD Capacitors
Tape reel:
Tape advance and return:
+2
W1 - 0
10 - 20 empty compartments
180/330 +0
-2
N1.5
130.5
Cover film advance
Tape advance
Tape return
min. 200 mm
Unwinding direction
All dims. in mm.
G
W2 max.
E
F
W
B1
B0
T
W0
A1
A0
P
P0
P2
D0
D1
P
P 0*
K
Type
W2max
W1± 20
N ±1.5
1812
19
12.4
62
2220
19
12.4
62
2824
19
12.4
62
4030
22.4
16.4
60
5040
30.4
24.4
90
6054
30.4
24.4
90
Packing units
Size Code 1812 A0
± 0.1
A1
B0
± 0.1
B1
D0
+ 0.1
-0
D1
+ 0.1
-0
± 0.1
P2
E
F
G
± 0.1 ± 0.05 ± 0.1 ± 0.05
W W0
K
T
± 0.3
± 0.2
± 0.1
± 0.1
taped
taped
Reel
Reel
180 mm P 330 mm P
bulk
Standard
Box size
Code
4.8 x 3.3 x 3
KA
3.55 3.3
5.1
4.8 P1.5 P1.5
8
4
2
1.75 5.5
2.2
12
9.5
3.4
0.3
700
2500
3000
4.8 x 3.3 x 4
KB
3.55 3.3
5.1
4.8 P1.5 P1.5
8
4
2
1.75 5.5
2.2
12
9.5
4.4
0.3
500
2000
3000
A1
B0
± 0.1
B1
P 0* P 2 E
F
G
Size Code 2220 A 0
± 0.1
Box size
Code
D0
+ 0.1
-0
D1
+ 0.1
-0
P
± 0.1
W W0
K
T
± 0.3
± 0.2
± 0.1
± 0.1
taped
taped
Reel
Reel
180 mm P 330 mm P
bulk
Standard
5.7 x 5.1 x 3.5 QA
6.3
5.7
5.6
5.1 P1.5 P1.5
8
4
2
1.75 5.5 1.95 12
9.5
3.7
0.3
500
1800
3000
5.7 x 5.1 x 4.5 QB
6.3
5.7
5.6
5.1 P1.5 P1.5
8
4
2
1.75 5.5 1.95 12
9.5
4.7
0.3
400
1500
3000
Size Code 2824 A 0
A1
B0
± 0.1
B1
± 0.1
D0
+ 0.1
-0
D1
+ 0.1
-0
P
± 0.1
P 0* P 2 E
F
G
W W0
K
T
± 0.3
± 0.2
± 0.1
± 0.1
taped
Reel
330 mm P
Standard
bulk
Box size
Code
7.2 x 6.1 x 3
TA
6.6
6.1
7.7
7.2 P1.5 P1.5 12
4
2
1.75 5.5
0.9
12
9.5
3.4
0.3
1500
2000
7.2 x 6.1 x 5
TB
6.6
6.1
7.7
7.2 P1.5 P1.5 12
4
2
1.75 5.5
0.9
12
9.5
5.4
0.4
750
2000
taped
Reel
330 mm P
bulk
Standard
775
2000
Code
A0
± 0.1
A1
B0
± 0.1
B1 D0 D1
P P 0* P 2 E F
+ 0.1 + 0.1 ± 0.1 ± 0.1 ± 0.05 ± 0.1 ± 0.05
-0
-0
Size Code 4030 VA 10.7 10.2 8.1 9.1 P1.5 P1.5 16
4
2
G
W W0 K T
± 0.3 ± 0.2 ± 0.1 ± 0.1
1.75 7.5 1.9 16 13.3 5.5 0.3
Size Code 5040 XA 13.5 12.7 11 11.5 P1.5 P1.5 16
4
2
1.75 11.5 4.7
24 21.3 6.5 0.3
600
1000
Size Code 6054
4
2
1.75 11.5 2.95 24 21.3 7.5 0.3
450
500
YA
17.0 16.5 15.6 15.0 P1.5 P1.5 20
* cumulative after 10 steps p 0.2 mm max.
Samples and pre-production needs on request or 1 Reel minimum.
