PBSS4580PA,115
PBSS4580PA,115
    NEXPERIA(安世)
    SOT-1061
    通用三极管 NPN Ic=5.6A Vceo=80V hfe=45 P=2.1W SOT1061
PBSS4580PA,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PBSS4580PA 80 V, 5.6 A NPN low VCEsat (BISS) transistor Rev. 01 — 15 April 2010 Product data sheet 1. Product profile 1.1 General description NPN low VCEsat Breakthrough In Small Signal (BISS) transistor, encapsulated in an ultra thin SOT1061 leadless small Surface-Mounted Device (SMD) plastic package with medium power capability. PNP complement: PBSS5580PA. 1.2 Features and benefits „ „ „ „ „ Low collector-emitter saturation voltage VCEsat High collector current capability IC and ICM Smaller required Printed-Circuit Board (PCB) area than for conventional transistors Exposed heat sink for excellent thermal and electrical conductivity Leadless small SMD plastic package with medium power capability 1.3 Applications „ „ „ „ „ Loadswitch Battery-driven devices Power management Charging circuits Power switches (e.g. motors, fans) 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 80 V IC collector current - - 5.6 A ICM peak collector current single pulse; tp ≤ 1 ms - - 7 A RCEsat collector-emitter saturation resistance IC = 5.6 A; IB = 280 mA - 40 57 mΩ [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [1] PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 2. Pinning information Table 2. Pinning Pin Description 1 base 2 emitter 3 collector Simplified outline Graphic symbol 3 3 1 2 1 sym021 2 Transparent top view 3. Ordering information Table 3. Ordering information Type number Package Name PBSS4580PA Description Version HUSON3 plastic thermal enhanced ultra thin small outline package; SOT1061 no leads; three terminals; body 2 × 2 × 0.65 mm 4. Marking Table 4. Marking codes Type number Marking code PBSS4580PA AD 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). PBSS4580PA_1 Product data sheet Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 80 V VCEO collector-emitter voltage open base - 80 V VEBO emitter-base voltage open collector - 6 V IC collector current - 5.6 A ICM peak collector current - 7 A IB base current Ptot total power dissipation single pulse; tp ≤ 1 ms Tamb ≤ 25 °C All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 - 600 mA [1] - 500 mW [2] - 1 W [3] - 1.4 W [4] - 2.1 W © NXP B.V. 2010. All rights reserved. 2 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Tj Conditions Min Max Unit junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [4] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aab978 2.5 Ptot (W) (1) 2.0 1.5 (2) (3) 1.0 (4) 0.5 0.0 −75 −25 25 75 125 175 Tamb (°C) (1) Ceramic PCB, Al2O3, standard footprint (2) FR4 PCB, mounting pad for collector 6 cm2 (3) FR4 PCB, mounting pad for collector 1 cm2 (4) FR4 PCB, standard footprint Fig 1. Power derating curves 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) PBSS4580PA_1 Product data sheet Conditions thermal resistance from junction to ambient in free air Min Typ Max Unit [1] - - 250 K/W [2] - - 125 K/W [3] - - 90 K/W [4] - - 60 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [4] Device mounted on a ceramic PCB, Al2O3, standard footprint. All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 3 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 006aab979 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.5 0.33 0.2 0.1 0.05 10 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aab980 103 Zth(j-a) (K/W) duty cycle = 1 102 0.75 0.5 0.33 0.2 0.1 10 0.05 0.02 1 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 1 cm2 Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4580PA_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 4 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 006aab981 103 Zth(j-a) (K/W) duty cycle = 1 102 0.75 0.5 0.33 0.2 10 0.1 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 6 cm2 Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aab982 102 duty cycle = 1 Zth(j-a) (K/W) 0.75 0.5 0.33 0.2 10 0.1 0.05 0.02 1 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) Ceramic PCB, Al2O3, standard footprint Fig 5. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4580PA_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 5 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 64 V; IE = 0 A - - 100 nA VCB = 64 V; IE = 0 A; Tj = 150 °C - - 50 μA ICES collector-emitter cut-off current VCE = 64 V; VBE = 0 V - - 100 nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 2 V IC = 0.5 A 270 425 - IC = 1 A 240 375 - IC = 2 A 150 245 - [1] IC = 6 A VCEsat Product data sheet 75 - IC = 0.5 A; IB = 50 mA - 25 35 mV IC = 1 A; IB = 50 mA [1] - 50 70 mV IC = 1 A; IB = 10 mA [1] - 85 120 mV IC = 2 A; IB = 20 mA [1] - 150 220 mV IC = 3 A; IB = 30 mA [1] - 265 360 mV IC = 4 A; IB = 400 mA [1] - 155 210 mV IC = 5.6 A; IB = 280 mA [1] - 230 320 mV - 40 57 mΩ RCEsat collector-emitter saturation resistance IC = 5.6 A; IB = 280 mA [1] VBEsat base-emitter saturation voltage IC = 1 A; IB = 10 mA [1] - 0.74 0.9 V IC = 5.6 A; IB = 280 mA [1] - 1 1.1 V [1] - 0.76 0.9 V VBEon base-emitter turn-on voltage VCE = 2 V; IC = 2 A td delay time tr rise time ton