PHPT610030NPKX
PHPT610030NPKX
    NEXPERIA(安世)
    SOT-1205
    NPN/PNP高功率双极晶体管
PHPT610030NPKX 数据手册
PHPT610030NPK NPN/PNP high power double bipolar transistor 14 October 2014 Product data sheet 1. General description NPN/PNP high power double bipolar transistor in a SOT1205 (LFPAK56D) SurfaceMounted Device (SMD) power plastic package. NPN/NPN complement: PHPT610030NK. PNP/PNP complement: PHPT610030PK. 2. Features and benefits • • • • • High thermal power dissipation capability Suitable for high temperature applications up to 175 °C Reduced Printed-Circuit Board (PCB) requirements comparing to transistors in DPAK High energy efficiency due to less heat generation AEC-Q101 qualified 3. Applications • • • • • • Motor control Power management Load switch Linear mode voltage regulator Backlighting applications Relay replacement 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit - - 100 V - - 3 A - 75 110 mΩ Per transistor; for the PNP transistor with negative polarity VCEO collector-emitter voltage IC collector current open base TR1 (NPN) RCEsat collector-emitter saturation resistance IC = 3 A; IB = 300 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor Symbol Parameter Conditions Min Typ Max Unit collector-emitter saturation resistance IC = -2 A; IB = -200 mA; pulsed; - 110 180 mΩ TR2 (PNP) RCEsat tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 E1 emitter TR1 2 B1 base TR1 3 E2 emitter TR2 4 B2 base TR2 5 C2 collector TR2 6 C2 collector TR2 7 C1 collector TR1 8 C1 collector TR1 Simplified outline 8 7 6 Graphic symbol 5 C1 B2 E2 TR2 TR1 E1 B1 C2 sym139 1 2 3 4 LFPAK56D (SOT1205) 6. Ordering information Table 3. Ordering information Type number PHPT610030NPK Package Name Description Version LFPAK56D Plastic single ended surface mounted package (LFPAK56D); 8 leads SOT1205 7. Marking Table 4. Marking codes Type number Marking code PHPT610030NPK 1003NPK PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 2 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per transistor; for the PNP transistor with negative polarity VCBO collector-base voltage open emitter - 100 V VCEO collector-emitter voltage open base - 100 V VEBO emitter-base voltage open collector - 7 V IC collector current - 3 A ICM peak collector current - 8 A IB base current - 0.5 A Ptot total power dissipation single pulse; tp ≤ 1 ms Tamb ≤ 25 °C [1] - 1 W Tamb ≤ 25 °C [2] - 2.4 W [3] - 25 W [1] - 1.25 W [2] - 3 W [4] - 5 W Per device Ptot total power dissipation Tamb ≤ 25 °C Tj junction temperature - 175 °C Tamb ambient temperature -55 175 °C Tstg storage temperature -65 175 °C [1] [2] [3] [4] PHPT610030NPK Product data sheet Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm . Power dissipation from junction to mounting base. Device mounted on a ceramic PCB, Al2O3, standard footprint. All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 3 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor aaa-014341 4 Ptot (W) 3 (1) 2 1 (2) 0 -75 0 75 (1) FR4 PCB, mounting pad for collector 6 cm (2) FR4 PCB, standard footprint Fig. 1. 150 225 Tamb (°C) 2 Per transistor: power derating curves 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient in free air Min Typ Max Unit [1] - - 150 K/W [2] - - 62.5 K/W - - 6 K/W [1] - - 120 K/W [2] - - 50 K/W [3] - - 30 K/W Per transistor Rth(j-a) Rth(j-sp) thermal resistance from junction to solder point Per device Rth(j-a) thermal resistance from junction to ambient [1] [2] [3] PHPT610030NPK Product data sheet in free air Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm . Device mounted on a ceramic PCB, Al2O3, standard footprint. All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 4 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor aaa-014342 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.25 0.2 10 0.1 0.05 0.02 0.01 0 1 10-1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 2. Per transistor: transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-014343 102 Zth(j-a) (K/W) duty cycle = 1 0.75 0.33 10 0.2 0.5 0.25 0.1 0.05 1 0.01 10-1 10-5 0.02 0 10-4 10-3 10-2 FR4 PCB, mounting pad for collector 6 cm Fig. 3. 