PBSS4350SSJ
PBSS4350SSJ
    NEXPERIA(安世)
    SOIC-8
    三极管 NPN/NPN Ic=2.7A Vceo=50V hfe=520 P=1.43W SOIC8_150MIL 4.9X3.9MM
PBSS4350SSJ 数据手册
PBSS4350SS 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor Rev. 01 — 3 April 2007 Product data sheet 1. Product profile 1.1 General description NPN/NPN double low VCEsat Breakthrough In Small Signal (BISS) transistor in a medium power Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number PBSS4350SS Package Nexperia Name NPN/PNP complement SOT96-1 SO8 PBSS4350SPN PNP/PNP complement PBSS5350SS 1.2 Features n n n n n Low collector-emitter saturation voltage VCEsat High collector current capability IC and ICM High collector current gain (hFE) at high IC High efficiency due to less heat generation Smaller required Printed-Circuit Board (PCB) area than for conventional transistors 1.3 Applications n Dual low power switches (e.g. motors, fans) n Automotive 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit open base - - 50 V - - 2.7 A - - 5 A - 90 130 mΩ Per transistor VCEO collector-emitter voltage IC collector current ICM peak collector current single pulse; tp ≤ 1 ms RCEsat collector-emitter saturation resistance IC = 2 A; IB = 200 mA [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02. [1] PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 2. Pinning information Table 3. Pinning Pin Description 1 emitter TR1 2 base TR1 3 emitter TR2 4 base TR2 5 collector TR2 6 collector TR2 7 collector TR1 8 collector TR1 Simplified outline 8 Symbol 8 5 7 TR1 1 4 1 6 5 TR2 2 3 4 006aaa966 3. Ordering information Table 4. Ordering information Type number PBSS4350SS Package Name Description Version SO8 plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 4. Marking Table 5. Marking codes Type number Marking code PBSS4350SS 4350SS 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit open emitter - 50 V Per transistor VCBO collector-base voltage VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage open collector - 5 V IC collector current - 2.7 A ICM peak collector current - 5 A IB base current Ptot total power dissipation single pulse; tp ≤ 1 ms Tamb ≤ 25 °C 0.5 A - 0.55 W [2] - 0.87 W [3] - 1.43 W © PBSS4350SS_1 Product data sheet [1] Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 2 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor Table 6. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions total power dissipation Tamb ≤ 25 °C Min Max Unit [1] - 0.75 W [2] - 1.2 W [3] - 2 W Per device Ptot Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aaa967 2.5 Ptot (W) (1) 2.0 1.5 (2) 1.0 (3) 0.5 0 −75 −25 25 75 125 175 Tamb (°C) (1) Ceramic PCB, Al2O3, standard footprint (2) FR4 PCB, mounting pad for collector 1 cm2 (3) FR4 PCB, standard footprint Fig 1. Per device: Power derating curves © PBSS4350SS_1 Product data sheet Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 3 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit [1] - - 227 K/W [2] - - 144 K/W [3] - - 87 K/W - - 40 K/W [1] - - 167 K/W [2] - - 104 K/W [3] - - 63 K/W Per transistor thermal resistance from junction to ambient Rth(j-a) in free air thermal resistance from junction to solder point Rth(j-sp) Per device Rth(j-a) thermal resistance from junction to ambient in free air [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aaa809 103 duty cycle = Zth(j-a) (K/W) 102 1.0 0.75 0.5 0.33 0.2 10 0.05 0.1 0.02 0.01 0 1 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values © PBSS4350SS_1 Product data sheet Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 4 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 006aaa810 103 duty cycle = Zth(j-a) (K/W) 1.0 0.75 0.5 0.33 0.2 102 0.1 10 0.05 0.02 0.01 0 1 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 1 cm2 Fig 3. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aaa811 103 Zth(j-a) (K/W) duty cycle = 102 1.0 0.75 0.5 0.33 0.2 10 0.1 0.05 0.02 0.01 0 1 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) Ceramic PCB, Al2O3, standard footprint Fig 4. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values © PBSS4350SS_1 Product data sheet Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 5 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit collector-base cut-off VCB = 50 V; IE = 0 A current VCB = 50 V; IE = 0 A; Tj = 150 °C - - 100 nA - - 50 µA ICES collector-emitter cut-off current VCE = 50 V; VBE = 0 V - - 100 nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 2 V; IC = 100 mA Per transistor ICBO VCEsat collector-emitter saturation voltage 300 520 - VCE = 2 V; IC = 500 mA [1] 300 500 - VCE = 2 V; IC = 1 A [1] 300 470 - VCE = 2 V; IC = 2 A [1] 200 340 - VCE = 2 V; IC = 2.7 A [1] 120 180 - IC = 0.5 A; IB = 50 mA - 50 80 mV IC = 1 A; IB = 50 mA - 100 160 mV IC = 2 A; IB = 100 mA - 190 280 mV IC = 2 A; IB = 200 mA - 180 260 mV IC = 2.7 A; IB = 270 mA - 240 340 mV - 90 130 mΩ - 0.95 1.1 V - 1.1 1.2 V - 0.8 1.2 V - 8 - ns - 96 - ns - 104 - ns [1] RCEsat collector-emitter IC = 2 A; IB = 200 mA saturation resistance [1] VBEsat base-emitter saturation voltage [1] IC = 2 A; IB = 100 mA IC = 2.7 A; IB = 270 mA VBEon base-emitter turn-on VCE = 2 V; IC = 1 A