Part number codes for SMD packing
W (Blister)
P in mm
Code
12
180
P
12
330
Q
16
330
R
24
330
T
S
06.21
Bulk Standard
160
D
WIMA Part Number System
A WIMA part number consists of 18 digits and is composed as follows:
Field 1 - 4: Type description
Field 5 - 6: Rated voltage
Field 7 - 10: Capacitance
Field 11 - 12: Size and PCM
Field 13 - 14: Version code (e.g. Snubber versions)
Field 15:
Field 16:
Packing
Field 17 - 18: Pin length (untaped)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
M
K
S
2
C
1
A
M
S
S
D
20 %
bulk
MKS 2
06.21
Type description:
SMD-PET
= SMDT
SMD-PEN
= SMDN
SMD-PPS
= SMDI
FKP 02
= FKP0
MKS 02
= MKS0
FKS 2
= FKS2
FKP 2
= FKP2
FKS 3
= FKS3
FKP 3
= FKP 3
MKS 2
= MKS2
MKP 2
= MKP2
MKS 4
= MKS4
MKP 4
= MKP4
MKP 10
= MKP1
FKP 4
= FKP4
FKP 1
= FKP1
MKP-X2
= MKX2
MKP-X1 R
= MKX1
MKP-Y2
= MKY2
MP 3-X2
= MPX2
MP 3-X1
= MPX1
MP 3-Y2
= MPY2
MP 3R-Y2
= MPRY
MKP 4F
= MKPF
Snubber MKP = SNMP
Snubber FKP
= SNFP
GTO MKP
= GTOM
DC-LINK MKP 4 = DCP4
DC-LINK MKP 6 = DCP6
DC-LINK HC
= DCHC
63 VDC
Rated voltage:
50 VDC = B0
63 VDC = C0
100 VDC = D0
250 VDC = F0
400 VDC = G0
450 VDC = H0
520 VDC = H2
600 VDC = I0
630 VDC = J0
700 VDC = K0
800 VDC = L0
850 VDC = M0
900 VDC = N0
1000 VDC = O1
1100 VDC = P0
1200 VDC = Q0
1250 VDC = R0
1500 VDC = S0
1600 VDC = T0
1700 VDC = TA
2000 VDC = U0
2500 VDC = V0
3000 VDC = W0
4000 VDC = X0
6000 VDC = Y0
250 VAC = 0W
275 VAC = 1W
300 VAC = 2W
305 VAC = AW
350 VAC = BW
440 VAC = 4W
500 VAC = 5W
0.01 mF
Capacitance:
22 pF
= 0022
47 pF
= 0047
100 pF = 0100
150 pF = 0150
220 pF = 0220
330 pF = 0330
470 pF = 0470
680 pF = 0680
1000 pF = 1100
1500 pF = 1150
2200 pF = 1220
3300 pF = 1330
4700 pF = 1470
6800 pF = 1680
0.01 mF = 2100
0.022 mF = 2220
0.047 mF = 2470
0.1 mF = 3100
0.22 mF = 3220
0.47 mF = 3470
= 4100
1 mF
2.2 mF = 4220
4.7 mF = 4470
= 5100
10 mF
= 5220
22 mF
= 5470
47 mF
100 mF = 6100
220 mF = 6220
1000 mF = 7100
1500 mF = 7150
2.5 x 6.5 x 7.2
Size:
4.8 x 3.3 x 3 Size 1812 = KA
4.8 x 3.3 x 4 Size 1812 = KB
5.7 x 5.1 x 3.5 Size 2220 = QA
5.7 x 5.1 x 4.5 Size 2220 = QB
7.2 x 6.1 x 3 Size 2824 = TA
7.2 x 6.1 x 5 Size 2824 = TB
10.2 x 7.6 x 5 Size 4030 = VA
12.7 x 10.2 x 6 Size 5040 = XA
15.3 x 13.7 x 7 Size 6054 = YA
2.5 x 7 x 4.6 PCM 2.5 = 0B
3 x 7.5 x 4.6 PCM 2.5 = 0C
2.5 x 6.5 x 7.2 PCM 5 = 1A
3 x 7.5 x 7.2 PCM 5
= 1B
2.5 x 7 x 10 PCM 7.5
= 2A
3 x 8.5 x 10 PCM 7.5
= 2B
3 x 9 x 13 PCM 10
= 3A
4 x 9 x 13 PCM 10
= 3C
5 x 11 x 18 PCM 15
= 4B
6 x 12.5 x 18 PCM 15 = 4C
5 x 14 x 26.5 PCM 22.5 = 5A
6 x 15 x 26.5 PCM 22.5 = 5B
9 x 19 x 31.5 PCM 27.5 = 6A
11 x21 x 31.5 PCM 27.5 = 6B
9 x 19 x 41.5 PCM 37.5 = 7A
11 x 22 x 41.5 PCM 37.5 = 7B
19 x 31 x 56 PCM 48.5 = 8D
25 x 45 x 57 PCM 52.5 = 9D
Version code:
Standard
Version A1
Version A1.1.1 =
Version A2
00
1A
1B
2A
Tolerance:
±20 % =
±10 % =
±5 %
±2.5 % =
±1 %
6 -2
M
K
J
H
E
Packing:
AMMO H16.5 340 x 340
AMMO H16.5 490 x 370
AMMO H18.5 340 x 340
AMMO H18.5 490 x 370
REEL H16.5 360
REEL H16.5 500
REEL H18.5 360
REEL H18.5 500
ROLL H16.5
ROLL H18.5
BLISTER W12 180
BLISTER W12 330
BLISTER W16 330
BLISTER W24 330
Bulk/TPS Standard
=A
=B
=C
=D
=F
=H
=I
=J
=N
=O
=P
=Q
=R
=T
=S
3.5 ±0.5 = C9
6 -2
= SD
16 ±1
= P1
Pin length (taped)
none
= 00
The data on this page is not complete and serves only to explain the part number system. Part number information is listed on the
pages of the respective WIMA range.
159
很抱歉,暂时无法提供与“SMDTC04470XA00MT00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.21080
- 10+15.83280
- 30+15.57360