10-1 1 10 102 tp (s) 103 2 Per transistor: transient thermal impedance from junction to ambient as a function of pulse duration; typical values PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 5 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit collector-base cut-off current VCB = 80 V; IE = 0 A; Tamb = 25 °C - - 100 nA VCB = 80 V; IE = 0 A; Tj = 150 °C - - 50 µA TR1 (NPN) ICBO ICES collector-emitter cut-off VCE = 80 V; VBE = 0 V current - - 100 nA IEBO emitter-base cut-off current VEB = 7 V; IC = 0 A; Tamb = 25 °C - - 100 nA hFE DC current gain VCE = 10 V; IC = 500 mA; pulsed; 150 250 - 80 250 - 20 100 - 10 40 - - 90 150 mV - 225 330 mV - 75 110 mΩ - 0.86 1 V - 1 1.2 V - 0.67 0.85 V tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VCE = 10 V; IC = 1 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VCE = 10 V; IC = 2 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VCE = 10 V; IC = 3 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VCEsat collector-emitter saturation voltage IC = 1 A; IB = 50 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C IC = 3 A; IB = 0.3 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C RCEsat VBEsat collector-emitter saturation resistance IC = 3 A; IB = 300 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C base-emitter saturation IC = 1 A; IB = 50 mA; pulsed; voltage tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C IC = 2 A; IB = 200 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VBEon td base-emitter turn-on voltage VCE = 2 V; IC = 100 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C delay time VCC = 12.5 V; IC = 1 A; IBon = 50 mA; - 20 - ns tr rise time IBoff = -50 mA; Tamb = 25 °C - 300 - ns ton turn-on time - 320 - ns ts storage time - 830 - ns tf fall time - 470 - ns toff turn-off time - 1300 - ns fT transition frequency - 140 - MHz VCE = 10 V; IC = 100 mA; f = 100 MHz; Tamb = 25 °C PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 6 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor Symbol Parameter Conditions Min Typ Max Unit Cc collector capacitance VCB = 10 V; IE = 0 A; ie = 0 A; - 11 - pF VCB = -80 V; IE = 0 A - - -100 nA VCB = -80 V; IE = 0 A; Tj = 150 °C - - -50 µA f = 1 MHz; Tamb = 25 °C TR2 (PNP) ICBO collector-base cut-off current ICES collector-emitter cut-off VCE = -80 V; VBE = 0 V current - - -100 nA IEBO emitter-base cut-off current VEB = -7 V; IC = 0 A - - -100 nA hFE DC current gain VCE = -10 V; IC = -500 mA; 150 200 - 80 210 - 20 100 - 10 40 - - -70 -110 mV - -220 -360 mV - 110 180 mΩ - -0.91 -1 V - -1.02 -1.2 V - -0.68 -0.9 V Tamb = 25 °C VCE = -10 V; IC = -1 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VCE = -10 V; IC = -2 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VCE = -10 V; IC = -3 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VCEsat collector-emitter saturation voltage IC = -500 mA; IB = -50 mA; Tamb = 25 °C IC = -2 A; IB = -0.2 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C RCEsat VBEsat collector-emitter saturation resistance IC = -2 A; IB = -200 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C base-emitter saturation IC = -1 A; IB = -50 mA; pulsed; voltage tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C IC = -2 A; IB = -200 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C VBEon base-emitter turn-on voltage VCE = -2 V; IC = -100 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C td delay time VCC = -12.5 V; IC = -1 A; IBon = -50 mA; - 20 - ns tr rise time IBoff = 50 mA; Tamb = 25 °C - 180 - ns ton turn-on time - 200 - ns ts storage time - 350 - ns tf fall time - 220 - ns toff turn-off time - 570 - ns fT transition frequency - 125 - MHz VCE = -10 V; IC = -100 mA; f = 100 MHz; Tamb = 25 °C PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 7 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor Symbol Parameter Conditions Min Typ Max Unit Cc collector capacitance VCB = -10 V; IE = 0 A; ie = 0 A; - 30 - pF f = 1 MHz; Tamb = 25 °C aaa-010261 400 hFE aaa-010267 3 (1) IB = 50 mA 45 IC (A) 300 40 35 30 2 (2) 200 25 20 15 10 (3) 1 5 100 0 10-1 1 102 10 0 103 104 IC (mA) VCE = 10 V 1 2 3 4 VCE (V) 5 Tamb = 25 °C (1) Tamb = 100 °C Fig. 5. (2) Tamb = 25 °C TR1 (NPN): Collector current as a function of collector-emitter voltage; typical values (3) Tamb = −55 °C Fig. 4. 