IRFR024NTRPBF
IRFR024NTRPBF
    VBSEMI(微碧)
    TO-252AA
    MOS管 N-Channel VDS=60V VGS=±20V ID=16.9A RDS(ON)=83mΩ@4.5V TO252AA
IRFR024NTRPBF 数据手册
IRFR024NTRPBF www.VBsemi.com N-Channel 60 V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) 60 RDS(on) () Max. ID (A) 0.073 at VGS = 10 V 18.2 0.085 at VGS = 4.5 V 13.2 Qg (Typ.) 19.8 • TrenchFET® Power MOSFET • 100 % Rg and UIS Tested • Material categorization: For definitions of compliance please see TO-252 APPLICATIONS • DC/DC Converters D • DC/AC Inverters • Motor Drives G Drain Connected to Tab G D S S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) Symbol Limit Drain-Source Voltage Parameter VDS 60 Gate-Source Voltage VGS ± 20 TC = 25 °C Continuous Drain Current TC = 70 °C ID 13.6 IDM 25 Avalanche Current IAS 15 EAS 11.25 Single Avalanche L = 0.1 mH TC = 25 °C Maximum Power Dissipationa TA = 25 °Cc Operating Junction and Storage Temperature Range PD V 16.9 Pulsed Drain Current (t = 300 µs) Energya Unit 41.7b 2.1 A mJ W TJ, Tstg - 55 to 150 °C Symbol Limit Unit RthJA 60 RthJC 3 THERMAL RESISTANCE RATINGS Parameter Junction-to-Ambient (PCB Mount) c Junction-to-Case (Drain) °C/W Notes: a. Duty cycle  1 %. b. See SOA curve for voltage derating. c. When mounted on 1" square PCB (FR-4 material). d. Base on TC = 25 °C. 服务热线:400-655-8788 1 IRFR024NTRPBF www.VBsemi.com SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) Parameter Symbol Test Conditions Min. VDS VGS = 0 V, ID = 250 µA 60 VGS(th) VDS = VGS, ID = 250 µA 1.0 IGSS VDS = 0 V, VGS = ± 20 V Typ. Max. Unit Static Drain-Source Breakdown Voltage Gate Threshold Voltage Gate-Body Leakage VDS = 60 V, V Zero Gate Voltage Drain Current On-State Drain Currenta Drain-Source On-State Resistancea Forward Transconductancea IDSS GS = VDS = 60 V, V GS = 0 V, TJ = 150 °C gfs V nA 1 0 V, TJ = 125 °C VDS 10 V, VGS = 10 V RDS(on) ± 250 GS = 0 V VDS = 60 V, V ID(on) 3.0 50 µA 250 20 A VGS = 10 V, ID = 6.6 A 0.073 VGS = 4.5 V, ID = 6 A 0.083 VDS = 15 V, ID = 6.6 A 25  S Dynamicb Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Chargec Qg Gate-Source Chargec Qgs Gate-Drain Chargec Gate Resistance Turn-On Delay Timec Rise Timec Fall Timec Turn-On Delay Timec Rise Timec Turn-Off Delay Fall Timec Drain-Source Body Diode Ratings and 19.8 VDS = 30 V, VGS = 10 V, ID = 6.6 A 30 3.6 nC 4.1 f = 1 MHz td(on) td(off) pF 40 Rg VDD = 30 V, RL = 9.6  ID  5.2 A, VGEN = 10 V, Rg = 1  0.4 2 4 8 16 11 20 18 27 tf 5 10 td(on) 38 57 58 87 18 27 8 16 tr Timec 85 Qgd tr Turn-Off Delay Timec 860 VDS = 30 V, VGS = 0 V, f = 1 MHz td(off) VDD = 30 V, RL = 9.6  ID  5.2 A, VGEN = 4.5 V, Rg = 1  tf Characteristicsb 16.9 Pulsed Current ISM 25 Forward Voltagea VSD Reverse Recovery Time Peak Reverse Recovery Current Reverse Recovery Charge IF = 5.2 A, VGS = 0 V trr IRM(REC) Qrr ns TC = 25 °C IS Continuous Current  IF = 5.2 A, dI/dt = 100 A/µs A 0.8 1.5 V 34 51 ns 3 5 A 50 75 nC Notes: a. Pulse test; pulse width  300 µs, duty cycle  2 %. b. Guaranteed by design, not subject to production testing. c. Independent of operating temperature. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 服务热线:400-655-8788 2 IRFR024NTRPBF www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 0.10 25 VGS = 10 V thru 7 V 0.09 RDS(on) - On-Resistance (Ω) ID - Drain Current (A) 20 VGS = 4 V 15 10 5 0.08 VGS =4.5V 0.07 VGS = 10 V 0.06 VGS = 3 V 0 0 0.5 1 1.5 0.04 2 0 5 10 VDS - Drain-to-Source Voltage (V) 15 20 25 ID - Drain Current (A) Output Characteristics On-Resistance vs. Drain Current 5 0.15 ID = 6.6 A 3 RDS(on) - On-Resistance (Ω) ID - Drain Current (A) 4 TC = 25 °C 2 1 0.12 TJ = 125 °C 0.09 TJ = 25 °C 0.06 TC = 125 °C TC = - 55 °C 0 0 1 2 3 0.03 2 4 VGS - Gate-to-Source Voltage (V) 6 8 10 On-Resistance vs. Gate-to-Source Voltage Transfer Characteristics 10 40 ID = 6.6 A TC = - 55 °C TC = 25 °C 30 VGS - Gate-to-Source Voltage (V) gfs - Transconductance (S) 4 VGS - Gate-to-Source Voltage (V) TC = 125 °C 20 10 0 0 3 6 ID - Drain Current (A) Transconductance 服务热线:400-655-8788 9 12 VDS = 30 V 8 VDS = 15 V 6 VDS = 40 V 4 2 0 0 6 12 18 24 Qg - Total Gate Charge (nC) Gate Charge 3 IRFR024NTRPBF www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 100 2.7 ID = 250 μA 2.4 10 VGS(th) (V) IS - Source Current (A) TJ = 150 °C 2.1 1.8 TJ = 25 °C 1 1.5 0.1 1.2 0.0 0.2 0.4 0.6 0.8 1.0 1.2 - 50 - 25 0 25 VSD - Source-to-Drain Voltage (V) 50 75 100 125 150 125 150 TJ - Temperature (°C) Source-Drain Diode Forward Voltage Threshold Voltage 127 1250 VDS (V) Drain-to-Source Voltage ID = 250 μA C - Capacitance (pF) 1000 Ciss 750 500 250 122 117 112 107 Coss 0 Crss 102 0 20 40 60 80 VDS - Drain-to-Source Voltage (V) - 50 100 25 0 50 75 100 TJ - Temperature (°C) Capacitance Drain Source Breakdown vs. Junction Temperature 20 2.25 VGS = 10 V, ID = 6.6 A 15 1.8 VGS = 4.5 V, ID = 6 A 1.35 ID - Drain Current (A) RDS(on) - On-Resistance (Normalized) - 25 10 5 0.9 0 0.45 - 50 - 25 0 25 50 75 100 125 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature 服务热线:400-655-8788 150 0 25 50 75 100 125 150 TC - Case Temperature (°C) Current Derating 4 IRFR024NTRPBF www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 100 Limited by RDS(on)* 10 ID - Drain Current (A) TJ = 25 °C IDAV (A) 10 100 μs 1 ms 1 10 ms DC, 10 s 1 s, 100 ms 0.1 TJ = 150 °C TC = 25 °C Single Pulse 1 BVDSS Limited 0.01 0.000001 0.00001 0.0001 0.001 0.01 0.1 Time (s) Single Pulse Avalanche Current Capability vs. Time 1 10 100 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified Safe Operating Area 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.02 0.05 Single Pulse 0.01 10-4 10-3 10-2 10-1 Square Wave Pulse Duration (s) 1 10 30 Normalized Thermal Transient Impedance, Junction-to-Case 服务热线:400-655-8788 5 IRFR024NTRPBF www.VBsemi.com TO-252AA Case Outline E C2 L3 H D b2 D1 e1 E1 L gage plane height (0.5 mm) e L5 L4 b C A1 INCHES MILLIMETERS A b3 DIM. MIN. MAX. MIN. MAX. A 2.18 2.38 0.086 0.094 A1 - 0.127 - 0.005 b 0.64 0.88 0.025 0.035 b2 0.76 1.14 0.030 0.045 b3 4.95 5.46 0.195 0.215 0.024 C 0.46 0.61 0.018 C2 0.46 0.89 0.018 0.035 D 5.97 6.22 0.235 0.245 D1 4.10 - 0.161 - E 6.35 6.73 0.250 0.265 E1 4.32 - 0.170 - H 9.40 10.41 0.370 0.410 e 2.28 BSC e1 0.090 BSC 4.56 BSC 0.180 BSC L 1.40 1.78 0.055 0.070 L3 0.89 1.27 0.035 0.050 L4 - 1.02 - 0.040 L5 1.01 1.52 0.040 0.060 ECN: T16-0236-Rev. P, 16-May-16 DWG: 5347 Notes • Dimension L3 is for reference only. 服务热线:400-655-8788 6 IRFR024NTRPBF www.VBsemi.com RECOMMENDED MINIMUM PADS FOR DPAK (TO-252) 0.224 0.243 0.087 (2.202) 0.090 (2.286) (10.668) 0.420 (6.180) (5.690) 0.180 0.055 (4.572) (1.397) Recommended Minimum Pads Dimensions in Inches/(mm) Return to Index 服务热线:400-655-8788 7 IRFR024NTRPBF www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A. 服务热线:400-655-8788 8
IRFR024NTRPBF 价格&库存
很抱歉,暂时无法提供与“IRFR024NTRPBF”相匹配的价格&库存,您可以联系我们找货
IRFR024NTRPBF
  • 1+1.72115
  • 30+1.66180
  • 100+1.54310
  • 500+1.42440
  • 1000+1.36505
