PBSS4260QAZ
PBSS4260QAZ
    NEXPERIA(安世)
    DFN1010D-3
    三极管 NPN Ic=2A Vceo=60V hfe=400 P=1000mW DFN1010D-3
PBSS4260QAZ 数据手册
PBSS4260QA 60 V, 2 A NPN low VCEsat (BISS) transistor 28 August 2013 Product data sheet 1. General description NPN low VCEsat Breakthrough In Small Signal (BISS) transistor in a leadless ultra small DFN1010D-3 (SOT1215) Surface-Mounted Device (SMD) plastic package with visible and solderable side pads. PNP complement: PBSS5260QA. 2. Features and benefits • • • • • • • Very low collector-emitter saturation voltage VCEsat High collector current capability IC and ICM High collector current gain hFE at high IC High energy efficiency due to less heat generation Reduced Printed-Circuit Board (PCB) area requirements Solderable side pads AEC-Q101 qualified 3. Applications • • • • • Loadswitch Battery-driven devices Power management Charging circuits Power switches (e.g. motors, fans) 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 60 V IC collector current - - 2 A ICM peak collector current single pulse; tp ≤ 1 ms - - 3 A RCEsat collector-emitter saturation resistance IC = 1 A; IB = 0.1 A; pulsed; tp ≤ 300 µs; - 130 180 mΩ δ ≤ 0.02 ; Tamb = 25 °C PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 B base 2 E emitter 3 C collector 4 C collector Simplified outline Graphic symbol C 1 B 4 3 E sym123 2 Transparent top view DFN1010D-3 (SOT1215) 6. Ordering information Table 3. Ordering information Type number Package PBSS4260QA Name Description Version DFN1010D-3 plastic thermal enhanced ultra thin small outline package; no leads; 3 terminals SOT1215 7. Marking Table 4. Marking codes Type number Marking code PBSS4260QA 11 11 00 MARKING CODE (EXAMPLE) READING DIRECTION YEAR DATE CODE VENDOR CODE PIN 1 INDICATION MARK MARK-FREE AREA READING EXAMPLE: 11 01 10 Fig. 1. aaa-008041 DFN1010D-3 (SOT1215) binary marking code description PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 2 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 60 V VCEO collector-emitter voltage open base - 60 V VEBO emitter-base voltage open collector - 7 V IC collector current - 2 A ICM peak collector current - 3 A IB base current - 0.3 A IBM peak base current single pulse; tp ≤ 1 ms - 1 A Ptot total power dissipation Tamb ≤ 25 °C [1] - 325 mW [2] - 600 mW [3] - 740 mW [4] - 540 mW [5] - 1000 mW single pulse; tp ≤ 1 ms Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] [2] [3] [4] [5] PBSS4260QA Product data sheet Device mounted on an FR4 PCB single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated mounting pad for collector 1 cm . 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated mounting pad for collector 6 cm . Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, 4-layer copper, tin-plated mounting pad for collector 1 cm . All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 3 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor aaa-007844 1.25 Ptot (W) 1.00 (1) 0.75 (2) (3) 0.50 (4) (5) 0.25 0 -75 -25 (1) FR4 PCB, 4-layer copper, 1 cm 25 75 125 175 Tamb (°C) 2 (2) FR4 PCB, single-sided copper, 6 cm 2 2 (3) FR4 PCB, single-sided copper, 1 cm (4) FR4 PCB, 4-layer copper, standard footprint (5) FR4 PCB, single-sided copper, standard footprint Fig. 2. Power derating curves 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) thermal resistance from junction to ambient [1] [2] [3] [4] [5] PBSS4260QA Product data sheet Conditions in free air Min Typ Max Unit [1] - - 385 K/W [2] - - 209 K/W [3] - - 169 K/W [4] - - 232 K/W [5] - - 125 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated mounting pad for collector 1 cm . 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated mounting pad for collector 6 cm . Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, 4-layer copper, tin-plated mounting pad for collector 1 cm . All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 4 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor aaa-007845 103 duty cycle = 1 Zth(j-a) (K/W) 0.75 102 0.5 0.33 0.2 0.1 0.05 10 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, single-sided copper, standard footprint Fig. 