0 TR1 (NPN): DC current gain as a function of collector current; typical values aaa-010262 1.2 aaa-010265 1.4 VBE (V) VBEsat (V) (1) 0.8 1.0 (2) (1) (3) 0.4 0.6 (2) (3) 0 10-1 Fig. 6. 1 10 102 103 0.2 10-1 104 105 IC (mA) 1 10 VCE = 2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C TR1 (NPN): Base-emitter voltage as a function of collector current; typical values PHPT610030NPK Product data sheet Fig. 7. 103 104 105 IC (mA) TR1 (NPN): Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 14 October 2014 102 © Nexperia B.V. 2017. All rights reserved 8 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor aaa-010263 1 aaa-010264 10 VCEsat (V) VCEsat (V) 1 10-1 (2) (1) (1) (2) (3) 10-1 (3) 10-2 10-2 10-3 10-1 Fig. 8. 1 10 102 10-3 10-1 103 104 IC (mA) 1 10 IC/IB = 20 Tamb = 25 °C (1) Tamb = 100 °C (1) IC/IB = 50 102 103 104 IC (mA) (2) Tamb = 25 °C (2) IC/IB = 20 (3) Tamb = −55 °C (3) IC/IB = 10 TR1 (NPN): Collector-emitter saturation voltage Fig. 9. as a function of collector current; typical values TR1 (NPN): Collector-emitter saturation voltage as a function of collector current; typical values aaa-010266 103 RCEsat (Ω) RCEsat (Ω) 102 102 10 10 (1) 1 aaa-010268 103 1 (2) (3) 10-1 10-2 10-1 (1) 1 10 102 (2) 10-1 10-2 10-1 103 104 IC (mA) IC/IB = 20 (3) 1 (1) IC/IB = 50 (2) Tamb = 25 °C (2) IC/IB = 20 (3) Tamb = −55 °C (3) IC/IB = 10 Fig. 10. TR1 (NPN): Collector-emitter saturation resistance as a function of collector current; typical values Product data sheet 102 103 104 IC (mA) Tamb = 25 °C (1) Tamb = 100 °C PHPT610030NPK 10 Fig. 11. TR1 (NPN): Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 9 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor aaa-010858 500 hFE aaa-010859 -2.5 IC (A) (1) 400 IB = -50 mA -45 -40 -35 -2.0 -30 -25 -20 (2) 300 -1.5 -15 -10 200 -1.0 (3) 100 0 -10-1 -5 -0.5 -1 -10 -102 0 -103 -104 IC (mA) VCE = −10 V 0 -1 -2 -3 -4 VCE (V) -5 Tamb = 25 °C (1) Tamb = 100 °C Fig. 13. TR2 (PNP): Collector current as a function of collector-emitter voltage; typical values (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 12. TR2 (PNP): DC current gain as a function of collector current; typical values aaa-010860 -1.6 aaa-010861 -1.2 VBEsat (V) VBE (V) -1.0 -1.2 (1) -0.8 (1) -0.8 (2) (2) -0.6 (3) (3) -0.4 0 -10-1 -0.4 -1 -10 -102 -0.2 -10-1 -103 -104 IC (mA) -1 -10 VCE = −2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Fig. 14. TR2 (PNP): Base-emitter voltage as a function of collector current; typical values PHPT610030NPK Product data sheet -102 -103 -104 IC (mA) Fig. 15. TR2 (PNP): Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 10 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor aaa-010862 -10 aaa-010863 -10 VCEsat (V) VCEsat (V) -1 -1 (1) (2) -10-1 -10-1 (1) (3) (2) -10-2 -10-3 -10-1 -10-2 -1 -10 -102 -10-3 -10-1 -103 -104 IC (mA) (3) -1 -10 IC/IB = 20 Tamb = 25 °C (1) Tamb = 100 °C (1) IC/IB = 50 (2) Tamb = 25 °C (2) IC/IB = 20 (3) Tamb = −55 °C (3) IC/IB = 10 -102 -103 -104 IC (mA) Fig. 16. TR2 (PNP): Collector-emitter saturation voltage Fig. 17. TR2 (PNP): Collector-emitter saturation voltage as a function of collector current; typical values as a function of collector current; typical values aaa-010864 103 aaa-010865 103 RCEsat RCEsat (Ω) 102 102 10 10 (1) (2) 1 (2) 10-1 10-2 -10-1 (1) 1 (3) (3) 10-1 -1 -10 -102 10-2 -10-1 -103 -104 IC (mA) IC/IB = 20 -1 (1) IC/IB = 50 (2) Tamb = 25 °C (2) IC/IB = 20 (3) Tamb = −55 °C (3) IC/IB = 10 Fig. 18. TR2 (PNP): Collector-emitter saturation resistance as a function of collector current; typical values Product data sheet -102 -103 -104 IC (mA) Tamb = 25 °C (1) Tamb = 100 °C PHPT610030NPK -10 Fig. 19. TR2 (PNP): Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 11 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor 11. Test information IB input pulse (idealized waveform) 90 % IBon (100 %) 10 % IBoff output pulse (idealized waveform) IC 90 % IC (100 %) 10 % t td ts tr ton tf toff 006aaa003 Fig. 20. TR1 (NPN): BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω R2 VI oscilloscope DUT R1 mlb826 Fig. 21. TR1 (NPN): Test circuit for switching times PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 12 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor - IB input pulse (idealized waveform) 90 % - I Bon (100 %) 10 % - I Boff output pulse (idealized waveform) - IC 90 % - I C (100 %) 10 % t td ts tr t on tf t off 006aaa266 Fig. 22. TR2 (PNP): BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω R2 VI oscilloscope DUT R1 mgd624 Fig. 23. TR2 (PNP): Test circuit for switching times 11.