turn-on time VCC = 9 V; IC = 2 A; IBon = 0.1 A; IBoff = −0.1 A ts storage time tf fall time - 205 - ns toff turn-off time - 925 - ns fT transition frequency VCE = 10 V; IC = 100 mA; f = 100 MHz 95 155 - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 20 25 pF [1] PBSS4580PA_1 collector-emitter saturation voltage 45 [1] - 21 - ns - 162 - ns - 183 - ns - 720 - ns Pulse test: tp ≤ 300 μs; δ ≤ 0.02. All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 6 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 006aab983 800 006aab984 8.0 IC (A) hFE IB (mA) = 70 63 (1) 6.0 600 56 49 42 35 (2) 28 400 21 4.0 14 (3) 7 2.0 200 0 10−1 1 102 10 0.0 0.0 103 104 IC (mA) 1.0 2.0 3.0 4.0 5.0 VCE (V) Tamb = 25 °C VCE = 2 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 6. DC current gain as a function of collector current; typical values Fig 7. 006aab985 1.2 VBE (V) Collector current as a function of collector-emitter voltage; typical values 006aab986 1.2 VBEsat (V) (1) (1) 0.8 0.8 (2) (2) (3) (3) 0.4 0.4 0.0 10−1 1 10 102 0.0 10−1 103 104 IC (mA) 1 VCE = 2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Fig 8. Base-emitter voltage as a function of collector current; typical values PBSS4580PA_1 Product data sheet Fig 9. 10 102 103 104 IC (mA) Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 7 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 006aab987 1 006aab988 10 VCEsat (V) VCEsat (V) 1 10−1 (1) (2) 10−1 (3) (1) 10−2 (2) 10−2 10−3 10−1 1 10 102 103 104 IC (mA) (3) 10−3 10−1 1 10 102 103 104 IC (mA) Tamb = 25 °C IC/IB = 20 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 10. Collector-emitter saturation voltage as a function of collector current; typical values 006aab989 103 Fig 11. Collector-emitter saturation voltage as a function of collector current; typical values 006aab990 103 RCEsat (Ω) RCEsat (Ω) 102 102 10 10 1 1 (1) (1) (2) (3) 10−1 (2) 10−1 (3) 10−2 10−1 1 10 102 103 104 IC (mA) 10−2 10−1 1 (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 12. Collector-emitter saturation resistance as a function of collector current; typical values Product data sheet 102 103 104 IC (mA) Tamb = 25 °C IC/IB = 20 (1) Tamb = 100 °C PBSS4580PA_1 10 Fig 13. Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 8 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 8. Test information IB input pulse (idealized waveform) 90 % IBon (100 %) 10 % IBoff output pulse (idealized waveform) IC 90 % IC (100 %) 10 % t td ts tr ton tf toff 006aaa003 Fig 14. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mlb826 VCC = 9 V; IC = 2 A; IBon = 0.1 A; IBoff = −0.1 A Fig 15. Test circuit for switching times PBSS4580PA_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 9 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 9. Package outline 1.3 0.65 max 0.35 0.25 1 1.05 0.95 2 0.45 0.35 1.1 0.9 0.3 0.2 2.1 1.9 3 1.6 1.4 Dimensions in mm 2.1 1.9 09-11-12 Fig 16. Package outline SOT1061 (HUSON3) 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 3000 PBSS4580PA [1] PBSS4580PA_1 Product data sheet SOT1061 4 mm pitch, 8 mm tape and reel -115 For further information and the availability of packing methods, see Section 14. All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 10 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 11. Soldering 2.1 1.3 0.5 (2×) 0.4 (2×) 0.5 (2×) 0.6 (2×) 1.05 2.3 0.6 0.55 0.25 1.1 0.25 1.2 0.25 0.4 0.5 1.6 1.7 Dimensions in mm solder paste = solder lands solder resist occupied area sot1061_fr Reflow soldering is the only recommended soldering method. Fig 17. Reflow soldering footprint SOT1061 (HUSON3) PBSS4580PA_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 11 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PBSS4580PA_1 20100415 Product data sheet - - PBSS4580PA_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 12 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or PBSS4580PA_1 Product data sheet malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the NXP Semiconductors product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. NXP Semiconductors does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 13 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PBSS4580PA_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 15 April 2010 © NXP B.V. 2010. All rights reserved. 14 of 15 PBSS4580PA NXP Semiconductors 80 V, 5.6 A NPN low VCEsat (BISS) transistor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Packing information . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2010. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 15 April 2010 Document identifier: PBSS4580PA_1
PBSS4580PA,115 价格&库存
很抱歉,暂时无法提供与“PBSS4580PA,115”相匹配的价格&库存,您可以联系我们找货
PBSS4580PA,115
  • 1+1.60600
  • 100+1.27600
  • 750+1.14400
  • 1500+1.08130
  • 3000+1.02520
PBSS4580PA,115
  • 3000+2.168613000+0.27195
  • 6000+1.984666000+0.24888
  • 9000+1.890929000+0.23713
  • 15000+1.7855815000+0.22392
  • 21000+1.7232121000+0.21610
  • 30000+1.6625930000+0.20850
库存:3678
PBSS4580PA,115
  • 1+9.289431+1.16492
  • 10+5.7728010+0.72392
  • 100+3.71037100+0.46529
  • 500+2.82083500+0.35374
  • 1000+2.533701000+0.31773
库存:3678
