CQB60W-110S24
CQB60W-110S24
    CINCON
CQB60W-110S24 数据手册
V12 CQB60W-110S SERIES ︳ 60 WATT DC-DC CONVERTERS FEATURES * 60W Isolated Output * Efficiency to 92% * Low No Load Power Consumption * 4:1 Input Range * Regulated Outputs * Remote On/Off * Over Temperature/Voltage/Current Protection * Continuous Short Circuit Protection * Quarter Brick Size Meet Industrial Standard * UL60950-1 (Basic Insulation) Approval * Meets EN50155 with External Circuits * Shock & Vibration Meets EN50155 (EN61373) * CE Mark Meets 2014/30/EU * Fire & Smoke Meets EN45545-2 * 4000m Operating Altitude MODEL NUMBER INPUT VOLTAGE OUTPUT VOLTAGE OUTPUT CURRENT MIN. MAX. INPUT CURRENT % EFF. CAPACITOR LOAD MAX. NO LOAD FULL LOAD 91 6800µF CQB60W-110S05 43-160 VDC CQB60W-110S12 43-160 VDC 5 VDC 0 mA 12 A 5 mA 12 VDC 0 mA 5A 5 mA 600 mA 593 mA 92 3300µF CQB60W-110S15 43-160 VDC 15 VDC 0 mA 4A 5 mA 606 mA 90 3300µF CQB60W-110S24 43-160 VDC 24 VDC 0 mA 2.5 A 5 mA 606 mA 90 1200µF CQB60W-110S28 43-160 VDC 28 VDC 0 mA 2.14 A 5 mA 606 mA 90 1200µF CQB60W-110S48 43-160 VDC 48 VDC 0 mA 1.25 A 5 mA 613 mA 89 470µF NOTE: 1. Nominal Input Voltage 110VDC 1 V12 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENRAL SPECIFICATIONS: Input Voltage Range ....……………........…........ 110V ................... 43-160V Input Surge Voltage (100ms max.) ………………..…….…... 180Vdc max. Under Voltage Lockout ……….........…….. Power up …..….......………. 42V Power down ………..….…. 38V Positive Logic Remote On/Off (note 4&5) Input Filter …………………………..……………………..….……... PI Type Efficiency .................….......................................……..........…....... See Table Isolation Voltage ……………..…. Input/Output …..……..…… 3000VDC min. Input/Case …………..….… 3000VDC min. Output/Case …….……...… 1500VDC min. 7 Isolation Resistance ..............................…......................…….... 10 ohm min. Isolation Capacitance …………………...…………..…….…..…… 1000pF typ. OUTPUT SPECIFICATIONS: Switching Frequency ........…………..........................……….…... 200KHz typ. Voltage Accuracy ........................................……...…….......... ±1.0% max. Transient Response (25% Step Load Change) ….………………… 3.5VDC to 75VDC or open circuit Module off …………………….………………………….. < 1.2 VDC 5. Suffix "N" to the model number with negative logic remote on/off Module on ……………………………………………..…. < 1.2 VDC Module off …………..……….. >3.5VDC to 75VDC or open circuit 6. Suffix “-C” to the model number with clear mounting insert (3.2mm DIA.) 7. An external input capacitor 68uF for all models are recommended to reduce input ripple voltage. 8. Design meet EN50155 and RIA12 refer to application note. CASE QB All Dimensions In Inches(mm) Tolerances Inches: X.XX= ±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX=±0.25 REMOTE ON/OFF CONTROL ON/OFF (2) 2.28 [57.9] HIGH SIGNAL HERE DISABLE OUTPUT 2.000[50.8] BOTTOM VIEW 1 0.300[7.62] 2 4 5 6 7 8 0.600[15.24] 3 Pin 1 2 3 4 5 6 7 8 -VIN(3) EXTERNAL OUTPUT TRIM +SENSE(7) +SENSE(7) TRIM DOWN 0.059[1.50] 0.16min [4.1] 0.040[1.02] DIA 6PLACES Function +V Input On/Off -V Input -V Output -Sense Trim +Sense +V Output TRIM(6) 1.86[47.2] TRIM(6) TRIM UP DIA 2PLACES -SENSE (5) 0.50 [12.7] 1.03[26.2] 0.600[15.24] 1.45 [36.8] Mounting Inserts M3*0.5 Through 2pl. 2 -SENSE (5) 10K ohms TRIMPOT
CQB60W-110S24 价格&库存
很抱歉,暂时无法提供与“CQB60W-110S24”相匹配的价格&库存,您可以联系我们找货