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 13 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor 12. Package outline Plastic single ended surface mounted package LFPAK56D; 8 leads E SOT1205 A A b1 c1 L1 mounting base D H D1 D2 L 1 2 3 e b (8x) 4 w X c A E1 E2 A1 C θ Lp detail X 0 2.5 mm 5 mm scale Dimensions Unit y C A max 1.05 nom min c c1 D(1) D1(1) A1 b b1 0.1 0.50 4.4 0.25 0.30 4.70 0.0 0.35 4.1 0.19 0.24 4.45 4.8 D2 (ref) 3.5 E(1) E1(1) 5.30 1.8 4.95 1.6 E2 0.85 e 1.27 H L L1 Lp 6.2 1.3 0.55 0.85 5.9 0.8 0.30 0.40 w y 0.25 0.1 Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. Outline version References IEC JEDEC JEITA θ 8° 0° sot1205_po European projection Issue date 13-02-21 14-08-21 SOT1205 Fig. 24. Package outline LFPAK56D (SOT1205) PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 14 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor 13. Soldering Footprint information for reflow soldering of LFPAK56D package SOT1205 5.85 3.81 1.27 0.7 (4x) 3.2 3.175 3.325 2.0 1.275 0.8 1.875 2.1 1.0 (2x) 2.7 3.85 3.975 0.0625 0.025 0.7 (4x) 1.44 1.27 1.1 (2x) 3.81 solder land solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm sot1205_fr Fig. 25. Reflow soldering footprint for LFPAK56D (SOT1205) PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 15 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PHPT610030NPK v.1 20141014 Product data sheet - - PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 16 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 15. Legal information 15.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PHPT610030NPK Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 17 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 18 / 19 PHPT610030NPK Nexperia NPN/PNP high power double bipolar transistor 16. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................3 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 6 11 11.1 Test information ................................................... 12 Quality information ............................................. 13 12 Package outline ................................................... 14 13 Soldering .............................................................. 15 14 Revision history ................................................... 16 15 15.1 15.2 15.3 15.4 Legal information .................................................17 Data sheet status ............................................... 17 Definitions ...........................................................17 Disclaimers .........................................................17 Trademarks ........................................................ 18 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 14 October 2014 PHPT610030NPK Product data sheet All information provided in this document is subject to legal disclaimers. 14 October 2014 © Nexperia B.V. 2017. All rights reserved 19 / 19
PHPT610030NPKX 价格&库存
很抱歉,暂时无法提供与“PHPT610030NPKX”相匹配的价格&库存,您可以联系我们找货
PHPT610030NPKX
  • 1+12.541001+1.63030
  • 10+7.7617010+1.00900
  • 100+5.11460100+0.66490
  • 500+4.01260500+0.52170
  • 1000+3.425701000+0.44540
  • 1500+3.114301500+0.40490
  • 3000+2.766903000+0.35970
  • 9000+2.671109000+0.34730
  • 24000+2.3357024000+0.30370
库存:26798
PHPT610030NPKX
库存:3000
PHPT610030NPKX
  • 1+9.109771+1.18424
  • 10+5.6240710+0.73111
  • 50+4.4853550+0.58308
PHPT610030NPKX
  • 1+15.27026
  • 10+9.53946
  • 50+8.35296
  • 200+7.15460
  • 500+5.51723
库存:1
PHPT610030NPKX
  • 1+15.27026
  • 10+9.53946
  • 50+8.35296
  • 200+7.15460
  • 500+5.51723
库存:1