voltage td delay time tr rise time ton turn-on time ts storage time - 355 - ns tf fall time - 165 - ns toff turn-off time - 520 - ns Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 18 25 pF [1] VCC = 10 V; IC = 2 A; IBon = 100 mA; IBoff = −100 mA Pulse test: tp ≤ 300 µs; δ ≤ 0.02. © PBSS4350SS_1 Product data sheet [1] Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 6 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 006aaa968 1000 006aaa969 5 hFE IB (mA) = 100 IC (A) (1) 800 80 4 (2) 600 90 60 70 50 40 30 3 20 10 400 2 (3) 200 0 10−1 1 1 10 102 103 104 IC (mA) 0 0 0.4 0.8 1.2 1.6 2.0 VCE (V) Tamb = 25 °C VCE = 2 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 5. DC current gain as a function of collector current; typical values 006aaa970 1.2 Fig 6. Collector current as a function of collector-emitter voltage; typical values 006aaa971 1.4 VBE (V) VBEsat (V) 0.8 1.0 (1) (2) (1) (3) 0.4 (2) 0.6 (3) 0 10−1 1 10 102 103 104 IC (mA) 0.2 10−1 1 VCE = 2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Fig 7. Base-emitter voltage as a function of collector current; typical values 102 103 104 IC (mA) Fig 8. Base-emitter saturation voltage as a function of collector current; typical values © PBSS4350SS_1 Product data sheet 10 Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 7 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 006aaa972 1 006aaa973 1 VCEsat (V) VCEsat (V) 10−1 10−1 (1) (2) (3) (1) (2) 10−2 10−2 (3) 10−3 10−1 1 10 102 103 104 IC (mA) 10−3 10−1 1 (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 9. Collector-emitter saturation voltage as a function of collector current; typical values 006aaa974 103 103 104 IC (mA) Fig 10. Collector-emitter saturation voltage as a function of collector current; typical values RCEsat (Ω) 102 102 10 10 (1) (2) (3) 1 006aaa975 103 RCEsat (Ω) (1) (2) (3) 1 10−1 10−1 1 10 102 103 104 IC (mA) 10−2 10−1 1 10 102 103 104 IC (mA) Tamb = 25 °C IC/IB = 20 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 11. Collector-emitter saturation resistance as a function of collector current; typical values Fig 12. Collector-emitter saturation resistance as a function of collector current; typical values © PBSS4350SS_1 Product data sheet 102 Tamb = 25 °C IC/IB = 20 (1) Tamb = 100 °C 10−2 10−1 10 Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 8 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 8. Test information IB input pulse (idealized waveform) 90 % IBon (100 %) 10 % IBoff output pulse (idealized waveform) IC 90 % IC (100 %) 10 % t td ts tr ton tf toff 006aaa003 Fig 13. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mlb826 VCC = 10 V; IC = 2 A; IBon = 100 mA; IBoff = −100 mA Fig 14. Test circuit for switching times © PBSS4350SS_1 Product data sheet Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 9 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 9. Package outline 5.0 4.8 1.75 1.0 0.4 6.2 5.8 4.0 3.8 pin 1 index 1.27 0.49 0.36 Dimensions in mm 0.25 0.19 03-02-18 Fig 15. Package outline SOT96-1 (SO8) 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PBSS4350SS [1] Package SOT96-1 Description 8 mm pitch, 12 mm tape and reel 1000 2500 -115 -118 For further information and the availability of packing methods, see Section 14. © PBSS4350SS_1 Product data sheet Packing quantity Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 10 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 11. Soldering 5.50 0.60 (8×) 1.30 4.00 6.60 7.00 1.27 (6×) solder lands occupied area placement accuracy ± 0.25 Dimensions in mm sot096-1_fr Fig 16. Reflow soldering footprint SOT96-1 (SO8) 1.20 (2×) 0.60 (6×) enlarged solder land 0.3 (2×) 1.30 4.00 6.60 7.00 1.27 (6×) 5.50 board direction solder lands occupied area solder resist placement accurracy ± 0.25 Dimensions in mm sot096-1_fw Fig 17. Wave soldering footprint SOT96-1 (SO8) © PBSS4350SS_1 Product data sheet Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 11 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PBSS4350SS_1 20070403 Product data sheet - - © PBSS4350SS_1 Product data sheet Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 12 of 14 PBSS4350SS Nexperia 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © PBSS4350SS_1 Product data sheet Rev. 01 — 3 April 2007 Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia PBSS4350SS 50 V, 2.7 A NPN/NPN low VCEsat (BISS) transistor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics. . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Packing information. . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 03 April 2007
PBSS4350SSJ
物料型号:PBSS4350SS
器件简介: - 这是一款NPN/NPN双低VCEsat(BISS)晶体管,采用中等功率的表面贴装设备(SMD)塑料封装。 - 特点包括低集电极-发射极饱和电压VCEsat、高集电极电流能力IC和ICM、高集电极电流增益hFE、高效率、较小的所需PCB面积。
引脚分配: - 引脚1:TR1发射极 - 引脚2:TR1基极 - 引脚3:TR2发射极 - 引脚4:TR2基极 - 引脚5:TR2集电极 - 引脚6:TR2集电极 - 引脚7:TR1集电极 - 引脚8:TR1集电极
参数特性: - VCEO:集电极-发射极电压,开基极条件下,最大50V。 - Ic:集电极电流,最大2.7A。 - ICM:峰值集电极电流,单脉冲条件下,最大5A。 - RcEsat:集电极-发射极饱和电阻,Ic=2A; IB=200mA条件下,范围在1mΩ到130mΩ。
功能详解: - 该晶体管适用于双低功耗开关,例如在汽车领域的电机和风扇控制。
应用信息: - 主要应用于汽车领域的双低功耗开关。
封装信息: - 封装类型为SOT96-1,8个引脚,体宽3.9mm。
PBSS4350SSJ 价格&库存
很抱歉,暂时无法提供与“PBSS4350SSJ”相匹配的价格&库存,您可以联系我们找货