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-007846 103 Zth(j-a) (K/W) duty cycle = 1 102 0.75 0.33 0.5 0.2 0.1 0.05 10 0.02 1 0.01 0 10-1 10-5 10-4 10-3 10-2 FR4 PCB, single-sided copper, 1 cm Fig. 4. 10-1 1 10 102 tp (s) 103 2 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 5 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor aaa-007847 103 Zth(j-a) (K/W) duty cycle = 1 102 0.75 0.33 0.5 0.2 0.1 10 0.05 0.02 0.01 1 10-5 0 10-4 10-3 10-2 FR4 PCB, single-sided copper, 6 cm Fig. 5. 10-1 1 10 102 tp (s) 103 2 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-007848 103 Zth(j-a) (K/W) duty cycle = 1 102 0.75 0.5 0.33 0.2 0.1 0.05 10 0.02 1 10-5 0.01 0 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, 4-layer copper, standard footprint Fig. 6. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 6 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor aaa-007849 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 10 0.1 0.05 0.02 1 10-5 0.01 0 10-4 10-3 FR4 PCB, 4-layer copper, 1 cm Fig. 7. 10-2 10-1 1 102 10 tp (s) 103 2 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 48 V; IE = 0 A; Tamb = 25 °C - - 100 nA VCB = 48 V; IE = 0 A; Tj = 150 °C - - 50 µA ICES collector-emitter cut-off VCE = 48 V; VBE = 0 V; Tamb = 25 °C current - - 100 nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A; Tamb = 25 °C - - 100 nA hFE DC current gain VCE = 2 V; IC = 100 mA; pulsed; 235 400 - 150 240 - 85 125 - 40 65 - - 75 100 mV - 145 190 mV - 130 180 mV tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C VCE = 2 V; IC = 500 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C VCE = 2 V; IC = 1 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C VCE = 2 V; IC = 2 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C VCEsat collector-emitter saturation voltage IC = 500 mA; IB = 50 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IC = 1 A; IB = 50 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IC = 1 A; IB = 100 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 7 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor Symbol Parameter Conditions Min Typ Max Unit IC = 2 A; IB = 100 mA; pulsed; - 275 370 mV - 250 350 mV - 130 180 mΩ - 0.88 1 V - 0.91 1.05 V - 1 1.15 V - 1.05 1.2 V - 0.77 0.9 V tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IC = 2 A; IB = 200 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C RCEsat VBEsat collector-emitter saturation resistance IC = 1 A; IB = 0.1 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C base-emitter saturation IC = 500 mA; IB = 50 mA; pulsed; voltage tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IC = 1 A; IB = 50 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IC = 2 A; IB = 100 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IC = 2 A; IB = 200 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C VBEon base-emitter turn-on voltage VCE = 2 V; IC = 0.5 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C td delay time VCC = 10 V; IC = 0.5 A; IBon = 25 mA; - 15 - ns tr rise time IBoff = -25 mA; Tamb = 25 °C - 85 - ns ton turn-on time - 100 - ns ts storage time - 545 - ns tf fall time - 125 - ns toff turn-off time - 670 - ns fT transition frequency 120 180 - MHz - 4.7 6 pF VCE = 10 V; IC = 50 mA; f = 100 MHz; Tamb = 25 °C Cc collector capacitance VCB = 10 V; IE = 0 A; ie = 0 A; f = 1 MHz; Tamb = 25 °C PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 8 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor aaa-008064 103 3 IB (mA) = 60 (1) IC (A) (2) hFE 48 36 (3) 2 24 102 1 10 102 0 103 104 IC (mA) VCE = 2 V 42 30 18 6 0 1 2 3 4 VCE (V) 5 Tamb = 25 °C (1) Tamb = 100 °C Fig. 9. (2) Tamb = 25 °C Collector current as a function of collectoremitter voltage; typical values (3) Tamb = −55 °C Fig. 8. 54 12 1 10 10-1 aaa-008065 DC current gain as a function of collector current; typical values aaa-008066 1.2 aaa-008067 1.2 VBE (V) VBEsat (V) (1) (1) 0.8 0.8 (2) (2) (3) (3) 0.4 0 10-1 0.4 1 10 102 0 10-1 103 104 IC (mA) 1 10 VCE = 2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb= 100 °C Fig. 10. Base-emitter voltage as a function of collector current; typical values PBSS4260QA Product data sheet 102 103 104 IC (mA) Fig. 11. Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 9 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor aaa-008068 1 aaa-008069 1 VCEsat (V) VCEsat (V) 10-1 (1) 10-1 10-2 10-1 (2) 1 10 10-2 (1) (2) (3) 102 103 104 IC (mA) 10-3 10-1 (3) 1 IC/IB = 20 Tamb = 25 °C (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig. 12. Collector-emitter saturation voltage as a function of collector current; typical values aaa-008070 103 102 10 103 104 IC (mA) Fig. 13. Collector-emitter saturation voltage as a function of collector current; typical values aaa-008071 103 RCEsat (Ω) RCEsat (Ω) 102 102 10 10 (1) 1 10-1 10-1 (1) (2) (3) 1 10 102 (2) 1 (3) 10-1 10-1 103 104 IC (mA) IC/IB = 20 1 (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig. 14. Collector-emitter saturation resistance as a function of collector current; typical values Product data sheet 102 103 104 IC (mA) Tamb = 25 °C (1) Tamb = 100 °C PBSS4260QA 10 Fig. 15. Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 10 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor 11. Test information IB input pulse (idealized waveform) 90 % IBon (100 %) 10 % IBoff output pulse (idealized waveform) IC 90 % IC (100 %) 10 % t td ts tr ton tf toff 006aaa003 Fig. 16. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω R2 VI oscilloscope DUT R1 mlb826 Fig. 17. Test circuit for switching times 11.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 11 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor 12. Package outline 0.87 0.95 0.75 1 0.95 1.05 0.22 0.30 2 0.16 0.24 0.1 3 0.04 max 0.34 0.40 Dimensions in mm 0.17 0.25 0.245 0.325 1.05 1.15 0.195 0.275 13-03-05 Fig. 18. Package outline DFN1010D-3 (SOT1215) PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 12 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor 13. Soldering Footprint information for reflow soldering of DFN1010D-3 package SOT1215 1.2 0.45 (2x) 0.3 1.1 0.35 (2x) 0.4 0.25 (2x) 0.75 0.3 0.5 1.5 1.4 0.4 0.5 0.4 0.3 0.5 1.3 0.4 0.3 0.4 0.5 1.3 solder land solder land plus solder paste occupied area solder resist Dimensions in mm Issue date 12-11-23 13-03-06 sot1215_fr Fig. 19. Reflow soldering footprint for DFN1010D-3 (SOT1215) PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 13 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PBSS4260QA v.1 20130828 Product data sheet - - PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 14 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 15. Legal information 15.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PBSS4260QA Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 15 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 16 / 17 PBSS4260QA Nexperia 60 V, 2 A NPN low VCEsat (BISS) transistor 16. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................3 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 7 11 11.1 Test information ................................................... 11 Quality information ............................................. 11 12 Package outline ................................................... 12 13 Soldering .............................................................. 13 14 Revision history ................................................... 14 15 15.1 15.2 15.3 15.4 Legal information .................................................15 Data sheet status ............................................... 15 Definitions ...........................................................15 Disclaimers .........................................................15 Trademarks ........................................................ 16 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 28 August 2013 PBSS4260QA Product data sheet All information provided in this document is subject to legal disclaimers. 28 August 2013 © Nexperia B.V. 2017. All rights reserved 17 / 17
PBSS4260QAZ 价格&库存
很抱歉,暂时无法提供与“PBSS4260QAZ”相匹配的价格&库存,您可以联系我们找货
PBSS4260QAZ
