AZ5125-02S.R7G
AZ5125-02S.R7G
    AMAZING(晶焱)
    SOT23-3L
    TVS VRWM=5V VBR(Min)=5.8V VC=11.5V SOT23-3L
AZ5125-02S.R7G 数据手册
AZ5125-02S Transient Voltage Suppressing Device For ESD/Transient Protection Features lines or control/data lines, downstream components. ESD Protect for 2 Lines with Bi-directional  Provide ESD protection for the protected line to protecting any  IEC 61000-4-2 (ESD) ±15kV (air), ±15kV (contact) IEC 61000-4-4 (EFT) 40A (5/50ns) Cable Discharge Event (CDE) Small SOT23-3L package saves board space  Protect two I/O lines or two power lines  Fast turn-on and Low clamping voltage  Low operating voltage: 5V  Solid-state silicon-avalanche and active circuit triggering technology  Green Part  AZ5125-02S is bi-directional and may be used on lines where the signal swings above and below ground. AZ5125-02S may be used to meet the ESD immunity requirements of IEC 61000-4-2, Level 4 (±15kV air, ±8kV contact discharge). Circuit Diagram / Pin Configuration 3 Applications Computer Interfaces Protection  Microprocessors Protection  Serial and Parallel Ports Protection  Control Signal Lines Protection  Power lines on PCB Protection  Latchup Protection  1 2 Description SOT23-3L (Top View) AZ5125-02S is a design which includes two bi-directional ESD rated clamping cells to protect two power lines, or two control lines, or two low speed data lines in an electronic systems. The AZ5125-02S has been specifically designed to protect sensitive components which are connected to power and control lines from over-voltage damage and latch-up caused by Electrostatic Discharging (ESD), Electrical Fast Transients (EFT), and Cable Discharge Event (CDE). AZ5125-02S is a unique design which includes proprietary clamping cells in a single package. During transient conditions, the proprietary clamping cells prevent over-voltage on the power Revision 2011/07/28 ©2011-2012 Amazing Micro. 1 www.amazingIC.com AZ5125-02S Transient Voltage Suppressing Device For ESD/Transient Protection SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PARAMETER PARAMETER RATING UNITS VDC ±5.8 V Operating Supply Voltage (pin-1,-2 to pin-3) ESD per IEC 61000-4-2 (Air) ±15 VESD ESD per IEC 61000-4-2 (Contact) Lead Soldering Temperature TSOL kV ±15 260 (10 sec.) o C Operating Temperature TOP -55 to +85 o Storage Temperature TSTO -55 to +150 o C C ELECTRICAL CHARACTERISTICS PARAMETER Reverse Stand-Off Voltage Reverse Leakage Current Reverse Breakdown Voltage ESD Clamping Voltage Channel Input Capacitance SYMBOL VRWM CONDITIONS T=25 oC ILeak VRWM = ±5V, T=25 oC. VBV IBV = 1mA, T=25 oC. VESD_CL CIN Revision 2011/07/28 ©2011-2012 TYP -5 5.8 IEC 61000-4-2 +6kV, T=25 oC, Contact mode VR= 0V, f = 1MHz, T=25 oC. Amazing Micro. MINI 2 MAX UNITS 5 V 1 µA 9 V 11.5 6 V 8 pF www.amazingIC.com AZ5125-02S Transient Voltage Suppressing Device For ESD/Transient Protection Typical Variation of CIN vs. VIN 8 Input Capacitance (pF) 7 6 Pin-1, -2 to pin-3 5 4 3 2 f = 1MHz, T=25 oC, 1 0 -5 -4 -3 -2 -1 0 1 2 3 4 5 Transmission Line Pulsing (TLP) Current (A) Typical Characteristics V_pulse Pulse from a transmission line TLP_I 100ns + TLP_V DUT - Pin-1, -2 to Pin-3 -12 -10 -8 -6 -4 -2 0 2 4 6 8 10 Transmission Line Pulsing (TLP) Voltage (V) Input Voltage (V) Revision 2011/07/28 ©2011-2012 Transmission Line Pulsing (TLP) Measurement 18 16 14 12 10 8 6 4 2 0 -2 -4 -6 -8 -10 -12 -14 -16 -18 Amazing Micro. 3 www.amazingIC.com AZ5125-02S Transient Voltage Suppressing Device For ESD/Transient Protection Applications Information In order to obtain enough suppression of ESD induced transient, good circuit board is critical. The AZ5125-02S is designed to protect two lines Thus, the following guidelines are recommended: against  System ESD/EFT/Cable-Discharging pulses by clamping them to an acceptable reference. It provides bi-directional protection. Minimize the path length between the protected lines and the AZ5125-02S.  Place the AZ5125-02S near the input terminals or connectors to restrict transient The usage of the AZ5125-02S is shown in Fig. 1. Protected lines, such as data lines, control lines, coupling.  or power lines, are connected at pin 1 and pin 2 The ESD current return path to ground should be kept as short as possible. respectively. The pin 3 is connected to a ground  Use ground planes whenever possible. plane on the board. In order to minimize parasitic  NEVER route critical signals near board inductance in the board traces, all path lengths edges and near the lines which the ESD connected to the pins of AZ5125-02S should be transient easily injects to. kept as short as possible. Input Output VBR Transient Voltage -VBR VCL gnd gnd -VCL VBR Normal Operation -VBR gnd gnd Protected Devices 1 2 3 Fig. 1 Revision 2011/07/28 ©2011-2012 Amazing Micro. 4 www.amazingIC.com AZ5125-02S Transient Voltage Suppressing Device For ESD/Transient Protection Mechanical Details SOT23-3L PACKAGE DIAGRAMS TOP VIEW END VIEW SIDE VIEW PACKAGE DIMENSIONS Revision 2011/07/28 ©2011-2012 Amazing Micro. 5 www.amazingIC.com AZ5125-02S Transient Voltage Suppressing Device For ESD/Transient Protection LAND LAYOUT 0.9mm 1.4mm 3.5mm 0.7mm 0.95mm 0.95mm 1.4mm 0.9mm 1.0mm 0.9mm Notes: This LAND LAYOUT is for reference purposes only. Please consult your manufacturing partners to ensure your company’s PCB design guidelines are met. MARKING CODE 3 202X 502XY 1 Part Number Marking Code AZ5125-02S 502XY 2 502 = Device Code X = Date Code Y = Control Code Ordering Information PN# Material Type Reel size MOQ/internal box MOQ/carton AZ5125-02S.R7G Green T/R 7 inch 4 reel=12,000/box 6 box=72,000/carton Revision 2011/07/28 ©2011-2012 Amazing Micro. 6 www.amazingIC.com AZ5125-02S Transient Voltage Suppressing Device For ESD/Transient Protection Revision History Revision Modification Description Revision 2009/04/22 Preliminary Release. Revision 2009/08/19 Formal Release. Revision 2011/07/28 1. Update the Company Logo. 2. Add the Ordering Information. Revision 2011/07/28 ©2011-2012 Amazing Micro. 7 www.amazingIC.com
AZ5125-02S.R7G 价格&库存
很抱歉,暂时无法提供与“AZ5125-02S.R7G”相匹配的价格&库存,您可以联系我们找货
