PZT4403,115
PZT4403,115
    NEXPERIA(安世)
    SOT-223
    TRANS PNP 40V 0.6A SOT-223
PZT4403,115 数据手册
PZT4403 40 V, 600 mA PNP switching transistor Rev. 03 — 2 March 2010 Product data sheet 1. Product profile 1.1 General description PNP switching transistor in a medium power SOT223 (SC-73) small Surface-Mounted Device (SMD) plastic package. NPN complement: PZT4401. 1.2 Features and benefits „ High current (max. 600 mA) „ Low voltage (max. 40 V) 1.3 Applications „ Switching and linear amplification 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Max Unit VCEO collector-emitter voltage open base - - −40 V IC collector current - - −600 mA 100 - 300 DC current gain hFE [1] VCE = −1 V; IC = −150 mA [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. 2. Pinning information Table 2. Pinning Pin Description 1 base 2, 4 collector 3 emitter Simplified outline Graphic symbol 4 2, 4 1 1 2 3 3 sym028 PZT4403 Nexperia 40 V, 600 mA PNP switching transistor 3. Ordering information Table 3. Ordering information Type number PZT4403 Package Name Description Version SC-73 plastic surface-mounted package with increased heatsink; 4 leads SOT223 4. Marking Table 4. Marking codes Type number Marking code PZT4403 ZT4403 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - −40 V VCEO collector-emitter voltage open base - −40 V VEBO emitter-base voltage open collector - −6 V IC collector current - −600 mA ICM peak collector current - −800 mA IBM peak base current - −200 mA - 1150 mW Ptot total power dissipation Tamb ≤ 25 °C [1] Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for collector 1 cm2. 6. Thermal characteristics Table 6. Symbol Product data sheet Parameter Conditions Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point [1] PZT4403_3 Thermal characteristics in free air [1] Min Typ Max Unit - - 106 K/W - - 25 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. All information provided in this document is subject to legal disclaimers. Rev. 03 — 2 March 2010 © Nexperia B.V. 2017. All rights reserved 2 of 9 PZT4403 Nexperia 40 V, 600 mA PNP switching transistor 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = −40 V; IE = 0 A - - −50 nA IEBO emitter-base cut-off current VEB = −5 V; IC = 0 A - - −50 nA hFE DC current gain VCE = −1 V; IC = −0.1 mA 30 - - VCE = −1 V; IC = −1 mA 60 - - VCE = −1 V; IC = −10 mA 100 - - VCEsat VBEsat Product data sheet base-emitter saturation voltage [1] 100 - 300 VCE = −2 V; IC = −500 mA [1] 20 - - IC = −150 mA; IB = −15 mA [1] - - −400 mV IC = −500 mA; IB = −50 mA [1] - - −750 mV IC = −150 mA; IB = −15 mA [1] - - −950 mV IC = −500 mA; IB = −50 mA [1] - - −1300 mV - - 15 ns - - 30 ns - - 40 ns VCC = −29.5 V; IC = −150 mA; IBon = −15 mA; IBoff = 15 mA; VBB = 3.5 V td delay time tr rise time ton turn-on time ts storage time - - 300 ns tf fall time - - 50 ns toff turn-off time - - 350 ns fT transition frequency VCE = −10 V; IC = −20 mA; f = 100 MHz 200 - - MHz Cc collector capacitance VCB = −5 V; IE = ie = 0 A; f = 1 MHz - - 8.5 pF Ce emitter capacitance VEB = −500 mV; IC = ic = 0 A; f = 1 MHz - - 35 pF [1] PZT4403_3 collector-emitter saturation voltage VCE = −1 V; IC = −150 mA Pulse test: tp ≤ 300 μs; δ ≤ 0.02. All information provided in this document is subject to legal disclaimers. Rev. 03 — 2 March 2010 © Nexperia B.V. 2017. All rights reserved 3 of 9 PZT4403 Nexperia 40 V, 600 mA PNP switching transistor mgs333 300 hFE 200 100 0 −10−1 −1 −10 −102 IC (mA) −103 VCE = −1 V Fig 1. DC current gain as a function of collector current; typical values 8. Test information VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mgd624 Vi = −9.5 V; T = 500 μs; tp = 10 μs R1 = 68 Ω; R2 = 325 Ω; RB = 325 Ω; RC = 160 Ω VBB = 3.5 V; VCC = −29.5 V Oscilloscope input impedance Zi = 50 Ω Fig 2. PZT4403_3 Product data sheet Test circuit for switching times All information provided in this document is subject to legal disclaimers. Rev. 03 — 2 March 2010 © Nexperia B.V. 2017. All rights reserved 4 of 9 PZT4403 Nexperia 40 V, 600 mA PNP switching transistor 9. Package outline 6.7 6.3 3.1 2.9 1.8 1.5 4 1.1 0.7 7.3 6.7 3.7 3.3 1 2 3 2.3 4.6 0.8 0.6 Dimensions in mm Fig 3. 0.32 0.22 04-11-10 Package outline SOT223 (SC-73) 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PZT4403 [1] PZT4403_3 Product data sheet Package Description SOT223 8 mm pitch, 12 mm tape and reel Packing quantity 1000 4000 -115 -135 For further information and the availability of packing methods, see Section 13. All information provided in this document is subject to legal disclaimers. Rev. 03 — 2 March 2010 © Nexperia B.V. 2017. All rights reserved 5 of 9 PZT4403 Nexperia 40 V, 600 mA PNP switching transistor 11. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PZT4403_3 20100302 Product data sheet - PZT4403_N_2 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • • • • • Legal texts have been adapted to the new company name where appropriate. Section 1.1 “General description”: amended Section 1.4 “Quick reference data”: added Section 3 “Ordering information”: added Section 4 “Marking”: added Section 7 “Characteristics”: amended Section 8 “Test information”: added Figure 3: superseded by minimized package outline drawing Section 10 “Packing information”: added Section 12 “Legal information”: updated PZT4403_N_2 20080117 Product data sheet - PZT4403_1 PZT4403_1 19990510 Product specification - - PZT4403_3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 2 March 2010 © Nexperia B.V. 2017. All rights reserved 6 of 9 PZT4403 Nexperia 40 V, 600 mA PNP switching transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or PZT4403_3 Product data sheet malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 03 — 2 March 2010 © Nexperia B.V. 2017. All rights reserved 7 of 9 PZT4403 Nexperia 40 V, 600 mA PNP switching transistor 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PZT4403_3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 03 — 2 March 2010 © Nexperia B.V. 2017. All rights reserved 8 of 9 PZT4403 Nexperia 40 V, 600 mA PNP switching transistor 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description . . . . . . . . . . . . . . . . . . . . . Features and benefits . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Test information . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information. . . . . . . . . . . . . . . . . . . . . . Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 02 March 2010 1 1 1 1 1 1 2 2 2 2 3 4 5 5 6 7 7 7 7 7 8 9
PZT4403,115 价格&库存
很抱歉,暂时无法提供与“PZT4403,115”相匹配的价格&库存,您可以联系我们找货
PZT4403,115
  • 1+4.336081+0.56094
  • 10+2.6830210+0.34709
  • 100+1.69996100+0.21992
  • 500+1.27267500+0.16464
