IRFHM9331TRPBF
www.VBsemi.com
P-Channel 30 V (D-S) MOSFET
VDS
RDS(on),typ
RDS(on),typ
ID
VGS=10V
VGS=4.5V
-30
V
11
18
-45
mΩ
mΩ
A
FEATURES
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• Low Thermal Resistance PowerPAK®
Package with Small Size and Low 1.07 mm
Profile
• 100 % Rg and UIS Tested
• Compliant to RoHS Directive 2002/95/EC
APPLICATIONS
• Load Switch
• Adaptor Switch
• Notebook PC
DFN 3x3 EP
S
Bottom View
Top View
Top View
G
1
8
2
7
3
6
4
5
D
P-Channel MOSFET
Pin 1
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Drain-Source Voltage
Gate-Source Voltage
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
Continuous Drain Current (TJ = 150 °C)
ID
IDM
Pulsed Drain Current
Continuous Source-Drain Diode Current
TC = 25 °C
TA = 25 °C
IS
Avalanche Current
Single-Pulse Avalanche Energy
L = 0.1 mH
IAS
EAS
Maximum Power Dissipation
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
PD
Operating Junction and Storage Temperature Range
c, d
TJ, Tstg
Soldering Recommendations (Peak Temperature)
Notes:
a. Surface mounted on 1" x 1" FR4 board.
b. t = 10 s.
c.Rework conditions: manual soldering with a soldering iron is not recommended for leadless components.
d.Package limited.
e.Based on T C = 25 °C
Limit
- 30
± 20
Unit
V
- 45
- 30
- 14.4a, b
- 11.5a, b
- 60
- 35e
- 3.2a, b
- 25
31.25
52
A
mJ
43
3.8a, b
2.4a, b
- 50 to 150
260
W
°C
服务热线:400-655-8788
1
IRFHM9331TRPBF
www.VBsemi.com
THERMAL RESISTANCE RATINGS
Parameter
Symbol
RthJA
RthJC
t ≤ 10 s
Steady State
Maximum Junction-to-Ambienta, b
Maximum Junction-to-Case (Drain)
Typical
26
1.9
Maximum
33
2.4
Unit
°C/W
Notes:
b. Maximum under Steady State conditions is 81 °C/W.
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
VDS
VGS = 0 V, ID = - 250 µA
- 30
ΔVDS/TJ
VGS(th) Temperature Coefficient
ΔVGS(th)/TJ
Gate-Source Threshold Voltage
Typ.
Max.
V
- 20
ID = - 250 µA
Unit
mV/°C
5
VGS(th)
VDS = VGS, ID = - 250 µA
- 2.8
V
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
nA
Zero Gate Voltage Drain Current
IDSS
VDS = - 30 V, VGS = 0 V
VDS = - 30 V, VGS = 0 V, TJ = 55 °C
- 10
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
RDS(on)
Forward Transconductancea
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
gfs
Rg
Gate Resistance
VDS ≤ - 5 V, VGS = - 10 V
VGS = - 10 V, ID = - 14.4 A
tr
Rise Time
Fall Time
Turn-On Delay Time
VDS = - 15 V, ID = - 14.4 A
18
37
VDS = - 15 V, VGS = 0 V, f = 1 MHz
2000
385
a
Pulse Diode Forward Current
Body Diode Voltage
S
pF
322
15
VDS = - 15 V, VGS = - 10 V, ID = - 14.4 A
14
VDS = - 15 V, VGS = - 4.5 V, ID = - 14.4 A
f = 1 MHz
VDD = - 15 V, RL = 1.5 Ω
ID ≅ - 10 A, VGEN = - 4.5 V, Rg = 1 Ω
0.4
1.8
7
9
3.6
50
75
65
tf
14
21
td(on)
14
21
ID ≅ - 10 A, VGEN = - 10 V, Rg = 1 Ω
tf
Fall Time
Drain-Source Body Diode Characteristics
mΩ
45
td(off)
IS
9
