PUMD24,115
PUMD24,115
    NEXPERIA(安世)
    SOT-363
    TRANS PREBIAS NPN/PNP 6TSSOP
PUMD24,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PEMD24; PUMD24 NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ Rev. 01 — 2 May 2005 Product data sheet 1. Product profile 1.1 General description NPN/PNP Resistor-Equipped Transistors (RET). Table 1: Product overview Type number Package Philips JEITA PNP/PNP complement NPN/NPN complement PEMD24 SOT666 - PEMB24 PEMH24 PUMD24 SOT363 SC-88 PUMB24 PUMH24 1.2 Features ■ ■ ■ ■ Built-in bias resistors Simplifies circuit design Reduces component count Reduces pick and place costs 1.3 Applications ■ Low current peripheral driver ■ Control of IC inputs ■ Replaces general-purpose transistors in digital applications 1.4 Quick reference data Table 2: Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 50 V IO output current (DC) - - 20 mA R1 bias resistor 1 (input) 70 100 130 kΩ R2/R1 bias resistor ratio 0.8 1 1.2 PEMD24; PUMD24 Philips Semiconductors NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ 2. Pinning information Table 3: Pinning Pin Description Simplified outline 1 GND (emitter) TR1 2 input (base) TR1 3 output (collector) TR2 4 GND (emitter) TR2 5 input (base) TR2 6 output (collector) TR1 6 5 4 Symbol 6 5 R1 4 R2 TR2 1 2 3 TR1 001aab555 R2 1 R1 2 3 006aaa143 3. Ordering information Table 4: Ordering information Type number Package Name Description Version PEMD24 - plastic surface mounted package; 6 leads SOT666 PUMD24 SC-88 plastic surface mounted package; 6 leads SOT363 4. Marking Table 5: Marking codes Type number Marking code [1] PEMD24 6N PUMD24 T8* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 9397 750 14457 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 01 — 2 May 2005 2 of 10 PEMD24; PUMD24 Philips Semiconductors NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ 5. Limiting values Table 6: Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per transistor; for the PNP transistor with negative polarity VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage open collector - 10 V VI input voltage TR1 positive - +40 V negative - −10 V positive - +10 V negative input voltage TR2 - −40 V IO output current (DC) - 20 mA ICM peak collector current - 100 mA Ptot total power dissipation Tamb ≤ 25 °C SOT363 [1] - 200 mW SOT666 [1] [2] - 200 mW Tstg storage temperature −65 +150 °C Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Per device Ptot total power dissipation Tamb ≤ 25 °C SOT363 [1] - 300 mW SOT666 [1] [2] - 300 mW [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. 9397 750 14457 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 01 — 2 May 2005 3 of 10 PEMD24; PUMD24 Philips Semiconductors NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ 6. Thermal characteristics Table 7: Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Per transistor Rth(j-a) thermal resistance from junction to ambient in free air SOT363 [1] - - 625 K/W SOT666 [1] [2] - - 625 K/W SOT363 [1] - - 416 K/W SOT666 [1] [2] - - 416 K/W Per device Rth(j-a) thermal resistance from junction to ambient in free air [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Reflow soldering is the only recommended soldering method. 7. Characteristics Table 8: Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit - - 100 nA Per transistor; for the PNP transistor with negative polarity ICBO collector-base cut-off current VCB = 50 V; IE = 0 A ICEO collector-emitter cut-off current VCE = 30 V; IB = 0 A - - 1 µA VCE = 30 V; IB = 0 A; Tj = 150 °C - - 50 µA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 50 µA hFE DC current gain VCE = 5 V; IC = 5 mA 80 - - VCEsat collector-emitter saturation voltage IC = 5 mA; IB = 0.25 mA - - 150 VI(off) off-state input voltage VCE = 5 V; IC = 100 µA - 1.1 0.5 V VI(on) on-state input voltage VCE = 0.3 V; IC = 1 mA 3 1.5 - V R1 bias resistor 1 (input) 70 100 130 kΩ R2/R1 bias resistor ratio 0.8 1 1.2 Cc collector capacitance TR1 (NPN) - - 2.5 pF TR2 (PNP) - - 3 pF VCB = 10 V; IE = ie = 0 A; f = 1 MHz 9397 750 14457 Product data sheet mV © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 01 — 2 May 2005 4 of 10 PEMD24; PUMD24 Philips Semiconductors NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ 006aaa168 103 006aaa169 102 (1) VCEsat (mV) hFE (2) (1) (3) (2) 102 (3) 10 10−1 1 102 10 10 10−1 1 I C (mA) VCE = 5 V IC/IB = 20 (1) Tamb = 100 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C Fig 1. TR1 (NPN): DC current gain as a function of collector current; typical values 006aaa170 10 VI(on) (V) 10 I C (mA) Fig 2. TR1 (NPN): Collector-emitter saturation voltage as a function of collector current; typical values 006aaa171 10 VI(off) (V) (1) (2) (1) (3) 1 1 (2) (3) 10−1 10−1 1 10 10−1 10−2 I C (mA) 1 10 I C (mA) VCE = 0.3 V VCE = 5 V (1) Tamb = −40 °C (1) Tamb = −40 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Fig 3. TR1 (NPN): On-state input voltage as a function of collector current; typical values Fig 4. TR1 (NPN): Off-state input voltage as a function of collector current; typical values 9397 750 14457 Product data sheet 10−1 © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 01 — 2 May 2005 5 of 10 PEMD24; PUMD24 Philips Semiconductors NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ 006aaa188 103 hFE 006aaa189 −10−1 VCEsat (V) (1) (2) (1) (2) (3) (3) 102 10 −10−1 −1 −10 −102 −10−2 −10−1 −1 IC (mA) −10 IC (mA) VCE = −5 V IC/IB = 20 (1) Tamb = 100 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C Fig 5. TR2 (PNP): DC current gain as a function of collector current; typical values 006aaa190 −10 VI(on) (V) Fig 6. TR2 (PNP): Collector-emitter saturation voltage as a function of collector current; typical values 006aaa191 −10 VI(off) (V) (1) (1) (2) (2) (3) (3) −1 −10−1 −10−1 −1 −1 −10 −10−1 −10−2 −10−1 IC (mA) −10 IC (mA) VCE = −0.3 V VCE = −5 V (1) Tamb = −40 °C (1) Tamb = −40 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Fig 7. TR2 (PNP): On-state input voltage as a function of collector current; typical values Fig 8. TR2 (PNP): Off-state input voltage as a function of collector current; typical values 9397 750 14457 Product data sheet −1 © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 01 — 2 May 2005 6 of 10 PEMD24; PUMD24 Philips Semiconductors NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ 8. Package outline 2.2 1.8 6 1.1 0.8 5 1.7 1.5 0.45 0.15 4 6 0.6 0.5 5 4 0.3 0.1 2.2 1.35 2.0 1.15 1.7 1.5 pin 1 index 1.3 1.1 pin 1 index 1 2 3 1 0.25 0.10 0.3 0.2 0.65 2 3 0.18 0.08 0.27 0.17 0.5 1.3 1 Dimensions in mm 04-11-08 Fig 9. Package outline SOT363 (SC-88) Dimensions in mm 04-11-08 Fig 10. Package outline SOT666 9. Packing information Table 9: Packing methods The indicated -xxx are the last three digits of the 12NC ordering code. [1] Type number Package Description Packing quantity 3000 4000 8000 10000 PEMD24 - - -315 - SOT666 2 mm pitch, 8 mm tape and reel 4 mm pitch, 8 mm tape and reel PUMD24 SOT363 - -115 - - 4 mm pitch, 8 mm tape and reel; T1 [2] -115 - - -135 4 mm pitch, 8 mm tape and reel; T2 [3] -125 - - -165 [1] For further information and the availability of packing methods, see Section 15. [2] T1: normal taping [3] T2: reverse taping 9397 750 14457 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 01 — 2 May 2005 7 of 10 PEMD24; PUMD24 Philips Semiconductors NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ 10. Revision history Table 10: Revision history Document ID Release date Data sheet status Change notice Doc. number Supersedes PEMD24_PUMD24_1 20050502 Product data sheet - 9397 750 14457 - 9397 750 14457 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 01 — 2 May 2005 8 of 10 PEMD24; PUMD24 Philips Semiconductors NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ 11. Data sheet status Level Data sheet status [1] Product status [2] [3] Definition I Objective data Development This data sheet contains data from the objective specification for product development. Philips Semiconductors reserves the right to change the specification in any manner without notice. II Preliminary data Qualification This data sheet contains data from the preliminary specification. Supplementary data will be published at a later date. Philips Semiconductors reserves the right to change the specification without notice, in order to improve the design and supply the best possible product. III Product data Production This data sheet contains data from the product specification. Philips Semiconductors reserves the right to make changes at any time in order to improve the design, manufacturing and supply. Relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). [1] Please consult the most recently issued data sheet before initiating or completing a design. [2] The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com. [3] For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status. 12. Definitions customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Right to make changes — Philips Semiconductors reserves the right to make changes in the products - including circuits, standard cells, and/or software - described or contained herein in order to improve design and/or performance. When the product is in full production (status ‘Production’), relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. 14. Trademarks 13. Disclaimers Notice — All referenced brands, product names, service names and trademarks are the property of their respective owners. Life support — These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors 15. Contact information For additional information, please visit: http://www.semiconductors.philips.com For sales office addresses, send an email to: sales.addresses@www.semiconductors.philips.com 9397 750 14457 Product data sheet © Koninklijke Philips Electronics N.V. 2005. All rights reserved. Rev. 01 — 2 May 2005 9 of 10 PEMD24; PUMD24 Philips Semiconductors NPN/PNP resistor-equipped transistors; R1 = 100 kΩ, R2 = 100 kΩ 16. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description. . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data. . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics. . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information. . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 2 2 2 3 4 4 7 7 8 9 9 9 9 9 © Koninklijke Philips Electronics N.V. 2005 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Date of release: 2 May 2005 Document number: 9397 750 14457 Published in The Netherlands
PUMD24,115 价格&库存
很抱歉,暂时无法提供与“PUMD24,115”相匹配的价格&库存,您可以联系我们找货
PUMD24,115
  • 1+2.191221+0.28363
  • 10+1.3269610+0.17176
  • 100+0.81189100+0.10509
