SMH-106-02-T-S
SMH-106-02-T-S
    SAMTEC(申泰)
    SMD
    1X6P 间距:2.54MM 卧贴
SMH-106-02-T-S 数据手册
REVISION AG SMH-1XX-XX-XX-X-XX NO. OF POSITIONS -02 THRU -36 (PER ROW) DO NOT SCALE FROM THIS PRINT LEAD STYLE -02: SURFACE MOUNT (USE C-8-03-X) -22: LOW INSERTION FORCE (USE C-17-03-X) ((No OF POS x .100[2.54] ) + .020[.51]) .010[.25] POSITION 01 2 MAX SWAY (EITHER DIRECTION) .031 0.79 x .016[.41] REF (TYP) OPTIONS -XX: INDICATES POSITION POLARIZED (USE PK-06-N) -TR: TAPE & REEL PACKAGING (2 - 29 POSITIONS ONLY) ROW SPECIFICATION -D: DOUBLE ROW (USE SMH-50-D) (SEE FIG 1) -S: SINGLE ROW (USE SSW-50-S) (SEE FIG 2, SHT 2) PLATING -G: 20µ" OVER IN CONTACT AREA, FLASH GOLD ON TAIL -T: TIN OVER, MATTE TIN ON TAIL -S: 30µ" OVER IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" OVER IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" OVER IN CONTACT AREA, FLASH GOLD ON TAIL -L: 10µ" OVER IN CONTACT AREA, MATTE TIN ON TAIL -TM: TIN OVER, MATTE TIN ON TAIL -SM: 30µ" OVER IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" OVER IN CONTACT AREA, MATTE TIN ON TAIL .335 8.51 REF SECTION "A"-"A" C SMH-50-D .285±.010 7.24±0.25 SEE TABLE 1 02 .195 4.95 REF .100 2.54 REF C SEE NOTE 2 01 "A" "A" .045 1.15 REF .028 0.72 REF FIG 1 SMH-120-XX-XX-D SHOWN .135±.010 3.43±0.25 C SEE SHEET 2 FOR IN-PROCESS VIEWS NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. COPLANARITY: POSITIONS 02-24= .006[.15], POSITIONS 25-36= .008[.20]. 3. BURR ALLOWANCE: .003[.08] MAX. 4. ONE POSITION WILL BE LOST FOR EVERY CUT MADE ON A SOCKET STRIP: CUT FLASH TO BE .010 [.25] MAX WITH NO FLASH ALLOWED IN HOLES OR EXTENDING BELOW LEADS 5. MINIMUM PUSHOUT FORCE: 1.5 LB. 6. MAXIMUM ALLOWABLE BOW: .003[.08] INCH/INCH AFTER ASSEMBLY. 7. ENDWALLS AFTER CUTTING: .045 +/-.003. 8. SHEAR TAILS TO DIMENSION SHOWN. 9. CONTACT TAILS TO BE FLUSH TO .003[.08] ABOVE OR BELOW A DATUM LINE MADE BY THE INSULATOR. (-DH ONLY) 10. NOTE DELETED. 11. POSITIONS 4 OR LESS SHOULD BE LAYER PACKAGED UNLESS OTHERWISE NOTED IN THE PART CALLOUT. 12. NOTE DELETED. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] MATERIAL: 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94 VO, COLOR: BLACK CONTACT: PHOSPHOR BRONZE F:\DWG\MISC\MKTG\SMH-1XX-XX-XX-X-XX-MKT.SLDDRW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .100 [2.54] HORIZONTAL SMT SOCKET ASSEMBLY DWG. NO. SMH-1XX-XX-XX-X-XX BY: BRATCHER 2/5/99 SHEET 1 OF 3 REVISION AG .394 10.01 SEE NOTE 9 (-DH ONLY) .394 10.01 IN-PROCESS 1 .135±.010 3.43±0.25 IN-PROCESS 3 MUST FILL WITH DIE SIDE OF PIN FACING DOWN, PINS ARE STAMPED WITH A SQUARE INDICATOR MARK ON DIE SIDE .350 .010 (SEE NOTE 8) .145±.010 3.68±0.25 (SEE NOTE 8) IN-PROCESS 2 .045 1.15 REF MUST FILL WITH DIE SIDE OF PIN FACING DOWN, PINS ARE STAMPED WITH A SQUARE INDICATOR MARK ON DIE SIDE .135±.010 3.43±0.25 IN-PROCESS 4 C .003 0.08 IN-PROCESS 5 TAILS MUST BE WITHIN +/-.003 WITH RESPECT TO EACH OTHER. SSW-50-S SEE TABLE 1 .095 2.41 REF C SEE NOTE 2 01 .045 1.15 REF C .135±.010 3.43±0.25 FIG 2 F:\DWG\MISC\MKTG\SMH-1XX-XX-XX-X-XX-MKT.SLDDRW SMH-120-XX-XX-S SHOWN (SAME AS FIG 1, UNLESS OTHERWISE STATED) .394 10.01 IN-PROCESS 1 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. .140±.010 3.56±0.25 (SEE NOTE 8) IN-PROCESS 2 DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .100 [2.54] HORIZONTAL SMT SOCKET ASSEMBLY DWG. NO. SMH-1XX-XX-XX-X-XX BY: BRATCHER 2/5/99 SHEET 2 OF 3 REVISION AG POSITION 01 POSITION 01 USER DIRECTION OF REELING POCKET NOT DETAILED USER DIRECTION OF REELING POCKET NOT DETAILED SHM-105-XX-XX-S-TR SHOWN SHM-105-XX-XX-D-TR SHOWN -TR PACKAGING VIEW PT-1-24-03-29 SEE NOTE 11 TUBE PACKAGING PT-1-24-01-30 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\SMH-1XX-XX-XX-X-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .100 [2.54] HORIZONTAL SMT SOCKET ASSEMBLY DWG. NO. SMH-1XX-XX-XX-X-XX BY: BRATCHER 2/5/99 SHEET 3 OF 3
SMH-106-02-T-S 价格&库存
很抱歉,暂时无法提供与“SMH-106-02-T-S”相匹配的价格&库存,您可以联系我们找货