18
36
54
10
- 35e
- 60
TC = 25 °C
ISM
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
µA
A
11
43
tr
Rise Time
Turn-Off DelayTime
- 20
30
td(off)
Turn-Off DelayTime
-1
VGS = - 4.5 V, ID = - 11.5 A
td(on)
Turn-On Delay Time
- 1.5
IF = - 10 A
IF = - 10 A, dI/dt = 100 A/µs, TJ = 25 °C
nC
Ω
ns
A
- 0.8
- 1.2
V
31
47
ns
30
45
nC
15
16
ns
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
IRFHM9331TRPBF
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
60
1.2
VGS = 10 V thru 5 V
0.9
ID - Drain Current (A)
45
4V
30
125 ºC
0.6
25 ºC
15
0.3
- 55 ºC
3
6
9
12
15
2
3
4
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
0.030
3600
0.025
3000
C - Capacitance (pF)
RDS - On-Resistance (mΩ)
VGS = 4.5 V
0.015
VGS = 10 V
0.010
Ciss
2400
1800
1200
0.005
600
0.000
Coss
Crss
30
40
50
6
12
18
24
30
VDS - Drain-Source Voltage (V)
Capacitance
On-Resistance vs. Drain Current and Gate Voltage
10
1.8
RDS(on) - On-Resistance
(normalized)
ID = 14.4 A
8
VDS = 15 V, ID = 14.4 A
6
4
VDS = 24 V, ID = 14.4 A
2
服务热线:400-655-8788
40
50
1.5
VGS = 10 V
1.2
VGS = 4.5 V
0.9
0.6
- 50
- 25
50
75
100
125
150
Qg - Total Gate Charge (nC)
TJ - Junction Temperature (ºC)
Gate Charge
On-Resistance vs. Junction Temperature
3
IRFHM9331TRPBF
www.VBsemi.com
0.04
RDS(on) - Drain-to-Source On-Resistance (Ω)
IS - Source Current (A)
100
TJ = 150 ºC
10
TJ = 25 ºC
1
0.1
0.0
0.03
0.02
TJ = 125 ºC
0.01
TJ = 25 ºC
0.00
0.2
0.4
0.6
0.8
1.0
1.2
VSD - Source-to-Drain Voltage (V)
4
6
8
10 12 14 16
18
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
50
2.4
ID = 250 µA
2.2
40
Power (W)
VGS(th) (V)
2.0
1.8
30
10
1.4
1.2
- 50
- 25
50
75
100
125
150
0.1
TJ - Temperature (ºC)
1.0
10
100
1000
Time (s)
Single Pulse Power, Junction-to-Ambient
Threshold Voltage
100
Limited by RDS(on)*
100 µs
10
1 ms
10ms
1
100 ms
1s
10 s
0.1
TA = 25 ºC
Single Pulse
0.01
0.1
DC
BVDSS Limited
1
10
10
* VGS > minimum VGS at which RDS(on) is Specified
Safe Operating Area, Junction-to-Ambient
服务热线:400-655-8788
4
IRFHM9331TRPBF
www.VBsemi.com
60
50
40
30
50
75
100
125
150
TC - CaseTemperature (°C)
Current Derating*
75
2
60
Power (W)
Power (W)
1.5
45
30
1
0.5
15
50
75
100
125
150
50
75
100
125
TC - Case Temperature (ºC)
TA - Ambient Temperature (ºC)
Power, Junction-to-Case
150
* The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
服务热线:400-655-8788
5
IRFHM9331TRPBF
www.VBsemi.com
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
Notes:
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = RthJA = 50 °C/W
0.02
3. TJM - TA = PDMZthJA(t)
Single Pulse
0.01
10 -4
10 -3
10 -2
4. Surface Mounted
10 -1
1
Square Wave Pulse Duration (s)
10
100
1000
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
6
IRFHM9331TRPBF
www.VBsemi.com
服务热线:400-655-8788
7
IRFHM9331TRPBF
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
